Visitor Agreement.
Went over to K Mart in my town. Wanted some Dextron III fluid. They had none on the shelf. I found the "boy" who said he was in charge of Auto. He said that they haven't had any of that for three months....all they have is the type for Chrysler products. He said Corporate persons were the blame for the product not being on the shelf. Horseshit!
My reply was that I predicted that K Mart would be going out of business soon. Any place that has no communication betweed the workers and the buyers will not survive. They have a tremendous Management problem at the store level...and probably higher.. It is as much the "boy's" fault as it is "corporate's" fault that Dextron III is missing from shelf. There's plenty of "apathy" laying around there...
Of course WalMart had shelves full...with two brands to choose from. Sheesh.. $1.22 or $1.88...take your choice!
Any guesses as to probable problem would be nice. Thanks, Chris.
Has anyone else had similar issues? I've heard here and there that this transmission is generally a poor one. If this is the case, why hasn't Jeep extended the warranty on it in the same way they extended the warranty on the manifold cover?
Here's the kicker: it all started when the tech put on a new timing belt. Why would changing the timing belt have anything to do with that?
Thanks in advance for your help and advice.
I have a 98 Civic EX (automatic) and suddenly it developed transmission problem. When I change gear from Parking or when it automatically changes gear while driving, it gives a big jerk. On taking to the dealer, we found out that the transmission is bad and need to be replaced (costs around $4000). Has anybody faced such a problem with 98 Civic or any relatively new car. Also, what shud I do with the car. Fix it or drive with it etc.. Please advice.
Venky
Stay away from that crook.
I have a 1994 Jeep Grand Cherokee 5.2L V-8 Limited with 102K trouble free miles. Now, a low pitch/frequency growling noise occurs with vibration when moving at 58 to 65 mph from the front end area independent of turning or moving in straight direction. The noise and vibration are worst at about 62 mph with accelerator only slightly depressed. Noise and vibration goes away completely during coasting or hard acceleration, or at any other speed.
My mechanic checked the wheel bearings, drive shaft, CV joints/boots, pinion oil seal, front axles, front differential, universal joint, motor mounts, and other possible sources. He found no obvious problems with them. The transmission, and both front and rear differential services were completed recently with appropriate fluids/oil. My mechanic thinks that the vibration and noise may be coming from the TRANSFER CASE.
What do all of you think? What do you think I should do next? Any input would be greatly appreciated!
TSB # 01-07-30-023A
Harsh 1-2 Upshift, SES, MIL, or CEL Illuminated, DTC P1870 Set (Replace Valve Body)
1996 Buick Roadmaster
1996 Cadillac Fleetwood
1999-2000 Cadillac Escalade
1996-2000 Chevrolet Camaro, Corvette
1996-2000 Pontiac Firebird
1996-2000 Chevrolet and GMC Light Duty Truck Models
1996-2000 Oldsmobile Bravada
with 4L60-E Automatic Transmission (RPO M30)
Built Prior to January 15, 1999 (Julian Date 9015)
This bulletin is being revised to update the Parts Information. Please discard Corporate Bulletin Number 01-07-30-023 (Section 07 -- Transmission/Transaxle).
Condition
Some customers may comment on a harsh 1-2 upshift and the Check Engine Light or Service Engine Soon indicator is illuminated.
Diagnosis
Typically, these vehicles will have been driven more than 32,000 km (20,000 mi) before this condition occurs.
The scan tool may show a DTC P1870 set as a history code.
A harsh 1-2 shift or DTC P1870, caused by wear in the control valve body, may be difficult to duplicate when the transmission temperature is below 93°C (200°F).
Cause
The condition may be due to wear in the control valve body. This wear occurs in the bore that contains the TCC isolator and regulator valves, and results in poor, or no, TCC apply.
Important
DTC P1870 is a type B code. The conditions for setting the P1870 DTC must occur on TWO CONSECUTIVE TRIPS (ignition cycles, with a drive cycle) before setting a P1870 history code.
When the conditions for setting DTC P1870 are met (first trip), the PCM commands maximum line pressure and harsh 1-2 shifts are the result.
This may result in a harsh 1-2 shift with no history code if the conditions for setting the DTC required for the second trip are not met, on two consecutive trips (Ignition cycles, with a drive cycle).
When the conditions for setting the DTC are met, on the second consecutive trip, a DTC P1870 is stored as a history code.
When the P1870 code is stored, the PCM will turn on the Service Engine Soon (SES), Check Engine Light (CEL), or Malfunction Indicator Lamp (MIL).
Correction
Install a control valve body with the revised TCC regulator and isolator valves. These valves are used in all transmissions produced after January 15, 1999 (Julian Date 9015), and all of the service parts currently available through GMSPO contain revised TCC regulator and isolator valves.
Important
If all of the following conditions are true, it is not necessary to rebuild the transmission or to replace additional transmission components beyond the control valve body.
Transmission operation is normal before the transmission reaches operating temperature, or before DTC P1870 is set (no slips, flares, or missing gears).
The torque converter is not blue or overheated.
The transmission fluid is not burned or has no burned odor.
The transmission fluid pan contains no abnormal debris (clutch material, bronze, brass, or metal fragments
Ebb
General Motors Corporate Product Service Bulletin #01-07-30-023B
1996-2000 Oldsmobile Bravada with 4L60-E Automatic Transmission (RPO M30)
Built Prior to January 15, 2000 (Julian Date 0015)
This bulletin is being revised to update VIN Breakpoint Date information and revise the Parts Information table. Please discard Corporate Bulletin Number 01-07-30-023A (Section 07 -- Transmission/Transaxle).
Condition
Diagnosis
Cause
Important
When the conditions for setting DTC P1870 are met (first trip), the PCM commands maximum line pressure and harsh 1-2 shifts are the result. This may result in a harsh 1-2 shift with no history code if the conditions for setting the DTC required for the second trip are not met, on two consecutive trips (Ignition cycles, with a drive cycle).
Correction
Install a control valve body with the revised TCC regulator and isolator valves. Refer to the Parts Information table below.
These valves are used in all transmissions produced after January 15, 2000 (Julian Date 0015), and all of the service parts currently available through GMSPO contain revised TCC regulator and isolator valves.
Important
The transmission fluid pan contains no abnormal debris (clutch material, bronze, brass, or metal fragments).
I know that the torque convertor locks on auto trannies when put into park. Is this a symptom that my tranny is starting to go?
I'm also having a separate problem with the torque convertor not releasing soon enough in OD. If I have to push it to go up a steep hill, I hear vibrations from the area of the transmission. The RPMs don't increase therefore I'm assuming the torque convertor is still locked. If I really push it hard, it will unlock a second before downshifting.
Time to bite the bullet and take it to a tranny shop.
I guess that's the risk you take with a used vehicle.
bnosyt
with 66K miles. Occaisionally a sound like driving over highway rumble strips occurs. Anyone experience this in a Ford product? Could
this be a Torque Converter problem? Thanks.
Problem sounds similar to jonbgood, so if you have any more insight or solution to this problem I would appreciate it!
In reverse, when backing up under a load (like pushing my boat uphill into the garage) it sounds like a gear is trying to strike another gear, although it still goes uphill OK. But the sounds are getting louder since the spring.
The truck has 187K and the original clutch. Transmission fluid has been changed according to schedule, including the differential. Last changed the fluid just 10K ago, at the dealership.
Any clues?
That's hard on any transmission. My guess is that after 187,000 miles the transmission is getting pretty worn out and probably needs an overhaul. Do the clutch, of course, at the same time.
Or you could just let it go...could last a long time.
