Which one offers the best performance for Canadian winters? The tires will not be studded as studs are illegal here.
I'm looking for good snow/slush performance without sacrificing dry handling & noise too much.
Any suggestions will be appreciated.
You should also consider the Blizzack.
Which Blizzak model do you recommend? I heard Blizzaks wear out pretty fast. Is it true?
I hope thie helps!
Drew
This being said, I have to disagree with Drew on the performance of the Michelins. They do handle dry asphalt better than the Blizzaks; in fact they are as good as most 4 seasons on dry pavement. However, they are certainly not as good as the Blizzaks on snow, sleet and ice. They tend to pack more and they dont have the sheer adhesion of the Blizzaks in those conditions. My Volvo S-70 is still on Michelin Alpins and so was my CR-V. As I mentioned earlier, I put Blizzaks on my Santa-Fe and wow; what incredible traction, braking and cornering on snow, ice, wet snow... Next tires on the Volvo will certainly be Blizzaks.
For the Hakkas, sorry cocomo, I can't help much. I know they are good tires but my earlier post was mainly to mention what I knew about the Toyo's. I would probably go for the NRW which is, I think, their latest design.
I did find that the Alpins have one major weakness. They get there traction from sipes that are perpindicular to the direction of travel. This is excellent for braking and starting, but maybe not so good for lateral traction. My wife were driving 2 cars in 35-45 mph cross winds once, and she could not keep up with our minivan (wich had all-season tires) while driving the Integra with Alpins. She said the car just wanted to go sideways. I had been in wind before but never noticed this. Maybe the snow/ice was just the wrong temp It was just a little below freezing.
Last year I bought a tire by Yokohama called the Gaurdex 720 (for the minivan) and it seems to have much better dry handling than the Blizzak, and winter traction that is just as good. It uses micropores like the blizzak, and tons of sipes like the Alpin. The tread blocks are large to help with handling, and the micropores go all the way through - unlike the Bridgestone which is only 55%. I highly reccomend this tire. I will put this tire on my Integra when the Alpins wear out, or I might experiment with a pair of Hakka's.
If you are concerned about cost, buy snow tires at Walmart (inexpensive) and obtain take off wheels from a business that deals in wheels. This would be much cheaper than your regular dealer.
An example: For my Toyota Echo I bought 4 wheels that way (NOT from Toyota). Toyota charges CAD$ 110 per wheel, I bought them at CECO Distributors in Vancouver for CAD$ 38 each (brand new).
I bought take off rims for my Integra at the Acura dealer for $25 each. The dealer has no use for them and may give you a good deal. Tire rack also has good package deals. you can get 4 snows mounted and balanced on wheels for just over $300 for small tires (civic or corolla) to $400 for larger (Accord etc).
I did have two snows on front for a short while thinking I could handle it. Blizzaks in front and Pirelli P600's in back (not the all weather version you get at Sams, but the European ones that are summer only) There can hardly be any greater difference in snow traction than there was between these two tires. The Pirelli's were helpless in the snow even with front wheel drive. When I placed the Blizzaks on front the car would go like crazy, but when I had to stop suddenly the front would grip and the back would keep going and I would swing right around.
I can assure you that this manuever will cause a major decuction in style points!
I was considering going to a wrecker for used rims but Canadian tire has fairly cheap winter rims ('starting' at $38 or so) so I guess I'll go there and get some Arctic Alpins as their house brand snow tires are only a few bucks cheaper per tire. Around here most roads are usually plowed well eventually so I think I'd wear Blizzaks in no time so it sounds like the Alpins would be better for my conditions.
You will have to weigh the pros and cons.
This year I'm trying to decide if I'll mount winter tires on a seperate set of rims for our second car, mount them on the stock rims, or go with Nokian NRW's.
If I go with winter tires, I'll have to decide how much I'm willing to spend. I could go with a cheaper studded tire (Canadian Tire, Bridgestone Wintertrax, Walmart), or a non-studded tire. Alpins tend to go on sale at Canadian tire, while Blizzaks, Oberves, Q's tend to be more.
The Aplins worked well on snow covered roads last year every time I had to go out and get a snowblower part in the middle of a storm!! The deepest I've gone is about 8" but the Ody has traction control so that helps. On cleared roads they handled very well and were fairly quiet. Someone else noted here that the design of the Alpins lend themselves to good dry road manners.
Studs are a no no here in MA so I can't offer help. I got mine at tirerack.com and they offer plenty of different options. I stuck with the 16" size for the Ody but I bet if you looked at 15" you'll find a better selection.
Good Luck
Give them a call and have them send it out to you.
Michelin and Nokian are much better choices.
Which Cooper tires did the magazine test review refer to? Was it the Weathermaster or Wintermaster?
Thanks, as I have been quoted a price on the Cooper tires, and was considering spending a bit more money for dedicated, directional winter tires, such as the Yokohama Geolander I/t's
I once had a set of Pirelli Winter Ice Asym on a Honda CR-V. They were excellent on Ice and asphalt but tended to pack with snow. After 2 winters, about 40,000 kms, they were gone.
I am leaning strongly toward getting the Bridgestone Winter Duellers for my Sequoia but am a bit concerned about the wear issue, as we do put a lot of miles on our vehicle (almost 2K/month) and I would really prefer not to have to buy new winter tires every year or two!
How quickly do the Bridgestones wear? We do about half dirt roads and half pavement driving. I think we have ruled out studs as we plan to drive to Ontario this winter, and studs are not allowed there. (Also MA? I didn't think that was the case, but we do drive to MA a lot too.)
What about "mud season" in the spring? I think the snows would be better than our (original equipment) all seasons in the serious mud we have to deal with, but that has to be weighed against wearing out the snows on the warming pavement.
Thanks again,
--RobynK
Are studs really needed? I realize they help on ice, but do they do much when driving on packed snow?
As for the Bridgestones, I don't have any personal experience. The two people I knew who used them were on the road sales reps and both seemed to get 2 years max out of Bridgestones. But keep in mind they also drove 30-40K per year.
I am leaning toward Bridgestones but would really like to get 3 winters (approx 30,000 miles) out of one set -- I don't know if that is realistic or not.
On the Blizzak-type tires, once you wear down the 55% special compound, do you have to replace the tire, or does it just degrade to standard snow tire performance, or what? Could I get them studded at that point?
--RobynK
www.tirerack.com is where I found the Winter Duelers supposedly the right size for my Sequoia (2001 SR5 4x4). However all the winter tires they recommended for my vehicle are 245/75-16's and the tires on my vehicle now are actually P265/70R16 111's.
Neither Bridgestone nor Goodyear appears to make a winter tire in a 265/70-16 size.
Can I use the 245/75's? on my existing rims??
--RobynK
Yes, after the Blizzaks are worn down to 50%, they act like a regular winter tire, but you cannot have them studded at that point.
Varig, with only 4 snows a year and an AWD car, you could go with Michelin or Pirelli ice tires. They handle dry asphalt a little better than the Blizzaks but are not quite as good in snow. They are all very close on ice. The Hakkas are more of a snow tire than ice.
I had seriously considered the Bridgestone Winter Dueler DM-Z2's but they were over $120 more for the set. Jake, at the TireRack, checked the specs between the two and the Winterfire's had just slightly less snow traction capability than the DM-Z2's and were equal in all other areas. His recommendation for the money was the Winterfire's.
Now on the size issue: narrower is better in the snow. If you look around on the net you can find several tire size comparison sites. Even go to TireRack and check the specs of a tire line and you can see the differences between different sizes.
In my case, the tires that came on my truck are 225/70X15's. I went with the 215/75X15's because they are slightly narrower. Load range is the same and the diameter is so close to not be a problem with the engine control computer. I essentially went to a minus-size tire - narrower tread width for better snow driving but the same overall diameter to eliminate driveability issues as a result of using a tire that is too tall/too short for the engine management to compensate for.
Even though the DM-Z2 may be a better tire than the Winterfire, they are both winter tires and any one of them will be far superior in the snow than my stock Firestone Wilderness HT's.
It sounds like a great tire - those little ground up walnut shells for ice traction and unidirectional tread design for snow traction.
Has anyone out there tried the Toyo Observe or has buddies that have?
Thanks very much.
I had Coopers and Pirellis on previous vehicles and was not impressed at all. In fact, my Pirellis developed cracks on at the base of the outer treads. Pirelli rep was no help.
I had Bridgestones WT-04s at one point...also a very good tire, but this was several generations ago.
For Cdns, you can get the Artic Alpins at Canadian Tire....watch for the sale when they have the 2nd tire half price. I got mine through this sale 1st week of Jan a couple of years ago, but have seen the sale on sooner. Check their e-flyer each week at http://www.canadiantire.ca.
For moderate snow belt dwellers
( I'm in Boston, MA): what are your experiences w/faster winter tires ?
Has anybody tried Goodyear Ultra Grip Ice at fast speeds on highway ?
Actually, T rating would suffice for me, but I'd rather have above Q.
My 80% driving is dry roads, but the driveway is steep, icy, and rarely
free of snow. So I was looking at Dunlop Winter Sports, Nokian Hakka 1's, and Pirellis
Some of them don't even come in 50 profile:
55 is the smallest for 16 in.- not much performance then, also 205 is the narrowest,
has anyone seen a 195 in 16 in. winter tire ?
Any comments appreciated.
Check out tirerack.com. I happened to have a catlog in front of me and they have Pirelli's in 50 series but not 195/16. Pirelli's are offered down to 40 series and V ratings in some sizes. But be prepared to break the bank!!!
This is an H-rated tire, is it an older version of Pilot Alpin ?
akangl, thanks for Goodyear info, have you ever
taken them beyond 100mph on a dry hwy ?
( I would like to have that option in a winter tire )
Thank
I've noticed that the Toyo's seem softer than the OEM Michelin Symmetry's, even pumped up to 35psi (I prefer better handling over smoother ride), and just a bit noisier. With the mild weather we've had so far (no snow and it's Dec!), I can't say how good these are on snow/ice, but when the white stuff hits I'll report back.
People have been trying to talk me out of it - since I'm in NYC, and the snow here during the winter isn't exactly a regular occurrence. The thing is - after spending so much money with the concentration being safety and security - wouldn't I want to go the extra $500-700 to add a set of winter tires and make the hazardous weather that much safer?
It looks like I've got a choice of winter tires, as follows:
Nokian Haakepellita
Dunlop Winter Sport M2
Bridgestone Blizzak Winter Dueler
Michelin 4x4 Alpin
Anyone have any experience with the above? They're all in the same price range (the stock tire size on the 2001 rims I bought is 255/65R16) - ranging from $104 to 124 per tire.
The Bridgestones should be a bit more expensive, if you consider the fact that the winter tire compound that gives them their winter kick covers only 55% of the tire. After that - you're looking at a general purpose all weather tire. In NYC, winters range from no snow, to bunches, to no snow again - so the wear rate for this tire here would be ridiculous.
The Nokians are intriguing - but they're almost impossible to find here, and I'm inclined not to order online, just in case there's a problem with the tire.
Any suggestions?
-John
