2016 Audi A7 Lease Questions
asp76asp76 Member Posts: 2
edited April 2015 in Audi
Any information on lease parameters for the new 2016 Audi A7 Prestige Plus--looking at 36/12K?
«134
  • asp76asp76 Member Posts: 2
    sorry, looking at premium plus
  • MichaellMichaell Moderator Posts: 267,982
    .00130 and 57% for 3.0T and TDI
  • sk99sk99 Member Posts: 20
    Thanks @Michaell, what are the res/MF 2016 for Prestige for 12k/36mo?
    Also, what are the 2015 A7 Prem Plus and Prestige residual/MF for 12k/36mo? Thanks.
  • kyfdxkyfdx Moderator Posts: 271,579
    Prestige residuals are 2% lower than Premium Plus
    .00087 and 52% for Prem Plus. Deduct 2% for Prestige.
  • strongboxkeystrongboxkey Member Posts: 1
    edited April 2015
    Hello All,
    Would anyone happen to have current MF/Residual for the following?
    2016 A7 Prestige 10k/36 month with Audicare being thrown in.
    Thank you in advance for your help.
    Hello All,
    Gas - .00085 and 55%
    TDI - .00090 and 55%
    Add 1% for AudiCare
  • 12thman12thman Member Posts: 13
    Are the MF's the same for a 2016 Premium Plus as a Prestige, but with residuals just 2% higher?
    Correct.
  • ogbzaogbza Member Posts: 17
    Can anyone help me with the MF and residual for A7, Premium Plus, 36 month lease, 10,000 miles/year? Much thanks!
    Gas - .00085 and 57%
    TDI - .00090 and 57%
  • sigma2sigma2 Member Posts: 7
    What's the MF and residual for A7 Prestige & Premium plus (15K/36)?
    Gas or diesel?
    Gas
    sigma2 said:
    Gas
    Prem Plus - 54%
    Prestige - 52%
    MF is .00085 for both
  • psanginariopsanginario Member Posts: 18
    What's a typical discount off MSRP for a7 premium plus gas?
    In general, 4-6% off MSRP is good for Audi.
  • powerfadepowerfade Member Posts: 1
    what is this month's MF and residual on a A7 TDI and TFSI premium plus with 10k/36 term?
    TDI: .00095 MF and 56% residual
    Gas: .00091 MF and 56% residual
  • eaglesguy20eaglesguy20 Member Posts: 46
    Can you confirm that Audicare still increases residual by 1% when leasing through AFS? I had a dealer tell me recently that this was discontinued for certain models (although clearly everything there with a grain of salt).
    I see no restrictions on AudiCare and its effect on residual values. Check with another Audi dealer and see if you get the same story.
  • cc5813cc5813 Member Posts: 7
    I was told by Central Houston Audi today that a 0.00085 money factor on a 2016 A7 prestige does not exist, and the only way to get to a 55% residual was to do 7,500 miles
    Is that just BS or what am I missing here?
    Well... this is August, and I see no previous posts from August, so not sure which numbers you are quoting.
    2016 A7 Prestige is .00095 MF and 51% residual for 36mo, 15K/yr
    55% residual is indeed correct for 36mo, 7.5K/yr
    For the 3.0T, the numbers are .00091 and 55% for 36/7.5
    For the TDI, the numbers are .00095 and 55% for 36/7.5
    So, the dealer is right in this case.
  • dman228dman228 Member Posts: 1
    Moderator
    Can you please provide the current MF and residual for a 2016 A7 Prestige. Looking at 36 months for both 10K and 12K miles.
    Thanks in advance.
    dman228 said:
    Moderator
    Thanks in advance.
    36/12 numbers:
    3.0T - .00091 and 53%
    TDI - .00095 and 53%
    Add 1% for 10K
  • ROBRTM5ROBRTM5 Member Posts: 81
    Hello Kyfdx & Michaell - Can you please share the MF and Residual for a 2016 S7 Premium Plus... Looking for 24/10 and 36/10.. Also, are there any rebates from Audi for the S7?
    RM
    RM
    .00143 and 62% / 55%
    No rebates that I'm aware of.
  • optic77optic77 Member Posts: 5
    Hello - Can you please share the MF and Residual for a 2016 A7 Premium Plus... Looking for 36 months/10k. Thanks.
    3.0T - .00062 and 56%
    TDI - .00095 and 56%
  • smoody42smoody42 Member Posts: 1
    Hi, can you please share the MF and residual for a 2016 A7 premium plus..leasing for 48months/10k and 48months/12k..thank you
    48/12 numbers:
    3.0T - .00082 and 48%
    TDI - .00115 and 48%
    Add 1% for 10K
  • muffinflavoredmuffinflavored Member Posts: 83
    Prestige is the more expensive package, right? It lowers residual? These things lease horribly, no? Can you do MSDs?
    Yes. Yes. Yes. Yes - I believe the Audi program allows 9 MSDs, each of which lowers the MF by .00005
  • stuartshustuartshu Member Posts: 18
    Can some one provide MF and residual for A7 premium plus 36mths/10?
    Thx in advance.
    Thx in advance.
    .00024 MF and 55% residual
  • sonicolonesonicolone Member Posts: 28
    Pls post current lease numbers for 2016 A7 3.0T Premium Plus AND Prestige, 36 Mo/12,000 miles. Thanks!
    .00024 and 54% (Prem Plus) or 52% (Prestige)
    Thanks. How does the money factor and residual change for the TDI (diesel) version?
    .00029 MF and same residuals
  • luivampaluivampa Member Posts: 3
    Hi - Can someone post the MF's for a 2016 A7 basis 15k miles/year and 39mos (both TDI and 3.0T engines)? Also, does the MF change for leasing a 2015 A7 same assumptions? (there are still some new 2015's on the lots and used/CPO that are available for lease). Thank you in advance, this forum is an incredible resource...
    2016 A7 gas premium plus: .00044 MF and 50% residual
    2016 A7 TDI premium plus: .00049 MF and 50% residual
    2015 A7 : .00195 MF and 45% residual for either.
    Thanks - I assume Prestige reduces residual by 2% for each engine 2016 and for 2015 as well? Does previous owner on a 2016 model (i.e. used car still available for lease) further reduce residual?
    Yes... 2% less for Prestige in all cases on the A7.
    If it's truly used and not a service loaner/demo/factory official model, then it probably doesn't qualify for the lease program. But, ask the dealer. Smaller volume Euro makes can sometimes get stuff through finance that a higher volume make (like BMW) might not be able to do.
  • coconcocon Member Posts: 154
    Can I get the current rates (MF and residuals)for 16 RS7 for terms of 36/10 , 24/10, 30/10(if available)?? 3% off MSRP is it good??
    .00175 MF and 50%/53%/57% residual for 36/30/24 month lease.
    No idea what the market is for an RS7, but 5%-6% off is usually good for the typical Audi.
  • rnm_gs3rnm_gs3 Member Posts: 38
    Hi - please provide MF and residual for 2016 A7 3.0T Premium Plus 36/10k miles.
    Also any available lease cash.
    .00024 MF and 55% residual.
    We don't have incentive info for Audi.
  • nait_98nait_98 Member Posts: 2
    Hello - can you let me know the MF and Residual for 2016 Audi A7 Prestige and Premium Plus? Looking for 42 month/12K.
    many thanks!
