Visitor Agreement.
In order to check a car's alignment it has to be put on an alignment rack or a machine and be hooked up to a devise that measures the alignment angles. This takes time and usually a shop will only have one or two techs that are trained to do this. Personally I NEVER have my alignment checked but I do take a look at my tires from time to time for uneven wear patterns.
When my renovations get underway and the washer gets relocated, I'm thinking of getting the plumber to install one of these things to make it easier to turn the washer water on and off:
The one I used did not have the foot switch as the one shown in the link I posted. We had the one that had a 3 position slide switch for: forward (to the right), reverse (to the left) and off (center). That gizmo I linked has to have a reverse switch and it looks like it is on the far left. Must throw it to select forward or reverse and then step on the foot switch. I don't know why it has to be so cute, we never had a problem with the slide switch.
I now notice that the threader price does not include the cart. The one we used had a cart. The electrical guys used to argue with the plumbers not to put it so close to where they were working but rather in a more central location. One day they caught me wheeling it to the location where me and another guy were doing our electrical work and was TOLD, yeah, they TOLD me to put it back since they were working with 4 inch black pipe.
They used to joke (and sometimes I'm not so sure they were joking) that the threader was a real mans tool and since the electrical guys used aluminum conduit that was a lot lighter than the black pipe and galvanized pipe they used, we could haul our work further to use the threader a lot easier than what they were hauling. No argument there. Lifting a 10 foot stick of 3 or 4 inch black pipe took some work. Whereas, even I could lift by myself (back in the day) a 10 foot stick of 4 inch aluminum conduit.
Oh the good old days.
We sell vitamin supplements in this topic for this condition
I like shutoffs everywhere they make things easier to isolate. When we bought our modest ranch it had a shutoff for everything and one on hot water heater. Now there's a shut off on every lav and sink. Plumber even put one ahead of the frost proof faucet in the wall between closet and bedroom since that outside faucet seems to freeze easily if hose is left on.
If I could, I'd put shutoffs on the line to the tub and master shower in the two baths where they share service inside an access.
My hoses on the washer say to replace in 2015. I turn off the water to washer whenever we leave for more than a daytime trip. Friend came home from school and found her house half covered with water from a burst hose.
Reminds me it's time to buy new hoses--it's after 2015.
We have one of those and that is the one Mrs. j likes because she only has to throw one lever and both the hot and cold water is shut off. IMPORTANT: Remember to bleed off the pressure in the hoses like I mentioned a month or two ago so that the filler hoses don't sit with pressure on them all the time especially when the water is shut off because shut off pressure is higher than flowing pressure when the washing machine is running. Doing what we do, bleeding off the pressure after throwing the lever, is why our hoses are as old as the washing machine (over 20 years old).
The lever valve we have is made by Watt. They last a long time but not forever. When we bought the house we have now in '98 it was there when we moved in. About 4 years ago it started to leak at the lever stem. I went to a plumbing supply place and bought another Watt complete unit. Took off the valve assembly and installed it in the original valve body. This replacement should outlast me. I don't know how long you plan to live in your place but I would buy another complete valve assembly unit to have it as a spare for what I did. It will save having to call a plumber to do the same thing or worse yet, solder in a new valve assembly unit. FWIW, the plumbing place I went to did not stock just the valve assembly, they only had the entire assembly and I was very happy about that.
If anyone in here needs a Watt single lever valve body, I have one. New, never used.
Are you confused about shutting off the water and bleeding the hose pressure? I can believe that one too.
I don't know...
Send me a case, Shifty - so long as it is "tax deductible"!
I had to drive down to the dealership where I bought the 740i earlier today - they had ordered a front screen specially made to fit the 7 series BMW inside the front windshield (about $65 - but they didn't charge me - nice!). I live just off the Florida Turnpike which is a delight when trying to get somewhere quickly. I get on the Turnpike and put the 740i into the "ECO PRO" drive setting (supposed to be the most efficient mode of the 4 or 5 options available). The trip is about 30 miles - all Turnpike, I-595 and then I-75. I pull into the dealership and reset the drive selection back into "Comfort Mode". I notice on the bottom of the instrument cluster that my average mpg's were 41.3! That's right - 41.3 miles per gallon! I mention this to the General Manager after greeting him and he said in that drive setting, he also gets over 40 mpg in his 740i when on the road doing 55-70 mph.
That is truly unbelievable, which is why I am asking you (GENIUS) RB - have you also experienced that in the 7 series or even the 5 series?
I put the drive setting back into ECO PRO for the trip home and again - 40.9 mpg's for the 30 mile trip. That is astounding in a 320 horsepower inline 6 turbo in a 4300 lb car. How is this possible, RB?
Check it out in one of your 740i's - I think you'll be astonished as I was - and it's a great selling point!
Thanks for posting about floodstop. Fairly expensive but can be put in by consumer, for the washer at least.
In case anyone wonders how the valves work.
It would be interesting if RB can get a hold of a 740i to try it out. It is not set for "Imperial", it is set for "US".
2013 LX 570 2016 LS 460
And remember VW passing the emissions tests US with a little manipulation.
Not California. Not Florida! Laughing to myself. Of course the bits of frozen ice on the window caused this BUT why could it have given trouble at 70 deg. F?
Some manufacturers' MPG calculators are wildly optimistic (and inaccurate).
Very informative link.
Never gonna happen, at least with this vehicle. Be interesting to see how Subaru approaches this.
Who?
No Watt!
It does everything well including not feeling underpowered, so I really don't have an excuse the ask about the Fusion Sport that I saw when I bought my car about 3 months ago.
It has 'Special Order' printed on the sticker which was why I didn't ask about it at the time, but it is still there.
I think the Cruze did very well in the last yearly ratings. GTI got a 20.
Chrysler performed miserably; makes the GTI's score look relatively high.
Of course, the cars can do well better. Just the drivers can't, or won't.
@abacomike
I had a memory lapse today so you're not alone--it's just my age. I just realized hours later that I could have turned on the heated seat in the Cruze besides having the heater on high. I forget about the heated seats unless my wife is with me. She always turns hers on for her lower back problems.
I admit to the same lapse as you as far as the heated seats. When Mrs. j turns on her bun warmer she always asks if I want her to turn mine on too. I've had cooling seats in both my '09 and '15 Genny and I almost never remember to turn that on.
He realizes now when the window mechanism was noisy when there was frost on window other days, he should have said something and we could have switched cars and taken it into dealer at our convenience. The window failed since summer when it was okay. It wasn't just today's ice because he had scraped the drops of frozen moisture off when he did the windows before leaving home. I think the cables were failing slowly on earlier days with the hard pulls to move window when there was frost on it. This is the first window failure on a GM car for me.
I said something to the effect of welcome to car ownership now that the car is in his name...it does have an extended warranty to 90K miles.
