Visitor Agreement.
I have an Accord 2002 EX/V6 for nearly 3 years and with 23k miles. According to the manual, it is the time to change the ATF. I have a few questions here:
1. Should I just drain and refill the fluid or should I do this 3-4 time with short drive in between in order to get a better flush?
2. Should I stick with Honda ATF or shift to synthetic one like ASMOIL ATF? Does it make a difference?
But, are there any specific reason why we should stick with Honda ATF?
Is there not true that some brand claims their product is better, especially on synthetic stuff?
Regards
Parker
74,000 miles on it, and now when i coast down the hill in reverse it will not even go into gear, and another thingis when i am in drive it wont go into 3rd gear, but when i drive in O.D. it goes into that skipping 3rd gear. looks like it needs to be rebuilded huh?
to the tranny shop . any heads up on how much we are talkin to fix?
And the winning price for all of this is $1,860.00 USD. But i guess i have to do it sence this van is my bread maker. Now that only comes with a 1 year 12k mile warranty, for $300 more i could get a 3 year 36k mile warranty. I chose not to get the 3 year do to finance reasons. Now you must excuse me while i go and drink a 12 pack of beer to forget the $$$ I just spent.
Sorry to rag.
Go to a transmission shop that has a good reputation and is recommended by friends!
A "sound" isn't necessarily bad all by itself but you should keep an eye on it.
did you notice if the color of the fluid was very clear red or if it were murky brown and smelled like burned cork?
But yes, if the damage is done, the damage is done, there is nothing "in a can" and no "procedure" that replaces real physical damage (mechanical wear) unless that procedure is an actual replacement of a worn part or adjustment of the wear---the latter being unlikely in most modern transmission units anymore.
thanks everyone
rryn122
1. DOes this sound right?
2. What should I expect my warranty (GE) to say?
2. Assuming my warranty covers it, the warranty allows for remanufactured parts. Is this better than rebuilt?
Thanks for your help.
If there is a lot of metallic debris in the pan, you have the early warning signs of a coming failure at some point.
And do like Mr shiftright says.
At 60k miles, I drained the transmission fluid on an aotomatic ford escort 99. To my suprise, only about a quart came out. Since 1 quart came out, I added a quart of mercron V transmission fluid. After that may car does not shift to the highest gear any more. It does not shift to the higher gear when i push hard on the gas pedal. What did i do wrong? what do I have to do to fix the problem. The car belongs to my daughter and i am very desperate. Please help. Thanks.
1) what is exactly a flush of the transmission fluid? It is the same as a drain of the fluid without changing the filter?
2) Can the problem be caused by a defective speed sensor? I have read a few articles on transmission problems and people have mentioned the sensor.
Where is the sensor located in an automatic 1999 ford escort? Is it the one that is located next to the fly wheel?
I took it to the local branch of a national transmission chain (because it was within walking distance from my house)...they said it was the transfer case, they said it was noisy (I never noticed)and hard to shift into 4WD (not for me). They added fluid to the tc and the transmission...I took it home but there was no change.
I called the service dept. of a local dealer, their guy said it could be a "drivability" problem, possibly electrical, I put my OBD2 scanner on it but got no codes. He didn't even mention a possible mechanical cause.
Any help out there? I need more ammunition for when I finally take it in.
#1190 of 1510 Automatic Transmission Problems by boltzman United States of America Oct 23, 2003 (3:27 pm)
Bookmark | Reply
Hi all, For the last couple of months I have been noticing that my 99 Rodeo's engine rpm is greater than before - at the same speeds. So, for e.g. it will go to 2800 at 75mph. I drove my friend's Rodeo and noted that it was 2500 at 75mph. I also notice clunking and a jolt when I put it into drive initially. Up-shifting also seems delayed. So I had the transmission fluid flushed and changed, and had it checked by the dealership (cost me $320) - to no avail. The problems still exist. They told me that it was showing a P0705 trouble code and that I should change the mode switch "and then go from there". This would cost me another $300 - but with no guarantees to fix the problem. So I decided to do some research before spending the extra $300. Can anybody think of why the transmission range/mode switch would be causing the transmission from slipping and clunking sounds when shifting to drive? I find that connection unconvincing.
#1192 of 1510 AT problems... by jtk152 United States of America Oct 23, 2003 (8:29 pm)
Bookmark | Reply
boltzman- A faulty gear range switch /sensor will give you these symptoms & OBDII code. The range sensor is located on the left side of the tranny. It's connected to the shift arm that sticks out the side. P/N 8-96017-511-0. Your tranny will act up when these go bad because this sensor not only lights up the appropriate "PRND321" dash light, it also tells the PCM what gear has been selected. If the powertrain computer is not getting a clean signal from the range sensor, it will put the tranny in "failsafe" mode which yeilds hard & erratic shifts. It's only a few small bolts, a nut on the shift arm & an electrical plug to undo to get the range sensor out. I've heard that just taking it apart & cleaning the contacts can fix it. It's about a $150 dealer part. This range/mode sensor seems to be the most problematic part of the 4L30E tranny. At least it's on the outside of the case!! G/luck
Joel
For example P0705 'Trans range switch illegal position' will NOT illiminate MIL.
By the way this trans will delay shift or shift in higher rpm(300-400 higher) when it cold(until ATF reach 70 C. It is normal.
If no code start from checking ATF level, there is no dipstick, correct level at fill hole, engine RUNNING, ATF is warm(90-145 F), more detail on Isuzu forum.
DON'T DO flush of trans.
Than try drain and fill, you get out about 4q from total 9q. $6 hand pump from Advance Auto work very well to put ATF back, more detail on Isuzu forum.
Couple things outside trans may really affect it performance: 1)going bad alternator, 2) on 1998+
bad IMG(intake man gasket).
Well... if after all of above checked/done you still have a problem do fancy/expensive stuff.
If it is a switch some people report to much grease inside the switch and cleaning it fix the problem.
Oh... if you do get a trouble code, report here, I can tell you short version what shop manual recomend for it.
Look for AUTORX dot com on the net.I NEVER try this stuff so USE ON YOUR OWN RISK.
I'm new here and I'm not very Car Savvy.
My Mazda 3 Hatchback has about 9500 miles on it and the transmission seems to be slipping. I can no longer accelerate properly. Going up-hill is a battle.
I bought the car from a dealer who claimed the car was returned to the lot because the owner defaulted on their loan.
Since the purchase I ahve had numerous problems.
The transmission problem is the most recent and by far the worst problem yet.
(others include, paint peeling, window making a cracking noise, fuel guage does not reflect correct fuel amt)
Is the transmission covered under the warranty?
What is the best way to deal with this?
Anyone else have problems with their Mazda 3s?
Thanks in advance for your help.
Also, run a CARFAX history check on this car and see if there's any problems.
If CARFAX shows a problem, like a salvage or a mileage discrepancy, contact an attorney immediately.
I think Audi are having some problems with these boxes but are not coming clean with it!?
But have it checked out...maybe you just busted a u-joint or something. I'd also check and see how well the engine installation was done and if there are cracks in the bell housing or bolts missing, etc., to indicate a sloppy installation and possible transmission damage as a result. Mercedes transmission rarely go "bang" and stop completely. Very weird.
You can also shop for a used transmission. There are lots of these cars produced and plenty in the wrecking yards.
I have a 1998 Mazda 626LX with about 82,000 miles on it. I've known that the tranny is bad and have been holding my breath, wondering when it was going to go on me.
Yesterday the O/D light started blinking and the car bucking a bit while on a 3 hour trip to Vancouver, CA. I kept driving, and after stopping at the border, the light went off and the drive went more smoothly.
So, I think I'm due for the replacement, yes? Or do you think there's a way to baby it for a while yet? If a replacement, do you recommend going to the dealer up here (maybe cheaper than in the STates) or to an AAMCO type dealer? there are also places up here and in Seattle that do lots of replacing of Japanese engines and trannys that I could look into.
Also, I heard that even after the tranny is replaced, it doesn't tend to be very successful. Why? Also, any particular model tranny that works better with a 626 than another?
Thanks so much for your help
Rondi Lightmark
Get a diagnosis and don't start off presuming to yourself or the mechanic that you need a transmission. Just describe the symptoms as you did here.
If you really needed a new transmission, you would not have made it to your destination I don't think.
So what am I going to do? All of the info I find on the Internet indicates new tranny.
Well, if the dealer would agree to apply the $200 diagnostic fee to the actual repair, I'd do it.
That's a pretty stiff fee. That's two hours shop time in California. Tell them they don't get paid for thinking slowly.
