Also, remember that these surveys are completed voluntarily - people who do not want to spend 30-45 minutes completing these surveys report nothing. Owners with an "axe to grind" will take the time to respond. Owners who are "in love with their brand" will take the time to respond. But what about others who believe completing the survey will change nothing?
The only way to accurately determine which vehicles are more trouble-free and which vehicles are problematic is to have total access to warranty repairs for the term of the warranty. That will never happen, so we have to live with the data gleaned from voluntarily returned JD Power, Marantz, etc., surveys.
2014 BMW 428i convertible, 2015 Honda CTX700D, 2025 Hyundai Tucson Limited.
I get the feeling our VW dealer is pretty low key and seems to be pretty up front. I don't think they would tarnish their reputation for this scam.
As a general rule I would try to see if I can find some positive info about the newer technology...and if I can't I would go with the tried and true system.
Not wanting to jack up my insurance premium I paid out of pocket for it. I am with Liberty Mutual and I understand last year they lost over a billion dollars. With losses like that a premium increase across the board is probably inevitable but I wanted to reduce the impact further by not filing an individual claim.
For the four days that my car was in the body shop I rented a 2015 Ford Focus SE from Enterprise at $30 day, a $60 value for private rentals. Again, a good price since I negotiated for the insurance rate. The manager was reluctant but he gave in without much fuss.
About the Focus SE--other than good forward visibility, there is nothing redeeming about it. The car is noisy. Frequently I had to check the windows because wind noise was so intrusive. Ditto for road and engine noise. Oh, what an insult on my eardrums. Nonetheless, the SE was well equipped with back-up camera, Ford Sync, and a decent stereo system.
In short, I can understand *Driver and *Mike's willingness to pay
more, much more for a premium automobile. The cacophony emanating from that Ford Focus SE is still paining my ears one day after turning it in.Yeh, but, houdini, your video would only get about 27 hits!
I agree, the hotel made a huge error, not sure it was $100million error. Whenever I have called someone in a hotel they put you through to the room, but, they don;t give you the number of the room, for obvious reasons. How could they do that?
I am shocked that you think I would get as many as 27 hits. Thanks for the compliment !
2013 LX 570 2016 LS 460
I need to stop overthinking this. I suspect the mini-split system would probably be sufficient, but without direct experience it's hard to say. I'd hate to spend that money and later on find my bedroom is still too warm.
I have owned minimal cars and I am fortunate to be able to drive something better...I sure hope the day doesn't come when I have to go back to minimal.
The review was good, just to hear the impressions of what a regular person noticed.
The times I used it I think she is right....as usual.
What do you think?
I really thought 3 people, but I didn't want to bruise your ego
DRIVER TIP: If you are flying somewhere and getting a long term rental get it from a car rental place away from the airport, take a taxi. Cost could be a lot less than getting a rental car at the airport.
Just for fun, I looked at the Atlantic City location. 1 week with a Focus comes to $290 with taxes and fees. So a hair over $40/day. Yikes.
Insanity. That alone would be enough to prevent me from buying a car, any car.
I remember back in the day, I was helping a friend change out the starter on a Vega. You had to unbolt the engine mount and jack up the engine to get the starter off. If you needed to change the rotor (inside the distributor cap), you had to remove the AC compressor.
Engineers who do things like that should be shot.
They are the units that you have probably seen that look like this on the outside of a house:
In the house, something that looks like this gets mounted on a wall:
As you can gather, the inside unit shoot air in its general vicinity but would not cool another level or rooms that are not in its direct line of airflow.
The ducted variety is the kind that ties in with a hot air furnace and looks like this on the outside of the house. Inside it uses the existing heat registers:
I think it works pretty well, but noisier than I would like. If you go this way make sure the unit and filter are in a place that is easy to get to. Our is easy, older models put the furnace in the attic and you have to go up a ladder and crawl to get at it.
And, that's all I know.
I have a confession to make. Up until today I had never nailed the Mustang full throttle.
I was entering the interstate with the gear shift in "sports" mode and feeling frisky and I notice a big tractor-trailer coming up fast in the right lane. Normally I would lay back and merge in behind it but I saw an opening into the middle lane and took it...
Holy crap! The car just flew down the road like a jet. I've never felt such acceleration. I don't know how fast I was going but I had to brake about a mile down the road to avoid rear ending a car doing 70.
I was a very, very bad boy.
And I liked it.
Please don't judge me. :'(
And I liked it.
but if it were to come along, I'd replace our central air heat pump with a gas furnace and heat pump together. Depending on the cost of electricity, the switch from using electricity and the heat pump to using the gas furnace for heat occurs when the heat pump can't keep up alone, getting the highest efficiency on both ends.
Currently the heat pump uses electrical heating strips--like a toaster or dryer to provide extra heat when the reverse AC doesn't provide enough to maintain the interior temperature. Dual fuel uses the gas for the backup.
Lennox makes them. Called dual fuel.
I hope you had some fresh undies wait for you when you got home.
I test-drove a 2011 GT and tried something similar on an expressway on-ramp. It scared the bejeezus out of me. The power was unlike anything I ever experienced. My ATS is quick, but nothing like that.
The best of the new mini-splits can produce significant heat down to somewhere just above 0 degrees F. Add some inexpensive electric strip heat as a supplement on the very coldest of days and you're good. No real need for a gas furnace and the cost of all that. The issue with the ducted systems I have found is that those heat pumps are not as advanced and do not produce heat at those low temps. So in that case you might need either a gas furnace or perhaps some electric heat, depending on where you are. If a house is designed in such a way that a few mini-splits can service the entire space then in a lot of the country you do not need a furnace at all, assuming the house is well built and properly insulated.
It is amazing how things have changed in both home construction and heating tech over the years.
Yes, you could easily scare yourself silly using full throttle in regular traffic.
But, in the immortal words of Tim Allen - "UHNN! UHNN! UHNN!"
Good on you for letting the ponies out of the barn.
Fast forward to when I was 24, and a friend of mine had just gotten a new motorcycle of some kind, I don't remember the brand, but it looked very similar to my old Allstate. He asked me if I wanted to take a spin and I said sure, I know how to ride as I used to have one of these.
I hopped on and slowly rode up to the highway (practically deserted) lined her up, and slammed on the throttle. Wow! That thing took off and very, very, nearly ripped my hands off the handlebars. I guess there is a huge difference between 16 HP and whatever that thing had !!
http://www.motortrend.com/news/comparison-2015-bmw-m4-vs-2016-chevrolet-camaro-ss/?_wcsid=803D36F0164E42D5126522EAB2C8C7A91DD643B7F08DF0FF
I think the Mustang GT has the Camaro beat in styling and ride. You made the right decision. You'll have many years of extra enjoyment because of your decision.
Speaking of efficiency, I replaced three toilets in my home with dual flush systems and cut my water bill in half. Now, only if I could do the same for my electric bill.
All sorts of heat pumps, geothermal, refrigerant cooling these days. The more efficient they are, the more expensive they are. Places without basements sometimes put HVAC in the attic. But ordinarily, the heat unit, with fan, is inside and the A/C condenser is outside.
Attention Colorado Residents
