A Mechanic's Life - Tales From Under the Hood
1143144146148149180
    Hmm...that's possible. Time for the "wiggle test"! Thanks for that.
    My ultimate solution might be to just hardwire an under-dash oil pressure gauge. I'm not getting into wiring harnesss issues with a nearly 20 year old truck.
  • thecardoc3thecardoc3 Member Posts: 5,852
    The frame wire insures that the invertor assembly is completely assembled. This video https://www.youtube.com/watch?v=98P5QmYwQ3s at 1:35 shows the frame wire connector with the service cover removed and at 6:35 the connector is visible (its moving fast you'll have to pause it) then a little later in the video you can see the actual wire (red) at 7:08.
    "36" is the pin ID for the interlock out, which goes to the HV battery pack, through the service disconnect and then grounds at the right "C" pillar.
    If the circuit failed open after the invertor, then the voltage at pin 36 would rise to battery voltage (12-14v). Since it stayed low, that confirmed that half of the circuit was operating correctly because it stayed at ground.
    What would be next? What should the circuit voltage be at pin 35 when it is operating correctly?
    If the voltage at that point went high, that would indicate what?
    If it went low that would indicate?
    The next move(s) would be?
    BTW. This is the advantage of using a multiple trace oscilloscope, being able to monitor four channels at a time saves tons of diagnostic time. (I can actually monitor 14 simultaneously with various tools combined.)
    Doc, maybe I'll fly you out to California for this one---the "check gauges" warning comes on randomly on my 1998 Dodge Dakota SLT pickup, and the oil pressure gauge falls to zero. Those are the only symptoms.
    Remove the sender and measure and confirm the oil pressure.
  • guitarzanguitarzan Member Posts: 874
    edited January 2017
    Pin ID 35 is sinusoidal 3Φ power? I don't know the spec. A cursory google shows 500 Volts output?
    If the voltage is too high that is a result of resistance and can be caused by corrosion/heat/a wire burning through on the power controller side.
    If the voltage is too low, a problem with the supply side. Test the batteries? If they test good then the inverter is toast.
    I already did---I drove it all the way home----JUUUUUST kidding, Doc.
    Sure, I can do that.
    It comes from pin 32 of the Power management controller, 12v signal.
    edited January 2017
    Looking at the schematic and the linked trouble tree, the interlock circuit has several connectors and two, one ohm resistors inside of the invertor. Looking at the Power Management ECU you see the power supply for the circuit and a resistor in the circuit, placing that resistor in series with the ones inside the invertor assembly.
    When the circuit is operating there would be current flowing through the circuit to ground and that current flow would be controlled by the circuit's total resistance. As the current flows through each resistor the voltage level will drop. The trouble tree shows the open circuit voltage at pin 35 to be 12v. But what is the voltage supposed to be when it is connected and operational? How much current should be flowing in the circuit?
    In every diagnostic there is often information that makes analyzing the system easier and the answers to those last two questions are what you need to know. Try to find that information.
    The open circuit voltage of 12V at pin 35 means no current is flowing in the controller, indicating that the power supply is also 12 V. Then connecting the circuit allows a total current I = 12/(1+1+Rps), where Rps = the Power Supply resistor.
    The voltage drop across each inverter resistor during normal operation is (I)(1) = I volts.
    The operational voltage at pin35 = 12 - (I)(Rps).
    While the base algebra represents the equation, the question is; "How much current is flowing and what is the value of that resistor in the controller? "
    Having that information in hand makes any diagnostic with that circuit much simpler, and in this case I had no choice but to measure and figure out the value of that resistor as it was presented. Without a spec however, how is one to know if there isn't some issue present that would be sufficient to have an impact on the circuit's performance but short of causing it to code?
    edited January 2017
    How many times do you see someone report their vehicle has a problem, but its a random failure and even though they have had it looked at numerous times, nobody can find the cause. The Prius was one of those cars, and the owner had been told the next thing to do would be to replace the invertor, but they couldn't guarantee that would fix the problem.
    As described, when the failure occurred Invertor pin 36 was at 0v, the thing is pin 36 should be at 0v (or at least very close to it) because that is the ground side of the interlock circuit. If someone disconnected the service interlock, pin 36 would rise to the source 12v signal. The question that needed to be asked and then answered by measurement is what was the voltage at Invertor pin 35 when the circuit failed and it was a 12v.
    What does that mean, and what is the next step?
    edited January 2017
    Before you go wiggling stuff, identify which circuit is failing and exactly how it is failing. To do that, try the following exercise.
    Got an electronics store near you? (aka a Radio Shack)
    Get a 50 ohm potentiometer (pot) Use your ohm meter to measure it and set it to 40ohms. Now take a piece of electrical tape and do a wrap around the pot and across the adjustment knob to hold it in place. Connect one of the pins of the pot to ground and the other one to the oil sender wire. Attach your voltmeter to the sensor wire as well and position the meter so that you can read the voltage. Now drive the car and monitor the gage and the voltmeter at the same time and tell us what you see.
    BTW this is where the oscilloscope outshines the volt meter, the oscilloscope will show even the slightest circuit error while the voltmeter can often miss the fine details. If you have a Hi-res function on the voltmeter or a bar graph display then that will speed up the display and provide more detail. (The graph function can update at as much as 40 times a second while the voltage display usually only updates about 4 times a second.)
    If there is (12-0) V across the inverter at failure, the current through it is the voltage divided by the resistance or 12/2. And this is the same current out of the controller. Is this what you are looking for?
    My work troubles are on my mind (software troubleshooting) and I can't seem to purge them to get in circuit analysis mode.
    edited January 2017
    No. If there is 12V at pin 35, then the circuit after it has failed and gone open. If the circuit failed and pin 36 was at 12V then the open would be after the invertor and then the wiring to the HV battery assembly and the service disconnect would be in play. But in this case with 12V at 35, and 0V at 36 the circuit when it fails is open between those two points. The value I was challenging someone to find was the normal circuit voltage and the current level for the circuit because knowing those values makes following some trouble tree completely unnecessary no matter how the circuit might fail.
    Here is the math.
    One open in a series circuit causes current to fall to 0 amps. The "normal" current in this circuit is found by knowing the correct voltage at pin 35 when the circuit is operating normally that value is 1.5v. However service information actually shows 0-1.5v if you look long enough to find it and 0-1v is too low.
    The schematic shows two, one ohm resistors inside of the invertor assembly, so knowing the voltage drop across them we can solve for current. 1.5/2 = .75 amps. Since the current is the same at every point in a series circuit we can now solve for the internal resistor in the power management controller. Since the source voltage is 12.5, and there is 1.5 dropped after the invertor then the formula is 11v/.75a = 14.6 ohm and that is the value of the resistor.
    Steve keeps trying to say that some computer program should do that for you.....
    Back to the Prius. Trying to wiggle the harness and connector does not have any impact on the circuit, does that mean the invertor does need to be replaced? ($4000) If not, what else should be done?
    edited January 2017
    The enterprise class software was written by programmers. And like the controller resistor value is not documented, the features of this software are not documented well. This week I found that they used the exact same term throughout the documentation to describe three distinctly different entities.
    The idea that a programmer is going to write a routine to troubleshoot their other code is quite comical.
    Regarding the circuit, UNCLE!
    That's exactly how I feel about them being able to design a system that can self diagnose (let alone self repair) much beyond what it can do right now.
    Yea, a lot of people would cut bait on this because the thought of committing the owner to a $4000 expense that conventional trouble tree testing hasn't actually confirmed (and cannot confirm) in this case would and should cause them to stop. If someone would have replaced the invertor, they would have repaired the vehicle, but it didn't have to be replaced to repair it. The next step required dividing the circuit at the interlock at the service cover and that goes way beyond what Toyota directs and allows their techs to do. The failure was in the socket for the service cover interlock and it was totally repairable.
    Problem is in wiring harness?
    Referring to?
    ghost voltages
    ghost voltages
    False display of a voltage in a wire that is in an open circuit usually has a legitimate explanation.
    I ain't afraid of no ghost...
    By using a fixed resistance, you take the possibility of a bad sending unit out of the testing of the circuit. Current does the work of moving the needle gage (not voltage) and the fixed resistance should result in the gage reading not changing, unless of course there is unwanted resistance somewhere else in the circuit affecting the current flow.
    See Doc--when you get tired of working on cars you can sell 'em instead. You'd probably make more money!
    I could have done a lot of things that would have allowed me to make more money, but I've never made making money the most important thing. What I found interesting about that link was that they are looking for several thousand people for service as well as sales, but only advertised a training program for the sales side.
    edited January 2017
    Of course. If guys like you disappear due to the training problem and attrition, the dealers sell a new car and put the eight year old car with the mysterious electrical problem in a landfill.
    SELL BABY SELL!
    edited January 2017
    Exactly and that's where all these 2017 high-tech cars are going once their 75+ computers experience dementia from old age.
    An hours 'labor is an hour's labor. Yes, it takes a mechanic 13 hours to replace the clutch in my Mini Cooper, and if it takes him 13 hours to track down some crazy computer problem in 2025, on a 2017 Prius, then it's the same issue---do you put $3000 in a $4000 car?
    The problem lies with the question..." OK I love this car so I'm willing to sink 3000.00 into my 4000.00 car?
    Here is where it gets dicey, If you KNEW you could drive it another 50,000 miles trouble free it might not be a hard decision. You know your car and how you have taken care of it. It **should** be Ok after the expensive repairs are done.
    Next week someone runs a red light and totals your 4000.00 car. Does anyone think for a minute that the Ins. company gives a rat's rear about the money you just spent?
    Some tough decisions.
  • kyfdxkyfdx Moderator Posts: 269,283
    Forget the totaled car.
    There is no guarantee that you won't need another $3000 in repairs, next month.
    I always use the analogy of car years vs. human years.
    A car with 150K is like a 70 year old man in very good shape playing tennis everyday. Could he play until he is 85? Maybe, yes. Could he drop dead of a stroke in 5 minutes? Sure, why not?
    The problem with repairing 2017 cars in the future is that you aren't getting a new clutch for all that money, or a dent repaired, or recovered seats--you will have the electronics repaired, but the car won't look any different, feel any different--and your stack of "old parts" could probably be picked up by two fingers. It's going to be a very unsatisfying expenditure.
    Let's face it---2017 cars are going to be disposable. You can only hope that your collision avoidance radar, your vibrating, cooled seats, your remote entry motion-sensing tailgate, your lane avoidance sensors, your bluetooth/wifi/nav and all the rest just keeps working for those number of miles you expect your car to last.
    The scary part is how *integrated* everything is.
    As doc memorably pointed out, when you say things like "stability control", that doesn't actually exist as a thing you can point to in your car. It's an entire nervous system. It's almost, I dare say, one of your car's "emotions".
    edited January 2017
    DOC---(this from another topic)---is this even possible?
    "Drove away from the house without key fob in car. Got to destination and realized I did not have fob with me and could not lock the doors. Got back in car and restarted it 3 separate times with key fob being more than 8 miles away!"
    2016 350is F sport
    2,000 miles
    I can think of several scenario's that might allow this to occur. One that would seem the likely could be the Lexus Enform Mobile App. Since you can do just about anything else with the car with your smart phone, why couldn't it double as a key fob? As far as it actually doing it goes, I have no way of knowing I don't see that documented anywhere. Another possibility that would have to be investigated would be some type of failsafe routine intended to prevent the owner from being stranded in the event of some type of a system failure. Again, the Enform app might play a role although not necessarily from a primary function.
    Don't be surprised when cars in the future don't need any key at all and operate via learned facial recognition.....
    edited January 2017
    Thanks for that, Doc. I will forward that idea to the owner. Very weird, to say the least.
    Face recognition, eh? Might not be a good idea for a prizefighter. ;)
    It's taken a long time but one by one people are starting to figure it out.http://www.msn.com/en-us/autos/ownership/how-to-talk-to-your-mechanic/ar-BBy7Y2o?ocid=DELLDHP
    I liked that article--I'll pass it around.
    How many times have you seen me say this in the last five years or so that I have contributed here?
    Step: 2: Tell Your Tech the Symptoms (without guessing the causes)
    What happened with that writer is exactly why I keep instructing technicians to gather all of the pertinent information about a vehicle issue, but when you start actually diagnosing the failure forget all of that and concentrate on exactly what the car is doing right now. This even applies to a problem that shows up when they are working on a given car. Traditional advice was to go back and look over what you just did to see where the problem (mistake) is and that is actually bad advice because it starts off with an assumption that isn't based on any other information. Of course it's logical that a new problem could have been an unintended result of the present service but starting off with a guess at any point isn't logical at all. What the tech has to do is close his/her eye's and immediately forget everything they know about the car and just analyze the new problem like it's a car that just came in the door with that condition. The result of that approach is they will go straight at the problem whether they caused it or not.
    The parallel here was the tendency for people to go online and get guesses about what might be wrong with their car and then take those guesses and start shopping prices before anyone ever began to genuinely investigate the situation and prove what was really wrong. That activity caused more problems between consumers and shops than it ever solved. The only thing about that which has never really been investigated was if creating disconnects between the consumers and the shops was actually the intention all along.
    edited January 2017
    So that you know Doc, this is not unique to cars, but it happens often in IT. A few days ago my boss walked in and exclaimed, "System X has a problem. How do we handle it when Y causes this?"
    Y is one typical cause of the X problem, but this time, the cause is Rare Issue Z. Since I am the expert, I make sure to identify the root cause myself. But I have seen IT analysts go in circles. For some who have a tyrannical boss who always feels the need to control the situation and point them them in a certain direction, the stage is set for a lot of wasted time and energy as the lowly worker does as they are told.
    I hear ya guitarzan. Did you ever notice how just letting experienced people do their jobs often produces amazing results?
    Of course, if it's a good tech, they follow the diagnosis procedure, no matter what the customer says. :p
    Quote from another technician...
    Had a customer in the bay once when I worked for someone
    else telling me " all you gotta do is..." . In front of the
    boss, told customer "what you need is a 20 dollar bill, a
    lawnchair and a twelve pack. The twenty rents my tools
    ,while I sit and drink the beer and watch."
    The body shop segment starts at 3:15
  • xwesxxwesx Member Posts: 17,793
    I found Steve's dream machine! It might be a tad on the expensive side, though....
    A good friend of mine is a principal employee at this company, and has worked on this project for the better part of fifteen years. The result is rather impressive, and is the result of a Navy bid request that was, by all standards, ridiculously impractical (even today, but definitely back in circa 2002).
    What's so special about it? Well, every component of the vehicle is modular, meaning that maintenance is a matter of swapping parts. Space and weight are at a premium on a ship, so there's no room for redundancy and no tolerance for down time.
    Why would the Navy need cleaning machines when it has access to so much slave labor? :p
    Hah, well, that's exactly how those decks were cleaned before this!
    Welcome to 2017. Here is the newest ACEA standards, dated December, 2016.
    http://www.acea.be/uploads/news_documents/ACEA_European_oil_sequences_2016.pdf
  • roadburnerroadburner Member Posts: 18,484
    edited January 2017
    I simplified my inventory; my Wrangler and mowers get Mobil 1 10W-30 and the BMWs all get BMW 5W-30.
    So far so good...
    Cardoc, I read through that table. It all looks like the oil standards today are primarily European emissions convoluted nonsense. You tell me, because I don't know, particularly anything about diesels, but will violating these standards in the modern engines cause catastrophic failure?
    If you misuse a low HTHS North American spec oil in a European vehicle that requires a High HTHS then it can absolutely do significant damage to the engine. The Euro's run flat tappet camshafts and require a thicker oil (A3/B3-A3/B4) than the North American and Asian manufacturers. North American and Asian vehicles are running low tension piston rings, shorter piston skirts and moving the top ring much higher on the piston on top of using roller cams and benefit greatly from the usage of thinner oils. The A5/B5 mentioned is the thinner low HTHS. What's really interesting is the A1/B1 specification and what they are doing with it.
    The biggest thing that consumers have to be aware of is how the oil doesn't just protect the engine, it also has to protect the emissions control system meaning the O2 sensors and catalysts. Ruin the catalyst by phosphorus poisoning on a newer BMW and the owner is looking at a repair that can easily go over $6,000.
    edited January 2017
    The Euro's run flat tappet camshafts and require a thicker oil (A3/B3-A3/B4) than the North American and Asian manufacturers."
    "A thicker oil" - While technically part of the spec it is was my assumption that one uses the appropriate viscosity for their vehicle.
    Are Euro flat tappet engines similar to old American technology? Because the engineer at the 540 Rat blog has thoroughly proven that it is a good oil formula that protects an engine, that thicker oil does not increase protection, and actually reduces it. On his 800 HP rat motor he usese nothing thicker than 30 weight. He has shown that thicker oil slows the flow, and that reduced flow causes wear.
    Consumers should not put up with a $6,000 catalyst system. This is where gaining that last 2% effect exponentially increases cost. I love the environment, but never that much.
    This is where we really have to do a lot of research and study to try and grasp just what this all means. One educator phrases it this way. "You can't look at just the SAE viscosity written on a label and judge the real world viscosity of a given product." He continues with "A 5W30 approved for BMW's LL01 specification is thicker than most 10W40's and a 5W30 approved for GM's dexos is thinner than a non-approved 5W20".
    Now those are both 5W30's but 5W30 is a very large category and if you don't choose a product by the O.E. spec approvals or ACEA ratings you could mistakenly substitute a 10W40 for a 5W20 or vice-versa.
    He is correct in some cases and maybe not totally correct in others. A thicker oil will protect a flat tappet camshaft better than a thinner one. In fact when building an engine the oil selected should primarily be focused on exactly that, the camshaft. Then you should design and build the rest of the engine to match the oil choice that best protects the camshaft.
    When hot-rodders first start playing they often start shoving in a different camshaft and valve train without any changes to the crank and bearings. They go to a thicker oil because of the tribal knowledge that thicker oil, and higher pressure is supposed to be better only to find out they end up starving some rod bearings and blowing the engine. While thicker oil is harder to wipe away it doesn't flow as fast as a thinner oil which means under severe loading oil that gets squeezed out risks not being replaced with fresh oil flowing back into the bearing. Thinner oil of course can be squeezed out easier, but since it flows faster it is replaced easier.
    BTW it is a myth that oil under pressure floats the crankshaft inside the bearing, the effect of hydrodynamic lubrication is closer to a tire hydroplaning.
    Last I checked BMW wasn't marketing for a consumer to drive their cars.
    Most of the BMW catalyst systems I've run across average around $1000-$2000 depending upon the car. I4s get one cat while I6s get two(cylinders 1-3 and 4-6), and V8s and V12s get one per cylinder bank. Plus labor, of course.
    edited January 2017
    I see your point on viscosity. This is quite a varied parameter to toss in the mix.
    "SAE" versus "real world." The rated SAE viscosity is measured at 212°F. Previously accepted engine operating temperature was 230°F, and who knows how far the engines exceed this, particularly BMW who eschews all other standards (because it knows better than everyone. ) The oil viscosity changes dramatically with the temperature change, so the viscosity in a hotter engine would be a complete unknown, and probably too thick. So here is a rating on the bottle that should be thoroughly adjusted for modern engines.
    Instead, we'll leave that murky standard, and let all of the OEMs set their own temperature range, and sell you a bottle that you must use for $9 a bottle. Just great, another profit center for something we have all considered a commodity for a long time.
    Everything you post does support your premise that things are getting far too complex and proprietary!
