The fuel filter has absolutely nothing to do with P0420.
First thing to check: spark plugs! Then ignition coils, then fuel injectors. The condition of the spark plugs may be a pointer to other problems. Also check the plug wires.
Did you do plug readings on the spark plugs you pulled out? That may have pointed you right to the problem.
Coil packs are a common problem of the VR6 cars. Spray some water on the coilpack while the engine is running in the dark, and watch the sparks fly! They commonly crack on the lower part of the housing.
It is possible that the coilpack is cracked. You could replace it for $200 or whatever they cost, or just pull it and mend the crack in the plastic housing with JBweld. $2 fix. Moisture gets inside through this crack and shorts out the ignition coils.
max
There's a special security code that you need to activate the radio. There should be a pamplet specific to your radio in one of the sleeves of your owner's manual with the instructions on how to reactivate your radio.
For the radio code, you will need to go to the nearest VW dealer and they will look up the code based on the radio's serial number and your vehicle's VIN (they usually have to remove the radio for the serial number). Once you get the code, simply follow the instructions in the radio guide for the procedures to take the radio out of safe mode.
I know this may be a pain, but in the previous version of VWs (before 1993), the radios were very easy to steal (I wish they had this feature in my 1987 Golf - my radio got ripped off).
Thanks!!
Thanks for clearing that up for me. This is the first time that I've had a car with no dipstick. One thing that I still dont understand is how do you check the fluid level? Thanks for helping me clear this up. This is my first VW, as I am sure you can tell. :-)
Thanks again!!
My 99 Jetta is having trouble with the climate control. I believe it is wiring related.
Does anyone know where I can get an A/C heater control wiring harness for a 99 1/2 Jetta IV ? ? ?
BTW - my car has the mysterious spring under the driver's seat as well. Anyone know what it is? :confuse:
Also, I have been told the ooze leaking from the doors of our Jettas is stuff they injected into the doors for shipping purposes. I was told no harm there - just messy. :P
Perhaps it is time to have the xmission serviced. 80K miles is a long way for an automatic xmission to go on the same fluid.
Anyone have any ideas what to do to fix this?
Joy
To fix it, just open the owners manual and find the radio section. There should be a special tag with the code # you need to key into the radio to make it work again.
BTW: That radio tag may have been removed and placed in a safe place away from the car. (It is not very secure to keep the code inside the car.)
If you cannot find the tag -- then you need to get the serial number off of the radio and take that number to a VW dealer so they can cross-reference it to the code you need to key in.
1997 VW Jetta, GL
The car died 2 months ago in a puddle. It started within 30 minutes. The engine light came on and stayed on, within a few hours and a few starts later it shut off. I was told to replace the ignition coil.(by VW) So i did and since no problems, until today. I went through the car wash and needed some help getting out. My money pit decided to die in the carwash. AAA came and took me home. It hasnt started since, Its been 8 hours. what now?
Interesting and ditto experience with a 1996 Jetta. "must be spark plug wires, we will replace distributor cap and the sparkplug wires". Seemed logical. Next puddle, Check Engine light, car died. 5 minutes later, started again. "Must be the coil". Sounded logical. Slushy snow on interstate and 10 minutes down the highway car died. After sitting in mechanic's yard overnight, started right up.
"Do you know the WD-40 and water bottle trick? WD 40 displaces water so start spraying on your wet wires. Wires not wet, run the engine & use a spray bottle and selectively get those wires wet," from an old bug hippy. "Engine starts to go rough, there is the problem wire, wire harness or what ever." Why don't those dumb mechanics figure that one out? Well 10 quarts of water later, sprayed at every wire, engine never stuttered.
"What does your check engine light say?" Evident the going rate is $35 to read it with an ODBII reader and to turn it off. It goes on before the engine dies. Mine stays on. 3 times it said "Miss fire $1cylinder". Decided to leave it on, then last week I bought an ODBII reader on Ebay for an Audi/VW/Jetta for under $40 delivered. Easy to use, got rid of the Check Engine light and learned myself that "Miss fire #1 cylinder" was the only event in its little memory.
I did notice that when I accidently nailed the "new" #1 spark plug wire with an errant stream, it started visably shorting along the rubber near the end.. Don't know if that is normal and just might be a problem.
I have started slowly renewing the wire harness coverings (not the hard plastic type) with liquid electrical tape. I am making sure where the wires emerge from the harness are sort of resealed with the goop. Trying to be neat.
My next moves? Pray for no rain of course but carry WD 40. Carefully clean up the grounds (first find that special radio code). Start looking at places where the water might be driven into the body where the wires disappear. Carry my ODBII unit and see what happens the next time my check engine light comes on. Replace the #1 sparkplug wire again. Hope someone else in the forum can come up with something for me to try.
Electrical problems are always horrible, especially the intermittent kind.
My daughter discovered a big puddle under her car (she paid for it) about a month ago having driven 40 miles.. Local college town garage said must be the rear seal and you need to replace your clutch - $1500. Decided if we were going to bend over, I would rather do it closer to home. Dye in the engine revealed a rocker cover seap, nothing from the rear seal, in fact no leak at all. I was feeling pissed at one place and happy with the other. Daughter lost all faith in Jetta, so now I am driving it and she has my Honda.
Then my wife drove it and I discovered about a quart of oil dump after she idled the car while talking to me. So my trusty american car mechanic said "head gasket, rear near #4 cylinder. And yes the oil sensor was leaking a little oil but I could not find one in town." But if it is a head gasket, why no oil in my antifreeze, why no antifreeze in my oil? I got the impression that the oil sensor could not throw out that much oil in so short a time.
I continue to drive the car to and from work 15 minutes, 12 miles each way. No oil leaks on the cardboard under the car at home for last 3 weeks.
Two cans of Gunk and my trusty spray bottle (see my posts on electrical problems) cleaned up all the new and old oil from the engine. Took my time, over 3 days hour or so each day. Not super show car clean, but wiped down with newspapers, scrapped nooks and crannies with a wooded stick. Engine block, head and pan has no oil on the surface and a paper towel comes away pretty clean..
Drove it 25 miles 50 to 65 MPH up and down hills. That is when I saw the sheen of oil. Nothing from the back side, comes from the front. Oil Filter does not have a drop of oil on it. Rubber boot on oil sensor has oil inside of it (a little).
Removed what I think is just a shield attached to the manual transmission, maybe clutch, because it continued to drip stuff. It had oil pooled in it along with water and Gunk. My paper towel said there was no fresh oil higher up in the cavity, just the normal black "road film". This would be where the rear seal is and I agree with the dye guy, it does not need to be replaced yet. I am looking along the head gasket and not seeing oil.
My next moves? Got to go to the big city in my Honda to an event. Will stop by the VW dealership and pick up a new oil sensor. I will have my american mechanic replace it. Then I will drive the car up the Mt Washington Auto Road and see if it leaks oil.
Sometimes this forum gets a little heavy. I will keep you posted.
Thks
For sure you got to replace that hose and dry things out, again. However if you are 50 miles from civilization and that hose has pressure, then your ducktape needs some help. Sometimes creative hose clamp work (2 or more of the screw type), with some sort of pad over the hole/split can act as a stronger finger in the [non-permissible content removed] than ducktape. The engine has to get dry and it would be a shame to get there (forever the optimist) and then have the temp repair get it wet all over again.
Sorry I could not be of more help
My Jetta GL 2.0 starts normal but after 15 minutes it stops running. I let it sit for about 3hrs and it starts right up, let it run for 15 minutes and it stops running.
I replaced 02 sensor, spark plugs and wires (had one bad wire) and several people told me it sounded like a bad ignition coil so I replaced that and it still shuts down after exactly 15 minutes. Also after the car shuts down I checked to see if there is power going to the coil and there is. Thanks for any help you can give me!
How long have you parked the car before started up last time? If it is within 8 hours, I think there is no problem. The only way you want to enlong the battery life is not to lock the car (set the anti-theft alarm on) after you park the car meanwhile before you fix the car at dealership.
There are a number of features that can be enabled/disabled like:
"to beep or not to beep" when locking/unlocking.
Flash lights or not when locking/unlocking.
automatic door-locking once underway
automatic UNLOCK when key removed
remote unlock ONE or ALL doors with specific pushes of the button
...etc many others.
1. The 'Check Engine Light' keeps coming on, and it stays on for 1 or 2 days and goes off.
2. Upon starting the car, it moves in a jerky motion for some time before returning to normalcy.
3. The EPC and the ASR lights have come on a couple of times, and the car has lost power. Upon re-starting the car the EPC and ASR lights did NOT come back on and the car seemed to work OK except for the jerky motion.
I've taken it to a shop which I found on the AutoZone website. The mechanic performed the Scan and then ran the Diagnostic ($75). The error code he came up with is P1142F (I think) and is related to 'Load Distribution / Disbursement?' and 'Air Flow / Mixture?'
He thinks its the "coil" that needs to be replaced ($450) and/or the "wires" ($200). Does this sound reasonable or am I not going to get these problems resolved even after spending all this money? Please advise.
With engine idling, spritz water on the various ignition components. A cracked coil or leaky wire will immediately "show itself" by making the idle get rough. Theroretically, you should be able to HOSE DOWN the engine with a garden hose while it is idling and it will never miss a beat. (dont try it, you can crack the block whith cold water on a hot engine)
If the problem is the coil, you may wish to try removing it and sealing any cracks with hi-temp silicone RTV. It is worth a try.Just yesterday, I pulled the ignition coil from my daughters Golf and bathed it in hot-soapy water. After a good scrubbing, rinsing and drying, she is happly driving her car again. (She too, was experiencing a cylinder not firing due to ignition system leaking high-voltage)
It it is the wires, I often have been able to "revitilize" them by removing and thoroughly cleaning them. (grit on the wires/connectors can cause leaking of the hi-voltage when they are damp.)
I found that coil for your 2001 VR6 for $265 and the wires for $93.45 at
http://www.germanautoparts.com
The fuse box has symbols and numbers but I can only make out a few of them and I have no idea which ones need replacing.
Need Help!
Garage was able to get a diagnostic code, but it proved too generic to identify the exact problem (something re. engine rpms, if I remember correctly).
Our mechanic suspects the problem could be the coil pack, but is not certain. Before blowing money on what could be a needless repair, would welcome any advice!
I have always wonderd how automible repair shops would change their ways and show more competency if THEY had to pay for all replaced parts that turned out to not fix a problem.
You could always get a coil-pack from a salvage-yard, the parts from there are cheeper and often much more reliable than new ones. In the world of industry, a fully-tested replacement component costs MORE than a new one that has never proven itself yet.
One for the humans. Thanks for the good thoughts and advice on similar problems on this forum.
Rainy day so took the Jetta for a spin. Feel it miss, check engine light started blinking, then came on full. Pulled under a bridge, popped the hood, sprayed WD-40 on distributor cap, where I saw some water splashes. Ran it through more puddles, started to miss again. Looked, really hit the distributor cap. Hit the sparkplug wires where they went under the hood seemed to run better. OBD code said #1 cyl missing.
Then a visitor from NJ came out and we started talking about what was going on. He has a 1995 Jeep which he maintains. Any I told him abour the sparkplug wire, he said probably not normal. I got out the spray bottle, adjusted it to a very fine mist. 1/4 spray and it started sparking . We could see where it was comming out of thewire, just above the shield.
New theory, steam from the engine creates conditions where it starts to spark. Why it started sparking there is a mystery. Guess I better replace just that wire, if possible.
A little closer to man over machine on this one item.
