Visitor Agreement.
Swedish Road and Transport Institute
ISO Certified Snow Tire Testing Facility
http://www.newind.is/engTests.htm#VTI
If he rebalances the tires and the problem goes away I'll post again.
and mandatory?
Who pays for that? I doubt the DOT pays. Let me guess, the consumer? Taxpayers? (Oh yeah, the DOT IS taxpayer money!)
I wonder how it will work when you air down your tires to 10-15 PSI for trails.
- telematic (?) pressure monitor inside each tire (possibly mounted to the wheel) transmitting pressure to receiver (it can be portable or in the car).
- ABS based - it deducts loss of pressure from different rotating speeds and because of it it might be prone to error. I guess if all 4 tires lose pressure simultanously it wil not detect anything.
Krzys
PS It might not be true, just my knowledge.
(rolls eyes!)
It is a light on the dash. It can be reset at any time by pressing a button so that it doesn't go off after changing wheels, adding or removing air, etc.
How does it tell the difference between traction loss and air loss? I'm not sure myself but I suspect the engineers thought about it for a little while
If you pull the fuse for ABS then of course you lose traction control and pressure monitoring as well. I like all three systems so I leave the fuse in, thanks!
More than likely, the system will measure differences over a set time period before warning.
Why would it have to? Fluctuations from slippage would be transient and readings should be correct when traction is recovered.
Well, that's the whole problem. Please define "transient"
If you're slipping regularly for more than a half hour at a time I don't think you're too concerned about pressure loss! ;-)
So far, they've already outperformed my OE Eagle RSAs on snow, ice and wet - and they seem to be comparable on the dry.
This is almost unthinkable - a performance V-rated* all-season which also carries the severe service emblem. Perfect for a guy like me who doesn't like to switch to snows for the winter.
I am very impressed.
the (well-named) iceman
*note the V rating is rare for WRs - most sizes earn a T or H rating; mine just happens to be V-rated.
Oh yeah, and a few other points:
Nokian lists the WR as both an all weather and a winter tire - whereas they list the NRV (with which I was more familiar)exclusively as an all-weather tiredon't go by the tire sizes you find on the web - Nokian is constantly adding new ones to their list. I couldn't find mine on any list I found on the web.there are two WR classes - the WR and the WR SUV - with the latter tending to be higher profile and higher load ratings.
I've had good results with Dunlop WinterSports on my MINI Cooper and Michelin Arctic Alpins on my Saturn LW200 here in southern Ontario where we are also getting more snow than usual (sort of north across the lake from PA). Others have reported good results with Bridgestone Blizzaks and Nokian Hakkalipettas so there many good snow/ice tires to choose from.
Definitely the best winter-performing all-season I've ever had.
ice
When last I heard (Last year)you were riding on Goodrich m65 or something like that as new tires. I was wondering why you are now looking for new tires. And yes the Nokians seem to be my next tire but I am going to wear out the Bridgestones on my Forester first.
Subaru has no comment on the choice for an AWD all-weather car. Replaced with Michelin Symmetry. So far, so good in a more typical northern New England winter here in Downeast Maine. Not as good as our Nokians, but safe and more durable than Duelers for all season compromise.
http://www.meadowcreektire.com/nokian/index.htm
I've been looking for winter tires for my new 2003 Mountaineer. I'm thinking I'll put 245/70R16 studded Hakkas on it. I have 17" wheels on it at the moment and there aren't many options in 245/65R17.
Nokia (the cell phone company from Finland) sold their 18% stake in Nokian to Bridgestone January 24, 2003.
Nokian is rolling out a Hakka 4 studded snow tire with an improved square stud system. They claim it works much better at retaining studs and that it works much better on dry paved roads.
Nokian makes one tire that is all season and has the snowflake emblem. The Michelin Arctic Alpic is a compromise tire that wears well on non-snow/ice covered roads.
Good luck in your decision.
I have the NRWs and they did fantastic for me up here in The Great White North.
Actually, I just went to their site (www.nokian.com) and noticed that the WR's are listed as winter passenger vehicle tires. They don't even list the NRW's under their current products (at least not that I can find).
Ah...now if you goto the North American site (http://www.nokiantires.com/indexen.html), they have the NRW's, but no WR's. Very confusing.
I live in the SF Bay Area, so only deal with snow about once a month in the winter on drives up to Tahoe (and then while I am there). I did not realize that good snow tires are a better idea than chains (or Spike's Spiders). Sounds like having a set of snow tires mounted on wheels makes sense. It's probably just as easy to change 4 tires as it is to mount my Spike's Spiders.
So, keep the "stock" tires on for most of the year, and then go to the snows on a weekend to weekend basis in the winter, eh?
I wonder if they have a rim that looks like a snowflake?
Go to the link below and click on NRW there is a scanned brochure.
You wouldn't have to put the snows on every weekend, you could put them on before your first trip up the mountains, and take them off after the season ends. They are fine as an all weather tire too. If you are going to put them on for the weekend you could get a more dedicated snow tire than the NRW, or a studded tire, since there is no need to compromise.
but perhaps those aren't the tires I want to drive on during the week in balmy Palo Alto
I'm thinking of doing this with my next car, which may be an XC90, Caddilac SRX or Chrylser Pacifica. (don't worry - I won't take offense when you guys make fun of me and my car choices)
There are indeed two WRs: one is a passenger car tire and the other is an SUV tire. The two are distinguished from one another based mostly on load rating. I put 4 225/55/17s WRs on my '00 Bonneville - these are passenger tires which have a 101 load rating and are V-rated for speed. In contrast, the only other 55 series 17" WR is an SUV tire. It has a 255 wide tread - a beefier tire all around - and is rated higher for load (at 104) but lower for speed (at H). Both consistent with SUV parameters.
Nokian invests a lot of resources in northern tire research but little in marketing - it seems that they're not interested in being big, just in being the best in their niche. I think their terribly inadequate websites reflect this rather accurately.
BTW - 8,000 kms on the WRs through an Ottawa, Ontario winter and have to say that these were a dream to drive on. The plus side apparently is that the rubber compound in the WR is also supposed to be wear-friendly. That negates the need to have two sets of wheels to alternate between - you know, for those Tahoe weekends.
Sadly, I think too few people give any thought to their tires - either in choosing a tire or in maintaining them or replacing them at proper intervals for their driving needs. Unfortunately, tires are easily the most critical safety components of our cars which is subject the most rapid degree of wear. Because of that, I'd never criticize anybody for maintaining their car - even if it means spending "unnecessarily" on their tires. Conversely, I know of people who pay prestige marque "performance" cars and who, at tire replacement time, buy their tires on sale at Sears.
"All seasons, don't you know - and they were 30% off..."
First - it keeps my alloys out of the winter weather.
Second - will Wal-Mart or Costco dismount/mount my tires every spring and fall forever for a single $50 charge?
Third - steel rims are fairly cheap - for about $120 I got 4 rims.
Again just MHO.
IMHO, a second set of rims for snow tires are worthwhile.
I do the same thing. I bought slightly used set of 15" VW steel rims and hub caps from somebody who had upgraded to alloy wheels. Saved wear and tear on my alloy wheels and makes it much easier to swap twice a year. Last spring, I swapped tires myself in a parking lot after I couldn't get any of the local tire shops to sneak me in.
I have ~22,000 miles on my Nokian Hakka Q studless friction tires on the VW and I have at least one more season left on them. I am very happy with their ice and snow performance and the wear has been excellent. I spend a lot of time on dry roads at 80 mph. The road noise is typical for a snow tire (lousy) and the handling is typical of a soft sidewall tire (lousy). Blizzaks don't wear this well and I get near-Blizzak ice grip.
I just bought some slightly used alloy wheels for my 2003 Mountaineer on Ebay for $350. Not quite the same deal as my steelies for the VW but it's still a pretty good value and they're clones of what is already on the car. The studded 235/65R17 Hakkapeliitta SUVs will fit on them perfectly. It's nice to finally have some decent snow tire options for SUVs. I've owned them for 17 years and their braking and cornering characteristics on slippery roads leave something to be desired. Not particularly surprising when you run stock A/T tires on a 5,000 pound truck. It will be nice to pick up the extra safety margin in emergency handling.
For people complaining about the lousy Nokian web site, they're supposed to be upgrading it for May. Until that happens, the search engines find some Nokian pages that aren't accessable from their stale site that talk about the WR and Hakka 2. This information is also stale but it's better than what is up officially on their site.
Nokia Hakkapeliitta SUV
Nokian Hakkapeliitta 1
Nokian Hakkapeliitta 2
Nokian WR
obviously, you don't carry the extra set around in the back of the minivan
if I go with the approach suggested by iceman, will I still need chains/spiders on a trip up to Tahoe in a FWD minivan? (I suspect that no matter what tires I am on, the CHP will require me to slap chains on, unless I am in a 4wd/AWD rig)
