They cost about 3x less, to around $60
velour
It's the velour material in general...while it's soft and comfy...it's a lint magnet, as you noticed. A lot of people (including me) use a lint roller to pick up the lint.
here's a reference I guess, for the price drop
http://forums.vwvortex.com/zerothread?id=516640
All work done in the last 60 days includes: air mass sensor, O2 sensor, 2 ECMs, spark plugs, all fuel injectors, oil changed 2-3 times, secondary air valve grounds reworked, throttle position sensor adjusted, fuel pressure checked over 24 hour period and advised to use premium gasoline and to allow car to idle 2-3 minutes on start up.
Needless to say nothing worked, after many phone calls to VW customer care, initiation of the TX Lemon Law process and a visit with the VW rep who happened to be in town this last time, much patience and prayer I received a call from the dealership on Friday telling me to come down to the dealership and pick out a new car.
Just for your information the representative from VW said the problem regarding the cold start is with the way the ECM and the secondary air valve communicate on startup. EPA regulations require that on start-up the 2002 VW 1.8 turbo has to meet exacting emission standards at the tail pipe. The representative stated that the engineers are working on additional software modifications to make the ECM work properly but these updates are only in the BETA testing phase and have not been approved by the EPA. Apparently, the EPA has to approve any modifications to ECM programming and this is not an overnight issue. The representative was quite surprised to learn that our car was exhibiting more than just a cold start problem on initial start-up for the day. He stated that if we were experiencing problems on subsequent starts throughout the day, which we were, that the fix from the engineers would not work and other causes should be investigated.
Please note that we not only experienced the starting problem but that acceleration without throttle input, flat spots in the acceleration, a high pitched “whrrring” noise/a burning smell from engine compartment and a feeling of “driving with the brake depressed” or driving against resistance” was felt. However I do believe that all of these problems developed as a result of the initial problem.
Be persistent, be patient, call customer service everyday the car does something wrong and have them document it, return it to the dealer every time it does something wrong, document everything and file with your state’s Lemon Law Act if the car meets your state’s criteria.
Good luck, keep us informed. I will probably get a 2003 VR6 in either Jetta or Passat. If I were not tied into a lease I would get a Chevy truck.
p.s. a "little bird" at VW advised to stay away from 1.8T platform, the 2003 may be worse.
Donna and Dale
And, just so you know, the Passat and Jetta V6s are not the same engine. So you might be better off with the Passat.
And Chevy had to recall all the trucks they made at first (full-size ones), because the engines were bad in them. They are alot worse than VW when it comes to quality.
So, what do you all have to say about VW's warranty coverage? Do they really stand behind their product or not. Are there a lot of exceptions in the fine print?
Thanks, Dan
02 TDI with 26k miles has been just about perfect.
Although the official warranty on most of the car ran out after two years, VW has paid to repair window regulators, rear seat belts, and a door lock control module - - AFTER the official warranty had expired.
I know a co-worker's rear brakes wore out (pads and rotors) at 34K. He bought the parts, and complained about having to replace them. I told him to talk to VWoA, and he did. He got the labor for free, but not the parts. He wasn't too worried about it though.
Now, he found the car might be leaking oil. They are running the consumption test on the car every 1500 miles, he said. He is tired of the problems with the car though, and he said he is going to sell it now. He said he likes it in one breath, and that he's selling in the next breath. It's his girlfriend's car, so it's not really his choice.
It's such a pity, because the Jetta is a really fun car to drive, but not own...
BTW, yes, it appears that VW is trying to improve their customer service. They repaired my wife's '97 Jetta window problems till the car's fifth year, then they started splitting the difference. I beleive the 7 year repair for the Windows is for '99 or newer.
So the reliability fell again? That's a shame.
A shame? No. That help keep them on their toes.
Expected? You bet. Haven't you been reading these boards?????
If I were deciding now, I would not do so. (My car is very new and has been mostly trouble-free, except for an EPC light and some emerging rattles in the dash. But I'm scared for the future.)
The CR report had decline in reliability for Camry and Altima that people have so much reliability praise for. You are left with the Accord which is a brand new design and they usually always have problems.
It appears 2001-2002 is the period that build quality of the "big 3" Japanese companies went right out the window. If I had a dime for every squeak, creak, and rattle I had heard about in new Nissans, Hondas, and Toyotas, I would be a very rich man!
My '03 Matrix is certainly no exception...
The current Jetta is in it's FIFTH year production run. You would at least think that they would get rid of SOME of the more well known problems outside of the power window regulators!
Come to think of it, the recent drop in quality coincides with the Jetta build dates when the Puebla plant was in bitter renegotiations for their yearly contracts. Coincidence?
I wonder if the Beetles also got a sudden spike of problems as well...
I am glad you have had a good experience with VW though.
This evening I noticed that the lights on the three climate control knobs, just below the radio, did not come on when I turned my interior lights on. I was wondering if anyone else has experienced this problem? Or if you know how the dealer fixed it? I have the 2002 Jetta
1.8T. Two weeks ago my radio stopped working (which has since been temporarily fixed by the dealer). Is the problem with the climate control knob lights related to the radio trouble and another fuse problem? Any suggestions would be much appreciated.
I guess I will have to make another trip to the dealer.
Highway mileage is about 25 mi/gallon and rattling noise in front doors when you drive over the bumps.
The answer from dealer (Ryedel in Edison NJ) for the first problem was that promised 30 mi/gallon can be achieved under ideal condition – driving 55 mi/h on a straight road without any wind. So if you driving from Boston to NY at 65-70 mi/h 25 mi/gal looks reasonable for them.
The problem with noise exposed much bigger problem. They sad, that problems like this do not covered by bumper to bumper warranty. The so name “adjustments” are covered only for 1 year or 12,000 miles what ever come first. It opens every job you need to do while under warranty open for discussion. For example if any part of your car is not working but can be fixed without replacement parts – you are responsible for repair cost. What a great idea - to benefit from the poor assembly quality.
I had Toyotas before and while under warranty all problems were fixed no questions asked. The dealer who sold me a car is claiming that he never heard about such a policy, but their service department as well as VW itself is well aware about it.
I hope that public awareness about this outrages interpretation of warranty either force VW to change their police or will affect their market share enough. One customer is lost for sure – it is my last VW. I can not deal with a company that engages in such a deceiving policy. Who knows what else in the small font at the bottom of their documentation?
If you use regular, knock occurs, and the ECU will retard the spark timing, possibly decreasing performance.
Have the dealership check the ECU for any codes also.
If you had the 2.0L motor, then the mechanic would be pretty much correct.
Way to go VW, they really understand the meaning of the term "Customer Satisfaction".
I've never had problems with the factory radio. However, earlier this year (summer) I replaced the factory radio with an aftermarket radio/CD. Before then, it worked flawlessly.
Hope that helps.
How old was the car?
min
In response to the person who said the VR6 lacks power above 70 mph.....I would have to disagree. Do you ever cruise with it above 80 mph? This engine does have variable valve timing and I do agree that between 65 and 80 mph it feels a bit sluggish, but thats because you are carrying the rpm (around 3000 rpm in a 5 speed manual) that is right before the change to the more aggressive valve timing and lift. I drove my Jetta to Washinton State and back to Va. last year and believe me, it has power in the upper ranges. The VR6 Jetta (12 valve) LOVES 80+ mph. I cruised across Wyoming at 3AM at 100 mph for almost an hour. The car had PLENTY of power. I even did a couple of "bursts" up to 125 and it pulled nice and strong.
To Ik4sp.....while under your "bumper to bumper" warranty your dealer should look into and fix (with or without) parts any problem you bring to their attention. FREE OF CHARGE to you. That's what a warranty period is all about. It sounds like you have a dealer that is less than honest. Do yourself a favor. When VW calls to ask you about your experience with this dealership give them all 1 (worst) ratings. And tell them why. These calls from VW KILL a dealer when they are negative. It affects the dealer's rating with VW, and it also effects which cars they get and when and also whether or not they remain a VW dealer or not in the long run. Even if they are a high volume dealer it will still effect them.
My car has 30 K on it now and thank GOD I haven't had any of the electric or rattle problems I'm seeing here. In fact it's been great. But I have noticed that the rear pads are wearing MUCH faster than the fronts. They are about to be in need of replacement. Also, they of course make my rear wheels much dirtier than my front ones. I went to :
http://www.alldata.com/TSB/0162_mo.html
And found a recall on my car for the ABS control unit. I believe this may be a source of my wear problem.
1. RECALLWJ MAR 02 Recall - ABS Control Unit Replacement
My advice to anyone here is to go to this site to look up your car. It may be helpful to you.
