For years, U.S. investigators were puzzled why the brakes on thousands of U.S.-made trucks and SUVs were failing without warning. Brake failures were behind at least 107 crashes and there were fears the problem could affect up to two million vehicles
On Thursday, after four years of study, the National Highway Traffic & Safety Administration (NHTSA) said it had solved the mystery: Salt.
In a “broad” public warning, the agency told millions of Americans to “thoroughly wash the underside of their vehicles.” Investigators found unexpected brake failure could happen to anyone driving a 2008 and earlier vehicle in a cold-weather state.
“Brake lines, they’ll just rust away, and it seems to be happening sooner on newer cars,” said Clint McKenzie, a service manager at Active Green + Ross in Barrie, Ont.
“Which is pretty scary, given that if your brake line blows, your brakes are essentially gone.”
The NHTSA probe, which began in 2011, looked at GM trucks made in 1999-2003 after numerous reports some of the U.S.’s largest passenger vehicles seemed unusually prone to sudden brake failure. Among the suspects: the Cadillac Escalade, the Chevy Suburban and the GMC Yuko
The probe came to the chilling finding sudden brake line ruptures were not limited to a couple of million GM cars. Rather they could be a danger to anyone behind the wheel of an older model truck or SUV in one the U.S.’s “salt states.”
“Salt and other chemicals can accumulate on road surfaces, can accumulate on your vehicle’s underbody, and could put you and your passengers in danger,” says a safety video issued Thursday by NHTSA.
The precise tipping point identified by the report was only eight years. By that point, cars driven in “harsh conditions” would have built up enough corrosion to produce dangerous structural problems.
‘Salt and other chemicals can accumulate on road surfaces, can accumulate on your vehicle’s underbody, and could put you and your passengers in danger’
Hence, the agency’s call to cold-weather drivers to “regularly wash the undercarriage throughout the winter” and schedule at least two safety inspections a year.
The "classic" '97 Miata is still in the fleet, although no one has written about it for a year. There's a lot of guys hoping the company will sell it and give employees first dibs on buying it.
This isn't the first used Corvette purchased for the long term fleet.
@oldfarmer50, sometimes there's an obvious editorial angle to getting something old (best used car under $x). Then again...
Who knows, maybe the '66 will get turned into another couch for the home office. Edmunds was founded in 1966 so maybe bigger plans are afoot.
They need to give the posters first dibs.....
I'm not sure how comfy the fleet Miata would be, unless they pull the mods and the roll cage. Even then my wife would not help me drive it back to Cruces.
Edmunds also bought an old ES300 and ran it for some time as a cheap beater.
It had the '66 seats and radio knobs, etc. Just strange.
*When we got back from Florida one of the two garage doors did not open.
*We opened it manually, but about the 6th time it got stuck.
*I called the garage guy and they found it didn't work because the batteries on the wall control (2 AAA batteries) were dead and they lost the codes. Fair enough, they redid the codes, put the door on tracks, set the remote in the car, did an overhaul of the door system. It cost $118 but seemed to be OK to get everything working again.
*He did say the top of the door has a beam and because of all the tugging that is showing cracks, a guy will come out and do an estimate to get a new top beam.
*Guy gives me 3 senarios;
1.All new doors and windows. Door will break really badly one day. New doors are insulated and won't get cracks $2900.
2. Just get new top beam and top row replaced to make it stronger $1400
3. Just replace top beam. $318.
I think the original service men were very good and honest. I got a feeling they are doing a scare job on me with the rest. Sales guy thinks number 3 won't last and I'll have to do the others later, so will cost more. He kept saying they are Wayne Dalton doors and they aren't made that well. btw, doors are 6 years old.
Any ideas?
I am inclined to leave it and see what happens next. #3 option is not bad as it would fix the problem for now and at least the beam which has cracks in it could break apart.
The color blue I had (and the one shown in the pictures) is called Marina Blue - the most popular.
http://www.vettefacts.com/C2/1967.aspx will give you all the specs and engine/carb combinations available that year along with options and amount produced.
I lived in San Diego and LA for about 4 years. I lived inland sufficiently where the sun always was shining. But if you drive west toward the ocean, about 4-6 miles inland, the air inversion blocks the sun for 1/2 of most days during the summer along the coastline only. In Poway or Carmel Mountain Ranch (about 10-12 miles inland and north of San Diego where I lived) temps would be in the mid to upper 80's while close to the coast, temps would be in the high 60's to mid 70's. If you got 90 miles east of LA or San Diego, temps would be in the 100-110 degree range. That is why San Francisco is only in the 60's during the summer with dense coastal clouds and why Sacramento (80 miles or so east from The Bay Area) temps are in the 100's.
After explaining all this, the reason cars don't rust in Southern and Central California is because of the low humidity levels and very little rain. When I lived in the Palm Springs area, many times we had "no" measurable precipitation for 2 and sometimes 3 years. All the water we used was from wells. Under the desert floor, there is a tremendous quantity of underground water. You just need to pump it to the surface using wells. But cars that spend most of their time right on the coast of California "do" rust at times because of the higher humidity levels during the summers and raining season in December through April.
I had doors where thanks to how opener was installed it started separating the inner layer off. Repair guy just put a flat piece of metal behind the bracket. Problem solved. That was many years ago.
The school I used to run had a large date-grove adjacent to it. The date palms are watered underground to the roots - a trickling water source. The further/farther south and east you go, the more date groves you find.
I am kind of thinking if it ain't broke, why fix it. And, now I am paranoid after finding out those surveys are all a scam, I think this is a selling scam, where they scare you with "what could happen".
Worse case scenario....I'll need new doors eventually, but, why buy them now if I can get another few years from these doors?
Are trucks responsible for rocks or other materials in their load that drops, hits the road, and bounces up to damage a windshield? I would assume that a truck having its tire throw a stone from the road would not be any more responsible for that damage than if the stone were thrown up from an auto tire.
But when it's their load that dribbles?
Mr Bean
Twice today I was told "you don't have permission" when trying to post. Brilliant stuff too.
Is the system on the blink or did I anger some big wheel in the executive suite?
I'm not a lawyer but my brother is. I remember back inn his first year of law school one of the things they taught was that signs saying you aren't responsible for something doesn't make it so. The classic example is the sign at the cleaners that say "not responsible for items left over 30 days." They are responsible. The sign mean nothing.
Haven't heard any other issues, although someone made a post in an old discussion this morning and it didn't go to the "top of the list".
Anyone else? (feel free to hit the Help or Contact Us link and "submit a request" when glitches like this happen).
Mr Bean
Mr Bean. I think I have even done better than that, though I will keep it in mind. I have a friend who is pretty knowledgeable about these things. He thinks there is a metal brace that has holes in it to place screws. He hasn't seen the cracks yet but he thinks it could be fixed for under $20.
I like Angies list too. When I got my dent in the trunk on the new E400 I was going to take it to the nearest garage, but they only had one star on sites. I thought for $10 a year I can get a good place from Angies List and what's $10 if you are spending $100s. I found a garage that had 10 5 stars out of 5 stars, and no bad reviews. I went there and they were excellent, did beautiful work and were honest and reasonable. Unfortunately, Angies List isn't in Canada yet. I will say, they guy who came here is a sales guy, and his goal is to sell you as much as possible. When he starts talking about how the only real solution is to buy all new doors I start running the other way.
I'd rather wait and see if it breaks and then decide what to do, but I would do this bracing first.
It's enough to make you wish for one AT&T to rule us all.
(Not really, lol...)
Fixed, lasted until I moved 6 years later, cost $40.
All of us have reached that point of waiting to see and observing whether an existing condition can be tolerated. But when the decision is carefully considered for its positives and negatives, it's just a matter of good timing.
Nothing scientific, but it sure seemed to me after all of my travels that rust was more prevalent when very near to the east coast, including the southeast and the gulf coast of Texas.
Probably be lucky to get 7 or 8 years out that Chinese compressor in a new refrigerator. Now why would I want to buy a Volvo when they start making them in China?
Yeah, they are banking on you being intimidated and backing off.
His answer went something like this, and I may have it the wrong way around.
If the door falls off the truck, flies through the air and hits your car, your compehensive insurance would cover it.
If the door falls off the truck, hits the road, bounces up, then your liability insurance would cover it.
This was a long time ago...does that sound even close.
I do know a big bolt fell off a truck...hit my windshield and shattered it. I went up to the driver when he stopped and asked him about it. He said prove it. I paid for it myself.
Uninsured/underinsured motorist insurance covers you for injuries and damage to your vehicle caused by a motorist who had no insurance or whose insurance was insufficient to cover sustained injuries and damages you incurred.
Property damage covers losses to property caused by you while driving a car - such as colliding with an electric pole, a fence or a house or business.
It can become complicated at times. I was driving on an interstate when a dump truck dropped a 2" diameter stone which hit the hood of my car after bouncing once or twice. It was paid for by by my collision coverage - taking out the dent and reprinting and refinishing my entire hood.
Maybe the insurance guy was defining the difference between collision insurance (door hits the road and you collide with it) and comprehensive (door comes flying through the air like an act of God). Which reminds me, if you don't believe in God can you have comprehensive insurance?
You hit something:
Collision pays for the damage to your vehicle, liability pays for damage to what you hit.
Something hits you:
Comprehensive pays if there is no other coverage from the source.
Driver, I had a similar problem on older doors and the doors were not closing completely. They were not stabilized from the top, and were at risk of cracking. I had the top beam reinforced with an added beam, like option 3. This was after I got a "second opinion" who said all new doors were not needed. This seemed to solve the problem and was much less costly.
I know it's not exactly the same situation you have; your results may vary.
2018 430i Gran Coupe
I had to remember the license number of the truck, and had to pull up bsdie it to see if there was something written on the door stating who the company was who operated the truck.
But, in doing all that, I called the trucking company, gave them the license plate number of the vehicle. They took my name and number to verify and call me back. They did indeed call back telling me they had a truck in that vicinity at the time I claimed. They gave me the number of their insurance carrier and a new windshield was replaced on their dime.
I guess I could put a sign on my car stating that everyone should stay 100' away from me, and that I'm not responsible for any damage I cause if I have a wreck, and that absolves me.
I carry 250-500 liability, but only 100-300 uninsured motorist. Florida requires at least 10,000 PIP to drive a vehicle. Part of a trial no-fault law that really has been a disaster. Your health insurance covers injuries above and beyond what you collect from the at fault driver and uninsured motorist.
Uninsured motorist is 3rd party insurance protection and pays whether you have health insurance or not. In Florida, the first $10,000 in medical costs is paid on a no-fault basis. After that, everything kicks in.
