Visitor Agreement.
At one point, Delta controlled 98% of the flights in/out of Cincinnati, so that set high fares to all the feeder flights in and out of the HUB (yes, Cincinnati was once a Delta HUB) with little to no competition. Airport board wouldn't allow competing airlines to come in and in turn, allow price competition.
Many, many jobs, two terminals, and ⅔ of the airport support staff were lost due to Delta's and CVG management/gov't malfeasance.
This coming from a person who's flown 1.3 million miles on Delta alone (another 1 million miles on American) and 100s of thousands of miles on another couple of airlines.
It's a bit better now that Delta moved the hub to Detroit, but it's taken a long time to draw other airlines. The others didn't forget how they were blocked from routes in and out of Cincinnati. Southwest is starting limited routes in Cincinnati, now.
Imid.....I haven't driven a Mercedes S Class, so don't know how it compares to the CT6. I have driven a 7 series, but it was the previous gen. CT6 compares favorably to that one, but not certain of the new 7. Assuming the A6 is similar to the A7, CT6 is probably better in some respects, equal in others. It's a good car in its segment.
alignments? Had it done once on that car (the last one on a 3 year plan I had bought for the Odyssey). My dealer checks it when you take it in for a normal service. That was back in June, and all was within spec. tires wearing perfectly too at 38K miles.
I'd get it checked it it's been 2 years and 15000 miles since the last alignment.
The car can drive very well and not be at optimum alignment settings for that model. A point on that is the machine can show the alignment is within the allowed limits of specifications for that car, BUT a good alignment guy for that brand/model will know that the ideal alignment is at a certain point within those specifications and not always at the median point.
My Cobalt's bushings for the front struts were noisy and there was a little play in the steering intermediate shaft. My dealer replaced all that under warranty. My 3 year old Michelins started getting a little noisy after a few thousand miles. My tire shop felt and said there was uneven wear on the inner edges. I told him it had just been aligned when struts were replaced. We rotated tires from side to side and still had noise. He wanted to check alignment.
Hmmm. I went back to my dealer and asked if there were an alignment done and told him the front tires were nubbing on the inner edge. Their charts did not show a specific billing to warranty (GMPP) for that but it would have been done when struts were replaced. They checked alignment a few days later when they had an open slot and the alignment was not done and front toe was off.
BUT the car drove perfectly on all kinds of roads including crossing the grooves between lanes on the interstate for example. The car actually reacted more to some irregularities AFTER the Chevy dealer did the alignment ,with profuse apologies.
So I'd get it not only checked but I'd get it done where they will put it at the optimum settings for that model, whether you tell the tire dealer "No" and have it done at a dealer or you have the tire store do it. You want it to be perfect when you start with the new tires.
I did buy a cordless Kobalt string trimmer. It only gets used about 15 minutes per month in the summer so I saw no point in going with something that was really heavy duty.
1. If I saw one, I'd be spending car money on them which I need to buy cars;
2. I might get cured - stop buying cars - and have no way of relieving my anxieties;
3. The Economy would take a dive and we'd all be in trouble and need psychiatric help!
See, I'm even helping the Economy make leaps and bounds.
On on the highway, it was smooth and quiet. Felt like I was driving an S Class rather than a Cadillac. I had not driven the new generation 740i at the time so I could not compare the two.
I did not consider the Cadillac when I found myself struggling in and out of the CLS400. As soon as I got into and out of the 7 series, I knew it was the right car for me - it is higher off the ground than the S Class was or even the CT6. But remember, I was interested only in a more comfortable entry and exit. The CT6, if given a chance by the media and the car critics, will eventually turn the heads of upscale luxury sport sedan connoisseurs.
I bought a Craftsman 20 volt lithium ion job about 5 years ago and I check the batteries every so often just to be sure they are charged. I'm amazed at how long it holds a charge sitting in the bag compared to the old ni-cads.
If you don't have a lithium ion drill now you otta get one. I have 4 of them and they are all good.
Oh, and do like @roadburner and I do. Don't cheap out. Only a rich man can afford to buy cheap tools.
In other rotten news, not a week after my water hearer blew up the washing machine died. :@
I can't tell you how many times I ran thread on electrical conduit using the standard of the industry Ridgid pipe threading machine when I was working as an industrial electrician while working my way through night school after I got out of the Navy and quit my job with UPS because I was missing too many classes.
So far, I don't think Ridgid has caved too much in quality.
FWIW, when I walk down the plumbing isle at Home Depot I see the old standard Ridgid threading machine. They haven't changed it very much and if they took the key pad off of it which allows only employees to us it, I know could still run a couple miles of thread today.
Some things you never forget.
The professional quality tools are of better quality for sure. They have tighter tolerances and for a guy working eight hours a day week after week, they feel better in the hand and are just nicer.
The professional tool companies have competition that they never had before. Harbor Freight has long had a reputation for selling "Chinese Junk" a term well deserved......however....the Chinese are perfectly capable of making tools to any quality asked for at a fraction of the cost. I recently ordered through Amazon a long bent handle flex head 3/8 "spark plug" ratchet made by a company called Texton for about 10% of the price the tool trucks charge. I just wanted to see what it was like. I have say that it was flawless in quality and it had a 72 tooth gears. Chrome and feel were perfect! NOW....will it hold up under professional demands? Will the chrome peel? Time will tell. I don't care since I may use it twice a year.
I've even heard the pros say....If I pay 20.00 for a cordless drill with auto chuck and lots of torque and it breaks in a year I'll just throw it away and buy a new one and still be money ahead.
The tool business has certainly changed.
I'm thinking of replacing my furnace soon. Got the washer and drier over the summer when we first moved.
as it works and is CHEAP! Craftsman tools are available in the old, heavy raised panel wrenches and also a high polish professional finish that are much nicer quality.
Regarding the Duratec V6's, Porsche had a hand in designing them. We've had a few. Our 2004 Escape had a leak or 2, but nothing else was ever touched in 12+ years and 140+k miles.
Also, Astin Martin V12 starts as to Duratec's end to end.
Here is a tool story.
Big box chain makes a deal with a local large toolmaker to buy one of their licenses to use as their house brand and also contracts with same toolmaker to manufacture them.
This is addition to the tools they already sell under a well known national brand.
Toolmaker expands their production capacity and hires a bunch of people.
Everything goes great for a year or so, then orders for the house brand drop off a cliff, but reps see plenty of that brand in the stores.
Turns out, once the box box chain got the license, they switched to an offshore supplier without saying anything to the toolmaker they bought the license from.
Nothing the toolmaker could do, since they still wanted to sell their main brand to the big box chain.
Facility shut down and workers deemed redundant.
Right after reading about Mike's memory lapse I got this in an email:
"Brain functionality has been constantly increased using this supplement mental tiredness is often a problem of the past using one new capsule Quit forgetting where you left your keys and wallet Adder-in"
It sounds like that shop owner has a bone to pick with tool trucks. Maybe he even had to pay too high of a price when he was starting out.
What I will say about that guys shop is, he has as good of a reputation as you can get around here. Something seems a little fishy.
Thanks for your feedback.
Anyway, I do like the Duratec.
Come to think of it I like a bunch of Ford motors: the Duratech, the 4.6L Intec and the Coyote 5.0L have been nice. Glad I never owned the 3.8L head gasket blower.
RIDGID makes the best wrenches & pipe cutters. I proudly stock ONLY RIDGID straight wrenches, end wrenches, offset wrenches, pipe cutters, tubing cutters, & die heads.
I see that the type I used to use costs almost 9 grand today.
https://www.ohiopowertool.com/p-279-ridgid-1224-threading-machine-12-4-26092.aspx?gclid=CLqOj-jbrNECFUZLDQoddt4Gfg
and the point of this, in the middle of the room, on a wooden base was a cast iron pipe machine, that made the one JM posted look petite. The thing was huge. Man, was it tough to get rid of all that stuff, especially the machine. Not sure how they finally got rid of that.
It's hard to find equipment like that these days.
Roger Over
Today is a Hitchcock day.
2013 LX 570 2016 LS 460
CT6 (and CTS, and the ATS) are moving Cadillac further and further away from their traditional customer base. There's going to be some "pain" involved as they continue to move further away. I think they're on the right track. For reasons only the car gods know, the brand seems to bite me in the posterior, even though I like the way they drive, the way they're made, and the way they perform.
We had a little snow last night and I took the CT6 out in it. Not a lot, mind you....maybe 2-3 inches. Handled the unplowed roads just fine with no drama. I suspect my CTS would have done the same.
Bradd...got a plumbing question for you. My lower level is finished into a rec room with a wet bar and full bath, with my home theater room being part of it. That said, I've got a ton of electronics there. I had access panels in the main plumbing connections to make it easier to detect, and if need be, shut off water if there's a leak. Don't want those electronics get wet.
Anyway, I check the plumbing and electric pretty regularly. This weekend, I found a very small drip coming from a connection that went from copper to PVC. Easy enough to fix. But, I'm also thinking of putting another shut off valve there. That way, in the future, I won't have to turn all the water off when doing such a repair. I can shut off only that area.
Pros? Cons?
Cranked up my stove over the Holidays to roast some prime rib. I bet I personally hadn't used that stove in a couple of years....maybe longer. Anyway, smoke immediately started pouring out of it.
Long and short of it, the ex apparently made something that was sticky/syrupy in the oven.....over and over and never cleaned it up. As such, "self clean" mode won't get rid of it. Don't want to use harsh chemicals. I even tried one of those steamers which didn't work. Called a repairman. He said the ceramic surface was damaged (what?) and using the oven was a fire hazzard.
Looks like I need a new stove. Happy New Year!!!!!!
From my perspective growing up when most cars ran 0-60 in the 12-17 sec range, 9 seconds would have been considered sports car quick! ( Yes, that was the late '70s, early 80's) My '62 Ford Galaxie with a 292 V8 and 3 speed manual would be hard pressed to do 60 in less than 14 sec!
Today's cars are great!
Most cars I've owned have a 0-60 time of around the mid 7 second range. Not blistering by any means, but that's my perception from what I've been driving for the past 25 years.
