Volkswagen Jetta Maintenance and Repair
1125126127128130
  • jmbrunjmbrun Member Posts: 1
    Did you ever find out what was wrong with your jetta and the epc light? mine is doing the exact same thing and no VW shop can figure it out.
  • roni33roni33 Member Posts: 2
    If the AC lines are clogged even a little bit the pressure relief valve will activate and tell the compressor to turn off. I had this problem with my Jetta and its only after the entire system was flushed that the compressor stopped doing that. Auto AC systems in general need to be kept squeaky clean and any debris will make the compressor shut down before more damage occurs.
  • jmdebelljmdebell Member Posts: 2
    I also have the same problem from my car, all the coils and plugs have been changed. still showing those codes!! ANY recommendations would be great! I was told by a repair shop (that admitted to knowing nothing about my car) that it needs a new computer, not what I wanted to hear..
  • bpeeblesbpeebles Member Posts: 4,085
    It is unfortunate that someone chose to "throw money" at the problem. It is always better to TROUBLESHOOT a problem and then fix the root-cause.
    The DTCs (Diagnostic Trouble Codes) are simply pointers and hints which help guide you to a problem. Unfortunately, some folks think the DTCs are telling you what needs to be replaced.
    For example, a "misfire" DTC is flagged when the O2 sensor is sensing that there is too much unburned fuel in the exhaust system. It does NOT necessarily mean that a cylinder misfires... perhaps the O2 sensor is wrong... or a fuel-injector is squirting too much fuel. Applying simple logic to the issue will lead to the proper solution.
    If you would please tell us specifically what DTCs are being flagged on your car (and which engine-code you have) we may be able to help point you in the right direction to a repair. Do not forget that the "mix" of DTCs you are seeing can combine to help lead to the solution.
    Thank you for the help! I will definitely get you a list of all the codes, mostly it is the ones listed in the first post by surfwax. I was told today that it seems like an injector going bad. Will post more when I get a list of the codes. Thank you again.
  • lok888lok888 Member Posts: 1,788
    My wife's 2006 VW Jetta has an airbag warning light on. I bought it to the dealer and read it. It is a faulty passenger side airbag. It costs $680 to replace. The car has 63,000 miles on it. So the warranty (4 years/40,000 miles) on airbag is out. I was wondering if it is common on Jetta. I looked at the complaints on NHTSA and found many problems with it. Does the scanner able to read what parts or the dealer just want to replace the airbag unit?
    There was a TSB for a re-flash procedure for some glitchy air bag light warnings, but I don't know if this applies to your situation. You might ask the dealer to review the TSB and decide if this is a possible solution:
    TSB 69 11 01
    February 17, 2011
    Otherwise, the answer to your question is "no"--a scanner cannot usually identifying the EXACT part that is bad---it could very well be a sensor.
  • jstalfordjstalford Member Posts: 1
    I have just changed mine i was looking for the answer too
  • flowerfarmerflowerfarmer Member Posts: 1
    Hi All, I have owned many VW's from buses to rabbits and by far the worst VW I have ever owned is my 2000 Jetta. I Purchased this car in 2002 when my pregnant belly could no longer squeeze under the wheel of my bus. Not the best decision I ever made. A German friend actually apologized on behalf of her country when she saw my car. Everything that could break or fall off of that car has: all cup holders, radio antenna, those plastic faux grill things on the front, not to mention the recalls and the fact that my engine check light is just always on and when I take it in for service, the light ALWAYS COMES BACK ON BEFORE I EVEN GET HOME. Where on Earth are they making these things? It can't be in Germany. China? The Czech Republic? I have a 1975 Bus with Westfalia conversion and it is in much better shape than that Jetta. The final straw? The car is on it's way to the nearest VW dealer, in Yakima, because we all know the process if you lose your electronic key. And us unfortunate VW owners East of the Cascades...don't get me started. Is it meant to only be a prima donna coastal car? Why did Carter VW not warn me? I strong armed my insurance company into paying for the tow. I will not be putting one more precious penny into that abomination. I will simply go back to driving my bus. Who needs heat and air conditioning anyway. Stay away from the Jetta you VW lovers, I think they are fakes.
  • dastammdastamm Member Posts: 3
    2012-08-14-02T23:15Z
    I have two or three problems with my 1991 GL diesel, which just turned over 204 000 mi. The problems might or might not be related. The last attempt at repairs treated them as three related problems. The problems:
    1. fuel gauge functioned irregularly and erratically (indicating OK or ¿high? then low)
    2. all the time, the coolant temp indicator indicates only barely "warmer" than the "cold" area
    3. infrequently and irregularly, the oil pressure warning light and buzzer come on for no apparent reason; accelerate or rev the engine, and they stop. This happens when driving "straight-and-level" and at steady, "in-town" speeds. Checking the engine oil indicates that it's just fine on the dipstick.
    What we did:
    1. Oil system under pressure tested "good"
    2. Replaced both senders or sensors for oil pressure
    3. Field-expedient soldering by senior mechanic of circuit for fuel gauge
    4. The instrument cluster tested "good," so its printed circuit board became suspect. Replacement circuit board was not found.
    4. What _might_ have worked: Field-expedient wiring by master mechanic of three circuits might have repaired the problem with the fuel gauge. A few weeks' time will tell.
    The problems with the coolant temp indicator and the oil pressure warning light and buzzer remain.
    Before posting this, I saw in the forum the recommendation to test the oil system under pressure. I don't remember whether that was done.
    About a year ago, I changed engine oil from Kendall-brand "straight" petroleum to Kendall-brand "synthetic blend." (I was told Kendall no longer makes "straight" petroleum oil for specification C.) I use 15W-40 during the Summer; 10W-30, Winter.
    I find it hard to believe that synthetic-blend oil would contribute to the two remaining problems. I have no impression that, at operating temp, the engine is running so "cool" as to cause the coolant temp indicator to indicate temp that's only barely just above the "cold" area. I also can't imagine that synthetic-blend oil would cause the pressure sensors and such to malfunction.
    While using "straight" petroleum oil, the oil pressure warning light came on perhaps five times in 15 years. Each time, it was while decelerating and turning right, as when on an exit ramp and decelerating from high speed. I was given to understand that this was because the oil in the pan sloshed away from the intake siphon when turning right at "high" speed. Didn't happen at "in-town" speeds.
  • tommyriordantommyriordan Member Posts: 3
    I have a Nissan Micra and its an excellent hatchback with a powerful engine,high mileage of 23 KMpl and hi tech features.But my friend has Jetta and he has to pay a lot on its maintenance.
    2012-08-20-01T23:15Z
    3. infrequently and irregularly, the oil pressure warning light and buzzer come on for no apparent reason; accelerate or rev the engine, and they stop. This happens when driving "straight-and-level" and at steady, "in-town" speeds (40 mi per h to 45 mi per h). Checking the engine oil indicates that it's just fine on the dipstick.
    What we did:
  • caviterruptuscaviterruptus Member Posts: 1
    Water is ponding at the floorboards of my 2007 Jetta. How do I clear a clogged AC evaporator drain on this car?
  • jdshorrockjdshorrock Member Posts: 1
    Do you know if the error codes were P0480 & P0481?
  • caseymae19caseymae19 Member Posts: 1
    Everytime I start my 2006 Jetta, ERROR flashes. It'll go off a few miles down the road. Does anyone know it means?
  • rizardrizard Member Posts: 3
    Anybody else having paint issues? Keep my car immaculate, but have noticed three new spots appearing where it looks like the clear coat has just come off. No rock or door ding associated with it, but it looks like it it is just flaking off. the worst one is now the right rear door. Looks horrible. Has there been any official notice? ( doubtful).
  • jeremi1023jeremi1023 Member Posts: 1
    So the other day I went to start my 1997 Jetta GLS 2.0, and it didn't want to turn over, but finally did, only to have it stall one second later, and have a puff of white smoke come from my engine. When I looked, the timing belt had snapped off. With this car it has a dual V belt setup. The thicker belt had snapped off. (The one on the crank, alternator, and ac compressor).
    I went to try and start the car again, and it started right up, perfectly. Sound clean, and drove smooth.
    I bought a new timing belt and put it on, and now the car struggles to start up again, and when it is on, there is a LOUD knocking sound coming from the area of the belt. Also, the car and electronics feel like it has surges or energy. Lights dim, idle goes down, etc.
    Keep in mind though, that when the belt was off, the car was fine.
    What could this be?
    WOOOOAAAHHH - that is *not* the timing-belt. It is simply an accessory belt which drives some external items.
    The timing-belt is under a cover and not viable by just looking at the engine.
    If your timing-belt had snapped, then your engine would likely be a suitable boat-anchor. (because the valves would have crashed into the pistons.)
    ---- Now - on to your question...
    If it were mine, I would remove those 2 accessory drive-belts and try to MANUALLY spin each of the accessories. (alternator, power-steering pump, AC compressor...etc) If anything does not spin freely, then you found the problem.
  • sounds like oil pump itself may require replacement too.
    many of the symptoms sound like they can be caused by flaky-ground-wire somewhere, or wildly varying voltage going above 14V or below 10V maybe. possibly the voltage regulator is flaky...
    Also if not done already, check or replace the ground wire that goes from negative battery post to the negative post on the starter motor, or the ground to chassis wire from there. I suppose the master-mechanic dude must have checked that already though! are battery cables or either post heavily corroded? again, mechanic must have checked/fixed that already?
    2012-09-29-06T14:50Z
    Thanks for your response. After my posting and with a planned road trip of about 1100 miles, I did have the oil pump replaced. In doing so, the oil was changed to 20W-50. I had had 15W-40 in for the Summer. I've been using 10W-30 for Winters. Since that time in the shop, the problem with oil pressure has stopped, and the pressure was fine throughout the trip. With more than 205 000 miles on the car now, I'm thinking of using higher-viscosity oils, both Summer and Winter.
    For the malfunctioning gauge for engine coolant temperature, I plan to have the voltage checked the next time I have the car in the shop.
    ¡Thanks for your help!
  • you are most welcome, dastamm - happy & safe motoring... :D
  • staterslaverstaterslaver Member Posts: 1
    I agree with you. VW jettas are crap!!!!! My 2002 vw jetta is always breaking down. Problem after problem after problem!! I'm sick of it :sick:
  • Just wondering if anyone else has had all four door latches in various stages of malfunction at the same time. I have a 2010 Sportwagen: driver's door will not lock at all, left rr pass door won't unlock if locked and won't lock if unlocked. Front pass door won't unlock, and right rr pass door won't lock. For the rear doors I've had to pop out the little access plug and manually lock the door by pushing the small red lever inside the hole in the door. I'd like to mention I feel like an idiot doing this day in and day out. Today is when I discovered the driver's door won't lock at all, and when I removed the access plug to push on the little red lever there, I discovered there is no little red lever present. Not sure if there isn't one there by design or what.
    I drive a little over 100 miles per day for work, so I drove the car out of warranty in a little over a year, although I don't use the door locks any more than anyone else. I've talked to my dealership about the locks and they pretty much just shrug at me and tell me how much new modules cost. I find this to be unacceptable since door latches are safety parts (of which I have reminded the dealer) but apparently Volkswagen doesnt' care about that.
    At any rate, if anyone has figured out a way to fix these things without simply replacing them all, I would appreciate hearing about it.
  • cosmocosmo Member Posts: 203
    Before you replace anything, run a diagnostic scan to determine what the fault code is. I would think that the dealer would at least have offered to run a diagnostic scan before telling you how much something you may not need costs. I use the Vag Com tool from Ross Tech. If you do not have access to one, an independent VW shop could do a diagnostic scan for a fee.
  • 06gli06gli Member Posts: 1
    I have the same problem. curious what you did?
  • lynne21lynne21 Member Posts: 2
    Has anyone had problems w/ tires fallling off? I had the tires replaced in June and in late Sept. started hearing a noise from the front driver's side wheel/tire. Some co-workers said it sounded like a tie-rod problem. After a couple of weeks, the sound got worse. there was a very loud noise, the car stopped and smoke came out of the front tire area. It was dark, so I didn't get out but the tow truck person said the tire came off. Apparently, the lug nuts came loose. The shop that replaced the tires said this wouldn't have happened after 4000 miles, but they are the only ones who worked on them. If this isn't something that has happened frequently w/ Jettas, then I feel that it is their problem and they owe me the cost of repair and towing.
    All aluminum wheels should have the lug nuts/bolts RETORQUED after about 300 miles after the wheels are installed. This is because aluminum tends to flex and loosen the fasteners.
    This is true for ANY type of car with aluminum wheels.
  • ventkmventkm Member Posts: 2
    So a friend borrowed my 2002 VW Jetta and when I picked it up from him the car would take some time to get into gear. While driving the car was revving up pretty high even in very low gears when I was going the correct speed for that gear. On the way home I was on the highway in 5th gear and going about 70 when the RPM needle was going crazy. All the way to 7 then back down to 2 then up to 6 and so on and so forth then the car just started slowing down but no light ever came on and fortunately I was able to get off the highway and park it but I haven't gotten it towed yet. Also, when I was got out of the car I noticed what I would call a burning smell. :sick: I was just wondering if anyone else has had the same problem or knows anything about a situation like this?? Also, if it was something that was waiting to happen or if the "friends" driving was the cause of the problem?? Thank you and any advice would be greatly appreciated!
    What kind of xmission do you have? (manual or automatic)
    If you have a manual, then I would say the clutch is slipping.
    If you have an automatic, then the problem may be the xmission itself.
    I have a manual xmission, if it is the clutch that is slipping what kind of repair would that take and is it something that someone who has some knowledge of vws would be able to tell without taking it to a repair shop first?
    The clutch is shot I'm afraid, if it's slipping that much. Hard to say how much of this relates to your friend's driving, but if they are very unskilled with a manual transmission, a bad driver can burn out a clutch that was, shall we say, on its last legs perhaps beforehand.
    He would have had to be extremely abusive to burn out a perfectly good clutch--it can be done, but would require some pretty radical burnouts, etc.
    So perhaps your clutch was worn---did you notice beforehand that the clutch grabbed only at the very top of the clutch pedal travel?
    There's a small chance that some kind of adjustment might help this, but with all that slipping, there's been a fair amount of damage already to the clutch disk. and given that your clutch is hydraulic and not cable driven, there's not much to adjust.
    Labor to replace a clutch is about 5 hours. Normally one installs a "clutch kit", which includes disk, pressure plate, throwout bearing and pilot bushing--and any guide pins, etc that might be required. Have it done right--you don't want to go in there 2X.
  • jduboi1jduboi1 Member Posts: 1
    my jetta does the same thing right now i went to the mechanic and once he pluged in the computer he said that the spark plugs were bad, so i changed the spark plugs n the car was the same so then i changed the ignition coils n it turns out that aparently it wus the spark plug connector something about its wires so right now im gonna wait till tomorow n get that piece from the dealership
    spark plug densel: $2.99/ea
    coils: $21.99/ea
    connector $16.99/ea
  • rbonfigliorbonfiglio Member Posts: 1
    I have an 04 jetta 2.0 liter sometimes when the fuel gauge reaches around one eigth tank the car will stutter one time about 1 second then will run fine
  • fordnutsfordnuts Member Posts: 19
    They (local police) definitiely like to pull one for lights out. The older the car, the more often the lights are prone to go out when least expected. I didn't even know certain lamps existed, though I think I have replaced every lamp in 2002 Jetta. Now I have to replace rear middle brake light, which does not look easy, and license plate lamps (well one, but might as well do both).
  • mindilouuumindilouuu Member Posts: 1
    Non-Start issue. Bells and lights and all that come on. When turn key the engine doesnt budge. Battery is fine. No clicking noise. Removed kill switch fuse and replaced. Waited for Glow Plug light to go off and tried to start. Tried to start while in neutral and back in park. Still nothing. Whats really weird is you can hear an alarm going off inside the engine - like its trying to tell you something. Any ideas what this is?
    There is no "alarm" in the engine.
    Judging from your description.... I can only suggest that perhaps you are hearing the starter-moter spinning without engaging its gears. It would sound kinda like a 'whine' as the motor spins faster and faster with no load on it.
    ah, bad starter maybe? That was a brilliant guess bpeebles. :P
    Thanks Sir_Shiftright. I would not call it a "guess"...more like a "deduction" based on the limited facts put forth.
    Part of my livelihood is 'figuring things out' (perhaps better described as a professional troubleshooter) Compared to the complex, worldwide software-systems I work on, an automobile is a very simple machine to me. Except, with softwre, I miss the hands-on of holding a piston in my hand to diagnose why it failed.
    yes perhaps I should have said "educated" guess. :P
  • jentruckjentruck Member Posts: 1
    i recently bought a VW passat the MIL is on, had auto zone ...PO299-"turbo charger , air pressure sensor /PO420 rich air ratio, air leak near oxygen censor. i dont want to waste time /money doing the processs of elimination. Please, would somebody point me in the right direction
    sounds like a leak in the turbo intake tubing somewhere.
  • lilredneck6922lilredneck6922 Member Posts: 1
    i need to know how to hook up the clutch cable to the clutch pedal.. i have found that it very frustrating and not very much room.. i would like to have a little guiedence to this matter
    edited May 2013
    Is it the manual cable or the self-adjusting one?
    MANUAL
    REMOVAL
    Loosen the cable adjusting sleeve locknut and turn until tension is relieved in the cable. Remove all parts from the cable end beneath the clutch release lever and pull the cable end from the lever.
    Unhook the cable from the top of the clutch pedal assembly and pull the cable through the firewall from the engine compartment side.
    INSTALLATION
    Install the clutch cable. Be sure to lubricate both ends of the cable with multi-purpose grease, then insert the cable end through the firewall and hook the cable onto the clutch pedal.
    Position the rubber washer and rubber grommet properly.
    CAUTION: Make sure that all rubber parts are installed correctly. If parts are not installed properly, the transaxle vent which is protected by the rubber washer could become clogged, causing oil to leak past the seals.
    Insert clutch cable end through rubber grommet and the release lever. Attach all parts to the end of the cable.
    SELF-ADJUSTING
    This is more complicated and would require a guide with illustrations
  • vdudzz84vdudzz84 Member Posts: 8
    I just got a full tune up. The coolant temp sensor was the wrong one so we just put the original back in until Tuesday. Before tune up i had 6 codes mostly misfires seeing as the previous owner never maintained out and just let it sit for almost a year. Now i have one code. P1128 Obv fuel trim. I replaced the fuel pump which was three original as well. I just bought a new cat so i know that's not burning out but my car as 119k so it is burning a little but of oil. I cleaned put the MAF which was dirty and of course original. Why ours this light still coming on and reading this code? Please help
    RE: p1128 engine code
    Exhaust system --Leaks
    Fuel injectors --clogged, dirty
    Fuel pressure regulator and residual pressure
    Fuel Pump (FP)
    Intake system -- Checking intake system for leaks (false air)
    Secondary Air Injection (AIR) system
    Checking secondary air system for proper seal
    Note: Check vacuum lines for leaks.
    I just got an oil change but my oil light still comes on. Is there another meaning behind this light
  • lambjetta03lambjetta03 Member Posts: 1
    i have a 2003 Jetta. after driving at high speeds or for an extended period of time it becomes difficult to shift into 1st or 2nd and almost impossible to shift into reverse. i noticed that the clutch cable appears to be slipping. that is, where it can be adjusted becomes longer. so today, when i got home i simply adjusted it and it works fine-even after being hot. but i'm pretty sure this will continue so what could be causing this? i really don't want to have to pull over before i park in the city and have to continually adjust the cable so i can get into reverse. i have my theories, but i want to see what others might think it is. thank you.
  • revmarketrevmarket Member Posts: 48
    Sorry to have taken so long to respond but I thought someone else would have given you help by now.
    Is this the oil gauge light or the oil change reminder light?
    An oil change reminder light usually needs to be reset.
    The person doing the oil change should know how to and should do that reset
    If it is the oil pressure light:
    This light usually comes on because if there is not enough oil in the system to generate pressure it is sensed and lights up.
    It is not usually set to come on just because of low oil.
    So a bad or marginal oil pump might be the culprit if you just got an oil change and it is full.
    Poor pressure can be because of extra wear in the channels where the oil must travel.
    If the oil light was on when they did the oil change why was the vehicle not checked for correct oil pressure?
    Some of these instant oil change places have no clue of why the oil light may come on?
  • haases1haases1 Member Posts: 2
    hello my 99 jetta 2.0 is doing exact same thing .it just shut off while driving., when it turns over it cranks and then makes same noise you said,. any help would be greatly appreciated
