Visitor Agreement.
Can somebody tell me in what model year the 4T65 replaced the 4T60 in the Chev Lumina with the 3.1L engine? I'm thinking of buying a used one and I don't want a 4T60.
Does the 2001 Aurora with the 4.0L V-8 use the 4T65? If so, I wonder if they're close to the torque limit for the transmission. Is the 4T80 used in anything except Cadillac?
Finally, has anybody seen a resource on the net for info like this? gmpowertrain.com is all I've seen.
Does it really make sence? Anybody heard something like that about Maximas or any other cars?
I have been wondering if I should press the company for a replacement car since they cannot find a cause for problem. According to the lemon law this car should qualify being in for service 5 times for a total of 23 days. Since I have put another 20k miles on the car since the problem started they might offer me only a 71% of the original value for a trade-in. I saw somewhere that you should be able to use the mileage that was put on the car before the problem started. Then I would get 92% of the original value.
Any comments?
Siggi
Give the situation some more slack and then re-evaluate it after the next fix. Also, get a copy of your state's lemon law to see if you even qualify. If you bring up the Lemon Law issue with the dealer too often, he may just give up on you and let you hassle it out.
GRRRROOOOAAAANNNN I'm mixing a strong drink.
Al-owner of a money sucking machine.
Like I am describing, it is just growling a bit louder than normal. Approx how much time do I have to try to save some good money and get this problem taken care of before this thing craps out on me??
Thanks in advance for any responses!!!
I don't think a full transmission flush would be necessary based on what you described.
The problem is that now the transmission is shifting very roughly from first to second gear, something it hasn't done in all of the ten years we've had the vehicle. Nothing sounds or seems amiss until a noticeable jerk (no real noise, just about a second-long halt) when it upshifts from first to second, and sometimes from second to third. There is no corresponding problem on the downshift, however. Having been taught on a V-6 engine, I sometimes accelerate more forcefully than I should, but the transmission has always shifted rather smoothly from gear to gear, even with my hard-driving attitude (hey, you try driving a 3,000 lb car with an 86-horsepower engine... even Geo Metros leave me in the dust!)
I know very little about automatic transaxles, but I would think that a clean transmission should shift much better than one with old fuel and a worn filter. Any clues before I go back to the mechanic?
Jeff
The contour has a 4 cylinder in it,with automatic and push button over drive. Please let me know.
I did it to my tranny that drove rough after a fender bender, and it smoothed it right out. I've used for 5 years, and it only gets smoother, and shifts easier. This is my second application and it works great.
I have been able to minimize the issue by draining out the Tranny fluid, and replacing it with 2 things. Lubegard for manual transmissions (found at NAPA) and synthetic manual transmission fluid. Lubegard is specially formulated to reduce mesh shock and gear grinding. The symptoms are not gone, but greatly reduced. I don't intend to get an overhaul anytime soon.
When downshifting, rev the engine, or double clutch. It will slide in easier.
A couple of months ago, felt it slipping again. Took it to local dealership who "couldn't find anything wrong" (Most likely honey-lube!).
My newest problem may have nothing at all to do with transmission but who knows. The gear sifter will not move out of park after being parked in the sun in hot weather for up to 10 minutes!!! No problem during cool weather or after being parked in garage.
I've had the problem diagnosed as the solenoid/actuator; however, after this was replaced there is no change in the problem.
Ever heard of anything like this? No one in my small town has and in talking to the dealership they deny this could have anything to do with the transmission. By the way, it is an automatic.
WELL TOMORROW I'M GOING TO A REPUTABLE/KNOWLEDGEABLE TRANNY SHOP IN TOWN TO HAVE THEM TEST DRIVE AND TROUBLE SHOOT IT.
I WAS DRIVING AROUND TODAY TO EXPERIMENT WITH THE GEARS AND FOUND THAT MY IDEA DID WORK AFTER ALL. INSTEAD OF DOWNSHIFTING DIRECTLY FROM 5-3 OR 4-3, I DEPRESS THE CLUTCH, MOVE THE SHIFTER FROM 4-2-3, THEN RELEASE THE CLUTCH. ALSO WORKS FROM 5-2-3. ALOT BETTER THAN HEARING THAT 3RD GEAR GRIND WHICH CAN'T BE GOOD FOR IT. I WONDER HOW LONG SHE'S BEEN DRIVING IT LIKE THAT??? SHE DIDN'T SEEM TO BE VERY OBSERVANT WITH THOSE KINDS OF DETAILS, BUT AT LEAST SHE FOLLOWED THE OIL CHANGE SCHEDULE EVERY 3K. ANYHOW, 3RD DOESN'T SEEM TO SLIP AT ALL, JUST STRANGE HOW THE DIRECT 4-3, OR 5-3 SHIFT MAKES IT GRIND. I CAN LIVE WITH MY SLIGHTLY LONGER SHIFTER TRAVEL FROM 4-2-3 FOR A LONG TIME, IF IT'S GOING TO COST ME ALOT TO FIX IT, SINCE EVERYTHING ELSE SEEMS FINE.
Let's say you've been grinding on a 3 to 2 downshift (like my Alfa does).
So instead of shifting into 2 from 3, you shift into neutral, lift up on the clutch pedal and race the engine at the same time, THEN depress the clutch again and shift into 2....bingo, nice and smooth, no noise. It sounds clunky and awkward, but it quickly becomes second nature. I don't even think about it anymore.
This is also done in racing not because of synchro problems but to avoid what is called "compression braking"....it helps to get engine speed up to wheel speed on high speed downshifts.
I noticed a couple months ago when I started the car in the morning it began to make a very loud thumping or clunking noise as if something was stuck in the fan motor. When the car was put into a gear the noise stopped. Then a couple of weeks later it began having trouble when I would come to a stop or turn it acted as if the anti-lock brake system was malfunctioning. After having 3 different quotes for a rebuilt transmission I am left wondering if I pay the 1,300 to 1,800 dollars to have the transmission replaced would the motor then go out? Is there anything you could suggest me checking before replacing?
I would be making a tranny fluid change next month.
I was thinking of putting Lubegard with friction modifiers as an additive in my new 100% synthetic tranny oil.
any ideas on how it would work out?
My automatic shifts smoother than it ever has. The second bottle added after the usual 30,000 mile service made it even quieter.
I will not be without Lubegard in the Transmission in the foreseeable future.
Highly recommened, and it's cheap compared to other brands that are fraudulent. I also put it in the power steering with good results. All for under $10.00 a bottle at NAPA.
Thank you, AUXESIS
I purchased a used 1995 Dodge Stealth about a year ago from a dealership. Since then I have only put about 12,000 miles on the car. The mileage is only at 47,666. The other day I could not get the car to go into reverse ( its an automatic) and was told the transmission was shot. When I contacted the Dodge dealership I was told they could give me a new transmission but the warranty was only for 12 months or 12,000 miles. That doesn't seem quite right to me. Seems to me if Dodge was confident in their transmissions, they would guarantee it longer than that. Any suggestions? Can anyone help??
http://www.thecomplaintstation.com/c/chrysler_toc.htm
Don't forget to service it every 15,000 miles with more synthetic. that will improve your chances.
