kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
kirstie_h
Roving Host
Edmunds.com
Review your vehicle
Earlier I had asked about changing the fuel fitler.
>>In short, does anyone have any advice on how to bleed the pressure in the fuel lines before removing the filter?
Thanks in advance.
I have a 2000 VW GLS Jetta (auto, non-turbo). I saw on earlier boards that there has been some discussion about VWs (high ?) oil consumption - didn't know about this until this week when it happened to me. Car bought May 2000. Only 14,932 miles (in Los Angeles no less). Had both 5,000 and 10,000 mile checkup. No problems that I knew of.
On 1/22/02, Flasher and turn signals froze, then started to work again after 2 miles. 1 mile later ENGINE OIL PRESSURE light goes on. VW service closed, told to check oil next day. There is NO oil reading on the dipstick. Have car towed into VW. Today service dept. says yes, your car had no oil, needs a change. They say my last change was at 9,550 miles and that now at 14,932, I am 382 miles over the 5,000 mile change.(even though I am 68 miles short of 15,000).
This seems like crap advice, because my owners manual says to service the oil change at 5,000, 10,000 and then 20,000. VW will not cover the 15,000 change and I get to pay 40- for it.
I received a letter from VW 3 mos ago saying that a 15,000 change is "highly recommended" but optional.
Any updates from earlier discussions? Should I sell it before the 2 year warranty is up? Should I just keep adding oil like crazy?
They say it will normally burn oil at a quart of oil per 1000 miles, but from earlier discussions (ending March 2001) here in Town Hall, this seems like a VW problem - not normal. I was so happy with the Jetta that my husband and I bought a 2002 New Beetle in December.
Thank you for any advice you can offer.
If you end up towing your VW to the dealer with a frozen or damaged engine and there is NO oil in it, you are going to pay the bill, not VW. You have got to come up with a system for checking your engine oil more frequently, and you also need to come up with a good way of recording the EXACT oil consumption level. Once you know what it is burning, you can have that recorded on a VW repair order, along the lines of "owner says engine burning quart every 1,000 miles--owner has checked this repeatedly".
That way, if a warranty or even post warranty issue comes up, you are covered. But with no oil in the engine, you are asking for trouble in making a warranty claim. As the owner, you are obligated to check the oil and keep it full, especially if there is no massive oil leak to point to as an excuse for engine failure.
I thought this would be the best place to bring up my topic. I have replaced the 2 rear window regulators on my car. I was told by the dealer that these regulators are typically used by VW, Lexus, Audi, Saab etc. and that they are known to fail.
Is this true? If so, has anyone heard of any plans to re-design the regulator?
Hope that helps. Good luck!
Good Luck!
I have a 2001 GLS VR6. It's been fantastic to me until 2 days ago. It appears that I burned our a brake light. No big deal EXCEPT that I no longer have turn signals. Well, occasionally I have a blink or two. They are erratic, inconsistent, and intermittent to say the least. Now I really hate the idea of taking the car to the dealer for a bulb (which I can certainly do myself) but I'm concerned about an electrical or multi switch problem. Has anyone experienced anything like this? It really seems stupid to me that VW would intentionally the system this way since it creates a driving hazard when you burn out a bulb.
Thanks in advance for your information and time.
Su
Or, it could be the beginning of the end. Get it checked out
I do want to change the bulb myself just to check. But I don't want it to mask the problem. The manual states the same thing as many other cars. When a turn signal bulb goes out, the signal flashes quickly. It doesn't mention anything about the brake lights, and after closer inspection, it looks like both sides have a failure. I never paid enough attention to the nominal status of the lights, so let me ask you. When you have your driving lights on, are both the upper and lower lens (above and below the turn signal) illuminated? Or is that just when you brake?
It's not a fuse or I would have lost all of the brake lights. Generally those systems are tied together and protected by the same fuse. But it could be that the switch is going. Otherwise, maybe some crazy electrical pulse went through and zapped the circuit. I'm thinking that there might be more than what meets the eye. I've work extensively on cars and bought this guy as a way to not have to work on every car I own.
Thanks again,
Su
And when no lights are on, just the daytime running lights up front, the turn signal/combo parking lights do NOT light up. Only the actual headlamp. Flipping the light switch to on turn on the yellow combo lights up front, all the red lights in back.
Something happened where both my lower brake lights do not illuminate when the brake pedal is depressed. But when the lights are on, the are illuminated.
So either I had one bulb go which could have caused a surge blowing the second or something else sent a surge which caused them both to go. Either way, that doesn't explain the blinker behavior. But as least it's problem solving progress.
Such a feature is listed in your owners manual.
And just for forum info, I did not have a burned out brake light at all. I have electrical problems which caused the loss of both the blinker and hazard functions. The cause is unknown at this time.
Su
Here is the answer guys.....
No, it is not normal for the VW engine to burn oil. They tried to reduce engine noise by putting in thicker rings. This reduced the noise, but the wider rings don't scrape the oil off the cylinder walls,(on the down stroke), as well as the thin rings.....It was a poor trade off.
That is the answer....the thick rings don't squeegy the oil off the walls as well as the thin rings. Makes sense to me.
I have a warning for any challengers to this theory...Unless you have spent 2 years dealing with lawyers, going to arbitration court, winning in court, placing 12 calls to VWOA, 10 trips to 2 different VW dealerships in different states, having the rings replaced in your Jetta engine, dealing with 3 service managers and 2 different VWOA Rep's., numerous letters and grief.....I would sit back and just smile at all of this.
Oh yeah....not that this means anything, but for you gearheads....Dr. Harry Andress, patent holder for Mobil 1, was my next door neighbor for 30 years in NJ. Wanna talk theories on oil? Let's all sit back and just smile....Yup YupOldBull
If so, I'm in the midst of a purchase of a VW Jetta wagon w/ diesel. I'd like to know the name of the dealer to gauge trust.
In any event, would love to know your opinion on Mobil1 for the diesel. From what I've heard, Mobil 1 is the best syn. oil around. I'm using it in all of my vehicles with no problems and longevity (about to trade in a Quad - 4 Pontiac w/ 144K on it).
Engines have to use some oil, especially if driven hard. Racing engines use plenty, for instance.
I think that using a quart between changes for instance is a perfectly acceptable manufacturing parameter.
Do you agree or ???
I highly suggest visiting www.tdiclub.com for more info. It should answer many of your questions.
VW TSB on oil consumption: http://www.springbreakdaytonabeach.com/vwtech/www.vwwebsource.com/vwtechcontent/vwpdf/v170101.pdf
You say that burning oil is normal, and I say it isn't. Your going to point out that some new car spec's might say that burning a quart in 1,500 or 2,000 miles is normal. I say it isn't.
Here is the answer again.....I sat with VWOA and now understand why some of the Jetta engines burn oil.
No, it wasn't because they were built in Mexico and someone got confused, and inverted the rings on installation.
No, it isn't going to happen on earlier engines.
No, it isn't going to happen on later engines.
Yes, it does happen on the engines that had the thicker rings to reduce engine knock.
Yes, they were built in Mexico
Yes, VW stopped using these rings.
No, the condition won't get better as the engine wears-in. Not sure if it will get worse....my guess is...yes it will.
You can't go by the book all the time. For instance, at one time GM had a 90 day warranty on new car paint. You mean to tell me that a new GM paint job will only last 90 days....not hardly. The spec's are written to protect the MFG....They write them! Wouldn't you do the same!
Pls. don't keep quoting that it is within the MFG. spec's to burn a quart of oil every 1,500 miles. Your are hiding behind skirts! I don't hide behind skirts....remember, I am the quiet
guy who watched this column for 2 years,(even before you arrived), while fighting a 2 year legal battle with VWOA, sued them, and won.
Now I talk.
There are over 1,500 comments here....most negative. How come?
I hope a contractor fixes your roof, and says that a quart of water dripping through your kitchen ceiling, is well within the Johns Manville specs. Be sure to follow the spec's....they recommend to dump the bucket every 4 days.
I am a preventive maintenance type....I found my problem with the Jetta engine at 3k, and watched it all the way through 42K. I kept a log and know the details exactly. I feel sorry for those that never checked, or buy one of these used, from a person that ran it dry. It is easy to do.
I bought each of my sons a new car....the 20 yr. old wanted a VW Jetta and the 22 yr. old wanted a Honda Prelude. The Prelude is fine.
Thanks to those of you that have written me for additional details. Pls. ref. the following in the archives:
#53 of 67 2000 VW Jetta Oil Burning....I sued them and won. by yupoldbull Nov 16, 2001 (11:18 am)
$2m is $2,000
You are correct "jabilda". Dr. Harry Andress worked at the Paulsboro, NJ Refinery for over 50 years. At one time, he was one of 7 senior research scientists, and he personally held 115 patents, including the one for Mobil 1. He was also a good neighbor.
Thanks Yup YupOldBull
At what point is oil burning "abnormal", is what I was driving at.
If you insist that ANY oil burning is abnormal, I must respectfully disagree.
I think some oil burning between changes is perfectly okay and nothing to worry about.
How much oil burning? I'd say anything up to a quart between changes would be fine.
Another problem here is that most people don't know exactly how much oil their engine is suing. They read comments like "any oil burning is bad" and their imaginations run wild with dread.
What I'd like to go on record as saying about this is:
IF
your car is burning oil between changes, and
IF
you have carefully tested this over the course of a few thousand miles and
IF
you have determined that the consumption approaches 1,ooo-1,500 miles per quart
THEN
this is probably not normal for a new car with under 50K-60K miles
BUT
an engine can burn a quart every 1,000 miles or less and run FOREVER.
AND
older engines with 60K++ miles might start using oil as they age.
So the oil burning may not be "normal" and you may want it fixed under warranty but it doesn't mean your car is going to blow up if perchance you don't get a warranty or post warranty adjustment.
Phew! I hope that clears up something. Thanks for listening.
"I went in for my 5,000 mile service and there was no oil on the dipstick! This car is a lemon!"
Well, now, let's consider that comment (not a real comment, but paraphrase of a few real ones).
As a dealer, or automaker, would YOU give a new engine to someone who hadn't looked at the dipstick for 5,000 miles?
Does the possible "defect" of oil burning allow the customer to destroy the engine from neglect?
I believe the lube plant is still there, though (correct??). I am a Gibbstown native and live locally.
Sorry to here about your VW. I just ordered a VW Jetta Wagon w/ the TDI. Any info. on them would be appreciated. I think the diesel (from what I've read) is a good engine - let me know if you know different. I'm a maintenance 'guy,' too and I never heard of anything 'using' oil, except maybe for a Harley and they (old ones, anyway) leak it out the base side gasket!!
Good to hear from a local.
justin....sounds easy to me also....no big deal....except for a couple of small items.
I added 21 quarts of oil (in addition to oil changes) in 42k. My engine light came on at 22K and that is only $140 (?) to scope and figure out the oxygen sensor is plugged with oil (?) And if the down- pipe (?) is coated with oil....you know that most of it is trapped in the catalitic converter (?) and that is bad also...and that is only $820 (?) installed. And now my new $20m car won't pass (?) the new PA emissions standards, normal inspection is $85, but for me because it fails, and has to be fixed....figure another 2 (?) trips to the garage and an additional $100 (?). Now because you still have the bad rings....plan on doing all this, all over again, at 80K also, and at 120k. I think I would rather have a puddle on my garage floor....or better yet....leaking all over the roadway. Makes it nice in the rain. VW would probably say that a 3" drip spot (per week) is within spec's and normal.
What if every car on the road did this? What ever happened to the concern over VOC emissions and our green earth? Gosh...this place would look like Russia!
Bad rings are hard to defend. I know VWOA didn't want to go in front of an arbitration court and try. I beat them.
I am a happy guy now....I got mine fixed!
#1592 of 1593 yupoldbull... by jabilda
jabilda Hi there. I went to PHS also. But it was Pitman PHS.....I come over from PA to vist your famous auction houses....Your town was booming in the 60's and 70's, and has really slowed down. The VW van was discontinued on the first try 8 to 10 years ago because it was under-powered....couldn't make hills. Hope they refit with more power.
#1591 of 1594 by Mr_Shiftright HOST
Yup, no one has the right to run an engine dry and claim defect. (tempting though) But if you lived the last two years like I have....being insulted and ignored by VW dealships and VWOA....You would be writing in here also. 21 quarts in 42k. Lets focus on that.
1593 of 1593 oil consumption by yettibutt
I enjoyed your comments and agree with all of them. I just don't like remembering to go out every week and a half, in 4 degree weather, at night, to put a cold quart of oil, in my son's new $20m car, while he is sleeping. Oh yeah....I forgot to mention the wind-chill part.
Yup YupOldBull
Too early to tell if it is fixed....They deglazed the cylinder walls and replaced the rings (n/c)....just 3 weeks ago.
I don't think it deals so much with degree of oil consumption....I think, unfortunately, it deals with who's lawyer has filed. They are aware of the problem, and rpm's and driving style probably has a little to do with it....but the problem is inherient. The dealerships and some VWOA rep's will tell you that it is normal....that's what they did with me....They even told me that it would go away at 15k....my butt. I knew that I had a problem at 3k with a dry dipstick....glad my lawyer filed at 10k. We won at 42K....18 months later. I watched this column for 18 months....Now I talk.
I don't have a problem with a few ounces of oil consumption between oil changes....but I added 21 quarts in 42k, plus normal oil changes....in a new car. Cut me a brake. And then the VW Service Mgr. and VWOA sit there and try to tell you that is normal oil consumption. Yeah right!
Now that the engine might be fixed, I still have the rest of the problems. Why are there over 1500 postings (mostly negative) for this car? Darn....No one wants to answer that question. They can't even make floor mats that don't rip out.
Yup YupOldBull
http://www.batauto.com/articles/brkfld.html
