Subaru Crew - Meet The Members II
1686687689691692
    Well that's encouraging! Honestly, my first choice would be the XT, but if that's out a WRX 5-door would be an acceptable substitute. ;-)
    I will not be buying a sedan or anything with a CVT.
    The OBS has been surprisingly expensive to keep on the road, much more than my previous Subarus. The front suspension was shot at 100K (visibly leaking and causing obviously uneven tire wear), along with the sway bar links (clunking and wallowing over every bump in the road), which cost a cool $1500 combined to replace. :-(
    And I had to replace a wheel sensor for the flat-tire warning system at a mere 77K miles, very disappointing, AND the malfunction light is back on now in the dash. I would have paid to delete this system when the car was new, it has no value for me at all, so having to pay to fix it repeatedly in such a young car is pretty irksome. My alternative is to drive around with a bright orange warning light on all the time.
  • xwesxxwesx Member Posts: 17,963
    I hear ya on that!
    So far, my check light has stayed blessedly quiet, but I've done a myriad of other things with it.
    I replaced my shocks at about 70,000 miles, which was before they were totally gone, but the new ones still made a marked improvement (gas shocks have an operational lifespan of 50-75K miles, even though most people run theirs much longer!). When shocks get worn, it puts a lot more stress on other parts of the suspension. I also put heavy duty springs on at that time so the car can better handle heavy loads... and boy, oh boy, does it ever! Total, that was about a grand in parts.
    Issues, though.... I had to replace the oil pump seal at about 66K (that was an emergency repair while on a trip), then the center differential's bearings/races at 95K as well as head gaskets. After the differential was repaired, the car was quiet enough that it became obvious I had wheel bearing issues, so both rear wheel bearings were replaced a few days later. Thankfully, all that stuff was under warranty (best $1,500 I ever spent)!
    I think all is well for now, but I imagine that TPMS will have issues soon enough. We've had the car 7.5 years now, and I am pretty sure those wheel sensors are battery-operated (hopefully not!). Overall, I figure that if I wasn't spending money on this car, it would be money spent on another. ;)
    You have a good attitude! :smile:
    By coincidence, I had a new intermittent problem start to occur today during a 2-hour drive - the radio is cutting in and out, just losing all power and then coming back on a few minutes later....I really expected less repairs from this car until at least 150K miles, based on all the Subarus I have had in the past. Still really like the car though, so I guess I will keep fixing things as long as nothing gets TOO expensive.
    (I had heard they had the head gasket problem in the 2.5 under control by the '09 model year, but if the head gaskets go, that will probably be the final straw and the car will go - will hate to see it go. I did have to replace the valve cover gaskets before 100K, another thing I would expect to last longer than that).
    You would think so, but not really! It was a basic design flaw in the non-turbo variant of the EJ series 2.5L engine: It has an open-deck design, meaning that the engine's cylinder walls are not supported against the outer walls of the engine along the sides. This made it less expensive to manufacture them (the turbo version of the block requires a sand cast, which means that each engine has a unique cast that is destroyed after the block is poured), but the cylinder walls aren't as stable. So, you induce vibration into the contact point of the cylinders and the head gaskets, and eventually that movement causes leaks to form, manifesting in one (hopefully) of three ways:
    1. Coolant leak into the cylinders or oil passages (least common).
    2. Combustion gas leak into the coolant (typical cause of EJ25 overheating issues).
    3. External oil leak.
    In about 2003, Subaru required the use of Stop Leak (they call it Subaru Coolant Conditioner) in the coolant of the EJ25. This, combined with a modified version of the head gasket material, drastically reduced the frequency of #1 and, to some extent, #2. Now, the most common issue is the external oil leak which, admittedly, is the least alarming of the three (and certainly the least disabling).
    The issue wasn't really "fixed" until they created a different engine head design, which they introduced first to the Forester in 2011 (the "FB" engine), and then to the rest of the line in 2012 (IIRC). From what I've read, the block itself remains somewhat similar, but the head is redesigned to route coolant differently.
    Mine was the external oil leak, but it started weeping very early in the life of the car (around 30,000 miles, IIRC), and it wasn't until the visit for the transmission that the tech actually volunteered that the gaskets were, indeed, leaking. If you look under the car, just to the inside of the exhaust ports, you will see the large black gasket that separates the block from the heads. If it is wet there, or there are little concentric, dark rings sort of haloing the gasket... that means you have the beginning of a problem!
  • kurtamaxxxguykurtamaxxxguy Member Posts: 1,798
    WRT Forester XT's, the stick shift version was dropped in the USA after Subaru found they didn't sell well enough. There are STI Forester variants in Japan and Australia with sticks, though.
    Also, XT's FA 2.0 Engine, while more efficient than the older EJ25, did have an issue in 2014-2015 with excessive wear within the left cylinder bank. Mine was one of those and while the engine was successfully repaired, I decided to trade to a '17 to avoid possibility of the __right__ cylinder bank going bad. The 17's had a number of refinements and (finally) an interior that's not all black. So far so good.
    Wow, Kurt! Is this your third XT (in a row!) now?
    Yes. Most likely there will be one more after Subaru sorts out the '19 Forester which should be using their new world chassis. The latest Impreza based on that chassis showed excellent resistance to the IIHS narrow width offset crash.
    Well, congrats on the 17! I don't care for the Gen 4 body style at all, but we just lost our '10 Forester to a crash yesterday, so we're still debating what to do about that. My wife really wants a manual transmission in her next one, so we may go with another gen three, or maybe even wait until Gen 5 makes its debut to see if they managed to keep the ugly stick in the closet for this one.
    edited March 2017
    Replaced another TPMS sensor to the tune of $300 this week, in my '09 OBS. That's both of the ones on the right side of the car now, as of 112K miles. Also put in a used radio from an Impreza, to replace my original stereo that had pretty much quit entirely by last week.
    Will I get 2 trouble-free years from this car now? Would have mostly expected that based on my past Subarus, but this one seems to be part of a new, not-so-good era....
    Am keeping a close eye on the Forester to see what they plan to do for the '19 model, since I want the stick and I'm afraid they may drop stick availability even further (or entirely) for the next-gen. A dream come true would be if they decide to start to offer the XT with a stick again...
    YES! Pipe dreams.....
    No more 2010 Forester for us. It was in a collision last Wednesday, with airbag deployment. I suspect they'll total it.
  • dcm61dcm61 Member Posts: 1,567
    edited March 2017
    Wes, sorry to hear about your loss. :(
    On the subject of pipe dreams ... going to Ireland / Northern Ireland again in May; will need to stop and visit with a Forester 2.0D w/ 6 spd manual. B)
    Yes, YES!!!!! :) Have a great trip, regardless!
  • jfljfl Member Posts: 1,399
    Wes, sorry to hear about your 2010 Forester. I sold my Impreza to Carmax yesterday.
    Sorry you lost your '10, but hopefully getting your desired replacement won't be a big hassle!
    As for stick with the XT, Subaru stopped those in '09 because they weren't selling well enough. Given every auto journalist hounds Subaru over that, perhaps Subaru will relent in '19.
    Well, considering that the option of a manual transmission is now relegated to base level only for the new 2017 Impreza (launched yesterday at dealerships nationwide), I would say the chances just aren't good.
    The new Impreza is a good looking car save for the head and taillight designs; those just ruin it. The interior is quite attractive.
    Forester was totaled. I will bring it home on Monday, most likely, and pull some mods off it before selling it for scrap. Sad deal, honestly.
    jfl said:
    Here's a side note regarding tires: I replaced the stock Yokohama Avid S34 tires on my Impreza Sport with Continental ExtremeContact DWS 06. (I've gone thru several sets of Continental ExtremeContact DWS tires on my Subaru Legacy in the past and was happy with them.)
    This change has resulted in a 0.75 MPG drop during the last 7,000 miles. :(
    Been some time since I posted here. We have a growing "Subaru Crew" private group over on Facebook. Up to 81 member as of today; a number are from this group. Would love to have any of you guys over there, if you're interested.
    edited September 2017
    I would, Bob, but it is so nice and quiet here now..... :p
  • hondafriekhondafriek Member Posts: 2,984
    I don't do Facebook, but I do miss the camaraderie that we had here in the past. This is the first time here in a long time.
    Cheers Pat.
    Hi Pat,
    I don't do Facebook either.
    It's a shame that this once wonderful forum is now nothing more than a leasing forum. :disappointed:
    Wes,
    I was in Iceland last month and was jealous of the Forester Boxer Diesels.
    Many of them were rentals, but no soup for me. I had VW Tiguan TDI and Kia Cee'd CRDI wagon rentals.
  • MichaellMichaell Moderator Posts: 267,938
    dcm61 said:
    Wes,
    I'm happy to contribute here.
    Wife has a 2015 Outback 3.6R - about 22,000 relatively trouble-free miles in just over 30 months.
    Beyond routine maintenance, it's had to go into the dealer for a couple of recall issues.
    It's equipped with Eyesight, which we both love on long road trips.
    dcm61 said:
    Wes,
    Ah, how I love me some diesel. I would, without hesitation, get a Forester diesel if it was ever an option. Particularly if they saw fit to equip it with a six-speed manual!
  • fibber2fibber2 Member Posts: 3,786
    Hi guys! Just stopped by to say Hi! I occasionally stop in on the Facebook board, but more likely can be found on the Outback, CRV or Sienna boards of AutoGuide.
    Good to hear from you, Steve! How are your Outback and Sienna holding up? And, you have a CR-V now?
    Hi Steve long time no hear I hope things are good with you.
    Cheers Pat.
    Good to hear from you Steve, I hope things are well with you.
    Cheers Pat.
    edited November 2017
    And another 10 days goes by! I got back from Pasadena, CA last night from a 5 day ASM conference on microelectronic failure analysis and reliability. I gave a tutorial on FIB tools, a tech paper on recent research, and lead a users group and panel discussion. IT. WAS. GREAT! I've been doing this for 20 years, and it's the best week of my professional life. Work on Monday will suck after this....
    We jettisoned the 2008 Sienna LE in favor of a 2015 Sienna Limited Premium two years ago. It's a great travel vehicle. And yes, we bought our daughter a CPO 2013 Honda CRV LX AWD nearly 2 years ago. I wanted her in a Forester, but the prices on similarly equipped base Subaru's were outrageous.
    Family is good, life is good. But I'm getting old.... Sitting in a plane seat for extended periods is getting harder as I get older. I spend most of my on-line time as a moderator on SiennaChat, and participate a bunch on SubaruOutback and a little bit on CRVOwnersClub when I'm not on Facebook or LinkedIn.
    It's good to see a number of you (Wes & Pat) are still around!
    Fond memories, though. That's all we really have in the end anyway! :)
    Hi Steve, good to hear from you. I was in Los Angeles early Nov and just returned home from there yesterday. Vacationing overseas in between.
    I'm guessing your daughter has one or two years of undergrad remaining, exciting times ahead!
    Yeah I have great memories of the camaraderie and empathy of this group. Got me through some tough times especially when my daughter passed away unexpectedly.
    Cheers Pat.
    I still think about that, Pat. It's still hard to believe. And yes, we held (virtually) each others hands a few times over the years. We had a good thing going. I remember fondly meeting up with Kate, Jim, Ken and others on my trips out West.
    My daughter was on track to graduate in May, 2018, Jim, but got temporarily derailed. She took on way too much, got caught up in some unfortunate events that happened to people she felt responsible for, and suffered from total overload. We brought her home a few weeks back and are making progress on getting her back on level ground. Kids.....
    Just goes to show how important it is to have a solid support network! Best wishes to your daughter's relaunch, Steve!
    Steve, Just be there for her. I'm sure she'll bounce back even stronger!
    BTW, I don't think I've mentioned but I've been a grandpa for nine months now. She arrived two weeks before my Audi got to the states!
    Huh. Priorities are clear....! :p
    Congratulations on your addition(s)!
    edited December 2017
    Steve, I hope things get back on track with your daughter, kids indeed just when you think things are going great and then Kaboom and you are back to earth in a heartbeat. Still with all the ups and downs treasure them, it can all go away in the blink of an eye.
    Cheers Pat.
    Wise words, Pat!
    So, Autoguide just published their Lemon's List, and unfortunately, Subaru didn't do so well....
    http://www.autoguide.com/auto-news/2016/01/toyota-tops-fiat-flops-in-autoguide-s-1st-annual-lemon-list.html
    I now have a 2016 KIA Soul SX luxury, and I love it. I am now awaiting the GEN3 it is supposed to have AWD. I will trade in 2 years. KIA has come a long long way in terms of quality and reliability. The Soul has won some awards and JD Power rates them very highly.
    Cheers Pat.
    It is nice to see familiar names during the holidays ;)
    I should have had cookies ready!! LOL
    Happy Holidays to [what's left of] the crew.
    Dave
  • grahampetersgrahampeters Member Posts: 1,786
    G'day
    I now post here very, very infrequently. Like many others, have moved over to FB. Nice to catch up with some family news.
    Sorry to hear about the daughter study woes. I know that one as well, but daughter is now graduated and working in England, so all things pass...
    Seasonal Greetings to all
    Cheers
    Graham
    A happy and prosperous new year to all the folks still here.
    Cheers pat.
    Hope you’ve all had a wonderful Christmas! May the new year be even better.
    Thanks for the sentiments! May 2018 become fondly memorable for you all! :)
  • rob_mrob_m Member Posts: 820
    Hi. Anyone still here??? Haven't posted in ages. Rob M
    Yes. Just me. :disappointed:
    I'm still here. Good thing my computer remembers my passwords!
    Haven't had a Subie in two years.
    My wife liked my Audi enough to get an Audi Q5 for herself.
    edited March 2019
    Where else would I be?? :) Nice to see you again!! You're an Insider, nice to see you figured out our new sign on ...heh So what's new? fill us in.
    You notice we're reviving the Owners Clubs, the Crew was certainly an inspiration!
    Still going along and still living the Subie lifestyle. Loving my black on black 3.6R Legacy.
    Scored a sweet little 2002 bug-eye Impreza 2.5TS wagon for Mikey a while back. Private sale on the side of the road. Great condition and cleanest maintenance record. Unfortunately got trashed in an 'incident'. He was ok. Searched for weeks and couldn't find a decent replacement Impreza wagon anywhere in New England. He wanted a wagon, not a sedan. Found him in the back lot at the Subie dealer looking at an older Forester of all things. Next thing I know we come across a Forester just traded for an Outback with 86k, clean, and completely gone through by the dealer. They wouldn't budge on the price because used Subarus in New England go for 'market value' and don't follow Edmunds pricing. But, my salesman let me on to a little 'secret'. The Forester was actually mispriced because someone thought it was a Premium. It wasn't. Next thing we know Mikey is rolling around in a fully loaded 2012 Satin White Pearl Forester Limited with all the options. He loves it!
    Traded the 2009 Outback with 46k miles for a 2018 Outback (OB #4) in Twilight Blue last June. Amazed at the difference in size between the 4th and 6th Generation Outbacks. Karen can barely get the snow off the roof with a long brush it's so much higher.
    'Visited' my beloved 1983 Mustang GT for the first time in months last weekend. It is in inside storage in an old mill building in town for the winter. Put in a battery and got it running because in two weeks, it is out for the summer and months earlier this year because it hardly snowed this winter and spring is already in bloom. I actually started bringing it to Car Shows two years ago. This year it MAY finally get to the big Mustang Show at the Budweiser Plant in Merrimack, NH.
