Audi R8 Lease Questions
MichaellMichaell Moderator Posts: 268,700
edited February 2016 in Audi
Ask your R8 lease questions, here!
«13456
  • bolteonbolteon Member Posts: 20
    Could I get the numbers on the R8? I've been searching and can't seem to find them...
    Standard lease terms, base car. MY `16 (Gen I) and `17 (Gen II) please and thank you.
    Much appreciated.
    Much appreciated.
    No 2016 or 2017 R8 lease numbers are available to us, yet.
    Much appreciated.
    For the sake of reference, do you have the 2015 then? Or whatever is most recent...
    Cheers.
    Much appreciated.
    Cheers.
    .00158 and 62% for 36/15 on the V8 model.
    Much appreciated.
    Cheers.
    What's the max MF buy-down with MSD's for AFS?
    For clarity, those numbers are MY15, yes?
    bolteon said:
    Much appreciated.
    Cheers.
    Yes, 2015.
    I believe Audi allows a maximum of 9 MSDs, each of which reduce the MF by .00005
    bolteon said:
    Much appreciated.
    Cheers.
    Yes, 2015.
    Much appreciated!
    Hi again,
    What's the residual on 48 months?
    Also, any idea on when MY16/17 numbers should be available?
    Cheers.
    bolteon said:
    Hi again,
    Cheers.
    .00164 MF and 52% residual for 48 mo, 5K/yr lease (new numbers for February).
    I'd guess the 15K/yr residual would be 42%, but it might not be..
    No clue on when the new programs will be out
  • lambusserlambusser Member Posts: 48
    What are the current 2017 R8 numbers for 24mo and 36mo. MF and residuals for 5k and 7.5k?
    For the V10 and V10 Plus models.
    Lam
    Lam
    Which trim level?
    Do you mean paint/features beyond the V10 or V10 Plus?
    Looking at V10's in the 182k range and V10 Plus' in the 202k range.
    - 20" Tires
    - Sport seats
    - Dynamic steering
    Does that help?
    Lam
    - 20" Tires
    - Sport seats
    - Dynamic steering
    Does that help?
    Lam
    .00186 MF and 65% for Premium/Premium+ or 59% residual for Prestige trim, 36/5K/yr
    Subtract 1% for 7.5K/yr
    v10 and v10+
    florida
    What term/mileage?
    gururob said:
    v10 and v10+
    florida
    What term/mileage?
    .00188 and 67% (Coupe) or 62% (Coupe +)
  • amgeateramgeater Member Posts: 20
    Hi can I please get the numbers for April, South Florida
    2017 (Coupe)
    24/10 & 24/7.5
    36/10 & 36/7.5
    Thank you in advance !!
    2017 (Coupe)
    24/10 & 24/7.5
    36/10 & 36/7.5
    .00201 and 73% (24/10) or 66% (36/10)
    Add 1% for 7.5K
    gururob said:
    2017 (Coupe)
    24/10 & 24/7.5
    36/10 & 36/7.5
    Add 1% for 7.5K
    Hi
    For a coupe plus the same numbers?
    Subtract 5% for plus
    2017 (Coupe)
    24/10 & 24/7.5
    36/10 & 36/7.5
    Add 1% for 7.5K
    Hi Michael and thank you for the late reply... any change on the numbers for May ?
    any word thank in advance !
    .00195 and 73% (24/10) or 66% (36/10)
    Add 1% for 7.5K
  • r8buyerr8buyer Member Posts: 6
    Thanks in advance:
    #'s for 36/10k and 48/10k for R8 V10 Plus.
    r8buyer said:
    Thanks in advance:
    .00195 and 61%
    .00215 and 54%
    Just to confirm the MF of .00195 and 61% RV is for a 2017 R8 V10 Plus for 36 months and 10k miles? That is vastly better numbers than what my Audi dealer quoted me!
    Also, any numbers for a 36/7.5k lease? Thanks so much!
    62% residual
    Add 1% for 7.5K
    Thank You !!
  • flaury23flaury23 Member Posts: 4
    I will be looking at buying a 2017 R8 later in the year. Any ideas if Audi would still lease a 2017 this fall?
    I'm hoping the lease rates are as good as they are now.
    No insight as to what may happen with the numbers, or even the program availability, months from now.
    If there is enough inventory, a program may be available.
    Just FYI, I cannot find any Audi dealers that quote those residuals with AFS. The MF of .00195 is correct however. The residuals I'm being quoted for the plus are 57 and 59 for 5k and 7.5k. The mark-up on the base MF is obviously negotiable. The residuals quoted me also include mandatory AudiCare purchase (which is a pretty good deal anyways)
    edited May 2017
    Oops. I meant 57% for 7.5k and 59% for 5k. 36 month lease.
    You are correct... above quoted residuals are wrong.
    Let's just say the "standard" mileage allowance is different for the R8, than the rest of the Audis, therefore our adjustments were incorrect. Also, higher mileage tiers adjust differently, as well.
    R8 V10 Plus
    36/5: 58%
    36/7.5: 56%
    36/10: 54%
    Add 1% for AudiCare
    .00195 MF
    R8 V10 Plus
    36/5: 58%
    36/7.5: 56%
    36/10: 54%
    Add 1% for AudiCare
    .00195 MF
    So are numbers for the regular R8 (Non Plus) wrong too ?
    Can you re-check for me 24/10 and 36/10
    Thank you in advance !!!
    R8 V10 Plus
    36/5: 58%
    36/7.5: 56%
    36/10: 54%
    Add 1% for AudiCare
    .00195 MF
    .00195 and 66% / 59%
  • jms135jms135 Member Posts: 10
    Hi do you have updated numbers for june, for 36/10 non plus and plus? thanks in advanced!
    .00193 and 66% (base) or 61% (plus)
    Thank you ! By chance do you have the numbers for the spyder for 36/10k?
    .00193 and 66%
    Wow 66% is strong! just to confirm that is for 10k miles? thanks for your help.
    Oh, wait. Darn, I keep forgetting that the mileage allowances are different for the R8.
    The base residual of 63% for the base Coupe and Spyder are for 5000 miles. Subtract 4% for 10K, therefore the residual is 59%
    54% is the 36/10 residual for the Coupe +
    gotcha, thank you :)
    At least I got the MF right ...
  • formula1fan5formula1fan5 Member Posts: 50
    Hi, Can you please let me know the MF and residual on a 2017 R8 Coupe (base not plus) for 36 months with 5k miles?
    .00198 MF and 62% residual
    Can u please post the August numbers for the base 2017 V10 Coupe for 36 months and 5K miles? Also if you aware of any manufacturer incentives?
    .00192 MF and 62% residual
    No incentives
    Thanks again!
  • eyemd54eyemd54 Member Posts: 2
    Any lease numbers for the 2018 base V10 Coupe yet?
    36/7.5
    48/7.5
    36/7.5
    48/7.5
    .00190 and 70%
    .00210 and 63%
