Which car should I buy ?
sjedmunds1sjedmunds1 Member Posts: 6
edited February 2017 in General
Want to upgrade to used luxury model.
Total Budget $25k
1. Audi A8 (2014) - approx mileage 40k
2. Benz E350 (2013) - approx mileage 40k
3. Jaguar XF (2013) - Approx mileage 40k
4. Range Rover LR2 Base - approx mileage 50k
5. BMW 535Xi - 2014 - approx mileage 60k
my criteria is less maintenance costs, drive 3 years trouble free, not looking for power (good to have).
Question 1: Please advise better option from above
Question 2: Which certified pre-owned option is the best amongst above. I am in Northeast USA, if it helps.
SJ
Answers
  • MichaellMichaell Moderator Posts: 267,958
    Total Budget $25k
    SJ
    Your desire to have a low cost maintenance ownership experience contradicts with every car you've listed.
    Have you considered a Lexus or Acura?
    Let me get some regular posters over here to offer their opinions.
  • qbrozenqbrozen Member Posts: 33,818
    Do you mean Land Rover LR2? First, I own one and it is far from luxurious. It is OK, but it is noisy and doesn't ride very well. Second, $25k for one is excessive. We spent $16k for one with 23k miles. Granted, it is an '09 model we bought in Nov 2015.
    Of those, I believe the Benz has the best odds of being kind to your wallet in the long run. Agree with above that you should give a look to Lexus. I would vote Infiniti rather than Acura, though. Just personal preference, but I don't care for Acura's use of the Honda FWD platforms.
    Vote for the Mercedes or BMW. Probably slide towards the Mercedes because of the lower mileage. And, that gen of E series has been solid and around for a while, very solid.
    As Q points out, Lexus (GS350), Infiniti (Q) and Acura (TL) would prove to be reliable, too.
  • stickguystickguy Member Posts: 54,192
    Infiniti, Acura, Lexus ES all should give the feature content, plus solid reliability. For the MB, how about a 2014 C class? Last year of a solid model run, pretty reliable, cheaper than an E class. And a little outside the box, but a Volvo S80 is a nice car.
    Some non-CPO options (if you pick a reliable brand, can save a huge amount not getting a CPO warranty you probably won't use). Keep in mind that most of these have 4 year bumper to bumper warranty, plus 6 year powertrain, so buy one with an eye toward inservice date, and still have full coverage initially and powertrain for 3 years or so.
    super low miles "big" infiniti. Just a little over budget, but one with normal miles would be less.
    http://www.royaleasing.com/detail-2014-infiniti-q70-4dr_sedan_v6_awd-used-15721104.html
    Normal ES350, nothing fancy but as reliable as an anvil.
    http://www.royaleasing.com/detail-2014-lexus-es_350-4dr_sedan-used-15881186.html
    Nice C class. Actually, look at all the inventory at this place. They have very nice stuff, good prices, and a great reputation. they carry a lot of the options you mention.
    http://www.eimports4less.com/detail-2014-mercedes~benz-c~class-certified_c300_4matic_sport_awd_sedan_camera__navi-used-15579344.html
  • fintailfintail Member Posts: 58,810
    Have 3 year old A8 depreciated that much already? Or do you mean A6?
    Of those, I would actually pick MB as the easiest to live with, by then the platform was 4 years old, and shouldn't have any big kinks. Audi and LR2 would scare me a bit. I agree with the other choices, a C or Japanese brands might be easier on the maintenance budget.
  • sjedmunds1sjedmunds1 Member Posts: 6
    1. Yes LR2 is the Range Rover (in my list above)
    2. If I buy an 2014 E350 (approx 40kmiles) and drive about 20 k miles per year do I need to get a CPO model or no ? Also do I need an extended warranty when I buy ? I intend to keep it till 100k miles.
    Cheers
    SJ
    Any particular reason you are wary of LR2 and Audi A8?? and yes A6 fits the 25k tab. A8 is at least 35k(my bad)
    Punishing maintenance and repair costs. If they're good, you're good. If they go bad, you're ....well...it isn't pretty.
    The LR2 is mostly Volvo, which is why I was fairly comfortable buying one. It does, however have a major and expensive common fault: rear differential bearing failure. It also gets about 18mpg on a regular basis under my wife's care, who gets 22mpg in her van, so I know she drives mildly.
    Reputation mostly. Rovers have a history of not aging well, and Audis are in the same boat, although I think both have improved a lot in recent years.
    And yeah, if the car will be doing heavy duty commuting, I would look for a warranty. These cars might not always break big, but small issues can cost big money.
    just MHO, but if you are looking for something to put 20K miles per year on, starting with a higher end European luxury car with 40K on the clock is not the best way to go.
  • andres3andres3 Member Posts: 14,159
    Better than getting a new one with 0 miles on it though!
    Also, I'd add you should check CR for the latest data. A lot of people here are stuck in their old ways and old-fashioned beliefs :smile:
    I think you'll find that Audi's been making exceptional cars for at least the last 7 years. Infinity seems to be plagued with Nissan's "cost cut at all cost" attitude as of late. Acura has fallen a bit too.
    Lexus is really your only sure-bet as they've been reliable 10 years ago, 5 years ago, and now.
    Thanks to great advise.
    I have narrowed down the choice between S550 4MATIC (slightly older) and an E350 4Matic (newer). Which one will be less hassle and better to drive for longer term ? Both are under $30K.
    Mercedes Benz SL550 4MATIC: $27,470 and 58,148 mi.: https://www.cars.com/vehicledetail/detail/690122055/overview/
    or
    Mercedes Benz E350 4MATIC $29,995 and 26,385 mi.
    https://www.cars.com/vehicledetail/detail/692897376/overview/
    Please send me your advise. thanks
  • kyfdxkyfdx Moderator Posts: 271,579
    Mercedes Benz SL550 4MATIC: $27,470 58,148 mi.: https://www.cars.com/vehicledetail/detail/690122055/overview/
    or
    Mercedes Benz E350 4MATIC 29,995 , 26,385 mi.
    I would think the newer, lower mileage E350 will not only be cheaper to maintain, it may hold it's value slightly better, as it will always have 30K less miles than the S550.
    between those 2, absolutely the E350.
    Google s550 reliability or s550 maintenance or s550 problems, etc. Pretty sure you'd be FAR better off with the E.
    I think the E350 will prove to be the better value now and at resale.
  • mlevinemlevine Member Posts: 595
    Go with E350 as I believe it will be more reliable and has less mileage. Would also get extended warranty for minimum of 2 years.
    How much will an extended warranty cost ? Any idea how many miles can I drive on EW ? Thx
    Check with different MB dealers, suspect a few thousand. There are 3rd party warranties, but be very careful. With MB I know CPO vehicles give you an additional 100,000 miles.
    Do you feel CPO is a better option ? I am planning to buy E350 2014 model or more recent one.  Thanks
    My son purchased a CPO C class 2014 in December. I made sure it was a CPO vehicle. When a lease is returned, a dealer may decide to buy it and make it either a CPO or regular pre-owned vehicle. They will not make certain vehicles CPO as it may require extra money to do it or it has many issues. I would go CPO as I feel you have more piece of mind. Others may disagree with me. BTW, you can still have issues with a CPO vehicle. I have a place up the block from me that sells pre-owned luxury with only 90 day warranty. Many of the local car dealers do not mind as theses vehicles often need work done at there service area.
