Visitor Agreement.
"I need to replace my speed sensor in the transmission. I can get the part but don't know where it goes. Can you help me with this?"
This is a 1992 Cavalier.
1992 Cavalier
When I searched again for 2003 I found a couple people who replaced their clusters to fix a problem where the speedometer didn't want to work at times. Is that your problem?
Issues: was told the clutch was slipping, car drives fine on highway but seems like i switch to like neutral when i stop at a stoplight, gives a hard jump and then pulls off....NOW, it has gotten worse.....it wouldn't really go pass 40 today and when i slow down, the car will start shaking and then shuts off. i start it up again, let it warm up good(MN weather), it shoke a little and then drove okay, no problem on highway, just local traffic stop and go areas...it's beginning to jerk alot
took car to tranmission shop today, they test drove it and said replace it...should i have another shop do a more thorough inspection...
Also, brakes and tires are good, but it feels as if i have not much control when the road is wet or slippery..i was told b/c the clutch is slipping....
Thanks a bunch
After about two miles it began shifting normally and has continued to do so ever since. Fluid levels are normal. I'm wondering could this just have been some random electronic glitch or something more.
The car has about 100K on it. The only transmission repair I've ever done is to replace the solenoid pack about 18 months ago. I change the fluid about every 30K.
You can do searching for speed sensor transmission cavalier 2003 and see if you get any hits. You might find somewhere that has people more familiar with the car and the problem.
Cavalier speedometer
Cavalier
Hou. Tx
link title
This is a link to the only repair manual I found for isuzu trooper on Ebay. It says it's a CD and you can print from it.
IN Helm they call the service manual the Workshop manual.
I'd recommend getting an authentic manual and not a Motors, Haynes, etc., that you find on the shelves at the local autoparts stores.
Check Amazon.com books and other sources for the manuals.
The question about ATRA and their credibility.
ATRA is one of the leading transmission expert groups.
It makes me wonder about the claims when they state that anything the consumer can buy is bad and the only good additives would be found sold by professional shops. Are they sounding their own horn for profit?
No.
I need help how to change transmission oil 2001 trooper 3.5 I see oil around pan How do I change and refill Please help, Donot have money to take to a dealership
This is a real pain to do by yourself. I would recommend going to a competent independent shop, not a dealer. You really need a lift to do this job, as you have to do everything from underneath the car.
You need to have a shop put it on a rack to determine where that leak is coming from.
Thanks Kim
Electronic shift module 4WD;Speedometer;Air Bag restraint;Automatic Transmission shift interlock;Automatic Day/Night mirror
Keep in mind my truck is 2 wheel drive. But when I replaced the fuse, the new one blew when I cranked the truck up and test drove it. I checked the transmission fluid level and it was normal. I haven't changed the transmission filter in some time, I don't know if that has anything to do with it. If anybody has an idea what happened here, I would be very grateful for any help.
Also, here's a link to a complete set of factory manuals for your car. A bit pricey, but they will tell you a lot of what you need to know, and they could pay for themselves now and in the future.
95 Avenger Factory Manuals
http://answers.edmunds.com/question-Why-transmission-speedometer-suddenly-functi- oning-properly-6408.aspx
It also sometimes clunks when put into reverse and you feel a bit of chugging backing up. Once on the freeway at 60mph the van runs fine and has power in passing gear fine as normal. Fluid looks ok but I know it needs a change and filter
Has any one had this problem or have any ideas
Rick
Any help would be greatly appreciated. Joe
parking lot, when it hit a very small dip in the road (like those drainways they put in the parking lot to help the
parking lot drain when it rains). Thinking back at the other times that it died. It always happened low speed
hitting a small dip in the road, not coasting but slight pressue on the accelerator pedal to get out of the dip.
When it dies, the car starts right up soon after.
This is a serious issue because I almost got rear ended the last time this happened. All the lights come on the
dash and the steering wheel locks up. I can't do anything but quickly press the hazzard and hope no one hits me.
The warranty is with Carmax, it's been there twice. they couldn't duplicate the problem, they sent it to the local
Volvo dealership on the second time around and couldn't duplicate it either.
The other night I did high speed runs on the freeway, stop and go traffic, and I hit several other dips in the road
at 25-30 MPH to try to duplicate it but it doesn't die out.
No DTC codes come up and the car starts right after.
VIN Check shows the ETM was upgraded:
SERVICE CAMP 155 Credited 4/19/06 36004 Software control module
30785453-9 ETM/ECM P UPGRADE 55221 5127 BOZZANI MOTORS
I checked the battery connections in the trunk and all the grounds that I can reach under the hood. They are all
tight. I also checked most of the connectors I could reach. Lot's of the wire loom is brittle and cracked when
squeezed. I saw a thin pair of yellow and black wires bare, no wire loom. I could see it but could not reach or see
where it begins or ends. Its above the transmisison housing. It seems like its coming from a larger pair of wires
underneath the airbox. It's just odd that it's sitting there above the transmission housing. I checked the
underhood fuse box. no blown fuses. I didn't check the trunk or interior fusebox for fuses though.
Just for the heck of it. I looked to see where the fuel filter was. It's underneath the right side rocker panel. I
don't think it's ever been changed. The quick connect has some play so I slid both connecting ends toward the
filter. Should I change the fuel filter, It's cheap DIY fix and if it doesnt solve it, one less maintanence thing
out of the way.
What are the usual suspsects? Agian this is a serious safety issue and it happens intermittently and neither
Carmax nor Volvo can duplicate it.
Same as with 1000's of other people my trans slips from 1st. to 2nd. and from 2nd.
to 1st. when comming to a stop light or leaveing one. also is monsterous in heavy
stop and go traffic on the highway. feels like getting rear ended.
Have had it in to a couple dealers and they reprogram the TCM. and or tell me that they cant find any problem ( I probably wouldent find one either if the shops
computer and a spin around the block told me there wasent one) with all the reprograming and as many times that I had it in, someone would think that there sure must be somthing wrong somewhere. CSR.at Ford Corporate is a joke,
after there done with there polite smoke screen spech, they tell me that if they cant duplicate the trouble in the shop they wont fix it . Even if the tech feels the slip
on a road test if he cant duplicate it in the shop they wont fix it.
that part had me cracking up most of the morning. (sounded so dumb assed)
Thay even tell the service department at the dealer's hands off these trans.
would you know as to how to fix this trans. and can it be fixed.
real tired of Ford,s B.S.on this matter. never expected this from Ford
never had trouble with my other explorers .
any help would be greatly appreciate any help on this .
Thank You.
Mike.
from Chicago IL.
I was having troubles initially getting my key out of the ignition, i found by moving my gear shift i could get it to come out. Then the problem got a little worse and now i am having problems starting it, i have to sometimes put it in neutral which actually appears to be reverse on my shifter. Im not sure what to do but i dont think its actually the transmission, probably the linkage?
Noobie here any tips would be appreciated. Thanks
