A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Synthetic motor oil
12324262829175
  • armtdmarmtdm Member Posts: 2,057
    These always confused me because some say 50:1 some say 100:1. I believe that I would go by the package as there appears to be different concentrations of the oil. If it says mix with one gallon you are probably safe.
  • adc100adc100 Member Posts: 1,521
    I sort of came to the same conclusion. I will probably use just a little extra just to be "safer". The LawnBoy lawnmower I bnought last year set me back a chunk of change. Don't want to take changes.
    BTW, I seem to recall you had a '91? Corsica which you got rid of. That may have been a good move. I have spent a chunk of change on a 92 that I reposessed from my daughter (actually traded her my '94 for her '92.) One thing after another keeps failing. I am just stuborn enough though to ride it out. I'm sort of disappointed because I felt that GM turned the corner in the late 80's after putting out pieces of junk from about 1975 on. One thing though that appears to be solid(relatively) is the auto transmission.
    Al
  • twobrownstwobrowns Member Posts: 52
    I recently purchased a Bonneville SSEI and was considering using Syn. at my next oil change but the pont. dealer where I prefer to have my work performed uses Quaker State Syn. which also has serveral mixed combinations on Syn. and Dino. Very confusing. Any one have experience with Quaker State?
    The blend is a very low concentration of syn. It is designed to fool Joe six-pack into thinking he is getting syn at a reduction in cost. My understanding is that a blend needs to be a minimum of 10%. If that's true then its unlikely that Quaker States blend is much greater.
    Quaker State's syn is a true PAO (polyalphaolefin) and ester base. This is similar to Mobil 1. Personally I prefer Mobil because they more or less pioneered syn in aircraft engines shortly after WW2 and I've read docomentation and tests on their products. Personally I have a problem with Quaker State because of their deep involvement in the Jiffy Lube type industry and their stressing that their oil is good beyond 3000 Miles. I don't know any vecicle which calls for a change less than 3500 miles under severe conditions. Also don't like Castrol because their product is not true syn.
    Personally, I would take the Mobil 1 to the dealer and have him put it in. I've already done that with syn transmission oil- several dealers-no problem. I would recommend that the dealer use the Delco "Ultraguard" instead of their standard filter. I prefer Mobil 1 filters and if the filter has a horizontal configuration the Purelator PureOne. PureOne has a better anti-drainback valve. I think you have a vertical configuration though.
    Al
  • mdecampsmdecamps Member Posts: 115
    What does anyone know/think about Valvoline Synthetic. I know they haven't been around as long as Mobil, but I haven't seen anything to prove that it is not a quality oil. They just came out with a 5W40 syn, which is what my Jetta TDI calls for. I was thinking about giving it a try, but wanted to hear some feedback first.
    Mark
    I believe Valvoline is a quality syn. It is also a PAO/ester. Like I said though- Mobil for me is a known quantity. Also - and this is my opinion as an engineer (I am not a Lubrication Engineer) The purpose of the 5W is to flow at lower temperatures, especially below 0 F. Since syn flows down to -38 F even for the 15W-50. Whats the point?? Also you are better off having the the upper and lower viscosity numbers closer because it takes viscosity additives to do this and they wear out as the oil gets older. ie. (10W-40) I'm curious why they recommend a 40 wt.? I'm guessing they have had bearing problems with the 30 wt. I would keep my ears to the ground on this... Has this engine been around for a while??
    The reason I'm suspicious is that many moons ago I owned a ford 2.3 L it had just been out a year and after a couple of years Ford came out with a bulletin that you needed to use their "special" oil. After 40,000 I was changine out main and big end rod bearings. Get my drift??
    Wow, Great memory. Yea, I owned the 91 Corsica my son drove until he fogot to stop before the car in front of him. Due to age the car became totaled at that point. Had 128,000 and going strong but an small oil leak somewhere. Used synthetic with once a year changes for the last 5 years filter at 6 months. Not manyl problems with it, two water pumps, front brakes went quick but tranny good basic engine too, so easy to work on. He replaced it (now he owns it not me) with a 97 Isuzu Rodeo, nto sure about this one, switched it to synthetic when he got it but we shall see.
    the water pump. I'm living on borrowed time on the first one. That's an ugly job I will farm out.
    My VW Jetta has the TDI engine in it. This little diesel has been around since 1996 and has brought a revolution to diesel engines. It is the first diesel ever put in a passenger car that is peppy, easy starting (even in sub-zero weather), quiet, and gets 49 mpg on the highway! The owners manual actually recommends the use of synthetic oil. They say that 5W40 is the recommended grade, but 5W30 is also acceptable. Up until now, the only over-the-counter 5W40 I could find is the Castrol Syntec that is available through Volkswagen. To my understanding this is a special oil produced especially for VW. I try to stay away from Castrol. There is also the Mobil 1 Delvac that is manufactured for big-rigs that comes in a 5W40. It is hard to find. The only place I have found it is through an oil wholesaler. You have to buy that in gallon jugs. I think I will try the Valvoline. Many European cars are now suggesting 5W40. I think it must have some kind of better properties. It receives all of the best ACEA ratings on the European cars. I would like to hear from anyone that has used Valvoline Synthetic. I have used it in my lawn mower and it seems to be a decent oil (I used 5W30 because that's what was on sale).
    Mark
  • jmsintxjmsintx Member Posts: 41
    Mercedes Benz & Synthetics
    MB AMG's, Porsche & Corvettes have Mobil 1 from the factory, break-in with conventional oil is not needed.
    Effective immediately, MB will be using only synthetic oil in all of their vehicles with the FSS, which usually signals for an oil change at 10k-12k miles. These are MB's recommended synthetics :
    Mobil 1 15/50 & 0/40
    Valvoline synpower full synthetic 5/40
    Castrol Syntec 5/50 & 10/40
    Castrol TXT softec plus 5/30
    Shell Helix ultra 5/30 & 5/40
    hope that helps
  • brorjacebrorjace Member Posts: 588
    I'm not sure why the manufacturers are recommending these 'extreme spread' oils. Even the synthetics in these weights are pumped up with polymeric goo that breaks down and forms sludge and varnish deposits after a few thousand miles.
    Europeans may get funky recommendations because of political considerations. They want the thin base oils for fuel economy standards and the government wants to import as little petroleum as possible so they want long drain intervals. The end result is these extreme-spread synthetics get recommended by most.
    It doesn't sound ideal but it'll probably work well enough for them. If their recommendations goo-up engines in the long run, (over 80k miles) what do they care??
    Here in the good ole' US of A, we have more (and better) alternatives. I suggest people who care about their car use them.
    --- Bror Jace
    I'm with ya. As I said before I'm going to the 10W30 Mobil 1 excusively (except for trying the Redline)
    The rumor and/or synthetic producers say that when a switchover is made to synthetic seepage may occur and then the seals/gaskets will swell again and the seepages will cease. This has not been my experience in the past, however, I recently swithced over a 97 Isuzu Rodeo at 57,000 miles. Engine not sludged but dark coating on parts visible via the valve cover oil filler cap. Anyway, after 1000 miles seepages occurred in three places, looked like the valve cover, oil pan and rear seal. Now after 3000 it appears that the valve cover and oil pan may have stopped seeping. Hoping the rear seal will do so also. Even when seeping though it was not enough to be converned about.
    Although the oil will have only 3000 miles on it I am going to change this weekend and remove the slime that hopefully the synthetic has cleaned up. After analysis I will see whether to go up to 5000 or 7500 on the next one. Gradually getting up to arouond 12,000 miles between changes and a filter at 6 months. The saga continues.
  • namfflownamfflow Member Posts: 202
    post your findings when you get them. it will be interesting.
  • robmb52robmb52 Member Posts: 6
    I have a 2000 Toyota Solara SE with a 3.0 V6 engine. I recently switched from regular oil to Mobil 1 fully synthetic oil. How many miles can I go between oil changes using synthetic oil vs. regular oil? What is the biggest advantage of using synthetic oil? Does anyone think I made a mistake? I live in Rhode Island and our summers are hot (90 degrees or more) and the winters are cold (10 degrees or lower). Plus, I made the switch after running regular oil in the engine for the first 12,000 miles. and, if I wanted to switch back to regular oil, could I without damaging the engine?
    Rob
    The books tell you that syn is good for anywhere from 3 times to 10+ the amount of time that of a conventional oil. It depends on the temperature and amount of dirt involved. There is no one clear answer and only an oil analysis can tell for sure. Mobil has run tests on new vehicles under real life driving conditions where 2 vehicles had their oil changed every 15,000 mi and 2 others had oil changed every 7500 miles. After 200,000 all wear parts in all 4 engines were measured and came up to specifications for new parts. They have also have tested to 25,000 mile intervals with excellent results. They will not recommend this figure. Amsoil will support oil changes every 25,000 or one year.
    Personally I changed every year and a filter every 6 months on my 94 Corsica. My Toyota gets changed every 10 months and a filter in between. I personally use the visual test as an added barrier. That is, if it looks dark and dirty I change.
    If you want to be conservative you could change at the maximum recommended interval in your manual. That's still overkill but a good compromise. Then you don't have the warranty issue. Theoretically the car manufacturer must prove that you neglected your engine even if you go beyond the recommended change interval.
    For my new Sentra the thought of fudging the dates and have enough receipts to avoid issues is appealing. But you will never prove that I did it.
    There is a lot of information in previous posts if you are interested.
    Al
    I am a firm believer in somewhat extended drains, 7,500 on my Camry and once a year on a few others with a filter half way. V6 Camry now has 132,000. However, with the Solara V6, if the same as the Sienna you should read the posts under the HEADING "SLUDGE" as this could be an issue in your engine, not sure. Mine is a 92 when Toyota still may great cars. Also, at 12,000, no problem assuming engine is clean. You can mix, switch back and forth etc etc. Suggest, I lived in East Providence for a while, that in cold winters go to a 0W30 synthetic oil, you will see much easier starting in the morning. Overall, I agree with above, for at least the warranty period stick the the manual for the change intervals, the normal schedule if using synthetics.
  • kruzer1kruzer1 Member Posts: 7
    Amsoil vs. Mobil 1:
    If you folks will permit me, I'd like to hear any or all opinions, good or bad experiences, with Amsoil or Mobil 1. I have read all 1267 posts in this topic and personally prefer the synthetic advantages so I'm not interested in continuing the "Dino vs. Synthetic" argument. I have been using Amsoil 10w/30 for a number of years with good results. My longer mileage experiences include an '88 Chev Nova that I sold at 198,000 miles and my current '92 Bonnevile at 145,000. Both engines perform nearly as new and burn no oil. Can't say I wouldn't have had the same results on "dino" but obviously the Amsoil didn't hurt. I know Mobil 1 is easier to find and a little cheaper, so that's why I'm asking for the comparison. Thanks for your responses!
    I don't want to really persuade you one way or the other. Amsoil is giving you good results so I probably would stick with it. I used it for a year or two and became a dealer to get the stuff cheaper.
    I use Mobil 1:
    They are the first to really pioneer syns on a large scale for jet engines, space missions etc. Army uses the stuff in their tanks.
    They, I feel have the technical know how and money to keep ahead of the crowd (IMO)
    I have an SAE technical report which took place in early/mid 90's. The laid out the program and test results of their oils. They did comparisons against other oils. I can not find this information for any other oils including Amsoil. (the SAE report is Technical Paper #951026 you can order it at 412-776-4841 -$25)Also see post 1266 above.
    Having said all that Amsoil works for you. I'm not resistant to change though- I'm trying Red Line next change.
    Al
    I too use Amsoil and have for the past 9 years with great results. However, at some meeting I was at out of curiosity I met one of the Amosil chemists and asked him about Mobil 1. He said that he thought Amsoil was better (biased of course) but also stated that Mobil 1 was a great oil and he would highly recommend it if Amsoil not available. If you pay the $20 to be a dealer the cost to purchase is the same as Mobil 1. I also use their filters and, based upon my oil analysis I know they filter better then OEM, but so do Mobil 1 and Pure One filters.
    As to technology Amsoil is fairly innovative in their product line with newer weights of oil, also catering to the motocycle market and more into racing then in the past. So is it better to be a huge multinational world comglomerate with hundreds of products to develop etc. or a small company focused on a few lines.??? Tough question. I am slightly peeved at Mobil for backing off of their original claim of 25,000 between changes (with no explanation) which I feel was due to pressure from several areas and they caved in.
    What are the visual differences between dark oil and dirty oil? It's easy to tell the difference between the oil color when new vs. oil color with 3,000 or so miles on it. At 3,000 miles, the oil in my vehicles, whether dino or synthetic, is fairly dark. But I don't know if it's dirty. Can anybody help?
    Oil turns dark for two reasons: oxidation of the oil which means the temperature and impurities are acting on the oil to turn it into a hydrocarbon which is burned (oxidized). The other reason is because of dirt that is suspended and not suspended in the oil. The sources here are mainly carbon and dirt mostly entering through less efficient rings.
    Now if the oil turns equally dark with the same driving conditions for both syn and conventional oil then the culprit is "dirt" (through the rings. This is true because the syn oil oxidizes very little after 3000 miles. It sounds that this is what is occuring with you. In any event. You could do an oil analysis, but thats really a waste of time because what are you really going to do about it. U use oil analysis to determine the wear products in the oil and its condition which would allow you to extend intervals.
    What does all this mean? I think for you it means that you change your oil when it gets beyond a dark honey color close to black (dirt or oxidation? who cares it's dirty). If you are using a good oil filter like Pure One, Mobil 1, Amsoil, or ultraguard you should be able to go longer. I supose that if its black and you do an oil analysis that says you can go longer that's an option. Personally I have only done one oil analysis on my vehicle. I use Mobil 1 and if the oil analysis shows something is bad with say 4000 miles on the oil and it is clean-what to do??? Probably change oil and repeat results after the same amount of miles. Then what?? Ignorance is bliss.
    My bottom line is if the vehicle runs fine, uses little oil all is probably well. I change when oil gets black which depending on which vehicle I'm dealind with its 10-12 month with filter in between. Sorry for the rambling.
    Al
    I'm using a Motorcraft FL820S filter, which many Contour owners at contour.org have said has a Purolator Pure One filter element. In other words, a good filter. The oil isn't black after 3-4k miles, but it's definitely fairly dark. I'll look again and use your comments as a helpful guide. I don't anticipate going past 5-6k miles with the same oil, even if it is Mobil1 and I'm using a good filter.
  • ocelot1ocelot1 Member Posts: 101
    I read that someone was looking for 5w-40 chevron makes a delo400 5w-40 syn and delo400 0w-30syn they have a supreme line 5w-30 10w-30 syn I use the 0w-30 delo in my 3.5 montero and i've tried mobil/penzoil/castrol syn they all seem to work but the delo stays clean for twice as long and its API certification covers all diesels and SJ for gas. for me the most important thing is flow on start up the sooner the better.
  • pepper32pepper32 Member Posts: 23
    Right on Ocelot, I use Chevron Supreme Synthetic 5w30. When it's -40 my pickup needs all the help it can get. That oil has never let me down.
  • pbraunpbraun Member Posts: 11
    I have been doing oil changes at 3k/3 months with dino oil. One of my 3 vehicles has 174k on it, and runs great. However, after reading all of these posts, I decided to try a synthetic. I bought a 5 qt jug of Mobil 1 at wal-Mart for $17.88. I am going to change the oil/filter at 6k/6 months. That is double what I am used to. I read the Amsoil web site, it says their product will last for 25k/1 yr. Maybe the oil will. But where do the hydrocarbon by-products go? I paid to much for my new truck to skimp on a oil change. I know several guys who still stick with the 3k/3 months with a synthtetic. It may be worth it for thier own peace of mind, but is not taking advantage of the product. Most sales info on synthetics says they increase the MPG. Any feedback on this? I have read many posts on this topic. It sounds like Mobil 1, Amsoil, or Redline is the way to go. With a Mobil 1, or Purolator Pure 1 filter.
  • vguardvguard Member Posts: 78
    I just changed the dino oil in my '95 Volvo today with Mobile 1....I also used the Mobile 1 filter....My Volvo has over 135,000 miles.
    I am thinking I will change this initial batch of synthetic at 3000 miles, simply because of how dirty my old oil was today. I have heard that synthetic will "clean" everything up, so perhaps I should slowly increase the time between changes and get rid of as much of the "old" as soon as possible, then start leaving the synthetic in longer. Of course, perhaps just changing the filter frequently will do the same thing.
    If my engine is anything like the end of my dipstick, my engine is dirty. I used my fingernail to scrape off a thin layer of "baked on black" from the end of the dipstick....lets hope the synthetic will help remove all this old dino residue from the engine.
    Wish I had used synthetic on my Volvo from day one, like I am on my new Ford Van.
  • newcar31newcar31 Member Posts: 3,711
    That is the same question I have. I worked at Jiffy Lube to put me through college (I know, I know, you all hate Jiffy Lube) for 4 years. I changed the oil in my 92 integra with Mobil 1 5W30 every 3000 miles. Why? #1 because it was free. #2 I had a unique opportunity to see literally THOUSANDS of cars in my time a Jiffy Lube. When customers would use synthetic and come back in 7500-10,000 miles for their next change the oil would look EXTREMELY dirty. pbraun brings up an excellent point: "Where do all of the hydrocarbon by-products go?" I'll tell you what, they don't get absorbed magically by synthetic oil. I was just too worried about all of those by-products sandwiched between moving parts in my engine. It may work for other people and maybe its just in my head, but I can't go longer than 3000 miles, even with synthetic.
    Well, problem is you were going by what the oil looked like and not by a scientific analysis of the oil. In my experience a the end of a year, 10,000-12,000 miles the synthetic oil looks dirty when cold, relatively amber when hot but oil analisys has come back with wear metals and dirt below the acceptable norm which is what you want. So, like many things in life, looks are not everything! By the way, what brand and/or who makes the cheapo filters used by Jiffy Lube?
    I have read many postings on this forum about people using oil analysis as a means of telling when the synthetic is no longer usable. Has anyone tested their dino oil on an extended drain interval? I'm sure that it doesn't go as long, but I would like to hear it from someone that has actually done the test.
    We used "Mileguard" filters which are made by Fram. They just switched to Pennzoil filters, I don't know if they are made by Pennzoil or not. I used Honda filters on my Integra anyway.
    pbraun: You may not be able to see it. One mile per gallon tops. What can happen is when you put the syn you tend to drive to get better milage because you expect. But hey there's nothing with that. My milage and I thought performance went up in my Corsica when I changed to syn-Unfortunately I switched to the Bosh Premium vanadium/platinum multi-ground plugs at the same time.
    newcay31: It depends on your vehicle. I am also uncomfortable with dirty oil. Its just a "feel good feeling". When oil turns beyond dark honey, its out of there. My 2001 sentra with 2900 miles was changed at 30 miles and If you looked at the dipstick and decided you needed to change-you are a canditate for therapy-big time. It's as clear as must dino oils out of the can- no BS. At 8000miles my '94 Corsica was a honey color. My toyota is at a dark honey going to allmost at 8-9K. Its out of there. A quality filter helps.
    Bluedevils - why don't you use the Pure One filter then you know what you got. They are a pretty blue color to. Check the box before you buy to make sure someone hasn't switched it from a standard one-favorite trick.
    medecamps: anyone in their right mind will use syn if he is truly interested in his vehicle enough to do an oil analysis. Just my opinion.
    Again,my $.02.
    Al
    I'd think twice about buying Chevron "synthetic" oils ... at least until I investigated them further. If you look at Chevron's site, they boast about their pioneering work in isocracking and isodewaxing mineral/petroleum stocks. I wouldn't be surprised to find out that Castrol buys their product (they don't refine anyhting themselves) from Chevron.
    So, I'd guess that Chevron's "synthetic" is actually highly refined dead-dino juice. Still very good oil, but not worth the $4+ per quart that synthetics often command. I recently saw some Delo 400 15W40 and it said right on the container that it was formulated with "Iso Syn."
    Now, THAT stuff, at $1.50 per quart, I would buy!
    And, as usual, I would avoid the formulas with the extreme spreads in them like 0W30 or 5W40. If you DO use these weights, avoid extended drain intervals to minimize sludge build up. They have too much viscosity improver polymeric goo in them for me to trust them for too long.
    --- Bror Jace
    I also agree with avoiding the large spread. So when Mobil 1 10W-30 pumps down to -49F why on earth go to the 0W-30 or 5W-30 ??Like I said, I'm gonna use the 10W for all cars, for all seasons.
    I really wouldn't go just by "color" to assess your oil's condition. That could fool you easily. It's not a reliable indicator. For example, fresh oil in a diesel is dirty in a few minutes, but the oil is perfectly fine.
    Better to go by miles, or if you are fanatical, an oil analysis of some kind.
    I was going to use just 10w-30 on both my Volvo and Ford Econoline van, if for no other reason than to keep from having to stock two different weights, but Ford calls for 5w-30 in the owners manual. Volvo on the other hand, "suggests" 10w-30.
    Life would be simpler if I could just stock the 10w30, but as long as my van is under warranty, I guess I had better use what the manual says, even if I don't understand just what the difference is between the two (10w-30 vs 5w-30).
    Mobile1 costs the same either way.
  • smily1smily1 Member Posts: 104
    I have used different synthetic oils for my SUV from 1k to 42k. I have noticed that mobile-1 has a tendency to form bubbles on my dip stick when I check the oil while the engine is still hot. If I check the oil when it is cold I wont find any bubbles. This has been the case every time I have used Mobile-1 synthetic. This dose not happen with any other synthetics I have used in the past. Those being castrol syntec and Valvoline synthetic.
    Does anyone else experience this with mobie-1 or any other synthetic? Any potential dangers to my motor due to this symptom?
    I use 10-30W for all seasons and use motorcraft filters.
    I have noticed that the Valvoline stays much cleaner looking than mobile-1 or castrol syntech. I dont notice any sound or preformence differences from any of the synthetics.
    Any input would be great.
    Usually this is caused by overfilling the crankcase. I have never seen foaming on a hot dipstick either with petroleum or synthetic. Could it be milky white and condesation you are seeing and not foam?
    I highly doubt its the Mobil 1. There's another piece of the puzzel thats missing. Next time you change put the recommended amount of oil in. I also believe you may have overfilled-big time.
    vguard.. as I said I'm using 10W30 for all my vehicles all year around-period. The manufacturer is worrried about pumpin below zero. Probably above 0 F. they say 10W-30 is OK. I'm just going to tell them I don't drive below 0F. But no one'll ask.
  • brucer2brucer2 Member Posts: 157
    According to the Mobil web site you could use either. I would use one oil also. It would be safer to use the 10w-30 for both.
    I think you all have convinced me to give Mobile ! a try. My new Truck "Perferred" oil is 5 W 30. I have read the Mobile information and it looks like the 10 W 30 actually flows better. I do not have temperature extremes, I live in Northern California and rarely see temperatures dropping below 30. Only once or twice a year. Nor does it get too hot. Rarely does it get over 100 degrees.
    Do you think 10 W 30 is more appropriate than 5 W 30? It would seem to me it would be.
    This is going to be used in the 4.7L V8. I will also use it in my 97 5.2L V8.
  • meca2meca2 Member Posts: 284
    Some synthetic oils the anti foaming agent "settles out" and the bottle should be shaken before it is pored into the engine. Synthetic aircraft turbine oil (Exxon 2380) has to be shaken to mix up the anti foaming agent that settles to the bottom of the can........... Steve
    I had better describe the oil better. It has no color change (it dosnt look milky), just a few small bubbles at the end of the dip stick. Its almost like it has an ever so slight soapy consistency. Its not something that I am too concerned about... but will cause me to switch to the Valvoline next time.
    I have used mobile-1 on 3 different occasions (not consecutive) and every time it does the same thing.
    I have never overfilled an engine. I know better than that. I always fill according to the manufactures reccomendation (5 quarts for my ford 5.0 V8) and check it when refueling, including after every oil change.
    I have a good understanding of cars and their mechanics (have history of mechanics in the family). I have tried to think of anything that would be different that I might have done but cant come up with anything other than Mobile-1 has a different characteristic than the other oil I use. So I pry the net for others that may be experiencing the same as I.
    Thanks for the feedback so far.
    Although I have doubts about what you are saying. I certainly can't dispute it. However-from now on I'll make sure I shake the bottle. Thanks.
    mamfflow- Yes I think the 10W30 is more appropriate. It gives a little more protection as the vehicle warms up to temp-in my opinion. And flowing at low temps isn't a consideration.
    Al
    In northern CA, the only stress your engine/oil will see is heavy traffic and going up long, steep grades. I would use the 10w-30 there.
    Yes, 10W30 (either dead dino or synthetic) is an excellent choice for most applications in North America ... but you will give up 1/4 or 1/3 of a mpg or so because of pumping losses ... even if you can't tell unless you track your mileage fanatically. >;^)
    Still, my car has over 100,000 miles on it (as of 2 weeks ago) and so I use this weight more than any other. In the Upstate NY area in the wintertime, I move down to 5W30.
    Both Mobil 1 and Valvoline Synpower are PAO based although Valvoline is 100% PAO and Mobil 1 has other things in it when they went to their "tri-synthetic" formula. So, you'd think that both would perform similarly. But you never know for sure ...
    --- Bror Jace
    it seems to me that the "tri-syn" was for the PAO, Ester, and VI improver. Don't quote me though. Did you add your Redline yet?? I'm gonna hold off until my mew car has 10K on it. Even though I'm skeptical about the requirement, that's what Redline says. It has been on a Mobil 1 diet since it was 30 miles old. I wish it would have been in when it was driven onto and off of car carrier!!!
    If I am reading the information in the charts on the Mobile 1 website right. The 10 W actually flows easier than the 5 W.
    The cold pumping data list 9300@@ -30 for 10W also the viscosity index is 620 for 5W and 147 for 10W This tells me the 10 W flows and pumps better than the 5W. According to mobil's oen data.
    http://dallnd6.dal.mobil.com/GIS/MobilPDS.nsf/Automotive?ReadForm&Start=1&Count=30&Expand=4.19
    I sure do like these post so much to talk about. All the dealerships around here use 10w-30 all year long we have temps from 0-85F they think I'm crazy for useing/using 0w-30 but some how I've convinced myself its good for me I change my oil more than I need to dino would be just fine for what I do. Anything bigger/better/special is all american.I'm like the trout looking for the pink power bait when the floating mesquito would do. Tony
    That table is screwed up. Numbers are shifted. But in the real low ranges-well below 0 F- like -30, -40, -50 there is not a whole lot of difference between the 0W,5W,10W. These API designations are mainly more relevant to conventional oils which turn to jelly at the above temperatures. That's why it makes no sense to wory about usint a 0W in syn. 10W is more than adequate. I didn't see that 620 VI anywhere- but anywhay that's just a measure of how much oil changes viscosity, I believe in the range of 32F to 212F. The higher the number the less the relative viscosity change (higher is better). Someone may be able to give better numbers here.
