2017 Ford F-150 Lease Deals and Prices
MichaellMichaell Moderator Posts: 269,547
edited September 2017 in Ford
Ask your 2017 F-150 lease questions here! Get info about prices, money factor, deals, incentives, and payments.
«13456715
  • avianohomeavianohome Member Posts: 9
    Are the Res and MF rates out yet?
    Mf and Res for a 2017 Plaatinum Supercrew 4x4 in MN. 36/10.5 and 24/10.5
    If your do the 1 payment upfront - does this lower the MF?
  • MichaellMichaell Moderator Posts: 269,547
    24/10.5 - 66% and 2.50%
    36/10.5 - 61% and 4.00%
  • gator00sigator00si Member Posts: 61
    2017 XL and XLT SuperCrew 4x4 in TN. 36/10.5 and 42/10.5. thank you!
  • kyfdxkyfdx Moderator Posts: 273,469
    edited November 2016
    4.00% APR and 61% residual for either trim, for 36 months.
    Don't have 42 month numbers.
  • matt_uktxmatt_uktx Member Posts: 13
    Can I please have residual and MF for the 2017 F-150 Raptor in both SuperCrew and SuperCab. Thanks! This is for 36 Month 36K miles
    SuperCrew - 60%
    SuperCab - 58%
    What state? MF numbers are regional.
    SuperCrew - 60%
    SuperCab - 58%
    Houston, Texas please.
    matt_uktx said:
    SuperCrew - 60%
    SuperCab - 58%
    Standard MF, which is around 5-6%
    Hi, what's the residual and MF on the 2017 4x2 and 4x4 F-150 Limited in Texas. Thanks!
    What cab style?
  • morgan1474morgan1474 Member Posts: 14
    Do you have residual value and money factor for a 2017 Supercrew Limited model in 4x4 for southeastern PA. Also do you see what/any rebates are available for this model too? Both public ones and X-Plan rebates?
    Sorry forget to mention this is for 10,500 miles and either 24 or 36 months.
    No incentives on the SuperCrew.
  • msnelson2msnelson2 Member Posts: 6
    can you help with a 2017 F 150 Lariat Supercrew 4x4 with 3.5 L Ecoboost MF and Residual in Colorado? 3 years 36k
    60% and 5.00%
    New month now. Anything change for a 4x4 Supercrew Limited model for 10.5K miles and either 24/36 months in zip code 18944(PA). These lease rates are really bad right now for these trucks. 5%...!?
    The Ford program is scheduled to run through the end of the year. They might update it, but they may not. Residuals will not change. Those are definitely locked in for the quarter.
  • reese917reese917 Member Posts: 11
    2017 XLT supercrew 2wd, 36/15k, Louisiana, thanks.
    56% and 5%
  • salslddsalsldd Member Posts: 3
    What is the money factor and residual value for a 2017 Ford F 150 Platinum Super Crew 4 x 4 for the month of December, 2016 in Texas?
    4.00% APR and 58% residual for 36/15.
    What about 36/10.5? Also, is there a RV for 7500 miles?
    Add 3% for 10.5K/yr.
    I don't think Ford does 7.5K/yr
    Thank you!!!
  • potstillpotstill Member Posts: 26
    Can I please get MF and Residual in CA for 2017 4x4:
    F150 supercrew Platinum shortbox 3.5 V6 (and V8 if there's a difference)
    24/36 month--15K
    24/36 month--15K
    24/15 - 63% and 3.50%
    36/15 - 58% and 5.00%
    thank you
  • jared_m_hjared_m_h Member Posts: 10
    Can I get the MF & residual on 4x4 XLT Crew Cab 10.5k/3yr in South Dakota?
    4.00% and 61%. No lease cash.
  • jcat009jcat009 Member Posts: 28
    edited December 2016
    Looking for numbers on 2017 Lariat Crew Cab 4x4 36/12 and 36/10 in RI. MSRP is $49,855, selling would be around $43k, looking for zero due numbers so that i can calculate adjustments on my own and sanity check what I get from the dealer.
    60% or 61% and, we think, 4.00% MF (we don't have the specific MF for RI)
    Would need to know the adjusted cap cost, with all the fees and such added in, in order to calculate a payment.
    Thanks for the quick response. Let's assume a total cap cost of $46k, which I think should be doable.
    $574/mo, plus tax, with your prices, for 36/12
  • ejendz24ejendz24 Member Posts: 19
    Could I get the MF/Res for 2017 F150 supercrew XLT 4x4 in MN (36/15k)? Thanks!
    Also, I'm new to leasing w/ Ford. It seems these numbers only change quarterly and are also state-dependent. Is this common for Ford? I've only leased imports.
    58% and 4%
    Ford has 50+ regions, each with their own set of numbers.
    The residuals change quarterly but the MF/Incentives can be updated each month.
    58% and 4%
    Great! Thanks for the help.
  • joshthenursejoshthenurse Member Posts: 9
    Looking for numbers on a 2017 Ford F-150 Lariat Supercrew 4x4 with the 502A package. 36 month/12,000 miles per year, $0 down. Dealer saying MSRP is $54,000. This is in Connecticut. Thanks!
    60% and 4%
  • houston713houston713 Member Posts: 4
    MF for Texas is a hard number from Ford? There's no negotiating to say something like .00084?
    Anything change now that we are in a new quarter? Looks like something changed for the good as the lease payment on Ford's website is lower. What is the MF and RV for 2017 F150 Limited 4x4 Supercrew in Southeastern Pennsylvania? Thanks.
    and at 24/10.5 and 36/10.5
  • psl25201psl25201 Member Posts: 7
    Good evening. Would appreciate guidance on the MF and RV for a 2017 F150 Limited 4X4 Supercrew in Omaha, NE. Looking at either 10,500 or 12,000/yr lease for 36 months. Also potentially interested in Lariat as well.
  • scruffy222scruffy222 Member Posts: 34
    Looking for residual and MF for:
    2017 4x4 XL crew in Ohio
    The APRs we quote are the base number. That's the lowest for top tier credit.
    1.75% APR and 64%/59% residual
    $500 lease cash
    1.75% APR and 59%/58% residual
    $500 lease cash
    1.75% APR and 56% residual for 36/15.
    $500 lease cash
    Hello Ky,
    I spoke with Ally Auto. They finance leases for many dealers around Houston and said top tier credit was 0% With a credit score of 746 I should potentially qualify for a 0% MF correct?
    edited January 2017
    Hello Ky,
    I would think so. Our quotes are for Ford Credit.
  • bigblockc3bigblockc3 Member Posts: 184
    Hello, just beginning the research. Looking for an MSRP of $45K to $55K. Ford advertises 24 month leases (which I assume is their best term). To narrow the search, can you please tell me which trim levels leases the best for 24 months with 10,500K per year? MF (or rate), RV, etc... Also, the vehicle will be registered in NJ; however, the dealer may be out of state (VA most likely) / Does this effect the #'s? Thanks!
