Visitor Agreement.
I mentioned above my 93 Escort Wagon, whinning noise when in gear. Tranny feels fine in all gears. I had the fluid changed, no improvement. Tech said it sounded like the pump sucking for fluid. Seems to get better when hot, not as noisy after a long trip. I tried a can of Trans Tune before the fluid flush. Any advice?
1. complete tune-up. (no more mis-fire) but says bank 1 is running rich
2. added sea-foam trans cleaner and drove car. changed fluid and filter.
3. dropped trans and changed TCC solenoid.
4. completely removed cat-converter (added straight pipe for time being)
since the repairs, this car runs and shift great in every gear but 3rd. no slipping, no hard shift, no nothing. it just wont shift from 2nd to 3rd unless i let off the gas. driving the car like normal, after it shifts into 2nd, it gets up to about 50mph and high rpm then i can just barely let off the gas pedal and it will shift just fine into 3rd and then goes rite into OD no probs. the only other thing i can thinnk of is changing the pressure solenoid but not sure if that would fix or not. any suggestions please....
Here we are again with Tranny problems in 2011 and of course it couldn't be a worse time as we're already dealing with some money issues like many of the people in our Nation. When we were traveling yesterday we were coming to a red signal and began to slow as were started to come to a stop and hear a metal like rumble under the car, :confuse: *tick* *tick* *tick* *tick* *tick* *tick*. I also noticed that when I pressed on the accelerator that we were not going anywhere...
At this point my "cheap" side began telling me that this was the better option but my "Safe" side said this wasn't an option. I've got two boys and another on the way and knew that parting out a tranny wasn't the best option at this point. Considering my lack of knowledge when it comes to vehicle maintenance I've decided to take it to a shop (CERTIFIED TRANSMISSIONS) on Monday to see if they can run a diagnostic on it and find out if I do need to get a new tranny or not. I'd rather get it checked out by someone who knows what they're doing then by tinkering around with it myself.
After reading up on the Certified Transmissions site it was pretty obvious that we could have been performing regular vehicle maintenance on our transmission. I was taking it into Big-O Tires to get oil changes, tire rotations and a "maintenance check"... but I don't think that covered a transmission fluid check as there wasn't a great description on what all was being checked in that "30 point" vehicle check. They also never mentioned anything about the transmission which leads me to believe it wasn't being checked at these services before taking long trips. The most recent service was on February 12th, 2011 ( this last month) and the only description to me on the service invoice that would make sense would be the description: *Check & Fill all vital fluids*. Again I don't know if this also covers the transmission fluid but I would have to assume this does being a consumer that doesn't know squat about vehicle maintenance and taking it to a reputable company.
So I think the best option at this point is to take our 2005 Saturn Vue to this tranny shop as they will tow it for free, run a free diagnostic, and we will be able to know more at this point as we don't know what is exactly wrong. Does anyone have any comments, questions, &/or suggestions?
Does sound like you need a transmission shop to look at it. Whether the best one in your local area is the one you have chosen, I have no idea one way or the other.
When I had a transmission problem years ago, I took it to one of the national chains (so I could get it fixed under warranty while traveling if need be), and the local franchise had a very good reputation and you could clearly see that was their specialty due to the volume of business in the shop.
That is a nice warranty they offer, what does the written warranty say if you are out of area? I guess this line of thinking only applies if you travel extensively out of state.
As far as a written warranty out of state, I don't know. It was after 5PM on Saturday this all happened which at that point the shop was closed for the day. They are also closed on Sundays, so I guess I'll be calling Big-O-Tires in the morning and see who they recommend for Transmission issues. Then I'll probably give these guys I found online (near us) a call and see how busy they might be. Luckily AAA will tow our butts all over the place but if it is going to cost a small fortune after the diagnostic... *ugh* I'm just going to be sick.
its a 4cyl ex coupe automatic transmission
tranmission does not shift properly. initially there was a delay in shift. as in when i first started noticing i felt like it would take a 'lil extra time to shift, now its getting worse. when i first turn on the car, i allow it to heat up for a couple of mins and then put my car in drive but the gear does not seem to engage. the car sits in idle for 30 seconds or so and then finally goes in to gear .. it does not shift and remains in the low gears .. as i continue to drive the problem seems to get less worse, as in shifting gets better (relative to not shifting at all).
I took it to Honda and they said they would replace the transmission for an arm, leg, and an eye. A local mechanic said to drive it till is dies and then bring it to him ..
I don't want it to get worse .. I feel like if i ride it till it dies, i may kill it to an extent that a tranmission replacement would not be the only thing i would need .. what are my options? i am concerned that if I get a new transmission, what are the odds that a couple months later something else goes out on me .. its a big investment and i am not sure which route to take.
Looking for suggestions/advice.
when we got ti used in 2008, (married to a mechanic honda/dodge) we knew the tranny could last a month or years, since it was alreadfy slipping.. it lasted a year. we were on the 400(major highway in ontario), and my hubby turns to me and says "i've got no gears", luckily we were by a turn off and we managed to get it to limp off the highway.
we replaced the tranny(used from a wreck).. and 6 months later the new one had started slipping, we've had the car 3 years and are just driving it till the next tranny blows, so we can stick in a 3rd one.. the car is great otherwise(even with close to 340,000kms) and it is cheaper to replace the tranny than to find another decent used car.
we have researched, and this is a common problem for the automatics of certain years, sadly other than what is said about the torque inverter .. i don't think honda gives a damn and i view it as a defect that honda should have fixed.
The transmission shop manager says he won't work on it till one of his techs can reproduce the problem (so far he has been unsuccessful). His explanation is that there are just *so* many tests that he could run that it would take weeks to try and track this down. This sounds a little fishy to me. :confuse:
He did say that it's probably a communication problem, and that there are *several* sensors that could be affecting it, as well as the ECM. (He also mentioned something about a technical bulletin indicating some problems with the ECMs that were installed in last Spring's recall.) This sounded reasonable, and since the car now has 73K miles, I thougt some of the sensors might be past due for replacement.
What surprised me, though, was the fact that when I review the car's maintenance schedule, there was no mention of *any* sensors whatsoever needing periodic replacement--not even O2! :surprise:
Anyway, I did learn from this forum that it is possible for an error code to be stored even though the "Check Engine" light hasn't come on, so I'm going to be looking into that. Any other advice would be appreciated!
i am leaning towards a shift fork broken or bent, possibly loose and sliding on the shaft, any help will be greatly appreciated
I was driving on a through street in Madison, 30 mph speed limit and a bit hilly. Going up one of the hills at 25-30mph, I felt it "gear-hunting" for a couple seconds, after which it settled into 3rd. Didn't think anything of it until I got to the top of the hill, and it stayed in 3rd. I put it in manual mode and upshifted to 4th, which worked. BUT... when I went back to D, it shifted back into 3rd even though I was doing between 35-40mph on flat road. So back to manual mode and forced 4th again.
A mile or two later, I came to a red light. Put it back into D, and it has shifted without incident ever since.
The car has almost 97K miles on it, and the extended warranty expires at the end of the month. Is it worth leaving with them for a day to see if they can duplicate the problem and better troubleshoot it? Anyone else had this happen, and what were the eventual results?
Not necessarily an indication of anything dire---have you had a transmission service lately?
Also, I should mention that I had it in for a routine oil change, and they said it hadn't stored any transmission trouble codes, and that the only thing to do would be to leave it with the shop foreman, and a detail description of what happened, so he can drive it and see if he can duplicate the problem. I think there's some hills/streets around Louisville that would resemble where I had the issue up in Mad-town.
About 6-12 months ago, the transmission would occasionally slip. Recently, I was driving and the transmission slipped COMPLETELY out (ie, it's like there is no gear). The interesting thing is that when I leave the car sit for a couple hours, it will drive for 2-3 miles, then I get no transmission action again. There is a leak of transmission fluid on the transaxle, so I added about 1qt of Lucas anti-slip fluid. This didn't seem to help. PLEASE, I'm looking at $3500 to replace this thing, so if anyone has a suggestion, please don't be shy. I would really appreciate it! Thanks!
if condition is the same, you'll have to scan for trouble codes and probably have the unit tested by a qualified shop before you condemn it to a rebuild.
