Oil Consumption On Chevy Equinoxes
 cj_herring
                    Member Posts: 5
cj_herring
                    Member Posts: 5
            Just how much oil do you guys add in between oil changes on the Equinox? I average 2 Quarts between oil changes and I always change my oil around the 30% life mark. Why do these engines use that much oil? I'm around 70,000 miles now and am the original owner.
I would guess you have the 4 Cyl version, there has been issues with that engine and oil consumption. I am not up on the last fixs for it though. I believe the current 'acceptable' rate is a quart every 2000 miles (like it or not). If yours is using more (and it sounds like it is) it might be time for dealer to do oil comsumption test and go from there.
The oil consumption problems are usually caused by the rings sticking in the piston ring lands. This is usually caused by deposits from the engine oil that accumulate in the ring grooves and is one of the reasons that GM always specified the 6094M or 4718M specifications that have been superseded by the dexos spec. The sad part is top techs made it a point to try and get consumers to be aware of this and yet at every turn there was someone else saying that it wasn't necessary to use an oil approved for the O.E. spec.
Amber N.
GM Customer Care
People just want to jump in the darn vehicle and drive off. Put in gas and drive off again. My equinox uses very little oil yet I check it every 500-1000 miles depending on how it's being driven, weather etc are factored in too. If it needs a 1/4 qt or whatever, it gets topped off and I do NOT wait until the OLM goes to zero or even 35%!!!.
Granted the 2010 and 11 models did have issues. But IMO if the cheap skates would change oil, use a good oil and check fluid levels once a month, they'd have a lot less belly aching to do and enjoy life more.
We apologize for this, and would be more than happy to look into this further for you. Please feel free to send us an e-mail to our socialmedia@gm.com along with your VIN, current mileage, contact information and preferred dealership. Looking forward to hearing from you soon.
Patsy G
GM Customer Care
secondly, I'm NO mechanic. when I brought my car to the dealership with my concerns they are paid to investigate and figure out the issue. I was not informed my car was low on oil. I was told it was my timing chain (which clearly was a mis-diagnosis). the sound is back and my consumption test is just under the 2k mark. And as of yesterday, the oil is still full. sounds to me like they are grasping at straws. there is a problem with this model and its time GM admits it. I will be on them like a tick because if 20k miles down the road they tell me my catalytic converter is bad or any other issue related to low and/or burning oil we they will have a big fight on their hands.
I respect everyones opinion on needing to do routine maintenance but this isnt 1985. There is absolutely no reason anyone should have to routinely get under the hood to check the oil level if you are getting oil changes in the regular time frame. Modern cars should not require someone to regularly get dirty to make sure the engine is doing something it is supposed to do. If it was normal they would put an oil level monitor in the car. It tells me I have a low tire or when it may be icy for gosh sakes. If checking the oil level was a normal part of maintenance it would be part of the car alteady. Dont try to tell me im lazy or dont maintain my car because I dont think i should need to check my dipstick whenever I get gas.
I am hopeful my dealer will do the right thing but im not optimistic. I bought this car because i owned an older one that treated me very well. I anticipated the same reliability with the newer model but it looks like i was wrong
Oh yeah, to do it right at the gas station, you have to wait for the oil to settle 15 minutes now, right? Or do it first thing in the morning as you are juggling you coffee heading out the door while you are running late.
As far as whether Mike actually gets it or not, no he doesn't get it, and any suggestion that he or anyone else sharing a similar attitude are the ones that are correct is never going to help them. Cars are machines, not appliances and machines demand attention, care and service from the operator.
You used the word "should" a lot. If I know one of my cars is using a bit of oil, I'll check it once in awhile and I don't mean every time I buy gas. Maybe once every couple of weeks. I don't see why this is a big deal? Checking my oil takes maybe a minute and I don't get dirty.
I am not a mechanic but I am not scared to fix a car. I have rebuilt several cars and I am 39. I do not need a mechanic or dealership trying to lie about something that clearly is a dealership product recall. I can't believe someone out there like this guy saying crap like this.
These cars clearly have issues....fuel pump pressures, timing guides, oil consumption.... Which department did they cheap out on here to save a few bucks? I am generally a Ford guy and my wife asked me why I am okay with a Chevy. I am questioning myself today about this.
BTW, while we are on the subject, here is a snippet of some of the latest information. http://newscenter.lubrizol.com/phoenix.zhtml?c=250972&p=irol-newsArticle&ID=2166149
We had known that a step up in the specification was coming but it wasn't explained how it was going to be approached. Based on this article they are keeping the specification written as is, but are adding a date similar to how the ACEA specifications work.
the adjuster. Crossing my fingers but to be honest, he didn't sound very positive.
In a cylinder leakdown test, pressurized air is injected into each cylinder, one at a time, and the percentage of air that leaks out over a measured amount of time is recorded. If the engine is pretty tight, not much air can leak past the piston rings below or the valve seats up top. If there is excessive engine wear, then the percentage of leakdown will be high. (A reading of more than 20% leakage isn't good).
This VIDEO explains the entire process pretty clearly.
I have been tossing the idea of opening a class action lawsuit against GM for this issue. The mechanic said the timing chain is a life of the engine part and should not really have to be replaced. Every forum I've looked at had people posting about this same issue, some at 25000 miles.
https://www.edmunds.com/car-care/do-i-have-to-use-the-manufacturers-oil.html
The result of stuff like that is that a lot of vehicles were serviced with products that fell short of the specification and that is the direct cause for piston ring wear and deposits that caused the rings to stick in the pistons resulting in consumption issues.
This is a recipe for disaster.
(I posted a capture of the testing results in the mechanics forum)
