"Under hood, center, upper engine area, mounted on rear driver side of engine
Ha, I used to work for a guy who owned a freakin shop, had for thirty years, and STILL had that mentality. Every time a MIL came in, he would promptly tell them to "tighten there gas cap, and see if the light goes out". I would always laugh, 90% of the cars coming in at that point didn't have enhanced EVAP, which means the cap wont cause a light any way!
Back to the original message about the toyota, yeah I know what monitors run, in general, each manufacturer does things a bit different but the end result is the same. First you have the heater moniters, which basically just measure the current and time it takes for the 02 heater circuits to operate, assuming that is ok, it runs a component function montitor, basically changing fuel trim a certain amount, and seeing if the 02 sensors are cabable of reacting in a manner which indicates proper function. Say if the computer adds xxx fuel to the mix, it expects to see the 02 rise by .xx volts in xx milliseconds, and vice versa. Any test which result out of range, twice consecutivly will throw an 02 code, and a single failure will inhibit any test that need a working 02 from ever being ran. In conclusion, the ecm will always test the 02's, before running a cat test, and these are HIGH priority for the EPA, so the test threshhold is small, and accurate.
http://www.carspace.com/kirstie_h
MODERATOR /ADMINISTRATOR
Review your vehicle
also possible in th process of replacing the temp gauge you did change, the wiring to it was damaged (connector).
Second question, is the second sensor the sensor AFTER the catalytic converter?
This vehicle has 4 sersors, and 2 catalytic converters. Each exhaust manifold comes down and under the vehicle, then has a sensor, a catalytic converter, another sensor, and then Y's to a single tailpipe. I'm "assuming" that the sensor 1 is the sensor before the catalytic, and sensor 2 is the sensor after the catalytic....but here again, it's not defined in the service manual.
Any knowledge out there to the definitive description as to which side is Bank1, and where is sensor2?
Have you gotten yours to run properly yet? If so, what did you do? A reply would be much appreciated. Thanks!
Don't know what to do next, I am wondering if it is the idle control valve, sending an incorrect signal to the computer? The next step for me would be to take it to the dealer $85.00 for diagnostic however, will they find the problem? This is ridiculous as this seems to be a somewhat common occurance with these '01-'02 saturns.
Do you happen to know in a GMotor V8, which is 'bank 1'? Is it on the passenger side or drivers side of the vehicle? I have an O2 sensor acting up, and other than knowing that piston 1 is also in bank 1, can't find anywhere in the service manuals to explain which is bank1.
Also, is bank1, sensor2 the 2nd sensor (ie. 'after' the cat?)
To the best of my knowledge, the Saturn S-Series only has downstream O2 sensors, and there are two sensors total on the car. If I am incorrect, let me know where the upstream might be located and I'll see about replacing the sensor. I'm willing to do a lot of things in order to get this thing back in shape again (i.e. no more engine light).
The vehicle has 4 o2 sensors. One set before and after the catalytic converter1 from bank1, a second set before and after the catalytic converter2 from bank2. After the catalytics, the pipes join for one tailpipe.
Nowhere can I find in the factory service manuals (97 Sub K1500), which side is "Bank1".
Thanks for the comments, you are probably correct. There seems to be nothing wrong with the performance of the vehicle so far since the CEL came on.
Cyl #1 - 160
Cyl #2 - 165
Cyl #3 - 160
Cyl #4 - 140
I did it again when it was hot and got the following:
Cyl #1 - 150
Cyl #2 - 150
Cyl #3 - 160
Cyl #4 - 155
The engine runs a lot better when it's warm, and the misfire code goes away. The only code left when the engine is hot is: P0507, Idle Air Control System RPM Higher Than Expected.
I think you are right though about the popping being a result of a lean mixture. I found there to be a leaky intake gasket, and spraying carb cleaner around it while the engine is running causes it to smooth out momentarily.
You may want to find a new Saturn mechanic who has a clue.
The upstream O2 sensor is located on teh exhaust manifold.
It is defined as the O2S-1 sensor.
The downstream sensor is located on the rear of the Cat and is defined as the HO2S-2 sensor.
DO NOT REPLACE O2 sensors without verifying another problem first. Contrary to popular belief, O2 sensors should have an extremely long life, unless there is another problem present.
Trying to figure out why Check Engine light stays on - - replaced Idle Speed Air Valve Switch, replaced Oxygen Sensor, replaced Distributor Cap & Rotor.. #11 did not come back but Code #18 continues to haunt me..
ANY IDEAS... The car idles around 5, dies when cold, dies when driving for awhile.. When it idles at 10, feels okay but light still on..
It's been several months and I am concerned about continuing to drive w/Check Engine light still on..
Thanks, Susan
It's Mercedes 300 TE, 166K miles, 1992.. My regular mechanic was stumped; he replaced the distributor cap & rotor then sent me to Mercedes dealership which replaced the idle air valve switch and wanted way more money than I wanted to spend so went back to regular mechanic and he replaced oxygen sensor and frankly, he's stumped..
Think Code #11 is gone but Code #18 still occurs.. So, any ideas for my regular mechanic would be greatly appreciated..
Thanx, Susan
As the code 11 could have 2 meanings, depending on what you used to retrieve the codes.
Have you cleared the codes and roadtested the vehicle to see what codes come back?
I can't help you if you don't help me with the information I asked for.
Any ideas?
The possiblilities could be a faulty air valve (if he replaced it with an aftermarket one, it may be half the problem) or one of two circuits are open.
Your mechanic will need a wiring diagram and the flow chart, but he will need to check continuity at pin 23 of the CIS-E to pin 1 of the Idle speed air valve and pin 4 of the CIS-E to pin 2 of the Idle speed air valve.
There should be less than 1 ohm in those circuits.
If either circuit has more than 1 ohm, then there is an open in that circuit.
