I'd be more inclinded to test your ignition and/or #7 injector circuit.
In cold, rainy weather I receive “Check Engine Light” on Diag and advise.
Technician found Medium Evap leak but code not active. Suspect intermittent failure of the leak detection pump but without code active or leak present.
Is this, perhaps, computer or computer program problem?
Happened this problem often in Dodge-Dakotas-2000?
Please give me a hint! ">
Ben
What are P1508 and P1259, and what could possibly be causing these problems. The cars idle is horrible. It constantly goes up and down...
Thanks for any help you can provide....
does the engine run rough or smooth spray a little
2+2 in intake does it smooth out if rough
disconnect injector does engine idle down a little
if runs rough and it has no change when disconnect
injector sound like clogged injector
possible bad fuel preasure regulator if smell raw gas
pull plug does it smell like gas
do you have spark
Quik history: I have mostly driven this car for short distances--just long enough for the Turbo to get nice and warm, then shut it off...apparently hard on it...only recently was told to let it idle 1 min. b/4 shutoff, but not why...16 year old car..first time I'd heard it...
I've had "loss of power" problems ever since I hit a huge pothole within 6 mos of purchase of this car...no one I took it to for repair ever could find anything wrong with it...nor could the "surging" trouble be located/fixed by anyone...I think I saw something about problems like this with this model that I suspect may be design flaw but not being a mechanic, and having scanned 100 or so VERY OLD postings on this site, can't be too sure about that...I had the "O2 sensor" replaced less than a year ago which fixed the surging problem. Now, after letting the car sit (w/o starting it up for aprx 2 wks when I was very ill), with it having a little less than 1/4 tank of gas in it, from the first time I started it up, I had trouble getting it to start--kept trying to die--but I found that if I kept giving it gas, it would eventually "warm up" and run ok...that lasted a few days and I only took short trips...
Then, I got paid, so I could afford to finally fill up the tank, figuring that I'd probably released some 'low gas tank scum' into it, but that it would be okay with more gas in it, and that driving it I could blow out any carbon residue...but...then...the Check Engine Light came on...and went off...I read the manual, and it said something like "...it was an indication of fuel emmissions not meeting mfg standards, take car to dealer.."
Yeah, right! Dealerships have, in the past, omitted info I needed, not been able to fix it, and bent me over in the process without so much as the HINT of a kiss...I knew I would have to find a trust-able mechanic, since the car was also losing power/not accelerating till after warmed up for quite a few minutes...but before I could do that...
I tried to make an emergent midnite run after my kid...I made it only a few blocks, when it just REFUSED to accelerate, the check engine light came/stayed on and finally had to turn around with it going maybe 10 mph, coughing/choking/gaging/backfiring the mile or so home...AAAARRGGHHH! My baby's really sick...HAVE there ever been any recalls on anything related to what could have happened? After reading postings, sure seems there should have been!! Or did I just get a lemon?!?">
if you know the codes, you can research them. you can consult a dealer or local shop specializing in your car and estimate what it would cost to get the system cleared.
I have a 1999 Ford XL (lx) wagon. I've been very happy with the car. About a year ago the speedometer started to go up and down on its own every now and then. I had the oil changed at a Jiffy Lube - all we have out here anymore - and the speedometer/odometer stopped working completely. At the same time the service engine soon light came on. Naturally Jiffy Lube could find nothing wrong when I took it back. I've lived in the rural area all of my life. I drive the same roads, etc. and have no problem without the speedometer. In NY all cars have to have this light off to pass inspection. Mine's due next month. I ordered the manual, have browsed here and there, but cannot find anywhere that gives me a hint as to how to turn this light off. I don't know anything about cars, and have no male friends or relatives that do either apparently. If I take it to a local dealer for the computer checkup it's $300 just to run the engine through the computer, any repair of the speedometer is extra. My car has well over 100,000 miles on it and I have no intention of ever selling it so the speedometer/odometer thing doesn't bother me. Can anyone give me a clue? Please? Like most people, I don't have the extra 3-5 hundred to throw at a problem that isn't a problem. Thanks so much.
You can reset the light, but if the condition is continuous, it will come back on. If it doesn't there is another hurdle... when you reset the light, you must drive the vehicle a certain amount before the computer will indicate "ready" to the inspection station's computer. If it stays off and readies itself, you will probably pass. If it readies itself and comes back on, sooner or later you're looking at a repair bill.
Perhaps you want to consult a mechanic/station that services Fords. The $300 for a checkup seems steep. Perhaps an independant shop will be more willing to work with you, but like I said, you probably can get the codes read for free at a parts store then google the heck out of them.
maybe, just maybe the code is for something trivial that the independant shop can quickly repair without killing you.
good luck.
You actually need a temperature gauge installed temporarily to see what the coolant temp does. I suspect it's the radiator having "bloom" on the ends of the tubes from interaction with the water--like mineral buildup. A radiator shop can probably look in it quickly and tell you. Or if you do-it-yourself and the radiator has never been service, in your car it's easy to take out and carry to the shop for opinion.
had hesitation starts. Midas found a P0300 code and suggestted me to do transmission tube flush and tune-up, and replace a few things, but they were not sure the problem will be gone. So I went to a Mazda dealer. They think there is something wrong with feul ignition system. To fix the problem, it will cost a lot of money, they don't think it's worth it, so they don't want to open the engine to dig further. But they found I used wrong grade of gas, so they put some kind of engine cleaning fluid and let me go. The car ran almost one week without any problem. Then the engine light is on again, but no much sign of hesitation. So I drove it for two weeks and bought a bottle of engine system cleaning fluid from WalMart for a new tank refill. Two days after the refill, the check engine light is off. I was so happy and thought it will be gone forever, but the happiness only lasted for one day. The light is on again until today, almost two weeks. I'm not sure if the engine hesitation is always there. Sometimes when I start car I feel more engine vibration than other times and I saw thick smoke comes from back. This morning, I felt clear hesitations when I was driving the car. The car seems not have much power. More than that, the engine light fleshed several times and then stays on. Anyone knows what is going on? Should I let the autoshop to look at it a little more and replace all kind of things? Thanks.
Did they replace the spark plugs with OEM plugs?
Did they replace the plug wires?
When was the fuel filter replaced?
Also, this TSB may help. "Top Engine Cleaner" can be purchased at any GM dealer.
01-027/02
1995 - 2002 Millenia (KL engine) - MIL ILLUMINATION WITH DTC P0300 TO P0306
APPLICABLE MODEL(S)/VINs
All 1995 - 2002 Millenia models with 2.5L V6 (KL)
DESCRIPTION
After a cold start, MIL comes on with DTC P0300 to P0306 stored in the memory. In most cases, this concern may be caused by misfire occurring in one cylinder during idle. The use of premium fuel (high-octane fuel) may be allowing carbon deposits to accumulate on the exhaust valve seat, causing momentary insufficient compression.
To correct this concern, remove carbon deposits using a suitable top engine cleaner.
NOTE : After removing the carbon deposits, be sure to advise the customer to use lower-octane fuel (87 or 89 octane) to help prevent future recurrences.
REPAIR PROCEDURE
1. Warm up the engine until it reaches the normal operating temperature, then turn the ignition off.
2. Locate the canister purge vacuum port into the intake manifold to feed the cleaner into the engine. This allows the cleaner to distribute evenly.
CAUTION: ^ Be sure to feed the "Top Engine Cleaner" into the engine through the correct vacuum port.
^ Do NOT use a PCV hose. If too much cleaner enters the engine, the engine may be damaged.
^ Do NOT use the vehicle vacuum hose. You have to prepare a new hose and fit an orifice (E5B6 13 986) into it to limit the suction rate.
^ With an orifice fitted into a new hose, about 7.5 fluid ounces will be fed into the engine, taking at least 1.5 minutes or longer. If the cleaner is fed at a faster rate than 7.5 fluid ounces per 1.5 minutes, excess liquid entering the cylinders may cause hydrolock, resulting in engine damage.
3. Fit the other end of hose into the container of "Top Engine Cleaner".
4. Choke off the hose with locking pliers (vise grips), then start the engine.
NOTE : Large amounts of exhaust smoke will be emitted in the next step. Be sure to connect the exhaust evacuation hose to the tailpipe and ensure there is adequate ventilation.
5. While cycling the engine speed between 1500 and 3000 rpm:
a. Remove the locking pliers from the hose with the orifice. The intake manifold vacuum will now draw the cleaner from the container.
b. Monitor the feed rate. Only 7.5 fluid ounces (half can) should be fed, taking at least 1.5 minutes or longer.
c. When almost 7.5 fluid ounces has been fed into the engine, reduce engine speed and allow the engine to stall. If the engine does not stall, turn the ignition off.
6. With the engine off, wait at least an hour (not more than 24 hours). This allows the cleaner to soak into the carbon deposits, increasing its effectiveness.
7. Repeat Step 1-5, using the remaining portion (approximately 7.5 fluid ounces) of the cleaner.
NOTE: Do not allow the engine to stall this time.
8. Remove the hose with the orifice and reconnect the canister purge vacuum hose to the intake manifold.
9. Test drive the vehicle 3 miles or longer to completely remove the remaining liquid and carbon deposits from the engine.
10. Perform engine oil and engine oil filter replacement service.
NOTE : With new engine oil and filter in the engine, start the engine, then raise the engine rpm several times to circulate the new oil throughout the engine.
11. Verify repair.
NOTE : Be sure to advise customer to use lower-octane fuel (87 or 89 octane). Periodic use of a well-known gas treatment (such as Chevron Techron) can be recommended to help prevent future recurrences.
The code will probably tell you one cylinder isn't firing but won't tell you why.
Engine coolent Temperature sensor
Mass Air flow sensor
Crank shaft Position Sensor
Throttle position sensor
Park / nuetral gear Selector Position
Vehicle Speed Sensor
Knock Sensor
Power steering Oil Pressure
Intake Air Sensor
Fule / Vapour Pressure
Absolute Manifold Pressure
Oxygen / Air-fuel Ratio Sensor
If you can start and steer your car well, and still Check Engine light remains on you should target last three sensors. Possible causes are:
1. Improper fuel pressure.
Leak in fuel system, may be pin-hole, To detect this fill-up your tank to the maximum, park your car in a clean space for a while 5 to 10 min. and check the for the fuel leak on the bottom, if there is any, may be because of Fuel intake pipe, Gas Tak or Fuel lines.
Exhaust system leak.
2. Leak in Exhaust system. Can be detected easily.
3. Fuel injector restricted. Use Fuel Injector Cleanner.
4. Defective heated Main oxygen sensor No. 1.
If you are very sure about 1,2 and 3, then target main oxygen sensor located after exhaust manifold and before catalytic convertor. Replace this with brand new one
after replacement disconnect battery positive terminal for a while and reconnect it. start the car and see if Check Engine light turn on after a while replace sub oxygen sensor after catalytic convertor and before exhaust tail pipe. after replacement disconnect battery positive terminal for a while and reconnect it. start the car and see if Check Engine light turn on after a while taget following sensors in sequence.
5. Defective Manifold Absolute Pressure (MAP) sensor.
6. Defective Engine Coolant Temperature (ECT) sensor.
99.9% your problem will be soved at the step 4.
GOOD LUCK!!!
"HI I HAVE A 2002 TOYOTA COROLLA. MY CHECK ENGINE LIGHT IS ON, I PUT A SCAN TOOL ON IT (P0420) (CAT EFFICIENCY BELOW THRESHOLD BANK 1) DOES THIS MEAN I NEED TO REPLACE MY 02-SENSOR THE ONE BEFORE THE CAT, OR AFTER THE CAT."
A failed upstream O2 Sensor will NOT cause this code to be thrown, so there is not purpose in throwing a part at it in hopes of a diagnosis. This code is triggered when the downstream o2, matches the upstream 02 too closely. Now lets think about this rationally, this code essentially says that the rear o2 is too active, has anyone ever seen an o2 sensor fail by being too active, me either.
Now to my point, the rational course of action,is to replace the CAT, check for an exhaust leak in front of the cat, behind the front 02, but if none is there, you probably need a CAT, this code is not easy to throw, BOTH o2 sensors have to pass their own monitors (test) before cat effiency is ever even considered by the ECM.
Most codes are easy to falsify, and the computer often throws a bogus code based on what it sees, but this praticular code is almost always right on the money, you need a catalytic convertor to cure your light, and to pass inspection (if that applies to you)...
Thanks for responding. Much appreciated!!
I have just had the P0420 code occur on my 2002 Corolla (95,000 miles). I have been researching this code for awhile and was all set to replace the upstream O2 sensor until I read you post. Your logic seems solid to me and it appears you know what you are talking about.
I am curious if you know what type of self-testing is performed on the sensors before they are used for monitoring the O2 levels?
"99.9% your problem will be solved at the step 4."
I really hate to see posts like this.
Any time you generalize what could cause the check engine light to come on, you are leading folks in the wrong direction.
Just like the people that say that every time the check engine light comes on, it is usually the gas cap loose.
Without knowing what the trouble codes are, NO ONE CAN GUESS!
Plain and simple.
To say that the O2 sensor or the gas cap is always the reason the check engine light comes on is PURE SPECULATION and most often wrong.
Now don't get me wrong, I am not trying to discount the information, but when it is wrong, it is necessary to correct it.
But then again, who am I to say what information is wrong or right?
As I have stated hundreds of times and has been stated by several of my associates...........
A trouble code or the check engine light on does NOT mean replace the sensor. It means that there is a problem with the CIRCUIT.
Diagnose the problem BEFORE replacing ANY sensor.
