Visitor Agreement.
Has anyone tried it? Need opinion.
I've been using nail polish remover to remove excess touch-up paint.
Then I see this Langka stuff. How good is it vs. nail polish remover (cheap, just $2 vs $20+ for Langka).
KK
Ed
edandty@msn.com
Make sure you dry the rubber around your doors as best as possible. I've had them freeze. You also may want to lubricate your door locks after washing to keep them from freezing. Try to remove as much of the dirt from the paint as possible before using the brush. The boar's hair brush is a good choice, but even the most careful will still get light swirl marks (the kind you can see in just the right light reflection). Not nearly as bad as the rotary brushes in car wash and about the same as a good quality mit. You may want to have a rinse bucket handy to rinse out your brush frequently.
Happy reading! :-)
Pat
Nevertheless, I'll add a few words. rs petty makes a few good points. Agreed that regular care is the most important factor. Both high quality waxes and true polymers will do a great job of protecting your finish. And both types will produce very good shines. And your personel requirements are also an important factor.
But alias, no one is really objective. So, here's my take: The high quality waxes such as Meguiars will produce a 'richer' looking shine. The high quality polymers such as Zaino and Finish First will produce a 'clearer' glassier shine (more liquid looking). I wouldn't consider the 'natural polymers' such as Nu-Finish as their addatives and 'natural' impurities age over time and can leave discolored layers. The purer (synth) polymers (Zaino and Finish First) will not discolor any clearcoated finish and will last much longer than the wax based products. The polymers are also much easier to apply and maintain. But then again, I'm a proud Zaino user.
Actually the nail polish remover is quite nice. Can remove excess touch-up paint for up to a week after application. Also, doesn't seem to affect surrounding paints.
Any way, I also bought Lanka to try it out. But $20 vs $2 is a big difference.
I'm sure it eats the wax off, but does it also hurt the clearcoat and paint job?
Thanks for the help!
I tried Lanka, and the result is not as good as expected....
The first problem is that Lanka tends to wipe out all the touch-up paint. I've to wait at least a week after touch-up application to use Lanka. This is bad esp. for deep chip.
Second Lanka tends to darken metallic paint. I guess I've to use a Glaze to shine it up.
Tips using Lanka is appreciated.
Thanks in advance...
You do not get an invisible repair like Langka claims, but you are able to smooth the touch-up paint blob even with the surface. I guess the real advantage over using fine grit sandpaper is that Langka doesn't remove the original paint around the repair.
BTW, I also use this on the underhood rubber hoses after cleaning the engine.
Stay tune...................
This stuff last for a long time if not up to 3 years.
I just bought a new Honda Accord SE with Ruby Red color. I got a personalized tag for it. DMV gave me a 60 day temporary paper tag and told me to tape it to the rear of the car.
I did as they told but when it was time to remove the tag, I realized that the tape is not coming off. I am afraid that doing anything drastic may do some permanent damage to my new car.
can anyone advise me? I used the transparent tape which is about 2" wide.
Thanking you in advance.
it will loosen.If it doesn`t loosen chances are it`s not a water based paint. You might look into
the clay products that everyone is raving about to remove it.Don`t forget to use the lube if you try the clay.Ask the guy called "eraser" he is usually in these forums somewhere talking about getting impurities out of paint without hurting the finish.
#229 - sticky tape
The safest thing to use on paint or glass is 3M General Purpose Adhesive Cleaner. You can get this at NAPA ,etc. Even Wal-Mart has it in small containers. Follow directions (apply, let soak in then remove tape.) You can apply with Q-tips if you wish. I use the edge of a credit card or my fingernail to GENTLY ease off the stuck on item. I have used it with complete success on stickers that have baked in the sun for 15 years. Beware applying it to the inside of your rear windshield as it will remove the adhesive that keeps the defoggger attached.
If you apply it to paint then you must rewax the area because the wax will be removed by the 3M.
#230 - stubborn paint
Detailer's clay was made for this kind of problem. Lots of lubricant and gentle pressure will see you through the night.
223: I just can't imagine what you went through to get so many rock chips on a 2 month old car that would require a total paint job, but if your insurance company is willing to pay the tab then get it repainted.
231: An alternative would be to have a glass shop pull the mouldings off and have them powder coated (DIY at eastwoodco.com) or polished. You'll never get the tape to stick at the edges for very long.
I have a '99 Solara SLE, Silverstream in color that recently had the hood repainted due to a manufacturing flaw. The bodyshop cleaned the car, dryed the hood area, then placed a plastic drop cloth over the roof and trunk area (still wet) to protect from overspray. Upon removal of the plastic, the paint on the roof/trunk area has clouded up and looks blochie (SP?). I was told that Toyota is using a water-based paint due to environmental restrictions. Anyway could the paint have 'absorbed' the trapped moisture and it taking a while to get back to normal? It has been over 2 weeks now and the paint still looks cloudy. It's been rather cold here in the mid-atlantic. As a brief background, the door handle pulls often get water marks on them and cause the handles to 'change color' then will eventually go back to a uniform hue. Anybody in the business have any insight on this dilema?
Thanks in advance - Michael J. - hoping for a miracle.
found it at autosupermart.com
had a new hood, left fender, bumper and headlights put on. what should i look for when i inspect the car? never needed a body shop before so it's new to us. thanks
Is the spacing between panels even and equal on both sides of the vehicle; is the space between the door and the new fender the same the entire length of the components? Does the door on the new fender side operate as easily as, or better than, it did before you had to replace the fender? Is the space between the hood and the new fender the same as the space between the hood and the old fender and is it parallel for the entire length? Is the space between the back of the hood and the panel under your windshield equal? Does the hood latch and unlatch and open as easily as, or better than, it did before you had to replace the parts? Does the hood stay properly open in the same way it did before the body work? (Do the springs still hold it open, or does the prop bar work correctly?) Is the space between the ends of the bumper where it meets the fenders the same on both sides? Is the space between the top of the bumper and the bottom of the grille the same all the way across? Is the bottom of the bumper properly/evenly aligned with any body panel that might be under the grille?
How well does the paint on top of the old fender match the paint on the new hood? How well does the paint on the new hood match the paint on the panel under the windshield? How well does the paint on the new fender match the paint on the old door? Is there any paint overspray; in the wheel well, onto the wheel or wheel cover, onto the grille, into the motor compartment, or onto the wires and front inside panel of the door?
Lesson learned: Tire Dressing isn't worth it!
thanks i will check all of those things out!
You could load the whole topic (over 500 posts, go get a cup of coffee!) and use your browser's search feature to find clay, or you could try looking around posts in the 400 to 450 range.
Pat
Avon Skin-So-Soft bath oil is successfully used to dissolve and clean a remarkable list of items. WD-40 is also used.
Try using the Edmunds Town Hall Search function to find other methods/products.
The archived posts about What is the Best Wax/Polish and similar topics, many of which are linked at the beginning or end to predecessor and successor topics, and each other is another source.
Darker cars, especially black, are certainly more susceptible to showing swirls. I believe that a buffer is more likely to create them than buffing by hand with the proper material.
Many folks believe that hand buffing with high quality bath towels (department store, not "mart" types) that are made in the USA labeled 100% cotton (loops and backing) is the best way to avoid or minimize swirling on dark cars.
There has been much discussion in these wax topics on what is the "best" and the "easiest" product to use, particularly when hand buffing. Seems to me the polymer products require less effort to put on, take off, and need renewing less often -- all of which adds up to fewer times you have to buff, and therefore fewer times to add swirls.
Just my two cents. Good luck!
Pat
I would never use a commercial car wash with those big brushes and I personally would stay away from buffers. Swirl Marks, nuff said. I'd absolutely recommend claying your car. And I'd also recommend a polymer finish such as Zaino. Using a polymer instead of wax will protect your car better, last longer, and shine better. Check out the results at: www.zainobros.com.
