Visitor Agreement.
Is it possible to have a bad O2 sensor without the engine light coming on? Could it be something else that is causing such poor gas mileage that might have been overlooked?
Bill
01-08-50-008 Power Seat Track
01-07-30-014 Delayed Shifts
99-01-38-005 AC Not Cold
00-01-38-007 A/C Performance/Leaks
00-01-38-003
and
00-01-38-003A Popping Sound from Dash
Thanks in advance.
If we had the year, make, model and engine size, we might be able to locate them.
Probably could locate them by the TSB number, but that is time consuming. I can tell you that I might help you out with one or two, but not the whole list.
2001 Chevy Impala LS 3.8L
With the amount of TSBs that you were concerned with, I would suggest you check out Alldata's DIY subscription. It will provide you with ALL info (including TSBs full text) for your vehicle for one year for about $25.
#01-07-30-014
Extended Shifts During Cold Operation (Replace Shift Solenoid Valve Assembly)
4T65-E Transmission Delayed Shifts, Slips, Flares or Extended Shifts During Cold Operation (Replace Shift Solenoid Valve Assembly)
Condition
Some owners may comment on one or several delayed shifts, slips, flares or extended shifts during cold operation. These symptoms can affect the 1-2 shift only. The transmission won't shift out of 1st gear until the temperature is high enough to unstick the solenoid. This condition can last up to several shift patterns. These symptoms can return after the vehicle sits, usually 6 hours or more.
Cause
The 1-2, 3-4 shift solenoid valve not exhausting may be the cause of these conditions.
Correction
Replace the 1-2, 3-4 shift solenoid valve. Refer to the appropriate Service Manual information for replacement procedure.
Parts Information
Part Number Description Qty
24219819 1-2, 3-4 Shift Solenoid 1
--------------------------------------------------#99-01-38-005
2000 models only.
#00-01-38-007
Is an informational TSB for the tech to use a tracer dye to loacate leaks in the AC system.
#00-01-38-003A is a revision of #00-01-38-003
2000 models only.
The mode valve actuator may have a bind in the linkage.
Correction
Remove the left (driver's) side instrument panel sound insulator panel.
Remove the left (driver's) side knee bolster.
Disconnect the two vacuum lines from the mode valve actuator. The mode valve actuator is behind the instrument panel just to the left of the radio and HVAC control. It has a blue vacuum line attached to the left side and a brown vacuum line on the back side.
Disconnect the mode valve actuator from it's attachment to the HVAC module case.
Notice
The mode door arm is plastic. Care must be taken to avoid damaging the mode door arm.
Disconnect the mode door actuator from the mode door arm.
Install the new mode valve actuator, P/N 52487750 (this is replacing P/N 52487554), to the mode valve actuator arm and snap into place on the HVAC module case.
Connect the vacuum lines to the actuator.
Install the driver's knee bolster. Tighten
Tighten the screws to 2 N·m (18 lb in).
Install the left side instrument panel sound insulator panel.
#01-08-50-008
Power Seat Track Adjusters
2001 Chevrolet Impala, Monte Carlo -- Built After VIN Breakpoint 19298567
Beginning with the VIN breakpoints listed above, the power seat track adjusters are non-serviceable and therefore individual parts are not available. If repairs are required to the power seat track adjuster on these vehicles, it will be necessary to replace the complete assembly.
Important
Vehicles built prior to the VIN breakpoints listed above have power seat track adjusters that can be serviced with individual parts.
Thanks again!
Here is a list of the ones for the 2001 GMC C series trucks.
#00-03-10-008 Unable to Lower Spare Tire (Install Spare Tire Cross Brace)
#01-06-04-012 Malfunction Indicator Lamp ON with a DTC P0341, P0342, P0343 (Replace Cam Sensor)
#01-06-02-002 Whining Noise In Passenger Compartment When Engine RPM is 1700-2300 (Remove Coolant Flow Restrictor)
#01-06-04-020 Service Engine Soon Indicator Lamp On, DTC P1781 Set (Reprogram Engine Control Module)
#01-01-37-008 Passenger SIde of Vehicle Colder/Warmer Than Drivers SIde (Repair HVAC Case to Cowl Seal)
#01-07-30-002B Malfunction Indicator Lamp (MIL) On, Transmission Stuck in Third Gear, Instrument Cluster Inoperative (Replace Ignition Switch)
#01-07-30-021 Park/Neutral Position Switch Connector Cannot Be Removed (Replace Switch and Connectors)
#99-01-39-004A Air Conditioning Odor (Install Kit)
#01-06-04-034 Engine RPM Limited to 3,000 RPM and No Cruise Control (Check Wiring and NSBU Switch)
#01-08-56-002A Security Lamp Illuminated on the IP, Engine Stalls, No Start, DTC B2960 (Security System Sensor Data Incorrect but Valid) Set (Inspect and Repair Cause of DTC B2960)
#01-06-01-018 Engine Tick Noise at Valve Train Speed/Loss of Power (Replace Push Rod)
#01-08-64-014 Door Manual Lock Lever Disengages from Door Trim Panel (Repair Lock Lever)
#01-08-64-015 Front and Rear Side Access Door Noise (Replace Door Check Link)
#01-04-17-004 Clunk, Bump or Squawk when Vehicle Comes to Complete Stop or Accelerating from Complete Stop (Replace Rear Drive Shaft Nickel-Plated Slip Yoke)
#01-06-04-037B Fuel Transfer Pump Inoperative (Replace Fuel Transfer Module)
#01-07-30-034 5-4 Shift Busyness (Excessive Shifting) While Using Cruise Control and Towing (Reprogram PCM)
#01-06-04-050 Decreased Engine Performance/Power, Filter Minder Indicator On, Possible MIL Illuminated and DTC P0101/P0103 Set (Replace AIr Cleaner/Reprogram ECM)
#01-08-66-014 Pickup Box Sheet Metal Fracture/Damage with Aftermarket Accessories Installed (Repair Pickup Box Damage and Install Pickup Box Reinforcements)
#01-07-30-038 DTC P0757 Set, SES Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris)
#01-06-01-029 Higher Than Expected Engine Oil Consumption (Replace PCV Valve)
#00-02-35-003A Clunking Noise Under Hood and can be felt in the Steering Wheel (Lubricate Intermediate Steering Shaft Assembly)
#00-06-04-003A Rough Idle After Start and/or A Service Engine Soon (SES) Light (Unstick and Clean Central Sequential Fuel Injection (CSFI) Poppet Valves)
#01-01-39-007 Loss of HVAC System Mode and/or Temperature Control (Reroute Wiring Harness)
#02-06-04-002 Possible Communication Information Irregularities when using Generic Scan Tools (Reprogram PCM)
#02-04-17-001 Launch Shudder/Vibration on Acceleration (Replace Propeller Shaft and Install New Pinion Flange/Seal)
#01-01-39-005A Noise or Vibration in Passenger Compartment with A/C On Between 2000-2400 RPM (Replace Heater Outlet Hose)
#02-06-01-007 Accessory Drive Belt Noise (Properly Align Power Steering Pump Pulley)
#00-08-64-018C Rear Door Window Inoperative (Replace Affected Motor/Inspect Opposite Motor)
#02-06-04-015 Intermittent No Crank, No Start (Clean Battery Side Terminal Stripped Threads, Replace Battery Cable Bolt)
I was specifically looking for #00-02-35-0031 Clunking Noise Under Hood and can be felt in the Steering Wheel. I'm feeling something of that nature in my steering, but not all the time (mostly on right hand turns at about 30 MPH).
I was actually going to get the AllData subscription for this specific TSB, but also felt it would be a good thing to have to stay informed about possible problems with my truck.
Thanks again for all the info!
Nowadays, they modify and lube the part. I'd get it done now, so it's under warranty. If it happens again out of warranty, you may be able to get it fixed again under warranty, then.
You may want to check out the Impala forum. They talk about that particular issue alot.
Condition
Some customers may comment on a clunk type noise coming from under the hood that also can be felt in the steering wheel. These conditions may be more noticeable when turning at low speeds on rough road surfaces.
Correction
Important
DO NOT REPLACE THE FOLLOWING INTERMEDIATE STEERING SHAFT P/Ns
26085548
26049343
26083324
26088325
Remove the intermediate shaft from the vehicle and lubricate the intermediate shaft with a Steering Column Intermediate Shaft Lubrication Kit, P/N 26098419.
The remote you should see the dealer about. The seatbelt, is a wear item.
CONDITION:
Water leaks onto headliner, causing possible water stain on headliner.
CAUSE:1. Sunroof front and/or rear drain hose connections loose at sunroof module.
2. Front drain hose pinched by roof panel attachment bolts and/or rear drain hose kinked due to assembly of the grommet to the hose on vehicles built before and including VIN WZ246268.
3. Grommets at lower end of sunroof module front drain hoses may be obstructed by debris and/or be too restrictive on vehicles built before and including VIN XZ301802.
4. Void(s) in body seam sealer used at various locations on sunroof module.
It might be worth it to check it out.
Before I take the car back, I'd like to know if anyone out there has had this problem and had these TSBs performed on his/her car, or otherwise have knowledge of what they are all about? I've lost my faith in the dealership and want to able to point out to them exactly what they're supposed to do. Many thanks in advance and sorry for the longish post.
It is a warranty item, If your vehicle is under warranty.
Engine - Idle Undershoot/Rough Idle
NUMBER: 18-017-01
GROUP: Vehicle Performance
DATE: Jul. 20, 2001
SUBJECT:
Engine Idle Undershoot/Performance
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control Module (PCM) with new software.
MODELS:
2000 - 2001 (PL) Neon
SYMPTOM/CONDITION:
Some vehicles may exhibit one or both of the following symptoms:
^ 2001 model year vehicles; in ambient conditions typically below 16°C. (60°F.) the engine may undershoot the normal idle speed when braking the vehicle to a stop with the clutch depressed (manual transmission equipped).
^ 2000 or 2001 model year vehicles; engine roughness immediately after manually switching the A/C system "Off". Normal operation returns after a wide open throttle (WOT) occurrence or after engine restart.
DIAGNOSIS PROCEDURES:
If Diagnostic Trouble Codes (DTC's) are present, record them on the repair order and repair as necessary before proceeding further with this bulletin. If the condition(s) can be duplicated or are described by the customer, perform the Repair Procedure.
Qty............ Part #.............Description
1...........04669020..............label,authorized software upadte
1...........04275086..............Label,authorized modification
Parts required
CH6000 Scan Tool (DRBIII)
CH7035 General Purpose Interface Bus Cable (GPIB)
CH7000/7001 J1962 Cable
MDS2 (Mopar Diagnostic System)
EQUIPMENT REQUIRED:
NOTE :THE MDS2 AND DRB III(R) ARE REQUIRED TO PERFORM PART OF THIS REPAIR, WHEN USING THE MDS2 AND THE DRB III(R), THE SYSTEM MUST BE OPERATING AT CIS CD 2085 OR HIGHER.
REPAIR PROCEDURE:
Reprogram the PCM using the MDS2 (Mopar Diagnostic System) and DRB III(R) (Scan Tool).
NOTE :THE FOLLOWING STEPS ARE REQUIRED BY LAW.
-Type the necessary information on the "Authorized Software Update Label" p/n 04669020. Attach the label to the PCM and cover the label with the clear plastic overlay.
-Type the necessary information on the "Authorized Modification Label" p/n 04275086 and attach the label near the VECI label.
So I don't have the new bulleting yet. I will see what I can find out though.
If the vehicle is not under warranty, then it is an out of pocket expense to you.
If you just bought the vehicle, then you may (not always) be able to get them to cover the repair, but the likelyhood of it happening is fairly slim.
If the dealer is a reputable dealer and concerned about his customers and you only recently purchased it, he might just cover it. But also be aware that the TSB may have been done already.
#00-032 - Moonroof - Squeaks from Moonroof Seal
and
#00-023 - Moonroof - Booming Sound When open
Need more info, like year, make , model and engine to be able to locate nay TSB. But I looked thur the Rodeo TSBs I could find and none on alignment.
garypen,
SYMPTOM
A booming sound when driving between 20 mph and 40 mph with the moon roof fully open.
PROBABLE CAUSE
The wind deflector is not dampened properly, or it is not sitting high enough. Some vehicles (above VIN 007200) may have the wrong wind deflector installed.
CORRECTIVE ACTION
Install new foam pads for the wind deflector, or replace the wind deflector.
PARTS INFORMATION
Foam Pad: P/N 70355-S3M-A00
Moonroof Wind Deflector: P/N 70500-S3M-A01
Squeak From the Moonroof Seal
SYMPTOM
The moonroof seal squeaks against the roof when the glass is closed and the sunshade is open.
CORRECTIVE ACTION
Install Honda Squeak Reduction tape around the moonroof opening.
REQUIRED MATERIALS
Honda Squeak Reduction Tape (One roll repairs about 12 vehicles): P/N 70200-ALL-999
No TSBs for an alignment problem or a winter mode problem. Sorry.
Service Bulletin Number: 01081
Component: POWER TRAIN: TRANSMISSION: STANDARD:
Service Bulletin Number: 01054
Component: SUSPENSION:INDEPENDENT FRONT
Service Bulletin Number: 010701
Component: FRONT CONTROL ARM:LOWER:BALL JOINT
Service Bulletin Number: 010201
Thank you very much.
If they are NHTSA numbers, the likelyhood of finding them is slim.
The other two, who knows. If they are relaeased, then Honda has not released them tot he aftermarket yet.
Information -- Battery Insulator Replacement
1999 and Prior Passenger Cars and Light Duty Trucks
It has been found that the battery thermal insulator, installed on many new General Motors vehicles, is not always being placed back on the vehicle's battery when the battery is removed or replaced. The installation of the insulator is essential for battery life.
When a battery insulator is specified for use on a particular vehicle, the underhood temperatures for that vehicle are high enough to be critical to battery life. Omitting the thermal insulator when installing the battery will considerably reduce the life of the battery by exposing it to higher underhood temperatures. Inspect the insulator for any damage. If the insulator is damaged or missing, replace as required.
-David
1) 99-01-38-005 DEC 99 HVAC Lack of Performance
2) 01-08-111-003 DEC 01 Roof Panel Joint (Ditch) Molding - Service
3) 01-08-64-008 New Style Water Deflector; 2000-2001 Chevrolet Impala
thanks in advance!
HVAC Lack of Performance (Evacuate and Recharge the A/C System) #99-01-38-005
1997-2000 Buick Regal
1999 - 2000 Buick Century
1997-2000 Chevrolet Monte Carlo
2000 Chevrolet Impala
1998-2000 Oldsmobile Intrigue
1998-2000 Pontiac Grand Prix
Condition
Some customers may comment on a lack of expected performance of the air conditioning system in hot humid weather.
Cause
This condition may be caused by an undercharged A/C System. This may have occurred during the vehicle assembly process.
Correction
Service correction procedure for 1997 through 1999 vehicles
Perform the Cooling Insufficient, A/C System Check found in the HVAC section of the appropriate Service Manual. If a condition is identified, make the appropriate repair. If no abnormal condition is identified, proceed to the next step.
Evacuate and recharge the A/C system with 1.02 kg (2-1/4 lbs) of R134a.
Replace the A/C evaporator label with P/N 10442041. This label will allow future service technicians to know at a glance how much refrigerant is required by the system.
Service correction procedure for 2000 model year vehicles.
Chevrolet Impala/Monte Carlo, SOP through VIN Y9133359.
Buick Regal/Century, SOP through VIN Y1101894.
Oldsmobile Intrigue, SOP through VIN YF115332
Pontiac Grand Prix, SOP through VIN YF115332
Service procedure for 2000 model year vehicles within the following VIN breakpoints
Chevrolet Impala/Monte Carlo, VINs Y9133360 through Y9206366.
Buick Regal/Century, VINs Y1101895 through Y1178929.
Oldsmobile Intrigue, VINs YF115333 through YF191330.
Pontiac Grand Prix, VINs YF115333 through YF191329
Important
This group of vehicles had the correct amount of R134a installed at time of manufacture, however, the label was incorrect.
Service procedure for 2000 model year vehicles greater than the following VINs
Chevrolet Impala/Monte Carlo with VINs greater than Y9206366.
Buick Regal/Century with VINs greater than Y1178929.
Oldsmobile Intrigue with VINs greater than YF191330.
Pontiac Grand Prix with VINs greater than YF191329.
Important
These vehicles were produced with the correct amount of R134a and the correct Label.
Inspect/test the A/C system for signs of leaks both visually and with the A/C leak tester used in your service facility.
If a leak is found, perform the recommended repair as outlined in the appropriate Service Manual for the vehicle being serviced.
If no leaks are found, perform the Cooling Insufficient, A/C System Check found in the HVAC sub-section of the appropriate Service Manual. If a condition is identified, make the appropriate repair. If no abnormal condition is identified, the system is operating per design specifications.
Parts Information
Part Name Part Number
Label, 10442041
Bulletin No.: 01-08-111-003
Date: December, 2001
INFORMATION
This bulletin is being issued to inform dealers that when a roof panel joint (ditch) molding is removed or becomes loose at the ends, a new molding MUST be installed. DO NOT attempt to repair loose areas or bond the molding with adhesives or other materials.
NUMBER: 14-001-02
GROUP: Fuel
DATE: May 6, 2002
THIS BULLETIN IS BEING PROVIDED IN ADVANCE. DO NOT ORDER PARTS OR PERFORM ANY ACTIONS RELATED TO THIS BULLETIN UNTIL JUNE 3, 2002.
SUBJECT:
Fuel Cap Difficult To Remove
OVERVIEW:
This bulletin involves installing a revised fuel cap seal.
Fuel cap is difficult to remove after being tightened and not removed for one day or more. If the cap is removed immediately after tightening the condition may not be apparent.
PARTS REQUIRED
REPAIR PROCEDURE:
1. Remove the fuel cap from the filler neck.
2. Remove the rubber seal from the fuel cap.
NOTE: BE CAREFUL NOT TO SCRATCH OR OTHERWISE DAMAGE THE SEALING SURFACE OF THE FUEL CAP.
3. Clean off any residue on the filler neck and the threaded area of the fuel cap.
4. Install the revised seal, p/n 05086655AA, being sure the seal is properly seated and not twisted on the fuel cap.
5. Install the fuel cap.
Do you not have a zip extractor? I tried 3 different zip extractors and had no problem opening it.
