There is really little or no cost to using the appropriate synthetic oil. Oil changes do cost about twice as much, but are only required about half as often.
I will try to touch on some of your questions
*) The waterpump MUST be changed when the TimingBelt is changed so it better have been changed at least once by now.
*) The temp guage on 2000 model year is KNOWN to be a problem. If your temp-sender is not GREEN... replace it with green one. Available here for $15 On the 2.0 engine, it is very easy to replace. I have done it in the dark in about 15 minutes with my daugher holding flashlight.
*)The rough running is either caused by
1)Ignition system
2)Fuel injection system
Since the ignition-system has been looked at, I would suggest having the fuel-pressure checked. Also consider that an injector is failing when it is hot.
As for the door lock / alarm system. There are some micro-switches in the door which may be malfinctioning. If the alarm-system does not "sense" that all the doors are closed/locked, then it will not arm.
A power wire is shorting out somewhere.
It may be that a wire for the headlight under the dash is crossing over to the heater control or the heater control is shorted over to the headlight relay.
Does the heater control allow you to set low, medium, and high?
Take to an electrical expert.
The extra cost invovled in searching this down will pay for itself in time spent by the expert rather than by an unseasoned mechanic poking around.
Unless you can visually see the shorted wires under the dash with a powerful light source.
Just had a customer with brake lights always on. Turns out the wife kicked the brakelight switch with her pointed shoes and broke it in it's housing. Since it was not in the housing the plunger was always out sensing the pedal was being depressed.
Pray this helps.
Or the connections to activate the valve.
Or a blocked heater core.
Or blender door.
If you mean some of these cheap kits on eBay to "upgrade" to Xenon, etc.---I'm pretty skeptical, as you can run into ECU problems.
http://www.autozone.com/R,1224987/vehicleId,2638104/initialAction,partProductDet- ail/store,796/partType,00044/shopping/partProductDetail.htm
The only SURE way to get better nighttime vision is to install the ecode (European) headlight units which are designed for improved nightime vision by way of better-focusing of the light.
There is no coolant loss that I can see. the coolant level is constantly where it needs to be. Often water in oil has this sign. The miles are all stop and go and it never gets on the highway. My 2001 E430 gets this foam under the oil cap some times, but I do not notice it to be as bad as Jetta's.
The oil changes are normal and on time at about 3K miles.
Joe
In contrast, on a 03 Jetta 1.9 TDI pushing 114,000 miles. Oil consumption is at 1/4 to 1/2 qt (8 oz to 16oz) per 20,000 miles. This presents a dilema to going to a 25,000 miles OCI.
Does one just change it out @ 20,000 miles, i.e. do not add as it (1/4 to 1/2 qt. 8 oz to 16oz) is still in acceptable ranges. Or does one top up and go the extra 5,000 miles.Of late I just top it and go to the full OCI.
If the entire valve train is covered in this goop, you have a serious problem. If it's pretty clean in there, then the little bit of foamy stuff is just normal condensation.
In other words, you can't make a judgment about this issue merely from the oil filler cap. You have to dig deeper.
So for example at 100,000 miles (in addition to the TB/WP R/R and Vag.Com tune) my concerns were three fold: 1. visual camshaft wear 2. intake/egr clogging due to use of NON ULSD fuel 3. Sludge formation. I had swagged before the procedure little to NO camshaft wear 2. slight intake/egr clogging 3. no sludge formation. The news was better than swagged: 1. original tool markings on the camshaft 2. no clogging at all 3. no sludge formation at all.
If I was so concerned, I would do the UOA BEFORE; so you can see if the spot UOA has predictive value. The subsequent visual inspection will confirm or deny what you and or the technician think or may have projected. My SWAG is no harm no foul. BUT.... if not, remediate and....
Then I would do one to 2 UOA's AFTER: to check on the trendline.
I have also read in passing that 2.0 and 1.8T engines are prone to coking (by product is producing sludge)
So if you dodged the coking (aka sludge build up) bullet and the UOA/s indicates normal wear metals progression, indeed your 700 miles per 1 qt may indeed be normal.
When i turn the key i have power and the lights come on but nothing else happens
New starter, ignition coil, battery, and battery connections, new distributor cap.
all my fuses seem in working order. When i touch the starter bolts together with a screwdriver the starter teeth turn with a high pitch whine sound but does not turn the engine.
Ive checked every electrical connetion that i can find and everything seems tight.
anybody got any suggestions???
If you have manual xmisison, suspect the switch on the clutch pedal "thinks" you do not have the clutch pushed.
The wiring harness in the drivers door!!.. if you take off the rubber boot that protects the wires by the door hinges you will find one of more wires that are broken... I had a total of 12, 8 of which the previous owner tried to fix with butt connectors... the wires get wet or move apart and the alarm system arms itself and the window rolls up!!!
I messed around with the remote to disarm also cause it also locks the doors
To temp fix it reattach all the broken wires.. and a perminatley fix, replace the whole harness for about 200$
Why would you think the two were connected?
Oil is to the engine what blood is the body.
Adding more blood to the body would not make your hat not protect you from the rain.
The airbag light signals that something is amiss with the airbag / passive restraint system in your car.
A sensor has determined that the airbag might not deploy as it should.
That should be handled by a professional.
Since the airbag can be deployed by accident when not needed and cause injury or death.
Please read your owners manual for precautions.
Most cars must have the battery disconnected for at least 2 or more minute to make sure the airbag is not deployed while working on any part of the passive restraint system.
An engine with too much oil may have that oil foam inside the crankcase and therefore cause damage. Remove the excess oil.
Pray this helps.
If so go to Autozone and have them read the codes for free.
The can give you a list of probable causes.
It may be that the Oxygen sensors are sending a signal to the engine computer sensing a lean or rich mixture. Then the engine is not going to run as smooth as it should. With the exhaust system compromised this surely could happen.
Or if so equipped an idle air control valve could have become inoperable causing the engine over speed.
Pray this helps.
I am assuming you are using the oil-sucker method to change your TDIs oil so sucking it out is very easy.
But...that isn't my only car troubles...
My car seems to be going through a lot of coolant and oil. I don't know exactly what the normal usage is for a 2000 Jetta 2.0L, but yeah.
Since you're losing oil and coolant, and since it's a Jetta, I think before I replaced the belt, I'd pressurize the cooling system and check for head gasket leaks, and also remove the valve cover and possibly the oil pan and check for engine sludge.
No sense putting new parts on a bad engine. You need to start digging here.
Also, your 2000 2.0 is KNOWN to consume oil... this is not a problem unless you do not keep it topped up.
To answer your original question... replacing TimingBelt also entails replacing idler-pullies, tensioner, waterpump and anything else that touches the belt. This is not inexpensive.
According to the VW website, your 2000 Jetta 2.0 has 40,000 mile TB replacement ... I assume you replaced it on-or-before it was due so this leads to the conclustion somone DID NOT replace all the necessarry components at 40K miles. (Those other components WILL NOT last to toi the next TB replacement!)
Do you have recourse against whom may not have done the TB replacement properly?
Gates suggests 60K mi replacement interval
http://www.gates.com/brochure.cfm?brochure=2256&location_id=3487
thanks so much!!
Bryana
HOWEVER: Replacing this is not likely to resolve your musty/stinky smell. That is caused by mold growing on your AC-evaperator. To fix it, there are some "sprays" which you can apply to kill the mold.
To keep stink from coming back, be cognizant about how you use the AC and be careful to blow enough air to keep the AC-evaperator dry as possible.
HOWEVER I have also heard that the initial buy on the jetta is cheaper than other midsized cars. So our main questions are is the Jetta high maintenance, meaning do they break easily? What are the facts on VW parts? How do the maintenance costs compare to the other cars explained? Which car would be the best buy out of the ones explained, best price, most durable, best gas mileage, etc.?
Happy birthday (soon) and have fun!
Honda Civic is reliable and if you take of the car and don't trash it, resale value is exceptional when you are ready for another car in 2-3 years.
You may be able to get a new one a lot closer in price to a used one that you think. People often think...new cars are FAR more exepensive. With some 150 days supply of Civics ( some US models are like 280 days), this is a true buyer market. The average daus supply of auto used to be 60 days.
If you decide to go with a used one, check autotrader.com for a used Civic in your area.
Joe
if you have not already, sit in each car and drive each of them that you don't reject based on that. I would think this would narrow the list down.
Take a look at a used Jetta at a VW dealer. VW has a "PreLoved" warranty on many of their used cars. It is for 2 years/ 24 months and covers most of the car. This would take away some worries about the cost of repairs.
Over the years, I have learned that if you don't love the way the car drives and responds to you, ultimately you won't like it. Get what drives great and you will be happy!
Good Luck.
Bel Air Car Guy.
do you guys have similar experience with that? i am really concernd about the car. i know it could be a small problem or indicates big problem of the car. should i also replace the wire that connect the spark plugs?
Something new might be wrong now.
If it is the same code then it might be the wire associated with that cylinder where you changed the spark plug.
Try using a fuel injector cleaner like "Lucas".
Just in case the injector (if you have them) is dirty?
If another code comes up then it may not be related to the spark plug issue but a new issue.
Please relate the code you were given.
Ask for a printout.
- P0301 (Cylinder 1 Misfire)
- P0140 (O2 Sensor)
- P0341 (Camshaft Position Sensor)
- P0134, (O2 Sensor) and
- P0141 (O2 Sensor)
I've never known my car not to have Camshaft Position Sensor issues, so I can probably assume that one's not important. My CEL has been on for almost all of the time that I've owned my car, but the other day it was flashing when my wife drove it.
I'm headed towards picking up an ignition coil, wires and plugs and going from there. Whaddya all think??
Thanks in advance! :confuse:
If the ECU gets bad signals from the CPS, it could misfire a sparkplug and thus allow raw fuel into the exhaust (causing O2 sensors to misread due to overload of raw fuel in the exhaust).
Using the troublecodes, you need to now interperet the readings and reduce them to a common problem. HOWEVER - since you claim that you have not been keeping your engine healthy and the CEL has been on for years... it may not be trivial to perform an accurate diagnosis.
However DO NOT make the mistake of thinking that this means the sensor itself is at fault.... It MAY be - but troublecodes can only tell you 'symptoms'... not the problem.
I think you should not drive the car with the CEL flashing.
AGM
Waiting for parts to arrive ...
