good ears...
I have a 2001 Jetta Wolfsburg that has been perfect. There, I broke the tradition!
-Jim
http://www.jettaownersclub.org
http://www.bluelagoonjetta.com
Click on "new" at the top of this page and follow directions. It's a great feature!
best
I? The tweeters don't do it everyday but the road I drive on everyday is the same. The dealership said that tweeters do that at low volumes but it does it at higher volumes just not everyday ???
I figured since they have taken the engine out twice they can't hurt the door too much. Could I be wrong?
Anyone have any insights as to the nature of this problem? We'll take any sound advice to the dealer as a suggestion.
-Steven-
-Steve (JettA, JettA)-
It sounds to me that (possibly) your dealer is trying to take the easy way out on this repair and hoping the problem would have gone away by now. It's time for them to take responsibility and take care of you once and for all and quit dinking around.
-Jim
I'm going to keep an eye (ear) on it.
By the way, love the WE...and a lot cheaper here in Canada with exchange rate.
Has anyone had the same problem?
Can I get "normal" wheels for this car - ones that can handle a bump in the road, like 15"?
Where can I get a new wheel other than the dealer?
My problem is that I don't want a FIXED new car. Do I have a leg to stand on in demanding a different car. I am just worried that this is the beginning of a nightmare!! Has anyone had a similar experience? I have always driven old cars and a some may know with old cars come constant worry. I looked forward to not experiencing that with my new Jetta. Now I am not so sure that is possible. Will my fixed computer problem be a constant cause of worry and is that fair to me?
Okay, that is it. I just need some input from fellow Jetta owners.
-Jim
I suspect the 'feeling' you have is due to your tires. Is the pressure too high? I have driven my Jetta plenty of miles at those speeds and it's rock solid, wind or no wind.
-Jim
-Jim
Anyway, I was determined when I got back to be very careful in the future. Tonight when taking my 90 year old mother back to her assisted living facility, I pulled back from a normal parking space, and the same thing happened. Interestly, looking at the GM auto next to it, one could see clearly that my Jetta didn't have the proper clearance over the end of the parking space where the sidewalk began.The GM auto had more than enough.
I have been looking for other people who have had similar problems and did find about 6 or 7 cases on the DOT.gov. web site. Any other suggestions?
Thanks, Roy
GOTCHA. HA HA LOL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Gotta a question about my seat heaters. When I use my seat heaters, I have to crank it up to 5 before I can feel anything and 5 is great because it's toasty warm! 4 is less so, and they don't feel like they are getting warm from 1 - 3.
I asked the service manager about this and he told me that there is an ambient temperature sensor in the Jetta cabin and if the ambient temperature doesn't detect that the inside cabin temperature is cold (I don't know what the minimum ambient temperature needs to be), you really won't feel anything between 1 - 3.
If the ambient temperature sensor detects that the inside cabin temperature is cold, the seat will feel hotter between 1 - 3.
Does anyone know if this is true, or was he feeding me a line?
I have a 2000 Jetta and I did my first oil change at 5k and when I got to 10k my oil light came on and when I checked I had no oil, took to dealer they advised that motor burns 1qt every 1500miles. Did oil change at 10k and last week my car had 14k miles and the oil light came back on, when I checked I had no oil again. Dealer again advised me of the same thing and told me this is normal. I have never heard of anything like this with a new car. Does anyone know why this occurs? Are the dealers feeding me a line? Is this happening to all the 2000 Jetta's or is this an isolated problem? Please reply with your input.
I would check out the following website: http://www.myvwlemon.com/. There is a discussion section and you may be able to find something on this. I am only at 6K miles with my jetta, but I know that my friend had the same problem. I think it had to do with water in the fuel pump - I am not sure though. Also, when you access the site above be sure to put your sound on mute. The webmaster says "Disappointed!" just as you access the site - not good when you are at work.
Hope this helps.
-Jetta Owner
I owned my VW for 10 years. I thought the car was pretty reliable. Have some friends with a 96. They've done exhaust and had to take to the dealer for addition of tranny fluid. There is no dipstick so you can't check it yourself. Dealer charged them $90 to add one pint of fluid!Once they go through the original muffler you can count on replacing one every two years. I was told this by my mechanic the first time I did mine and he was right on the money. First one lasted 6 years, then one at 8 and another at 10 years.
Be careful with VW dealers. They seem to have more than their fair share of dealers who offer poor service.
All of a sudden (brand new 2001 Jetta GLS) the dimmer doesn't work. Anyone experieced this? Anyway to fix this? (pull the fuse?)
In fact, burning some oil is probably good for an engine, if it's within reason.
