Visitor Agreement.
Praise be to God, Praise be to Yahwe, Praise be to Allah, etc...
Believe it or not, but just as I was pulling into the parking lot of the transmission specialist, the car started shifting again! Just ... Bang! Out of the Blue! I drove it around town a few times just to be sure. And sure enough, the tranny was working normally. I guess my mechanic was right, the computer needed some time to re-establish the shift points.
But geez, if it takes three whole days and 30 miles of driving for the computer to synchronize with the transmission, I have to wonder just how slow its processor is (remember the 286?).
Nevertheless, the grin plastered on my face will take a long time to remove ... or at least until the next problem which hopefully is a long ways away.
This is one strange story, and I believe you. Keep us up to date.
The main reason for tranny service is to replace the filter and of course the fluid.
I guess i am old fashion,i just replace the fluid and filter every 30K,never had a problem.
Post if you have any problems.
This is a dirty job best left to a professional with the right tools and a hoist.
Also, if that transmission has been sitting around a long timeI would reccommend replacing the front seal while it's out. The seal is probably 5.00 and takes nothing to install since it's out of the car. If the seal in it now is dried out from sitting, it'll leak.
So I'm either going to buy, borrow, beg or build a transmission jack, put the car on jackstands, and do it myself. I'll probably enlist the help of friends or something, but there is no way on earth I'm lettting some high-school dropout who really couldn't car less touch my car. I've been that route one too many times, and a lot of times I get the felling I know twice as much about this car as the guys working on it, and they get ticked off when I tell them specifically what needs to be done, and then still do it wrong. I think for most of this project, I'm going to do it myself, and that way, even if I mess up, I won't be paying 50 bucks an hour to screw up.
Change that ATF regularly and use the recommended ATF.
P.S. My reference to pulling the pan was on the replacement trans.
Naw, I've got a reliable car with a good transmission for transportation til I get this one running. This '78 was my grandma's car since new, the first car I ever rode in, and she gave it to me on my 16th birthday, so it's my first car. This is a labor of love, and one way or another, I'm going to make this thing go backwards under its own power.
I don't think it was slipping in third, but just before it quit engaging 3rd gear, it got really reluctant to shift into third, like it did with reverse. Other than a valve body/case gasket, am I correct in assuming the transmission has to be taken apart to fix the rest of that stuff?
But one crucial factor not mentioned by our resident experts (probably because they just assume you know) is CLEANLINESS when you take apart an automatic. As the little bacteria fells the largest beast, so too a little dirt can foul up your tranny's valve body.
Probably for tools you'll need a very long extension for your 1/2" drive, and some flex sockets or u-joint adapter, a 3/8" drive for the valve body (gentle, gentle) , a transmission jack (essential), snap ring pliers (essential if you're going inside)), air pressure for cleaning (ditto) , a nice strong workbench (ditto) and a good workshop manual for getting the converter/flex plate business correct. Also a good gasket scraper.
Be sure to inspect the flex plate closely for cracks.
Second Way to Do This: Buy a good used unit and have someone do the R&R for you. There are guys who are so good at this they'll blow your mind how fast they can put one in.
I was concerned so I now I use Redline D4 ATF; added the biggest Tranny cooler I could find, and lubeguard
Generally getting twice the mileage warranty is good service with the minimum recommended flush schedule obviously trannies which have the total ATF changed every 30k vs just the 3 quart pan drain live longer.
Approximately 16,000,000 trannies are repaired each year roughly equal to the number of new cars sold and the average age of the car on the road currently is 7-8 years.
> Generally getting twice the mileage warranty is good service with the minimum recommended flush schedule obviously trannies which have the total ATF changed every 30k vs just the 3 quart pan drain live longer.<
Obviously you don't read the three monthly magazines for transmission rebuilers.
http://www.atra-gears.com/gears/
http://www.atra.com/expo/
http://www.babcox.com/magintro.htm
"Considering that over 13 million automatic transmissions fail every year in this country, and that $2,000 isn't unusual for some trans overhauls,........"
"everybody including the Automatic Transmission Rebuilders Association agrees that 90% of failures are due to overheating. The oxidation rate (which determines the useful lubrication life) of ATF doubles for every 20 deg. F. temperature increase over the "normal" operating level, which means fluid that's formulated to last 100,000 miles at 175 deg. will only go 50 grand at 195, or a mere 3,000 at 275. ".....
The are over 720 AMMCO franchise locations with 6-10 employees to be fed! and each one can only do 500-1000 per year who changes the other 8,000,000?
Tranny are not a large part of our business but we change at least 25 Lexus and Infiniti AT units per year something like $75,000 per year worth or about 4-5% of our gross.
The gross margin rev minus cost is close to 40% takes more flushes than an human could do [in a year] to equal this amount $75,000/$130= 576 flushes in a year well I guees if 1420 cars need flushing we could do a new one every 3 hours...that would be 142 [55 gallon] drums of ATF
Have been doing pan drop and filter changes for 35 yrs and never had a failure,so i will never have a flush.
Even Allison recommends pan drop and filter change.
