Paint and Body Care
If you REALLY want your new car to look it's best,
- Instruct the dealer to to NOTHING to the outside when it arrives - no washing or detailing. This is where most of the scratches and swirl marks on a new car come from.
-Carefully detail the car yourself (or have it done at a good detailer). It is a good idea to clay even a new car to remove all kinds of stuff it is exposed to during transportation and sitting on the dock, in lots, etc.
- Treat it to a really good wax or polymer finish, and keep it up religiously. Your car will always look great, and be worth a lot more when you sell it. In general a good polymer can last longer and look better than waxes.
For the full story on clay, go to www.erazer.com. As Joe says, there are a lot of clays on the market, I have used Mother's with good results. Even brand new paint will become so smooth you won't believe it, and the wax/polish job will go even easier.
question: what wax product would be good to use? somewhere in the discussions, Meguir(?) is a good product, is it?
side question: what is clay?
I can not believe there's no auto shops around my area sell Mother Clay package. Does anyone purchase clay from interned retailers? Do you know where can I find clay at discount? Any input will be appreciated
Chris
www.zainobros.com
I also used to use MeGuiar's and they have a clay product. www.meguiars.com
Zaino is sold only by mail. Meguiar's is sold in most auto parts stores.
There are two forums at Edmunds that debate waxes and clays, etc. The "Store bought wax" forum and the Zaino forum. But be warned. Wandering in to Store bought waxes and asking about Zaino is like going to Harlem with a KKK hood on. The Zaino forum is a bit less uptight.
there is some product out there that will remove
black marks off parchment colored leather seats
and trim. I think some dye from a new leather
jacket rubbed off. Someone told me to use Simple
Green, but it did nothing! Maybe a good leather
cleaner? Any suggestions? The car is new and I'd
like to keep it looking plush.
I plan to apply a couple more coats before the nicks are raised to the existing paint's level. What exactly is the proper process to smoothen out the touched up areas? If I should wet sand, what is the specific grit? What are the steps to replace the clear coat, or is it necessary for such small areas?
Thanks for any advice!
dave
I noticed after washing my new Honda Accord there are several small "pimples" in the paint. Looks like a small speck of dirt or dust got into the paint or the clear coat. I pointed it out to the service department and they said they would be glad to fix them for me, but several of the techs. said they would'nt mess with them. One guy said he would'nt "break the clear coat seal" that I would be better off leaving them alone. They aren't that noticeable, however, I worry they will eventually chip off. Are the servicemen right or do you think they want to avoid warranty work. I will say, so far the service department at this dealership has been very helpful and willing to satisify their customers. I have read past posts on Edmunds about Honda's paint not being too good, especially the black. What do you think? Thanks!
I took my modeling paint complaint back to the Lexus dealer. Once they determined the paint was in fact less than perfect, we negotiated a settlement. I had the car for 6 weeks already, so swapping was not something the dealer would consider. They offered to have their shop fix the paint. I said that my body shop had recommended against that. They then asked "what can we do to make you happy" I ended up with new chrome rims (a $900 wholesale value)(No chrome comments Mr. S!!). I could have asked for free service or some other dealer instaled options.
I did have a friend once buy an BMW with 1,000 miles on it from a dealer (at a good discount) who's customer actually got a new car because of a paint defect. But I think the chances of this occuring very often are pretty small.
The dealer wants $94 for the 2x4 sheet of fiberglass. Other than getting the last made Aerostar's used foam from a junkyard, does anyone know of a discounter or alternatively, sheet fiberglass insulation replacement avaialable for custom fitting?
Thanks for the reply.
truck had just dropped a 5 gallon bucket of white
paint in the street.It got all over the lower
part of my car.My insurance paid for a full
detail to have it removed.Luckily it was latex.
In your case the state may be the cause but
they will reject a claim as they always do.
One thing I WON'T recommend due to safety factors is gasoline!
A buffing wheel expertly applied with a mild abrasive would probably do it. If it is a very heavy duty enamel paint, you might have a problem.
Whatever you do, do it soon!
Meguiar's Swirl Remover, Show Car Glaze, New Car Glaze, or Clear Coat Body Scrub. (More or less in order of harshest to mildest abrasion). Try the least abrasive compound first. Alternatively, a non-whitening toothpaste might do the trick. It also contains mild abrasives like the kind that is used in may car glaze products. For home use, a good quality orbital buffer is probably a good investment. You really need to have some experience with the rotory buffers.
- Forget the Bug & Tar removers that come in a little can. They are usually petroleum products which work great on dissolving tar but have almost no effect on bugs. Bugs are chemically acidic, unlike tar.
- Did you buy some kind of cleaner product with the Zaino stuff? I don't know their products but some of those chemical cleaner/polishes work great on removing bug guts. Takes some rubbing but at least no scratches.
- Do you have some of that citrus cleaner around the house? Not the stuff with pumice in it. Not OxyClean. The stuff I have is kinda thick, smooth, and really orangy smelling. If not go to the store and buy some. Even if it doesn't remove the bugs it's a good product to have around the house.
- 3M makes a product designed to remove bug goo. Check out your local NAPA Auto Parts as they always have lots of 3M stuff.
- Final shot: Avon Skin So Soft. This stuff works wonders. I used it years ago on bug guts with great results. Gotta call the Avon lady, though. I'm sure some ladies have websites so search that first.
My concern is that the bugs have eaten into the paint; at least the clear coat. You may have to go to a fine cleaner to finish the job.
Hope all this helps.
The use of Dawn is only recommended prior to the first application of Zaino. The idea is to get your paint clean and protect it (from dust, dirt and the sun, not acidic contaminants) with that first application of Zaino and subsequent renewals of it at least every six months unless the vehicle is garaged, more frequently would be better. You do not need, and some even warn against, recurring use of Dawn or other similar akaline soaps.
Cary
I am looking for a one or two step process to treat a new van, which requires a few hours work and will last at least 6-9 months for Northern CAL weather. It doesn't have to be concourse quality, just durable and a deep shine. Thanks.
Cary
1.)A day for shopping and washing with blue
Dawn. Dry with your new towels, hopefully
your wife will not find your receipts
from Bloomingdale's!
2.)Apply Z-1 and let dry overnight, unless you
live in Arizona and there is less than 2%
humidity.
3.)Apply a very tiny amount of Z-2(use your
atomizer bottle) or everything will smear and
you will need to start over again.
-Larry
Y'all don't think Protogextwo is an English teacher or, horrors, a lawyer do you?
Respectfully;
Larry
My sense is that too many peopole are scared off from trying Zaino because the recommendations to obtain the ultimate use of the product could sound exhausting to someone. Many of those same recommendations apply to get the best results of ANY paint care product, but are not critical to the outcome.
Cary
The $6.95 shipping and handling would seem excessive if you were buying only a few items. My initial order was for 25 items (one each of most products, 2 of 2 products that I saw using more of, and 12 applicatiors) and I still paid that same flat shipping charge. I guess it depends on your prospective.
Thanks, in advance.
Here's the link to their How-To articles. You will need Adobe Acrobat Reader to open the pdf files (it can be downloaded for free at Adobe's website):
http://www.carcareonline.com/howto_articles.html
