Visitor Agreement.
I've used 20W-50 on worn engines to keep the oil pressure up. I would be interested to see what the readings on a pressure gauge would be at idle and 2000 rpm.
If I go 12-15k miles between changes, will I run into problems with Chrysler if, God forbid, something goes wrong with my engine? Since they specify either 3k or 7.5k changes, can they say that because I waited 12-15k to change the oil (even tho it's synth-oil) that I caused the problem & therefore voided the warranty?
If they do, what recourse do I have? Anyone have any experience with this situation or have any thoughts/opinions?
You could be like the accountant on Shawshenk Redemption and have ... two.... oil change books. One for you and one for them. Stock up with extra oil and filters for receipts. I can't believe I just said that. Just thinking out loud. I have few scruples when it comes to scrupleless auto dealers/manufactures.
But I agree with what you said - I guess I'll change it at the max interval specified in the manual.
And I like your idea, Adc100. ;-) Sounds interesting...
Anyone...?
However Mobil's definition of a true "fully" synthetic is a PAO. Now the container of the ATF says "100%" synthetic. Mobil 1 Motor oil says "fully" and we know its a PAO. Here's what the data sheet says for the ATF: "The product is manufactured from synthesized hydrocarbon base oils and a specially balanced additive system. The synthetic fluid is fully compatible with petroleum ATF products. " I think they are playing games.
Would you consider sharing the 10k oil analysis results?
In what part of the country do you live and operate your vehicles? What are the typical summer temps?
My results after 10K. I live in Atlanta where the summer temperatures average around 95F, winter average low is about 30F. I drive 17 miles to work one way. I average about 17K on the Echo, my Odyssey (18k for 9 mo) for this first year may end up around 24k because I have been traveling a lot for vacations and table tennis tournaments. I don't encounter a lot of stop and go driving because I'll find alternate routes to keep moving.
oil vis oxd nox TBN Fe
2000 Echo 5W-30 12.2 12.2 48.6 7.0 20ppb
10740 miles w/byp 11.8new 12.0new
2000 Odyssey 0W-30 12.0 11.1 34.3 7.2 70
9558 miles w/o byp 11.5new 11.4new
Alert limit >12.5 >100.0 >100.0 <5.0 >300
There are other parameters such as Pb, Al, Sn, Cr, and Cu which are wear products from the engines. Most of the above are oil properties except for Fe.
brucer2: (re:professional credentials). Pardon me, But I didn't think they were required to post on this board here. But seriously, I would like to know the answer- is it a PAO or not??? Perhaps someone out there with sufficient "professional credentials" can enlighten me- I'm stumped.
Al, B.S.Eng.(M.E.), B.S Phys. Sci
Well, I'm not going to try and answer every point but there are some comments I'd like to make.
Brucer2 - just because I'm not an engineer or tribologist doesn't make my points or opinions invalid. Engineers disagree on the issue of synthetic oil's benefits and because they are human, some get "tunnel vision" on a given issue, become stubborn and fail to look at the big picture. So, having the title "engineer" attached to your name doesn't automatically make your opinion 100% valid while canceling out everyone else's ... especially when those layperson's opinions are backed up by at least siome reasoning.
Taass, I like the fact that you initially poked fun at some things I said but if you followed my earlier posts on this board and others, you'd see that we agree about a lot of points. Lots of little things like thicker oil isn't always better, It's the additives in oil that break down first, etc ...
I agree with adc100 that Honda and others are willing to trade a little long term durability in return for fuel economy numbers the EPA approves of. Sure, 5W20 may be fine for SOME everyday applications but for folks who live where it's constantly hot and they drive under higher loads or at higher RPMs, I think they are marginal. For example I drive a '95 Honda Civic 1.5L and I drive mostly highway at around 75mph. This car does not come with a tach but based on Hondas I've driven in the past, I'm estimating I'm turning around 4,000-4,500 rpms ... for hours at a time! Thanks, but I'll take the extra protection that a synthetic 5W30 or, now that my car has over 100K on the clock, a synthetic 10W30 provides.
When people ask me how to clean out their motor using additives, I tell them to forget the additives and do a couple short-interval oil & filter changes using a conventional oil and cheap filter. They are very inexpensive (compared to some services I've heard about) and they couldn't be any safer to perform. I referred to it as a "dead-dino enema," so what?
--- Bror Jace
What an engineering education does provide is the scientific and mathematical tools to make deductions from pieces of information and understand things that we see. Most importantly, engineering is about SOLVING PROBLEMS. Often, that is more art than it is science. I won't elaborate - this could go on a while.
So, I don't care about the crendentials of anyone who posts on this board. In fact, I prefer not to know. What I do object to is: 1. Spouting complete and utter crap; 2. Nonesensical conclusions without reasonable evidence. Adressing the 2nd point: People are sometimes wrong, and that's OK. But, spoken word without due thought is just criminal. If you are unsure about something, think about it and question why things are the way they are. For example - why is it presumed that 5W20 won't protect a particular engine as well as 5W30? I mean REALLY - not just because it's thinner. (Yes, the "presumed" can be read as commentary
Ranting over, I guess I'd better fulfill the synthetic oil discussion requirement that was left short by my meager effort in the last paragraph. I've not done any oil analysis as of yet. I drain at 5Kmi and figure that $20 for an oil analysis is not much less than it costs to change my oil. Perhaps that would pay for itself after the adoption of safe longer drain intervals. Personally, I'm not going to put much money into oil analysis. Twenty five bucks and 20 minutes of my time three times a year isn't a great expense. Shoot, it costs me more to fill up my gas tank right now! And, there's all the evidence in the world to show that I could safely extend oil services with synthetic well beyond 7500mi with the conditions under which I drive. That means I'm playing it safe, keeping expenses moderate, and not piddling away my time on oil analysis. I'd rather have fun driving then worry about whether my engine is happy. But, for some that may be a hobby as well as an intriguing science. To each his own.
Later.
Al
As for 5W20, remember when owner's manuals used to give you a chart for whatever vehicle or machine you'd buy and that chart would show different oil weights for different temperatures/climates? I do, and invariably the hotter the average temperaure expected during operation, the heavier/thicker oil was recommended. Many of us were brought up believing that the thinner oils can't put up with the heat and stress as well as the thicker stuff can. This has always been a basic truth where engine maintenance is concerned. When we see warm 5W20 oil drained out of a car and it's the consistency of water, I think our alarm/concern is reasonable. Think of all the other things that have been added to cars over the past 30 years that have made them run poorly or made them more difficult to maintain in the long run. I'm ready to add ultra-thin motor oils to this list as well.
Sure, synthetics have changed these rules somewhat, but I believe some of the tried and true practices still apply.
Oh, and if you use 6,000 mile oil & filter change intervals and you agree that synthetic oil provides a modest gain of 2% in fuel economy (I've seen tests that suggest 3-4% gains are more common) from fewer pumping losses and reduced friction, then the operating expense is almost an exact wash with mineral oil and 3,000 mile intervals.
--- Bror Jace
I'm becoming frustrated with a lack of information on long term results of 5W20 oil in production vehicles. Trade publications may be my next stop. I've not had the pleasure of draining hot 5W20, but I'm sure it is as everyone says, quite thin. However, Brorjace (here it comes), your perception of the viscous properties of the oil are quite subjective. And, ". . all the other things that have been added to cars over the past 30 years that have made them run poorly. . . " P-LEEEZ! Think about all the things that have been added to cars to make them run BETTER in the last 30 years. Cars today are faster, more reliable, cleaner burning, and much more fuel efficient then they were 30 years ago. That's just a poor argument, Brorjace. NO ONE has yet proven that 5W20 is an inappropriate lubricant when specified in whatever Honda engine we are talking about (Accord I-4?) Think about this - everyone who's posted reservations about the 5W20 oil recommendation has done so sole on the APPEARANCE that the oil is "thin." You'll have to do much better than that to convince me.
So, let's summarize:
1. Brorjace might have thought I was directing some generalizations toward him - I wasn't, but I also might have read his post wrong (my bad).
2. Taass is annoyed that there is no readily available comparative analysis of 5W20 motor oil as it pertains to engine performance and wear. Officially posting a bounty on said data.
3. Formally blasts Brorjace (in a nice way, I hope) for subjective statements regarding the viscosity of his 5W20.
4. Taass continues to question Brorjace's existence in the year 2001 with his list of things added to cars to make them run poorly. I'll take my fuel injection, thank you.
Hey, I probably wouldn't use the 5W20 in my engine if SAE30 was acceptible. But, I want someone to justify my moratorium on the thinner oil. I'll gladly shut my pie hole if someone can point me to a credible source demonstrating inferior protection of 5W20 related to the Honda engine.
I make no apologies for singling people out. It was Brorjace today, who will it be tomorrow? Can't we all just get along? Alright, I'm wearing my target. Fire away.
But if you want to extend the drain interval to say 5K to 10K miles between changes, then it is actually pretty cost neutral when compared to regular oil changes every 3K.
I worked out the costs a while back and one synthetic change every 5K miles vs 1.67 changes of regular oil is only a couple of bucks higher. BTW, I did this for my SVT Contour and MPV which both take 6 quarts of oil vs the 4 for my Buick, and since the oil is the largest cost in a synthetic change, it skews the numbers in favor of the regular oil, and it was still only a few dollars higher. (Less than $5 IIRC)
Not to mention:
1. Synthetic generally offers better protection at the extremes (heat and cold conditions)
2. If you only get a 1% improvement in fuel economy, then that is 50 free miles of gasoline over 5000 miles, check out the price of gas and tell me you wouldn't like some free gas. It might happen with synthetic oil.
3. It makes me feel better.
4. I have more free time since I'm doing fewer oil changes.
A mixture of pseudo scientific and pseudo psycological reasons why I do synth changes every 5K miles.
Cheers,
TB
150,000 miles would appear to me to be an nonimpressive engine life. As I said mobil has done tests with conventional and syn oil on various engines and evaluated wear at 200,000 miles. At least mobil presumably thinks engines -even with conventional oil should last that long.
For at least 30 years-30 weight oil has been the standard of use in automotive engines. This would be hundreds of millions of engines and thousands of engine designers and engineers involved. Apparently they all agreed on 30 wt oil. Honda and Ford may have come up with a new design to take advantage of a lighter oil, but I'm not ready to buy into it. And I don't believe they have.
I think my biggest concern is the level of protection when bad things happen in an engine. To me this would be, say a cooling system malfunction on a hot day. It's not unusual to see cars in traffic jams overheat as they sit there with their AC running. Race engines use 40/50 wt oil with RPM's of well in excess of 10K. Apparently that wt oil is necessary to insure a higher level of protection. Presumably 20wt would not do the job.
I have 3 questions for you:
1. Will the film strength of a 20 wt oil protect moving parts as well as a 30 wt? If so -why?
2. If your wife and daughter (or significiant other) were traveling in a vehicle and the the engine temperature was approaching the upper limit. Would you rather have a 20 wt ot 30 wt oil in the crankcase?? if a 20 wt. why?
3. Will the 20 wt raise fleet milage and allow these manufactures to make more (higher profit/lower milage rating) SUV's/Mini Vans/Trucks
I can't answer "yes" for #1, or 20 wt. for #2 or "no" for #3 so that clinches it for me. It would be interesting to ask Ford/Honda these questions.
Mercedes-Benz USA, LLC
A Daimler/Chrysler Company
March 27, 2001
One of the many benefits of owning a Mercedes-Benz is the confidence that comes from knowing your vehicle is backed by some of the world's best automotive engineers. Of course, another is our desire to make sure you continue to get superior performance as long as you own your Mercedes-Benz. For that reason, we ask that you review and follow the two recommendations below regarding the maintenance of your vehicle.
Mercedes-Benz now recommends pure synthetic motor oils.
Based on vehicle performance testing, our engineers have concluded that for vehicles equipped with flexible Service System
(FSS), continued optimal engine performance at service intervals called for by FSS can only be maintained through the
Consistent, long-term use of pure synthetic motor oil.
For that reason, pure synthetic oil is now the only engine lubricant recommended by Mercedes-Benz for 1998 and 1999 model year vehicles equipped with FSS While conventional oils deliver reliable performance, pure synthetic motor oil is engineered to flow faster than conventional oil, thus lubricating your engine more efficiently. Switching to pure synthetic motor oil at your next oil change will allow your engine to perform at its peak
Among the brands of synthetic oil we suggest are Mobil 1, Valvoline, Castrol and Shell. Detailed information on motor oil for your vehicle can be found in the endorsed Mercedes-Benz Factory Approved Service Products booklet
So, if you are currently using one of the recommended brands of pure synthetic motor oil in your vehicle, please continue to do so following FSS-recommended maintenance intervals. If you are using conventional oil, we strongly recommend that you switch to pure synthetic oil at the time of your next FSS scheduled maintenance interval.
Mercedes-Benz - registered trademarks of Daimlerchrysler AG. Stuttgart, Federal Republic of Germany
Can I do any harm to the engine? It's got 87000 miles on it using dino oil.
Already am using Mobile 1 for the new Camry(4 cyl). I do not mind about little more cost for the added protection.
Any input will be appreciated.
Due to the much better cleaning ability of Mobil 1 I would do another change after 3K miles (to remove accumulated deposits) and then go to longer periods of 6K miles or more. Just make sure you use one of the viscosities recommended in you manual. A 5W30 will probably be the best year round option.
To me, the question "will 30 protect better than 20" is not so much relevant as the question "will 20 protect good enough." If the difference between the oils is insignificant, then why not use the 20 to take advantage of the benefits of thinner oil. Then, there is the fuel economy issue. As one contributor wrote that a %1 increase in fuel economy would offer 50 free miles every 5000. That's generally not good enough for me. That equates to 3 bucks savings (max) which is not even the cost of a quart of Mobil1.
So, I can't find any pressing reasons NOT to use 20 weight, or any overwhelming economic reasons NOT to use 30 weight. So, it's just a toss up right now until I hear otherwise. Let me do some reading and look up the article in AE and get back to you.
My Previa SC is not consuming much oil. Will find out more as more driving occurs.
Looking at 10w30 since I am in So Cal.
Overall, it was a disappointing article - I was hoping they would take a stronger stand on one side (synth is worth it) or the other (it isn't). Just thought I'd mention it, in case anybody's interested in digging it up or in having me dig up the copy I've got laying around the house somewhere.
http://www.autoworldweekly.com/Feature%20Archive/Feature%20Pages/SyntheticOilFeature.htm
I used Mobil One in a Mitsubishi 3.0 V6 up to a 116000 miles and it started to blow oil. Valve guides dropped. No fault of the oil but then again I never saw any benefit either.
I wonder if blended oils would be a viable compromise?
passed smog check since brand new. I always had to take it back to dealer to get smog
test pass. The tranny went out twice. The timing belt broke before the recommended 60K
change. The engine overheat all the time. Always need to turn on the heater just to keep the
temperature gague low. Imagine doing that during summer time. The engine pust out a lot of smoke. So, I am not suprised that your Mitsubishi went out at 116000 miles. Since Mitsubishi makes bad engine, Mobile 1 will not help in this case.
Currently, I am using Mobile One 5W30 on my Honda Odyssey. I used to use Castro Synthetic oil on my Honda Civic for 5 years. After reading about Castro oil not being based on
PAO, I am switching it to Mobile 1. Good Bye Castro. Hello Mobile 1.
This forum is very informative. So please keep up the good work.
ocelot1: as yurakm's article indicated, Mobil invented the PAO in the late forties. Don't know where you get your info.
alanwagen: the "blended" syns have a low concentration of somewhere around 10%. Someone who seemed to know indicated this was the required minimum. It's unlikely they would use much more than this. Save money, blend your own, it would be better than 100% conventional oil. But then again the main advantage of syn is its ability to lubricate when bad things happen to your engine. So if you blended the conventional oil in your blend could start "cookin' "
Mark
I have a very high confidence in the Mobil product because in my former job (Engineering/ Maintenance Supervisor) , I was involved with selection of lubricants. I talked to the engineering departments which most people have no access to. I also received what I felt was honest information. I got benefits and also negatives of products with respect to Mobil's brand and competetor's brands. Ultimately I came to the conclusion that Mobil made the best automotive syn. As a matter of fact an Exxon engineer admitted this to me (his opinion only). We bought mostly Exxon products.
You can check an SAE Technical Paper (951026) which describes the developement in 1995 of their(Mobil 1) current generation of syn oils (Tri Synthetic). This report does not name competetors but describes oils such an com(competetor) 1, com 2, etc. Their goal of course was to maintain their product superiority. They tested vehicles at 15k drain intervals. Engine wear parts after 200K had "almost no wear" and were within the range of specs for new parts.
So, based on my research and information, I have concluded Mobil 1 is the best. It may not be, but unless I can see documentation that says something is better, I'll stick with Mobil 1. I must however confess that I am going to try Red Line 10W30. I really don't have a plan to determine if it's better than Mobil 1. It's really a curiosity issue.
taass...that's the Jan (2001) issue OF AE. Sorry.
http://www.tdiclub.com/
They are always talking about oil (especially synths) there, and would probably have some real good insight for your TDI.
The question of additives surviving could probably be answered very easily via analysis.
