Visitor Agreement.
Motorcycles are a royal pain to clean. By comparison, cars are a piece of cake. I've found one cleaner that flat out works. Period.
It's called S-100. It's made in Germany, I think, and if you call around to M/C shops in your area you should be able to find it. If not, let me know and I'll get the 800 #s for a couple of mail order sources.
I've used it on 100% of the surfaces of numerous motorcycles, including painted steel and plastic, unpainted plastic, clear plastic, alloy wheels (painted and otherwise), engines, vinyl seats, etc. I haven't found it to harm anything. The only problem with it I've heard of was from a friend who hand painted (!!) a pinstripe around the circumference of his wheels. S-100 took some of that paint off, but it hadn't been baked on at all, and I don't know how thoroughly prepped the wheels were first.
Anyway, this product will just about remove chain lube from a motorcycle wheel without scrubbing. A little light rubbing with a rag or sponge, and it will. It will also remove brake dust from auto wheels with very little effort.
HTH,
Bob
I have had excellent results using Meguiars product. I believe it is #41 or something like that. It is NOT greasy or oily like Armor All, and it has UV protection in it. It does NOT attract dust, or evaporate onto the windshield like many other products (Armor All, Formula 2000)
Bob-
Don't know if I would trust a product that would remove pinstriping on my wheels! Just my opinion.
Rob
thanks for the kleen wheel thoughts.:) sadly, everyone else's impressions match mine and since i am one of those maniac type drivers i wont risk brake fade to make my cleaning job easier.
I guess I should call the phone number, but if you buy on-line they promise free Priority Mail shipping. I can't pass up free stuff :-)
Brian
College Station, TX
When you order the spray wand, they also use a third party escrow service to handle payment. it's actually a good idea, because there's a degree of protection there for the consumer. Adds extra steps to the ordering process, but it does work.
'Course, don't have any Zaino yet, and followed up my clay job w/ Meguiar's carnauba wax. This always takes me so-o-o-o long to do, and today was no exception. The car looks awesome!, but need to know again...how long ave. does it take you all to Zaino your vehicle assuming you use the Z-2? How long to do the car w/ Z-1, then Z-5?
Getting close to making that purchase, but the time factor is a biggee for me. To wash, dry, clay, wax, and clean the wheels, took 4 1/2 hours. This is normal for me...sort of a perfectionist and very slow, too.
Thanks!!!
LOL, good analogy. :-) I ordered my wand through the online ordering process which, as mentioned by others above IS a little confusing but definitely worth the effort.
As for longevity, they rate them for X number of gallons. The flow rate is adjustable so the time span will vary according to your flow rate selection. To adjust the rate just turn the little slotted screw on the tip in or out until you achieve the rate you want within the wands range of adjustment.
I left mine at the factory setting and have grown used to it and like the amount of flow it gives me. At first I wasn't so sure about that since I used an open hose before and the flow rate of the wand is MUCH lower than the open hose.
bjmeyer,
It sounds like your friend may have used an uncatalyzed striping enamel such as "One Shot" on his wheels. Do you know what kind of paint he used? Just curious. :-)
reBMW,
If the plastic is smooth and non-porous I'd try Zaino Z2 and Z6 on it. That would be easier than using the plastic polish and should work great as long as it is not porous. :-)
needavan,
I feel your pain. I too had trouble when I ordered my wand. It's a shame that it's such a pain in the [non-permissible content removed] to get such a good product!! :-)
sebarge,
Applying and removing the first coat of Zaino Z1 and Z2 will probably take around 45 minutes not counting dry time. This allows for careful application to get a nice even coat. After you have that initial coat of Z1/Z2 out of the way each coat should take around 20 to 30 minutes to apply/remove, again not counting dry time.
The dry time can be as short as 30 minutes or as long as two hours (longest case I have seen personally-temp was in the 40's) on the first coat, depending on the temperature and humidity. Cool temps and high humidity tend to slow the dry time of Zaino.
To find out if a coat of Zaino polish is dry and ready to be removed just take a clean finger and wipe across the surface. If it wipes away clean and is crystal clear the polish is ready. If it doesn't wipe away crystal clear just give it a little more dry time. When it is completely dry it wipes away almost efortlessly.
A Z6 wipedown usually takes me about 10-15 minutes but it may take you longer until you get the hang of it. I hope this helps. :-)
Chris Parrish
nd4speed@bellsouth.net
Is there a reason why the inside of wheels need to be cleaned? I can see why it would be necessary for show purposes, but for normal everyday cars to be driven? I have trouble enough finding time to keep the visible parts clean.
#91
Never having used one, I can't comment on the effectiveness of those wands, but the explanatory material on that web page sounds like a "snake oil" pitch to me. "... a series of reversing magnetic fields" ...?? It may be a perfectly valid explanation, but it sure triggered my BS detector. I wonder if the wand is good for arthritis too? Of course, I must admit that Sal's web page sounds a little tecnobabbly too, but I've used and like his products.
Tom
Thanks for the info!
Using Z-6 (Gloss Enhancer Spray) and the Z-7 (car wash) really keep the finish looking fabulous for several months after polishing with Zaino.
I have had Zaino on my car for more than three months now, and am very impressed with how great the shine is, and how well the water is still beading!
Rob
> couple of weeks, and decided it was time for me to reply on this. I own a
> Island Teal 1968 Chevelle SS396 showcar, and was given a can of Marque D'
> Elegance by the painter of the car ($4000 paint job), who was an avid
> Collinite user for several years. I was using it on the Chevelle for about 2
> years, when my friend lent me some Zaino and said you gotta try this stuff. So I
> decided to go ahead after all I had a black 96 Viper RT10 on the way. I
> followed the instructions and did the Chevelle in Zaino. Amazing was the first
> thought that popped in my head. The car
> gleamed and actually seemed to be a different color. The gloss was much wetter
> and less greasy looking than the Collinite. The best part was the ease of
> application. Before the Collinite took over an hour to apply and properly
> buff. You had to do one panel at a time and couldn't let it dry too long, and
> hope the sun didn't come out. Otherwise it was a nightmare to remove. Zaino was
> applied to the whole car and done in 40 minutes with no streaks. Well if this
> wasn't proof enough I actually tested it on the VIPER!!!!!!!!! I did the car in
> Collinite and tested it for a month. First of all the Collinite was nothing
> less than a nuisance to apply and remove on a black car. It was oily (Zymol
> like) and very streaky. It left the paint blotchy in appearance. I was very
> unhappy with how hard it was to use on this color car. Now the Viper was being
> driven daily, so it was a good test. The car was so dirty for simply 10 minutes
> of outside time. The shine simply died after the first rain storm. No only
> that, but after 4 rain outings the car barely beaded any water!!!. I said this
> test is over, and prayed the Zaino was better than this. I followed Zaino's
> instructions once again. The application went smooth and pleasant. The paint
> was so crystal clear and wet looking and I couldn't keep a towel on it. The
> car also seemed to repelled dust, where the Collinite attracted it... I even
> applied a 2nd coat of Zaino in direct sunlight, and No streaks. (Try that with
> Collinite). The black paint got even deeper. The car looked (and still does)
> like a custom painted Viper. And durability was unreal. This stuff has such
> tight, high water beads. If you wash the car and take it down the street, it
> will actually shed the water beads to an almost spot free finish. The water
> never seems to penetrate the finish and dry like it did before. The car looks
> and stays cleaner longer. The funny part is I actually got the original
> Collinite lover (Chevelle painter) to convert to Zaino! He says it is unlike
> any product he as ever used.
> Jim
I'm gonna try the Zaino. My car looks so good now, I can't imagine it looking better, but then I couldn't imagine the Erazer clay removing what it did, either.
Going to get the Z-1, Z-2, and Z-6 for sure. Should I get the Z-5, as this is a fairly new car?
Thanks again.
There are so many benefits to the Zaino system, that it is hard to list them all;let alone describe them in excruciating detail.
I guess it's to each his own on whether or not to clean the inside/backside of wheels. Personally, if there is dirt there and it is visible (anywhere on the car) I clean it. On the visual side, with 17 inch alloy wheels and disk brakes, you can easily see it. Cleaning it out makes a big difference in how the whole wheel looks. Just my .02. :-)
I ordered the wand, the Zaino products and today am going to buy Clay Magic. I'm just getting everything in order and asking the experts on this site. Thanks.
I appreciate your results, but do not find Collinite to look or feel the least bit oily, greasy or streaky/blotchy. Sometimes extremely high humidity can cause this with some products. I agree carnuba products seem a bit tougher to wipe off than the Zaino I have tried, but I've never been able to see a clear difference in shine/depth in my comparision of the two so far.
One thought. Sometimes people tend to put on carnuba products too thick. I find that, especially Collinite, is at it's best when put on in a very thin layer by bare hand, and (as you found) wiped off after each panel rather than waiting till the entire car is done. I am not saying you did anything wrong, just making an observation based on my own use. When I put Collinite on thick, I got some of the same results you mention. I don't anymore.
Thanks for posting your results though, it appears that Zaino is just right for you.
Don
While cutting the towels in half shouldn't hurt anything as far as results, it will shorten the life of your towels. They will tend to ravel and become nasty looking (a technical term!)
A better solution if you don't like the big towels, is to buy hand towels rather than bath towels. They are usually the exact same cloth/thickness/quality, just smaller.
Don
No, I'm afraid I have no idea what kind of paint he used. But I'm sure he knows no more about paint than I do (which is almost nothing), so I'd not be surprised if it wasn't suitable for the purpose.
Bob
Glad you spoke up. The fact that the long time Collinite user converted to Zaino says it all. Zaino is pretty good stuff, huh?
A black Viper. Cool! No better color to test a polish/wax on than black!!! I have had 3 black cars, and I know what you mean about Carnauba based waxes attracting dust!!!
Sebarge-
Believe me, I thought the exact same thing before I tried Zaino...I thought no way could my car look better than it already did. But it can! But don't take my word for it, judge for yourself after applying a couple coats of Zaino!
Kate12-
I personally like to use a full size bath towel, and fold it over a couple times. This has the effect of giving a bit of "cushion" and prevents too much direct pressure from being applied to the paint surface, and helps provide more even pressure as well.
As far as using Martex towels (I have never heard of them) if they are made in the USA AND it says 100% cotton, they should be ok. Make sure they are not a cotton/polyester blend.
Rob
Thanks for the info. I'll try your method of folding the towels when my Zaino arrives. I mailed my order this past Monday from Ohio. I can't wait to try it out.
How many towels am I likely to need? OK, this might help: I have a new Odyssey mini-van, which (from looking at the car next to me in the parking lot this morning) is a couple feet shorter in length than a suburban. So lets say a big car or truck.
Do I need five towels? Ten? For what new towels cost, my wife is gonna SKIN me if I have to get too many.
By 'do it right' I'm talking about wash / dry the car, apply Zaino, wipe off. I won't be doing anything to the wheels at this time, as I have plastic wheelcovers. I'll just wash them (with a separate sponge) and leave them alone. Windows I'll use newspaper on (it really works, my mother is an artist and framer and will use nothing other than windex and a newspaper to put frames together).
I understand the 'buy american 100% cotton bit' so you don't need to remind me of that :-)
OH, btw, I went to three different auto stores in search of clay magic. Zippo. But every kind of Maguiers (sp?) was there, (at all of them) along with a bunch of other things which may or may not be snake oil. For that matter, Zaino looks like snake oil too but at least I have more than one person here saying they really like what it does.
Brian
College Station, TX
I've never tried Meguiars clay, but other posters have said that it's very inferior to Clay Magic and Erazer. Supposedly it leaves greasy streaks.
I can't remember if you're one of the people who asked me for my little informal guide to using Zaino stuff. If you haven't asked for it yet and want it, email me, and I'll send you a copy. Sal Zaino has seen it and says it's good.
I love the color of your car! :-)
needavan,
I agree, four towels minimum. Also, you can't go wrong with Erazer or Clay Magic.
You can order Erazer through their website ( www.erazer.com ). A mail order source for Clay Magic is www.summitracing.com . :-)
wstang,
"Orange peel" is simply the texture of the paint surface. It is present immediately after the paint is sprayed. It isn't a condition that occurs over time.
Chris Parrish
Terry
The Z5 and Z6 have worked great so far. Definitely give the Z5 time to dry. Thank goodness, the gas furnace is located in a closet in the garage so the garage is dry and 20 degrees warmer than the cold outside.
I'm glad I read the posts about applying the stuff on thinly. So far so good. The vehicle looks fantastic and I was a big fan of Nu Finish!
Now, if only Zaino only made a polish that would get rid of door dings, I'd have the perfect looking car.
Thanks to Chris Parrish for your dedication to Zaino. Now, if only I had a little more free time.... I'd get to that Odyssey.
-- Dale
Terry
I guess I should of tried www.collinite.com, shouldn't I? *grin sheepishly*
-- Dale
I just have some silly questions regarding 'claying' your car.
(1) What does 'claying' your car buy you and is it a simple procedure to do ?
(2) Also, if your car is brand new, is 'claying' necessary before applying the Zaino products ?
http://www.erazer.com for a fairly informative overview (with pictures!) of claying and what it can do for your finish.
Bri
If you to the Smart Shoppers conference and check topic 970, you'll read a ton of posts about claying and other related ideas.
Good luck,
Terry
You found the Collinite site, so that should answer most of your questions. I sell selected Collinite products at a discount, I'll send you the specifics privately.
#137
Since "Claying" is such a benign process (not destructive, no real downside, and lots of benefit), there is no reason not to clay anytime you want. Some vehicles really need it, and others new and old seem to never get the problems that clay is meant to address. Still, there are more and more new car dealers using clay on every car they get in, no matter how good the finish feels. So the answer is "Just do it!"
Don
I have since Z2'd and the results are awesome. If the car didn't have door dings and minor body work gaffs, you'd think my 67k mile Civic was just off the showroom floor. And it's black which is the worst color to keep looking good.
One comment on clay. I clayed quickly and can see where I should have taken more time with the clay. Don't get me wrong, I got 90% of the contaminents, but on compound inverted curves, I can actually feel were I skimped with it. The Z2 makes the pain look so good that you can see the particles that you missed. Not a big deal, but if you're car is older and never been clayed before, take your time and be thorough.
Now that I've finished the Civic, I can't wait to do my Odyssey and my parent's 91' Explorer. Of course, do you think my company will allow me to take a week off in order to Zaino everyone's car?
Overall, it takes less time than you think, it's just many steps. You need to put your car out of service for a couple days.
Chris, Does Zaino work on fiberglas boats? Just curious.
bostnwhalr,
Zaino is excellent for use on water craft. I have a friend that uses it on his jet ski and it has far outlasted any wax he's used on the hull of the craft. I would recommend applying a coat or two of Z5 to the submerged portion of the hull and Z2 on the rest. The higher solids/build that Z5 offers will probably last longer and the perfect gloss ain't exactly critical below the waterline. :-)
Chris Parrish
I'm not saying not to use it if you want to, I'm just trying to save you from any unnecessary headaches. If the company that makes/sells it recommends that you don't use it on clearcoats you can rest assured that it's for good reason. They would NOT recommend against their own product if it was ok to use for a given purpose. That's just good business sense. I do have to give them credit for publishing that information.:-) Some companies don't give you a warning. They just let you buy their stuff and screw something up. :-(
Chris Parrish
I completely agree with your comments about Zaino (z-2) making the paint look so good that you can see where you may have skimped on the clay. This happened to me the first time I used Zaino. I was in a bit of a hurry to try the Zaino given all the positive comments, so their were areas on the car that I did not clay as good as others. After a couple coats of Z-2, you could really tell where I had not clayed as well. Zaino is awesome stuff, but it is NOT a cleaner.
Glad to see so many people have discovered the awesome benefits of using a clay bar on their vehicles!
Rob
From what I have discovered (from Sal and other sources), even new cars have swirl marks (usually from the dealer prep). Check it really closely--you may be surprised at how many swirls you have. As you get a good shine on the car, the swirls become more noticeable.
Do you know if a California duster is safe to use? I don't want to use the product if it causes any marks on the vehicle. I thought wiping down the van when it only has a little surface dust on it would be beneficial. I'd appreciate your help. When I saw it in Pep Boys, the container the product was in made no mention of fabric type. 100% cotton??- I have no idea.
I've seen lots of positive comments ragarding claying your car before applying other product like Zaino. But I'm still unsure which product(s) you guys use to clay your car w/o any problems.
From what I gather, there is a product called "Clay Magic" which is not easy to find and some other product from "www.erazer.com".
1). Is there a difference between "Clay Magic" product versus the product offered by "www.erazer.com" which is called "Surface Cleaning Material". Is this is the product that some people use to clay their cars ?
2). Is there a temperature requirement when to clay your car. I live in Mass. which is still cold (low 30's to low 40's during the day) at the moment. My car is in the garage which is about 8-10 degrees "warmer" than outside. Is it OK to clay your car when the temp is in the low 40's ? Assuming there is no problem claying your car in this temperature, is it safe to Zaino your car in the same temperature as well ? Thanks.
