Synthetic motor oil
12223252728175
  • curreycurrey Member Posts: 144
    Howdy guys (and gals), I just purchased a 2001 Mazda Tribute and want to use a full synthetic oil in it. Here is my problem, I can only find one and they want $98 for 12 quarts. I know synthetic is more expensive, but, that is ridiculous. Anyway, does anyone out there know of a synthetic 5w-20 that I can get my hands on for the price in the range of other synthetic oils? Or, has anyone seen any press releases on when a synthetic 5w-20 will be hitting the market? Thanks in advance for any and all information.
    Via con Dios,
    me.
  • adc100adc100 Member Posts: 1,521
    If it were my car 10W-30 Mobil 1 would be going in - Period. The purpose of the 20wt is to squeeze out better gas milage at the expense of engine wear. I'll sacrafice a slight penalty for milage in order to gain engine life any day of the week. An engine has many sets of clearances and no one can tell me that each part in that engine needs exactly a 20wt oil. Besides as oils-(especially conventional) get thicker, the longer they stay in the engine. Also there are h-u-g-e discrepancies in an advertised viscosity and the actual viscosity. Chances are your 5W-30 as bought may be 5W-15 or 5W-30.
    As I said this is my opinion.
  • armtdmarmtdm Member Posts: 2,057
    My 95 Contour is running Mobil1 5W30. It was about a half-quart low, and I decided to top it off with some extra Sunoco 5W30 dino oil I had sitting around. This was the cheap-[non-permissible content removed] in me that decided to do this; I wanted to use the Sunoco rather than just recycling it. Does anybody see any problems with this? I'm about 3,500 miles into this change interval, and I'd already added almost a half-quart of Mobil1. Therefore I decided to top off with $0.50 worth of oil instead of $2 worth.
  • taasstaass Member Posts: 40
    Perhaps part of Mobil's initiative for no longer advertising 25,000mi drain intervals was for marketing reasons. As I understood it, though, car manufacturers had clearly stated they would not honor warranty engine repairs if people didn't adhere to the proper service schedule. It's kind of hard to market an oil that will survive 25Kmi when no one will ever use it that long. It has nothing to do with the oil not holding up for that period. In fact, the base stock (which is the advertised fully synthetic part) is in excellent shape at that point. Often when considering synthetic oils people overlook the additive package. There are all sorts of additives from viscosity enhancers/controllers (fewer used in syns), to extreme pressure additives (important at startup), and buffers (to neutralize acids formed by combustion by products - namely CO2 and H2O -> HCO3. There are also emulsifiers and anti-foaming additives. In short, there's a bunch of stuff in there that we take for granted. The base stock seems to get all the press. It's all these additives that get used up throughout the life of the oil. The buffers have a finite ability to neutralize the acids formed from crankcase condensation and blow-by. If you ran your oil 25K between changes, you'd most likely be without the protection of various additives in the oil - although the base stock may be in great shape.
    Is "fivespeed" a cajun? He sure writes like Justin Wilson talks (all in jest, of course). I've never heard anything definitive on the use of synthetic oil straight from the factory. I've heard people recommend that mineral oil be used at first so that high-spots on cam lobes be worn and mating surfaces properly "mate," but, I know Porche and Chevrolet (Corvette) have used factory fill Mobil1 for years (as well as many other manufacturers). I've also heard of some companies using friction modifiers or "break-in" oils for the first oil change to rememdy this problem. It certainly wouldn't hurt to wait a change or two before using synthetic fluids, but there's no evidence that says you can't - although, asking the manufacturer is the safe thing. Again, they are just people, and not the engineers who built and designed the engine.
    Problems with synthetic oil and engine seals results from sludge and varnish deposits being removed from the detergents in the synthetic oils. I switched to synthetic in my '84 olds with 181,000 miles with no problems. In addition to some of the additives I mentioned above, there are also additives used to make the seals swell. The list goes on. . ..
    Question for adc100 - where have you read that the advertised viscosities can differ appreciably from the actual viscosity? Oil manufactures/processors go to great lengths to ensure that a quality product is headed to the shelves. I've never had a problem with Mobil1 in my new vehicle, or Pep Boys 10W-30 which I used in my 1984 Olds Firenza.
    Probably 90% of drivers operate under the "severe service" guidlines of their owner's manual. So, frequent oil changes ought to be the norm for most people. 3K is recommended for my Durango, but I know 5K/5mo is the servere service for V6 Camry's. Arguing on behalf of synthetics is the reduction is engine sludge. Frequent oil changes will minimize the production of sludge - even with mineral oils. But, with synthetics I have never experienced ANY sludge buildup. For that, the fluids are remarkable. The cold weather flow properties are also impressive.
    Oil drain interval must be weighed on a cost/benefit scale. Many manufacturers recommend a 3K servere service interval, while others offer a 5K, or others still have 7500 mi. I used to believe in the 3K inerval, but am more inclined to go to 5K these days. How much benefit am I really getting from changing my oil 3 times more often per year. That's an additional $90 per year. It's not a significant amount, but, it's still 90 bucks. And, is that really doing me much more good? Today's engine technology is leaps and bounds beyond where it was in the early 80's. Lubricant technology for mineral oils as well as synthetic oils is also far advanced over what it was. A good quality mineral oil changed according to manufacturer's specifications should take an unabused engine's internals to 200K without incident. How many of us will have the same car for 200K mi? Some will, but not many. My dad had a 1985 Dodge Van with the 360 cid. He used the cheapest off the shelf 10W-30 and got 265,000 miles from the van. Compression was great, cam lobes were within spec - and we sold the van to someone who neglected to check the oil level and seized the engine 2 weeks after purchase. The rear seal leaked from 25,000 miles, other than that, none was coming out the tail.
    I use synthetic oil. I could be delusional and there may be no long term benefit. But, I do feel that synthetics are superior to mineral oils based on the literature that I've read. And, I want to do what is the VERY BEST for my car - and thus chose to use Mobil1 in the crankcase, 75W-90 synthetic gear lube in the differentials, and synthetic ATF in the transfer case. Mobil doesn't make a synthetic that satisfies Chrysler ATF+3 specs, so I may try Amsoil synthetic ATF+3 in the tranny. Has it been worth the cost? I don't know, but I feel better knowing that the mechanicals are protected the best that I can.
    Enough of my rambling. Later.
    You make a great point. We have engineers designing the engines and lubricants but we have trade school service reps and mechanics that service them. No problem with this except these people tend to base their opinions on past experience or on profit motive and not on what factory engineers may say. Of course, training is an issue as well. I have sat in on conference calls between Toyota service mgr, the mechanic and toyota home office where the HO and mechanic do not agree on how to service my differential. So, who do I believe?
    Service reps bounce around shops/dealers like mechanics do, few really know the cars they are bringing in for service, they simply know how to write an order.
    Sorry, off the subject of oil but this is what usually happens when you ask the service rep about the use of synthetic, they usually know nothing about them, say it will void your warranty and say to get your oil changed every 3000. THIS IS ALL THEY KNOW! They have received no training on synthetic lubricants.
    I will check with amsoil for a possible release date on a synthetic 5w-20. By the way, do you think their oil filters are as good as they claim? Again, this is my first brand new vehicle (when I picked it up it had five miles on it) and I want to baby it as much as I can.
    Hey adc 100, I have a question regarding your response. Please understand that my knowledge of all things automotive is limited. My question is that if I am sacrificing engine wear for mileage with the 5w-20, why is it that under normal driving conditions the manufacture says I can go 7500 miles between oil drains? I would think if 5w-20 sacrificed engine wear for mileage gain I would have to change it out at 3500 or 3000 miles. This is not a slam, I really don't understand.
    Anyone who wants to provide information on the above questions is more than welcomed to. Thanks again for your time.
  • tc93tc93 Member Posts: 19
    Ford is already marketing a 5W20 under its Motorcraft label. I recently saw some of it in the local Wal Mart. I wonder how well a conventional 5W20 would hold up in searing 100* F summer heat? Why not try one of the synthetic 0W30 oils as an alternative to the 5W20? It would give you the start-up fluidity that the mfg. seem to be striving for, yet offer a little more viscosity at the high end. If I'm not mistaken, I think Mobil 1 is the only that distributes the stuff through most common retail stores, and Amsoil, while quite a bit more expensive, is still pretty easy to obtain.
    I have used the Amsoil filters for 9 years. Have also used Mobil 1 and Pure One. All three are excellent and based upon my oil analysis do a better job of filtering then the OEM filters.Amsoil less then Mobil 1 but more expensive then Pure Ones (made by purolator).
    These 5W20 oils bother me. If the engine was truly machined to tighter clearances then a heavier weight oil may not be the best. Need an auto engineer to answer that one.
    Again my opinion sprinkled with a healthy amout of skepticizm. A quesion for you...will the car last 3 yrs. 36,000 miles with 5W20? Will it last 60,000 (doesnt need to), will it last 120,000 (doesn't need to). Get my drift?? It's a fact that 30wt protects better than 20wt.
    Taass: I read that informationin Journal of Tribology or Automotive world. Can't remember which or the month. But the jist of it was that oils are constantly tested in the market place by, I believe it was SAE. The percentage of oils that did not come up to specs in terms of additive package quality, Viscosity, cleanliness was shocking I'll give you a number like 30%. As I recall there were threats of fines or actual fines. I'll try to locate the article. I know it was a back issue of one of the publications. Believe me I'm not making it up. I was shocked.
    Al
    Sounds like the testing was on oils already on the shelf and kind of quality control measures. Re-test oils and find that the ones on the shelf do not pass the standards as opposed to a new type of oil?
    As a part of oil analysis they send back the weight of the oil sampled. Only once did my 10W30 come back showing up as a 10W40 weight. And, I don't know if oil changes weight over time due to use??? Their tests were on new oil I assume.
    The tests for viscosities and additive packages were done with new oils from the retail shelf. I don't remenber if these tests are a routing thing done or only a one time study.
    The viscosity increases I was refering to were mainly for conventional oils. The testing done for API certification involves various 64 hour "sequence" tests. In these tests one of the criteria for passing is limits on viscosity increases. That limit is around 350% increase. Once you get beyond the 64 hour tests conventional oils become "TVTM" (to viscous to measure) Syn oils breeze through double, tripple , and in some cases quadruple time test values. They can't advertise this fact because of court rulings. Of course taking the time to read and research information is fair game and provides useful information for those who are interested in learning. This contrasted to the some folks who say there's "no proof" that syn is a superior product.
    Again for those interested read SAE technical paper 951026. Unfortunately it costs 20-25 bucks from the SAE site.
    I think I'm going to use strictly 10W 30 Mobil 1. Basically 10W oil is certified to pump at -20F and a 5W pumps at -30F. Now below these themperatures all bets are off for conventional oils. But Mobil 1(10W30) pumps adequately at minus49F. Why bother with anything else. I can also tell you that my vehicle started -no problem at minus20F with 10W30 Mobil 1. When is the last time anyone has seen less than -40F??
    BTW Welcome to Walmart has 5 qt. Mobil 1 for $17.88, that's as low as it gets. Even though I'm going to try Redline, couldn't resist buying a couple.
  • yurakmyurakm Member Posts: 1,345
    You wrote: When is the last time anyone has seen less than -40F?
    The New Year night from 1978 to 79, the temperature was around -40F in Moscow, Russia, with -50F in some parts of city and in several suburbs. -40 to -45C.
    Though, even in Russia (the Central European region, not Siberia) this happens very seldom. I was 45 when immigrated, and it was the very cold night I can remember.
    hope you were using Mobil 1.
    I had no car before immigrating to USA. Some of my friends used synthetic oil, but I was not interested in brands and specs. Though, I am pretty sure Mobil-1 was not available in Soviet Union. It was a closed economy, with different brands of everything.
    I remember well that trouble with starting my friends' cars usually began at about -30C to -32C (-22F to -26F). Not unusual for the places, but still seriously cold.
    Typically, only one-two nights were so cold during the whole winter. Probably one winter in three was warm, and the temperature never approached these numbers. On the other hand, about one winter in five was more cold, and it was around -30C roughly every second morning for month, or two, or even longer.
    As well as I remember, the problem was not so much with oil (even not synthetic), as with weak batteries. The cars jump-started fine, but it was difficult to start the first car in the neighborhood. Some of my friends removed the batteries at evening, when expected a strong frost, and kept them at home overnight. One friend installed a big battery from a big track in his trunk, and had no problem with starting.
  • namfflownamfflow Member Posts: 202
    With all this discussion surrounding synthetic vs. conventioal oils, where do the Sythetic/Conventional blends fit in?
    The price is right, averaging about $2.50 a quart instead of $5.00 a quart. If conventional is good for the 3000 to 5000 mile interval "recommended" by most manufacturers. Would a blend offer some of the alledged superior advantages? The advantages I see are better starting in extreme cold (N/A for me, rarely goes below 35 here) and resistance to thermal breakdown.
    Would a blend be a good choice for someone who changes the oil regularly by the severe service schedule while maintaining some economic sense? I just can't see going from Quaker State 10W30 at about $1.50 a quart to Mobile 1 (or any other) at $5.00 a quart.
    In short, is mixing synthetic and conventional create an oil "better" than conventional or does it create a monster like the teflon additives?
    I am about to pick up a new Dakota with the 4.7 and am wondering to stick with "true and true" or try something different.
  • pbraunpbraun Member Posts: 11
    I enjoy reading all of these oil posts. I guess because oil changes were the first car main. tasks that I learned, many years ago. From reading many posts, on many boards, I have came to 2 conclusions: Change your oil every 3k/3months with what ever name brand oil/filter is on sale, or change it every 6k/6months with Mobil 1/Amsoil and a high quality filter. Remember, the oil may last for 25k/1 year in a synthetic, but where do the contaminants go? I would not run any oil over 6k. I change it myself, so the cost is no big deal. I have read many posts that slam dino oils, so, does anyone own a car that was damaged because they used a dino oil, vs a synthetic? Has anyone had a engine damaged by a Fram filter? Remember, studies in the lab are one thing, and reality is something else.
    I understand where you are comming from. Once upon a time I felt the same as you. The quality of filters, and the superioty of synthetic oils make the old way of thinking obsolete. Quick lube places and oil companies are happy to keep it that way. Leaving the synthetic oil in the crank case 10,000 miles and changing filters every 5000 will give your engine a level of protection beyond the 3K change. I am retired and have better things to do with my time. BTW I can not positively probe Fram filters are inferior in all respects. But take one apart as I have. The proven superior filters which have high multipass efficiencies are Mobil 1, Pure One, Amsiol, Delco Ultraguard. Oil analysis has proven you can leave engine oil in your vehicle well beyond my number (10K).
    I am absolutely driven when it comes to the care of my vehicle. You couldn't pay me to use a Fram Filter and 3K conventional oil changes. It's OK for some but not for me.
    I can't say that any car I am familiar with was damaged bu using a filter on sale and changing every 3000. No oil/filter should "damage" your car. I am aware of how my vehicles last and run with good filters and syn oil though.
    I'd suggest you try it and I'll bet you will observe the benefits and leave the 3K boondoggle behind you.
    Namfflow: Blends are about 10% syn. Waste of money. I'm thinking that your new Dakota 4.7 is worth an extra couple of bucks a year for the 100% syn. If you are bound and determined though. Just buy a quart of Mobil 1 and mix it. Some syn is better than none.
    Al
    No containers say how much synthetic is in the blend. Blend you own, you save money and know what you are getting. However, I also suggest the 100% synthetic.
    To those changing every 3000. If your new car came with cooper plugs that needed changing every 15,000 would you keep doing that if you knew platinum plugs could go 60,000, or coolant, that in lieu of changing every 24,000, could go 150,000. The same is true for oil. So why don't manufacturers put synthetic in engines like they do coolant or plugs. Two reason I believe. First, oil chagnes are one of the few things that require an owner to come back frequently (unlike coolant or plugs etc) , every 3 months or so, so this is killing the golden goose and two, most owners do not look under their hoods unless there is a problem. With synthetics I think the manufacturers would feel more warranty issues would surface as owners would believe the engines required "no" service forever. This board has people who service their cars, most people have no concept of what their service schedule is.
    Okay, so it looks like the blends are actually less economical than using straight synthetic.
    The only issue that is still left for me is the whole warranty issue. Many manufacturers of various products will use any excuse they can to get out of honoring a waranty. The Japanese manufactureres are the worst for this.They blame the owners for all the problems. Of course my vehicles are Dodges so that isn't an issue. I like many have never seen any engine failures as a result of oil problems unless it was never changed. Saw one like that In 76 I saw a 70 Dart that had a valve cover removed, the sludge was so thick it looked like the inside of the valve cover was a molded plastic insert. The owner never changed the oil since it was new. No wonder he had problems at 50K.
    Anyway, the jury still seems to be out as to the ability to extend the oil change interval due to warranty issues and whether the filter can trap the junk after 3000 or 5000 or 7000 or whatever.
    True on the warranty side they must prove the oil did the damage but why even go there?
    I will most likely, just to keep Dodge from using any excuses stick with the OEM schedule. I might be able to go with the "normal" schedule which I believe is 7500 miles. Even if it is 6000 miles that is still 2 times the life at that the synthetic becomes econmically viable (I also do my own changes).
    I have one more conventional oil change left to do on Dakota #1 to use up my 10W30. At least I finally found the Purolater Pure One filters. I will give these a try. Even though I never had problems with Fram and they used to be the best. I know being in manufacturering that it doesn't take much to start making crap and how can most people tell on a product like this? Besides that stupid hand grip they added is enough to make me switch. Thing is a pain in the you know what.
  • brorjacebrorjace Member Posts: 588
    The most troublesome contaminant in your crankcase (assuming you're using a good filter) is probably water and the corrosive acids it can produce ... but if your PCV valve is working the engine will get rid of this once it reaches full temperature (after running 20-30 minutes). So, extended (anything over 3-4K miles) drain intervals are not the problem you'd think they'd be.
    armtdm, I wouldn't use the sparkplug analogy if I were you. Most people I've talked to agree that the platinum plugs deliver SLIGHTLY less efficient performance ... but seem to last practically forever. I still use copper plugs, but I change them almost once each year.
    Yes, the synthetic blends are a bad investment. They cost 50% of the price of synthetic but offer only 10-20% synthetic.
    Synthetics DO NOT cost more to use than dino oil ... at least not significantly so. If you take the following points into account:
    1) Synthetic oils save you fuel in the form of reduced internal friction and pumping losses ... at least 1-3% depending. This is hard for most people to notice ... but can save you $5-15 per year if your fuel bill is $500.
    2) You can extend the drain interval safely. I would change out dino oil and a filter about evert 3-4K miles. With Mobil 1 I go 5-6K and with Redline I'm gonna try around 9K miles between changes.
    3) Synthetic oil doesn't burn or boil off like mineral oil does so there's less (or in my case no) topping off between changes.
    When you add all of these three factors together, they cancel out the price difference ... or reduce it to $2-3 annually which is insignificant when considering the price of keeping a car on the road these days.
    --- Bror Jace
  • vguardvguard Member Posts: 78
    Not trying to promote any one particular retailer, but since these sales on "Mobile 1" only come along once a year, I just thought I should let everyone know WalMart has the "5qt Mobile 1" on sale for $17.88 (which works out to $3.58 per qt, before tax). That is about $ .90 cheaper than the regular price of $4.47.
    I just spent the morning returning all the "Mobile 1" I paid $4.00 for (Kmart sale last week), and replaced them with these large 5qt containers.
    Now if I could only find the "Mobile 1" filters on sale......
    Thank for useful information!
    With 2 cars x 2 changes per year x 4.5 qts per change this will be $18 economy during the next 12 months, comparing with buying the oil at usual price at my usual place: $4.49 at Pep Boys.
    Looks as it does pay to drive to Wal-Mart this Monday, and to buy 4 bottles. Though, one of my cars is using 5W-30. Is the cheap Mobil-1 available in the weight?
    in all weights if they didn't sell out. They had a bunch of it at our welconm to Wal.
    Later
  • treyh1treyh1 Member Posts: 34
    Before you pay $6 for a Pure-One, check to see if there's a Motorcraft filter for your application. Same guts as a Pure-One (you don't think Ford really makes their own filters, do you?), and costs just a little more than a regular Purolator.
    This might almost be boring, but I am going on 85k on a TLC at 15,000 mile intervals using 5-30w Mobil One oil and OEM filters.
    I have changed the oil a grand total of 5 times and the 6th time will come due at 90k miles. Oil consumption is app 1/4 to 1/2 qt at the 14k mark.
    This vehicle not only is a stop and go 5 day a week daily driver with 35 miles one way, but on the weekend is the "load box" on wheels for the recreational trips.
    The last time the dealer had the valve covers off was at 60k, for the HIGHLY recommended valve check and adjust. Not only did the valves fall within specifications, but the technicians were amazed at how clean the inside of the motor was.
    If I had used the 3k interval with conventional oil, I would be on the 28th oil change. I am also sure the oil consumption would also be higher, but on this vehicle specifically, I have not been able to do an A/B test. Incidently the local dealer does the oil changes with me providing the oil and filters.
    Excellent. Of course, the type of driving you do has a bearing on the intervals. Mine, 12,000 is about max. None of my cars have ever had the valve covers of, oops, one did, a 91 Corsica with once a year changes (about 8,000-12,000 a year) , mechanic said it looked fine! Accident killed this one at 128,000.
    It might be interesting to dispell the myth that synthetic oil cost more per mile. If I had done the 3k interval the cost would have been 840 bucks for 85k miles doing the synthetic, 15k interval, as delinated it cost 282.
    Good point. The comparison of per-mile cost between petroleum-based oil and synthetic oil depends heavily on the change intervals. If you change synthetic every 5,000 miles, yes it will be more expensive. But if you're talking 15k mile intervals, synth is much less expensive.
    The comparison also depends on how cheaply people acquire their oil. Some folks say Mobil 1 is 5 bucks a quart. Maybe if you don't look around, but it's easily had for 4 bucks a quart and often even less.
  • yupyupyupyupyupyup Member Posts: 16
    I have a Dodge Caravan 3.8L with 106k miles on it. It have had 3k oil change intervals using regular petroleum 5w-30. I just picked up a couple of 5 quart jug of 5w-30 Mobil 1 from Wamart and was thinking of experimenting with the van at the next oil change. Question: will I be able to go beyond the 3k miles with the synthetic say like 5k miles or so. And will my engine be noticably quieter and get better gas mileage. Will this cause leakage as some people has claimed? Thanks for your comments.
  • brucer2brucer2 Member Posts: 157
    5k changes should be fine. There shouldn't be any oil leaks. I doubt that it will be quieter; maybe a little smoother. Gas milage may go up 1 - 2% (not much). It's not a magic liquid, just better than the conventional oils.
    #1231
    From a cost standpoint why would you want to do that? Conventional oils fulfill the manufacturers cycle of 7.5k oil changes or whatever your manual says.
    I change when the oil gets dirty but in any event I go at least 10 months between changes with a good filter(Pure-One, Mobil 1, Ultraguard, or Amsoil) between changes. You're wasting money by going only 5K. But the important thing is you're seeing the light with syn.
    My van uses about 2 quarts every 3k miles. So you think I can easily go 7.5k between changes and keep adding oil as it needed. How can I tell if the oil is still good since it normally gets all dark by 3k miles?
    I sort of disagree for the initial few changes. Your engine, although clean from 3000 mile changes has accumulated some deposits which will clean off with synthetics. As such I would go 5000 then 7500 but see how the oil looks at 5000 first. It will clean the engine. Also, the last time I checked the Mobil 1 site they said the oil seepage was common with synthetics. Maybe it has changed but my experience with this is that if a new engine seepage will occur at about 90,000 and if converted after say 50,000 it will be about a year later that you will see seepage, not really leaks but seepage. That's been my experience over 9 years with about 6 different cars. Still worth it and who knows if it would have happened anyway.
    with the seapage. I haven't experience anything abnormal. Haven't seen that at the Mobil site. I'm not doubting it-just don't think its a big issue. Yea you'll see darker oil earlier at first. Be conservative at first like armtdm says. I'm sure you will reduce your consumption with syn but not significantly. If I were you I'd switch to 10W-30(5W-30 in syn is just not necessary.) I would also mix in a quart of 15W-50. I did that with my '88Ranger which used a quart every 4000 and it cut it in half. Didn't affect cold weather operation or gas milage. I sold the truck a few years ago and 145,000 its still on the road. Pretty impressive for a 2.3L Ford (non-quality engine).
    If you didn't already have the oil, I would have suggested forgetting synthetic with an engine that burns 2 qts. in 3k miles. Just on a cost basis. If the oil is burning because of worn rings, then forget extended oil changes because the oil is being contaminated by large amounts of blow by. In fact, your oil consumption may go up with synthetic.
    So maybe I should just stick with the petroleum oil since it has ran fine all these years with it and I don't want to risk making matter worst such as seepage or getting gunk dissolved all over the engine. So if my van burns 2 quarts every 3k miles, could I just keep adding oil in and that way go longer drain interval since new oil is always being added? I remember that before the thing started burning oil that whenever I change the oil at 3k miles it would be pretty dark but now at 3k miles the oil looks pretty good. I guess that's because new oil is always being added right? Thanks for all your comments guys. I will save the 2 jugs of 5 quarts M1 5w-30 for my other cars.
    I pulled up the Amsoil website, and they claim it last 1 year or 25k. Since a new car cost about 20-40k, who really cares [on a cost basis] if the oil is changed at 6k or 25k. I have a friend that has been a auto mechanic for 30 years. He springs for the Mobil 1 and changes it every 3k. Overkill? Maybe, but he said it is worth it for the peace of mind. My opinion is still the same, dino oil, 3k or 3 months, synthetic, 6k or 6 months. Stretch it out longer if you want, but how much do you really save? Changing the oil/filter on a regular basis is the cheapest and most important maintainence item you can do for your vehicle.
    Its about spending time changing oil. I change oil on 7 cars. I'm 55 years old. The years left to me are not gonna be spent changing oil. But I do want to do it myself because I don't want the junior shop idiot or Jiffylube man screwing with my ride.
    About those chain oil places. I have seen too many stripped or cross-threaded drain plugs and overfilled engines because they weren't drained completely. And I'm not even in the auto or truck business.
    Your mechanic friend who has been a mechanic for 30 years. No doubt a great mechanic but technology, products change and it is the old timers that keep saying "if it ain't broke don't change it". Every old mechanic will say stay with Petroleum oil. They do not want to take any chances and also have not had the opportunity and/or time to learn about synthetics.
    It's like going to an old doctor, sorry but if I have a strange new illness I want a doc only a few years out of his residency, he knows the latest procedures!
    They would see the evidence that syn rally does the job.
    I may have mentioned this, but one of the things that impressed me the most about syn was that there was this old mechanic who worked in a power plant for a bizillion years. He said that in his whole career he never saw anything so dramatic in the area of a change which helped the longivity of a piece of mechanical equipment. It was that the plant switched to syn in ball bearings of a coal mill. The balls in these bearings are over an inch in diameter and they ran at 275 Degrees F.
    Overkill for our cars-you bet- thats me all the way.
  • goodwingoodwin Member Posts: 24
    i have a 2000 ford f250 with the v10, it has 13,000 miles on it. i was using castrol gtx 5w30 with a motorcraft fl820s oil filter on it till this last oil change on tuesday i switched to mobil1 syn 5w30 blue cap. i noticed that when i ran castrol my oil pressure stayed at 1/2, now with the mobil1 in there it shot up to 3/4 and seems to run a little high, is this normal for this to happen??? i cant tell you how much psi its running as ford doesnt put numbers on the gage. thanks for any info you can give me.
    Interesting, they say the opposite usually happens!
    What does our manual say as to what is normal?
    It doesn't make sense like armtdm says. There's got to be something else different. Maybe the oil senser is at the very end of the oil gallery instead of the beginning. Where's it located Did your operating temp change??? Something else changed. Does it (gage) move when you change rpm's. Without numbers on gage 1/4 difference may only be a psi. Yea-what's the manual say?
    I'm going to stai away from them for my Toyota because the filter is horizontal. The anti drainback did not work with the latest Mobil 1 filter. Had some startup noise. Switched to the Pure 1 and the noise is gone. Didn't change the oil so its the filter. I don't know if I'll switch for my Corsica with the vertical filter. I hate horizontal filters. They don't help the engine.In my opinion this is why the GM sixes last as long as they do.
    My experience with the Pure Ones is much better then OEM Toyota as welll. I am a loyal Amsoil filter user but on my Mystique for some reason the Amsoil's kept leaking at the gasket, now use only Pure Ones on it. I have not had the ticking on Mobil 1 horizontal position filters the few times that I have tried it but you may be correct.. Yea, a pure vertical filter is a joy to change (assuming nothing in the way) compared to these horizontal ones.
    I have some packets of 2-cycle oil. It says one of them (1 1/2 oz.) per gallon. My lawnboy calls for 4 oz. per gal. Is this stuff just an additive or is 1 1/2 oz going to be OK for a gallon??
    Al
