The pollen filter is located under the dash on the passanger side. You can access it from the engine compartment. On the passanger's side there is a panel with a few screws right next to right (passanger side) wiper arm. Pull that out and the pollen filter is nicely tucked in there.
The spark plugs were a bit of a surpirse to me. Remove the plastic cover over your engine and there should be 4 (or 6) black square caps with what looks like an epoxy resin iside. Each has two screws. These are the spark plug cable connections. It was weird seeing these and no typical spark plug cables. I scratched my head for a few minutes before I decided, what the heck, maybe this is it ... and found out.
Eric
- Better acceleration
- Cheaper
- Better gas mileage
The only advantage of the VR6 is that it's smoother but it's not as fun to drive and I hear insurance is more.
kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I replaced my rear brakes that were completly worn at 42,000 miles. Front pads still had a good 3/8" on them, plenty good....and good thing cause they cost twice as much as the rear pads.
Darnest thing I have ever seen....typically, the front brakes of a car will wear almost twice as fast as the rear.
And I am sure it isn't because of the parking brake being pulled....Our 5 speed jetta stalls in first gear with just, "one click", on the hand brake....so it is something else. I am sure of that....
Yup YupOldBull
My current miles is 48,500 Miles, but I replaced my rear break's pads in 23,000 miles for the first time. I changed my rear break's pads around 36,000 miles for the second time and I also changed my caliper because people from dealer told me there is something wrong with my caliper.
Until now, everything is fine, but I feel my rear break's pads still worn too much, after I check it. So, I believe there is still something wrong with the break eventhough I already changed caliper. Is there anyone can help me? Any good solution can complete solve this problem. Thank you very much.
But I still have a question.
If I change my pades from factory parts to Mintex Red Box, will it fit for my factory caliper? Will there any problem if I just use Mintex for my original break system?
Thank you very much !
Here is link that states the rotors should be turned of replaced when installing metallic pad such as mintex. http://www.newdimensions.com/products/page_2.html
I would replace the rotors, they are not too expensive.
* The car burns oil rapidly between oil changes and requires maintenance
* My drivers side AND passenger side window fell into the door and after the secretary told me there was nothing they could do (mind you, it was raining and I had a 1 hr commute home) I had the manager help, if you call it that...I was charged $250.
* The sunroof is broken (its $85 just for VW to look at it)
* The Mass Airflow Sensor needed replacement at 40,000 miles ($550)
* There is a rattling in the passenger side speaker (dealer can’t figure it out but charges for checking)
* The dash board lights sometimes don’t come on
Please note that all of these problems are not due to misuse of the car...at one time I ran a car detailing business and I treat the car very, very well and have been disheartened by its problems.
VW service is horrible!! and the workers are very unsypathethic to any problems. Since its not one problem that recurs over and over I dont qualify for the lemon-law; a loophole if you ask me.
I will never buy a VW again.
Feel free to ask me any questions… jeffebay2000@yahoo.com
2000 VW Jetta
You guys just don't get it....go get a good lawyer....my car burned oil...and my engine light came on...and my car mats broke free...and my rear window defroster worked (all but 2 strands)...and my window dropped into the door...and my young VWOA rep. taught me how to read a dry dipstick.....the car looks good, but it is poorly built....
21 quarts of oil.....42,000 miles
My Homelite chainsaw gets better mileage!
Do you really want me to go on....I sued them and they paid my lawyer close to $2m and I got almost twice that....and I am still mad....go figure. Scroll back...and see previous articles....all 4 of them...2 years worth....and then they fixed my engine on a N/C basis....
Doesn't VWOA read this column? Do they care?
My lawyers webpage has a yellow VW on it! (Lemon Color?) Wanna see....Wanna bet?
Someone should write the US Consumer Affairs Division....let them read this forum (all 1600 comments) and then talk to me.....I will even post my name and address.....bring it on....no fear here! I don't hide behind the same skirts that our moderators hide behind!
Our moderators want to keep everything calm and not talk bad about the mfg. Oh well. Come on...talk to me guys....do you have to add a quart of oil every 3 weeks to your new cars....How about it MR. Shiftup....You want to hear from another 200 unhappy car owners? And after them...another 200! Get the picture yet! What ever happened to the experts that told us how to calculate "true oil consumption". Where did they go...anyway?
The rings are bad....go figure that experts!
Good luck guys....get smart, get a good lawyer, I won my fight.....just having fun now.....Yup
YupOldBull
That is simply not true. What we ask is that people try not to lather themselves up into vituperous rants that simply drive others away. You can be mad. You can hate your car. But you can't cuss, ramble, or deluge our other visitors with basically emotional information of no use to them.
Give the facts and you end up helping others learn what they need to know.
But I get very confused by Yup Old Bull writing 2m when he means 2k (or $2,000,000 vs. $2,000). I have to wonder about the credibility of someone who doesn't know the difference!
I also wonder if some of the problems people are having is with the dealer, not the car. Sure the window regulators from the 99's and 2000's were defective. Everyone knows that and VW replaces them for free. If your service guy doesnt know that or doesnt know how to properly fix your car, GO SOMEWHERE ELSE! There are many VW dealers with competent service departments, so perhaps these people should find one.
I haven't had to service my Jetta yet, but when I do, I'm going to make sure my service department knows what they are doing and honors the warranty, or I will just go to another VW service department!
I have the same problem with my Monsoon system. Richer, fuller sound on the passenger's side. I have to adjust the balance control to driver's side to even hear that side. I brought it back to dealer, and sales manager listened to it, and another Monsoon, and agreed there was something wrong. He's waiting to hear back from VW, to figure iut how to correct it. I e-mailed Monsoon company, and they suggested that the dealer perform a test with a Vag?? to make sure the amp is tuned to the Jetta's acoustics. It's annoying that I spent an extra $300 for the system, and it's not working properly.
I'll let you know if it gets fixed. Anyone else have this problem?
"But I get very confused by Yup Old Bull writing 2m when he means 2k (or $2,000,000 vs. $2,000). I have to wonder about the credibility of someone who doesn't know the difference!"
Yup, we have a credibility problem.....
In automotive terms k is commonly used to designate thousands, and typically used to refer to mileage...as in mileage 40k or 40,000 miles.
In business terms m is commonly used to designate thousands and typically refers to thousands...as in $40m or 40,000 dollars. Business folks don't use k for some reason.
Now, if you can grasp the above...mm is millions.
So when I say that my lawyer got close to $2m it meant...close to $2,000.00 and I got almost twice that... you do the math on that one.
Stop picking on an old retiree that spent his entire life in (both) automotive and business! If I flunk townhall, they might send me back for another 30 yrs. of re-training.
My company had gross sales of $42 billion when I retired. .....mmmmmm
Yup YupOldBull
It is a proven fact that if a person has problems with his new car, he will always rate the deaaler satisifaction level lower than someone who has had fewer problems, even if the dealer fixed all the problems. So most people who have a bunch of warranty claims usually hate their dealers.
They had mentioned once before about the ground being bad. However, have never mentioned it since....they acted as if replacing the CD player was the answer.
Has anyone else had this problem, and do I just feel like I'm being overcharged, or does this seem realistic?
My god...scroll back to say...1200... and read up to here, and you will have your answer. Live in this town hall for two years, and you won't have to ask that question. Look'em in eye, and say you will sue'em! That's what I had to do...scroll up for details!
YupOldBull
kirstie_h
Roving Host
Edmunds.com
In 1998 I pre-ordered a New Jetta GLX with 16in. wheels and sport seats as stated in the catalog. It arrived in May 1999, beautiful black, but no sport seats or 16in rims. Confused, I questioned the dealer, they said they weren't made yet.
Suspicious, I contacted VWOA, they said the rims and seats were being made for the GLX. I confronted the dealer, the dealer stood firm on their information. VWOA stood firm as well, one year and many correspondences later, VWOA finally admitted that they must not have made those features on the 99 new jetta. I lost my friendship with that dealer, since VWOA gave them many complaints.
Then the problems started within 7,000mi:
Drivers side window breaks off track.
Sunroof shade comes off track twice.
Temperature reading sometimes says -60F when its 72F.
Engine warning light illuminates half a dozen separate times, oxygen sensors need to be replaced, etc.
One time a dealer told me to ignore the warning light. Power seat knob sticks, keeps moving back. Brakes really noisy, dealer says "VW brakes are noisy, they last between 60-100,000mi, hmmm.
Recently, the warning light has come on again, my warranty has expired. After only 27,000mi, I wonder what it will be, and how much. I'm expecting it to be the mass air flow sensor.
I just found this forum, I used to think I was the only one with a bunk car (not enough to be a lemon though). I'm glad I found this place. Yupoldbull, you have some good advice. Thanks JB
Thanks JB!
Front windows falling off the track.
Temperature gauge malfunction.
Engine light malfunction.
Torn floor mats.
Untruthful VW serivce managers.
Oil burning engine with bad rings.
CD skips.
Rear brakes wear out in 30k....fronts are Ok!
Loose shift knob.
Loose steering....rack and pinion.
Broken sunroof.
Rear Defroster with 2 strands out.
Broken glove box.
Insults by VWOA rep's.
Unresponsive VWOA customer service rep's.
Yup!
Can anyone add to this?
How about it MrShiftright.....are we all making this up? Do you see this kind of volume with other car manufacturers?
YupOldBull
The Jetta wagon is manufactured in Germany, hence quality control should be at least at Passat levels.
I personally avoid Mexican "Engineered" VW's.
There is no valid reason based in factual data to say Mexican is worse or better than any other assembly point. My opinion is that anyone choosing Jetta Wagon because "it is assembled in Germany and has quality at Passat level because of it's assembly location" is in for a huge disappointment when they have similar quality to the Jetta Sedan. VW is having quality/reliability problems in Europe, I wonder if that is from Mexican cars too?
Like some on this post, I'm not looking for perfection, just longevity. Hell, I have a 1990 Pontiac Grand Am w/ the crap 4 engine w/ 144,500 on it. It had it's issues (blown ICU units, ate spark plugs, accessory belt change is a b----) but it 'got me there' and back. I'm hoping that the VW will last as long (I don't beat 'em, I maintain 'em), or until they bring the Passat over w/ a diesel. In agreement w/ Moparbad, I do not understand why the US doesn't receive SOME allotment of Passat diesels. I think (w/ the current state of the auto industry) diesel will be employed more w/ some integration w/ electric in the short term until some new fuel source is perfected.
Additionally, the US car manufacturers have diesel in Europe. If you go to the Jeep website in the UK, there are Cherokees that have 2.5l Detroit diesels in them. Why can't I get that here in the US??? I think that many people would love a Jeep that got good gas mileage and could really tow like a son-of-a-b----. Americans, IMHO, are being short-changed here. Also, (as all of you know) the diesel engine would 9 of of 10 times outlast the vehicle around it.
When Japanese cars became popular, like Hondas which would last twice as long, US manufactures lost major business since people wanted a durable, fuel-efficient car, one that would last.
We've contemplated a theory that since diesels have the potential to last many years, increasing the life span of a car, new car sales would decline even further for US cars, without a demand for a new vehicle.
It could be possible that American cars don't have diesels in order to ensure a future for US car manufacturers that rely on people purchasing cars often.
Or maybe they can't imagine a diesel Cadillac. Just a thought, JB
This is why I'm going w/ the Jetta TDI wagon. Pro's: The engine should last me 15 years (projected total mileage 200k). The asthetics are good enough. The safety is among the best today. Con's: The nagging reliability problems whcih I'll have to deal with. The back seat is small as compared to industry standards. The car is over small in size as compared to cars priced similarly, especially US cars.
The only two cents I recall chipping in was with the oil burning, when people were claiming that a quart every 2,500 miles was "excessive" for a new engine and I stated that from an engineering point of view, this was not excessive and not necessarily indicative of a bad engine.
My points were (so that no one puts any more words in my mouth!)
1. How much oil are you burning exactly and how do you know this?
2. Even if the oil burning is "excessive" by your standards or even VW standards this does not mean your engine is going to blow up.
3. Okay, your engine is burning oil then keep a record proving the rate of consumption (if YOU don't, THEY won't) , report it to the dealer while under warranty and send a file copy to VW, and then ask for warranty assistance.
I never, ever, ever suggested that the other problems mentioned, about windows and brakes, weren't happening. Why would I say such a thing?
What I don't feel is productive or accurate is the claim that engines aren't supposed to burn some oil. They are and they do, it's just a fact.
Also, rupturing your relationship with the dealer and the VOA rep by taking a highly adverserial position will make everything more difficult.
Cool and professional gets the job done with warranty claims.
kirstie_h
Roving Host
Edmunds.com
I just wanted to point that out so folks wouldn't be making a claim that is not reasonable.
YupOldBull
