BTW, its more like a four year education, and then a five year apprenticeship before one really starts to learn which will take another ten years or so. (and that would be decent if nothing ever changed)
How can the consumers ever have qualified technicians ready to serve their needs when there isn't enough being done to recognize just what it takes to really be qualified?
The most annoying part however is when those that want it that way don't accept the responsibility for their choice and turn around and blame the techs when the way they wanted it proves that it doesn't work. Meanwhile, a top tech would make easy work of this and would have solved it in about an hour, maybe twoat the most while the system thinks its OK to pay him/her about a half of an hour for the effort. (even if it is the first and only time they ever encounter this failure)
What a country...
Yep, throwing parts at it with no clue if that'll fix it. At the very least they should be able to re-flash the ECU and see it that helps any.
But no, the present system is so much easier. Unless it's your car sitting at the shop for a week while you incur a rental bill of $45 a day.
We don't really have a tech problem, we have an engineering problem.
Which is to say, we have a beancounter problem, and the beans are being foisted on the consumer.
lower pricemore competitive price for .the consumers share of beans.They could build easier cars to work on, consumers will turn around and spend their money on something cheaper to buy.
So why hasn't anyone told this owner that when the fourteen to twenty year old car developed an oil leak that it could have easily been repaired by replacing the valve cover gasket(s)? Wouldn't that have made more sense instead of experiencing this failure and the associated loss?
I've seen worse articles in MSN but there are still too many holes in this one.
http://forums.edmunds.com/discussion/40708/ford/escape/instrument-panel-clicks-on-off-immediate-after-starting-engine#latest
BCM related?
You aren't doing anything with this system with less than the Ford IDS scan tool.
Seems to me I recall that replacing the SJB required programming it
https://www.motorcraftservice.com/Home/Index and after registering, recover the as built data from Ford and enter it manually. Here is an article on the subject by a friend of mine. http://www.searchautoparts.com/motorage/technicians/scope-scan-service-repair/using-built-data
BTW. This is the same routine that is used for airbag systems. Ford's process of trying to retrieve data from the current module before a replacement is installed is common for almost all of Ford's reprogrammable modules.
The engineers cannot create a trouble tree that can lead someone through diagnostics like this. It is up to the technician to know how to do it and apply critical thinking skills to make the best use of the information at hand.
This is why today's techs need (or at least have the equivalent training of) an associates degree in digital electronics engineering. Excellent math and science skills. Good reading and comprehension skills, and they have to either own or have access to not only the factory scan tool they need tools like PICOscope because they might have to directly measure and interpret the communication data bus and waveform. https://www.picotech.com/products/oscilloscope (the 4000 series or higher)
There have been attempts to suggest techs that do this work are a different career than ones that do mechanical work, that's a false perspective. The tech has to be the electronics specialist on top of being the master mechanic that can work on everything bumper to bumper.
Now imagine how much tooling, training and study is required to work on multiple vehicle manufacturer platforms and you'll have an idea what guys like me have been doing for the last twenty plus years.
One more thing. Before anyone can "google" and try to come up with some silver bullet, one of us using the right tools and techniques solved the problem and reported the information. Without that, there would be no magic answer. Meanwhile anyone who relies on those magic answers when available isn't learning how to do it without such information. That's the difference between qualified technicians who have the tools and training to do the whole job and anyone else.
Why is that? I mean, electrical contractors don't frame houses; dental surgeons don't clean teeth.
Techs work all by themselves 99% of the time, the job isn't done by committee. Heck for that matter I can tell you stories about techs that had to call into the hotline looking for help and that need has been used against them behind their backs. aka. "If he was really as good as he thinks he is, then he wouldn't have had to call for assistance". That is behavior by the critic that I call moving the finish line and it rarely mattered what one did, there was always someone else who wanted to move the finish line to suit their domineering perspective. That's a practice that is all too familiar even in these forums.
Are you following the Yukon misfire thread? Just getting exposed to the answers there doesn't equal knowing how to test and diagnose at that level. If you were a strong technician with excellent scope and electronics skills, it would take some forty hours of training spread out over a year or two as it is used and experience gained just in that one aspect to master that technology alone. Just learning about this level of capability is in itself an epiphany to anyone not already trained and equipped to perform it. Now to complete the cycle all someone who has never even performed a basic compression test has to do is parrot that information, pretend to be knowledgeable and they can and usually will try to make someone working as a technician that doesn't yet know about it yet appear to be incompetent.
Now imagine any one of the thousands of things a tech might have to deal with each year, and someone else just happen to be aware of some minutia that applies "this time" and instead of sharing it in support, use it as a chance to discriminate against the technician and you have the automobile repair trade.
But you can't blame people for trying to save a buck these days.
I would gladly spend $150 on bad guesses because that's just an hour's time at the Mini mechanic. He's not going to fix it for $150 either.
So we're even!
I'm in advertising and I certainly don't get bent out of shape when someone wants to make their own ad by reading on the internet "how to create your own advertisement." Some will do well enough that they will never need me. Some will fail and wind up coming to me for help anyway. I'll never begrudge either.
Mine: 1995 318ti Club Sport-2020 C43-2021 Sahara 4xe-1996 Speed Triple Challenge Cup Replica
Wife's: 2015 X1 xDrive28i
Qbroz... Where do you draw the line on someone treating you wrongly based on problems they had with other advertisers?
It's all a process, and each customer is different.
However, I would definitely fire any customer who is litigation-happy, as that is an aggressive form of behavior that rarely has a good outcome. I don't like being threatened.
As for $150/hour, that's what it costs to do business in California.
Let's use the Yukon. http://forums.edmunds.com/discussion/40712/gmc/yukon-xl/2007-yukon-misfire#latest
If a technician commits him/herself to studying, learning, and being equipped so that they make ordinary work out of such a complicated failure, does that make them a master at their craft, or just greedy?
I can hear the "buts" now. Of course there are some bad people, incompetents, newbies, and hard working honest people who just happen to be human and make mistakes once in a while. Get over it, because nobody here is above the rest of humanity, and nobody here is capable of being a technician that will never get beat by something, confused by circumstances, or encounter something that they have never seen before etc.. For techs seeing something for the first time is normal, having to learn something new is normal, and yes even having to learn on the fly the hard way is absolutely normal.
Being a consumer doesn't give someone the right to mistreat others and there is no greater insult than calling techs greedy, especially when it is being done by someone who refused to lower their lifestyle and self esteem to one that equals what the average technician can expect to have. Anyone that works as hard as techs do and lives with the physical abuse, low wages, unpaid labor hours, and poor benefits that plague the trade is anything but greedy. In fact not only are they the complete opposite, they accept losses that shouldn't be theirs when they occur and often blame themselves for "not being good enough this time". By anyone else's standards that would in part be foolish, but that's what a tech who accepts his/her strengths as well as weaknesses does. They accept the losses because they see those experiences as identifying something that they need to improve on. To be called greedy when that's what is really going on can't be labeled here as what it really is without it being censored.
You know this makes me wonder how Gandhi would have been treated if he had been a mechanic.
The rant turns another page.......
Now overselling, no doubt that is wrong I totally agree on that. But there are only a few who really do that and you should go after them and the people who pressure them to and benefit from such activity. Not use it as a standard to try and browbeat every person that attempts this career choice.
Charging for "misdiagnosis" how about being paid for such in any fashion? Let's group those together. If someone is being paid to give advice and they haven't done due diligence to prove its accuracy or validity even if it appears to be free to some end user then it is just as bad. You have recently gotten to see practical application of tools and routines that are so far beyond your expectations you chose to equate them to something that people who work for NASA have to do. Nothing that I have shared here is new, its all been around at least six to ten years if not more. (Frankly I often wonder just how did we get by in the past without the things we can do today) If you think what I have shared here is Werner Von Braun stuff, you should see what I have been spending time studying this week in preparation for classwork for technicians to be ready to deal with the advanced engine platforms that are hitting the streets in new cars today. Every tech is going to be challenged like never before with this stuff and there will be some growing pains for them. Guys like myself are hard at work today trying to minimize those pains for the tech, shop and the consumer.
Back to charging for "misdiagnosis", the reality is that most shops don't charge enough, which means the techs don't get paid enough to do diagnostics correctly.Let's try that again.
About charging for what ends up as a misdiagnosis. The reality is most shops don't charge enough for diagnostics, which results in the techs not being paid enough to do them completely every time. That results in them pulling up short before the task is really completed and that's what opens the door for the mistakes to occur. You've gotten to see a handful of the many routines they should have at the ready in order to get diagnostics correct, but because of the pressure to be too cheap they aren't prepared to work at that level so the technology beats them. If they charged more, and turned around and invested more in training and equipment those issues would eventually correct themselves, and while "the problem" would never go away completely (There is just too much to learn and have to do to know it all) it could be reduced to a more manageable level. Its time you realized that most of what goes on in forums like this serves to make the situation worse, not better. If you want it to get better, then ask what can you do to help. If you don't want to do that then at least get out of the way of the ones that are trying to. One more thing about trying to give someone a list of possibilities about what is wrong based on a symptom without any testing. When someone does that it is at best no different than a tech who has stopped short before doing everything possible to test and prove what is wrong and it easily isn't even at that level. The best that can really be done is to tell them how to test and prove what is going on. If they don't have the tools and skills to do that once they have been shown then the next step is up to them. If they then turn around and find out that there are no shops with techs available to them who can approach their cars problem the right way then you have your answer as to just how much everyone has helped that consumer.
You were making a cogent argument up to that last line---then you slipped into Orwellian Newspeak.
