Visitor Agreement.
This means to me that my transmission is now smoother and better functioning.
Don't know how much additional damage was done as now the trans "slips" a bit. To the point where my wife and young son even notice it (ya think maybe the service tech will notice it when I bring it in and complain??). My advice to all Chrsyler/Dodge owners. Hold onto your paperwork and service request letters. You're going to need them. . .
THANK YOU MARSHA
but I started hearing a humming noise from it when it is in gear-idling.Hum goes away by putting in park or nuetral.Sound serious?
"Reverse" has left me. Heading in tomorrow.
Anyone ever had a transmission job on a Saturn SW2?
The tranny died on me last week, was able to locate a used one for $350. How much of labour am I looking at ? Is it worth while ?
New tranny is going to cost $2000.00
As i start moving again, the lockup pin engages. I know it because there is no slippage in the first gear and engine vibrates due to so heavy a load on startup.
How to get it working normal?
If I am driving downhill, then the transmission works fine.
I found I have low level automatic transmission oil. Is this the possible cause or my transmission has any problem?
Please help me. Thanks.
Rick
Last Saturday in some stop and go traffic it seemed like it was slipping a bit. Seemed fine once it got going and did not behave strangely until today...
First, earlier in the day I notice the transmission is staying in lower gears. I let off the throttle and experience engine braking like in my stick shift cars. It seems hesitant to upshift as well.
Later, again in stop and go traffic for some sort of lane blockage began the slipping again, and finally lost all gears forward as well as reverse. So I'm in the left lane, no shoulder. Call AAA and the St. Louis Motorists Assist gives me a push down the ramp. About 30 minutes later the AAA truck arrives and now I've got a tranny again and the car moves under it's own power to the tow bar on the wrecker. I suspect I could have driven it home, but $22.50 for the 9 miles AAA didn't cover was a small price to pay to not worry during the trip.
I'm thinking something temperature sensative. I suspect the torque converter is flaky and believe it will probably require replacement.
Fluid was fine, changed about 30K miles ago with Mobil 1 ATX along with the filter. It didn't look bad, or smell bad. Level was good.
What sort of things should I expect from my transmission shop when they call me next week with the diagnosis?
TIA
TB
We had it towed into a shop that I trust, and they fixed him up for about $60.00, although his tranny's days are numbered. They said the filter was clogged..I'm guessing with debris from the tranny's inner workings. Anyway, it's running fine now, but they said that it's questionable as to how long it's going to last. Could be 6 months, could be 6 years. Toss of the dice, I guess.
Since I only paid $1K for the car 17 months and 37K ago, $1500 to remove, rebuild and replace the transaxle should give me another couple years life on the car.
I suppose if the car were a rusting hulk, That wouldn't make sense, but at 91K (now) the 3.8L is probably just getting broken in. Everything works, including the A/C thats been converted to R134a.
The way I look at it, I couldn't buy this car for $1500 so as long as it lasts another year, I'm money ahead.
I did toy with taking it home, dropping the pan and changing the filter, then putting a for sale sign on it and getting somewhere between 2K and 3K for it. But I would have a hard time sleeping at night, and would then need a daily beater. (Since it appears that a high-mile lease on a BMW 325i will not be cost effective.)
The shop replace the torque converter, first/second (was it bands or clutches) a rebuilt kit which I presume has a bunch of seals and such. About $500 in parts and $1000 in labor to remove the transaxle, rebuild it and replace it.
Call me crazy (not to my face) but I expect to get to 150K before I put this thing out to pasture. Of course at that rate we are talking about fall of 2003 when that happens.
TB
Sounds like you had about the same problem as my friend's Tracker. Unfortunately, his is far from paid for! It's one thing to have the luxury of junking the car or trying to sell it, but really sux when you still have to make payments on it!
The fluid was changed less than 30K ago with Mobil 1 and the GM filter.
So, since I did follow your advice prior to this, can I collect my $1500 from you? 8^)
The prior owner, my grandmother, also took care of the car. (That's why everything works after 15 years on the road. Heck even the vinyl top looks good!) So it wasn't lack of maintenance, but I suspect the type of driving. The first 54K was alot of around town driving, mixed with occassional weekend highway miles.
I do believe this was a fairly new design, back in 1987 so the General had some bugs to work out.
But if you are implying lack of maintenance, I strongly urge you to get your eyes checked because the original post indicates that maintenance was done at intervals recommended by the factory or even more frequently.
TB
ps, you can just e-mail that $1500
The tires really make a difference in handling. I can take 25MPH ramps at 2x that speed with ease.
I was hoping using the Mobil 1 fluid would buy less frequent changes. The nearly 30K miles I drove since the last fluid/filter change were done in 12 months, mostly highway, so those should be the easiest miles on a transmission.
If I'm going to do them more frequently, I'll probably look into putting a drain plug on the pan to reduce the messiness of that job. It would be nice if you could pump out most of the fluid through the dipstick, then drop the nearly empty pan. However, the dipstick goes into the filter, so you can't put a siphon pump hose down to the bottom of the pan. I tried that when I changed the fluid last fall.
TB
Back on topic. Yes, fluid changes on that GM transmission are particularly irritating. I'm embarrassed to report that I have had more than one pan-gasket to leak. Will soon try the Toyota brand super sealant. At ~$5/ounce, it had better be good. Has anyone tried this sealer?
TB
If that does not solve it, try going to the tranny shop.
Worked for my 90 ford taurus. Save me from goign to the tranny shop.
www.lubegard.com
I replaced the VSS (vehicle speed sensor) and had the transmission flushed with a filter change, and refilled with Mobil 1 synthetic ATF. Afterward the shifting was very much improved and the flaring problem disappeared. After 2 weeks, the problem is back. Any ideas? Do you think it could be "Shift Sensor"?
However, someone recently mentioned to me that a simple transmission additive could maybe "unstick" the tranny. Anyone think this may work? Conversely, anyone think this may be a bad idea? Older transmissions can be sensitive to new fluid, I've been told...I wouldn't want to just totally kill the tranny. Any other ideas on how to fix this, short of spending $750+ to overhaul/replace the tranny? Thanks!
http://www.batauto.com/Ford.html
At the very bottom of the link page is a link to Ford EEC-IV diagnostics giving clear, concise instructions re diagnostics info and code retrieval/interpretation. If no codes are present and the trans continues to drop out of 3rd or 4th gear, the direct clutch or overdrive band are probably on the way out.
I was backing my 2001 4mo TipTronic out of a parking space up a slight incline. I heard a soft 'clunk' and then a soft grinding noise. It sounded like I had backed over something (orange cone or something soft). I opened the door and looked under the car but there was nothing there.
When I put the car into drive, I hear more grinding (soft) and the car moved forward about 15 feet. That was it. I put the car in park and heard loud grinding and a bit of whirring. To my surprise, Park didn't hold the car and I found myself rolling down a hill backwards whilst digging for the manual and 800#.
When I spoke with the dealership they said they are replacing the entire transmission. I'm very disturbed that they haven't figured out what's actually wrong with the car. I'm even more shaken that something this major could happen by backing out of a parking space. There's only 17k miles on the car and I don't push it. What would have happened if I was on the highway...
Oh yea, the front CV's were replaced a few weeks ago due to a leak in the boot. Could that have anything to do with this failure? Hasn't this transmission be around for a long time and isn't it licensed from Porshe?? I just can't believe this is happening.
Has anyone had any problems like this with their Passat?
Thanks Alcan for your original reply stating that these transmissions are generally reliable. I have never had a problem with the transmission, the vehicle has 75,000 miles.
