Visitor Agreement.
If the scratch only goes to clear coat, then claying or Zaino may do the trick.
By the way, I had a real pro do my paint job (big scratches on the door), and the results were perfect.
In advance, many thanks.
PS It's hard to believe the original paint on this car is so flimsy!
Note: This has worked for me...thats all Im saying.
1)Washing. I use a 100% cotton towel-type thing that is wrapped around a sponge. I use a small amount of car wash, but lots of water. I use front to back strokes only on the hood, roof, and trunk. top to bottom strokes on doors/quarter panels/fenders. (This eliminates any swirl scratches)
2)Drying. I use the California Water blade. Fast and simple, and has never caused a scratch.
3)Waxing-Meguiars liquid cleaner wax. I use it sparingly, (I do apply it in a circular motion with a buffer bonnet (100% cotton) that I have, but I apply it by hand)let it dry completely to a haze, then remove it (in a circular motion) with an old 100% cotton Haynes t-shirt.
TO each his own...but the above has worked for me. Minimal spider web type scratches , and high gloss is what I always have.
FWIW
That scratch goes all the way down and the only cure is paint. The question now becomes do you just do a 'touch up job' or repaint the entire bumper.
Given that your car will soon be in contact with other terrible things (dogs, cats, fences, other cars, etc.), I'd use a little touch up paint for the present. After you have 'collection' a whole bunch of little 'marks', then I'd have the entire bumper re-painted. Either way, it is really a matter of personal choice. Good Luck - I've been there.
Search for topics with the word clay for more than you ever wanted to know about using it.
This might be time consuming, but there is lots of information to be had if you have a little patience. :-)
Pat
michele
i am to call him thursday and confirm my appt. for monday. he said they will wet sand the car. is this the same as using 'clay'? i'd appreciate any further input.
e-mail me with any questions at graphicguy@yahoo.com
Just think of how clay you may have played with as a child feels and is affected by temperature and weather. Cold might tend to make it less easy to use.
"Do I have to do the entire car or do I just clay where the overspray is?"
You don't HAVE to do the entire car, just the area you're interested in affecting.
"How long should I expect this to take?"
Once you've washed the area, five minutes per square foot would seem about right. I would wash the area afterward, too.
"Also, can I get any of the clay locally or shipped in time for me to do it prior to the weekend? I looked at the erazer site.. any recommendations?"
Beside Clay Magic, Mother's also makes a claying kit; should be available off the shelf of auto parts stores in the soap/waxes/polish area. If you call any stores before you go, the generic question to ask is if they have any "detailer's clay." You want to be sure that, if you have a choice of types, do NOT get clay with abrasives in it.
I'm betting you will be surprised at how easy claying is and the resulting greater cleaness of where you use it.
rs petty is right...wet sanding is much more "invasive" to your finish than claying. wetsanding actually removes some of the clearcoat/paint to make it smooth. After the wetsand, they usually have to reapply clear coat over the affected area (at least, this is what I'd make them do). That said, depending on the severity of the overspray, wetsanding may be the only way to go. you might want to ask your body shop to try claying first before they wetsand.
We cleaned it off the glass with a razor blade and chose to live with the bumps since the car was also painted white. Eleven years later I found out about clay. Before claying, you could still see and feel the overspray roughness. After claying the car was so shiny smooth I was amazed.
I would have never believed that getting off the overspray could be so easy. The car looked better than new!
I say claying is your answer.
Mr. Vivona
Thanks in advance!
After removal, you may have some residue left. Go to your nearest autoparts store and buy some detailers clay (like "Clay Magic"). Follow the directions that comes with the clay and "clay" the adhesive residue off.
Let us know how you make out.
thanks everyone. i used mothers brand clay and detailing spray.
touch up paint from Ford to fill in a couple of
spots where the paint has been chipped away (1" by
1/4" area). Paint codes match. When it dried, it was noticeably darker than the factory paint. I read in Haynes to let it cure for two weeks and then use rubbing compound to blend it with the factory paint, then wax it. The compound and wax didn't help. It's still too dark. Any suggestions?
I went looking last night for something to get rid of the scratches because they're not deep. I went to Wal-Mart and found some really good stuff that I would recommend. It's called GS27 Scratch Remover. It came in a 5.3 oz. tube and costs $9.97. It worked great!
Pat
Is it possible to put something on the glass so water will sheet away and also provide some protection against little dings in glass?
Is silicon spray good for rubber?
I bought some STP Glass Treatment but have not applied it yet. I want to clean the glass first.
What is the best glass polish?
I just got an idea. Do you thing that toothpaste should work?
I have a fairly-new dark color car with clearcoat. Has several scratches, ranging in age (from few days old to 8 mo. old), visibility (thin and clear to thick and white) and depth (mostly smooth, but can feel some fingernail). I know I won't be able to remove the white, thicker scratches. Just hoping to work on the lighter ones.
What is the best scratch removal product? I'm overwhelmed by all the messages in "Wax and Polish" related topics and can't decide. What is the time period for working on improving/removing scratches? (i.e. can I do anything about 6+ mo. old scratches?) I don't have a driveway to work on the car and would like to know how long I can wait?
thanks!
The best combination of stuff I have found thus far for my windows and especially the front windshield is:
* Apply Zaino's Glass Polish
* Clean with Windex
* And protect with some Zaino Z6 Gloss Enhancer.
re scratches: If the scratch only goes into the clearcoat and not down to the base primer or metal, Zaino's Z5 'Swirl Remover' should do the trick. If the scratch goes past the paint, then there are two cases to consider: 1. Touch Up Paint with the same color/formulation (from your car dealer), or 2. Repainting the affected area via a good detail shop.
Should we buy the protection, or just use a good wax and keep the car clean??
I have yet to see any system that dealers sell that is any better (and sometimes worse) than a good washing and coat of wax by the consumer. Dealership applied wax isn't any better than what you can buy on the open market.
Some due dilligence on your part in taking care of getting bird droppings, tar, bugs, etc off your car will actually go a long way in keeping your paint finish looking good. There are actually some waxes out there that will resist any of these things sticking to your finish.
In addition, I wouldn't want the dealership to apply anything to my paint. Mostly, they don't put these waxes with the best of methods and can scratch (or swirl) your paint in the process. You, the owner, can probably do a better job.
Good luck! Most on this thread can give you some good recommendations on some of the Waxes we find to be very good. Let us know!
I tried to rub some of them out with a detailer/cleaner and a terrycloth towel but it didn't do anything. The paint is perfect so it appears to only be in the clearcoat. I hope someone can help me.
BTW The truck is in northern Illinois where salt is placed on the roads, but I am very diligent to wash it frequently.
AND- My friend has a white Mercedes with the same problem
I just found this discussion so I apologize if this topic has been covered.
Best prescription is to "clay" your vehicle. There are many different types of clay. Go to your local PEP Boys or NAPA and ask for detailers clay. One brand I've used and like is called "Clay Magic". Follow the directions that come with the clay and your problem should be solved.
For those using wax on wheels to avoid excessive brake dust deposits, how many of the standard dawn/clay/dawn/z1/z2 steps are required for wheel treatments? Do you remove the wheels to get the etire wheel depth covered? Seems like this is a little fanatical, but if I only have to do it once a year, maybe not so bad.
Thanks in advance.
I've got polished aluminum on mine with the "brake discs" in full view behind the wheel. I could probably remove the wheels to "wax" the areas that I can't get to, but don't have the tools to do this very easily.
I know people who do remove their wheels, though. I'm pleased with the look of just waxing the outside of the wheels while on the car. I wax them just as often as I wax the car.
