Where did you find the numbers for redline? The two that I couldn't find we redline and valvoline products. I didn't bother looking for castrol, but I found kinematic viscosity numbers (and CCS since I live in Michigan) for everything else I was looking for.
As for Bob's comment about possibly having too much moly in redline, if moly is the primary reason you're using it, what about considering cutting it 50/50 with a high quality dino like chevron? Just a thought...
I presume you saw my post, #1345 in "Engine Oil - A slippery subject Part 2." My presumption that STP OIL EXTENDER would come back on the market with a corrected label was nothing more than that, a presumption. After the experience of gregb882, I am thinking the moly+zddp product is off the market permanently. At any rate, you asked about the price: My coupon made it free, but I noticed the price was $6.25 for 15 ounces. That alone could have driven it off the market.
Bob, I see what you are saying about the amount of MoS2 in Red Line. Comparing it to Schaeffer, they DO seem to use significantly more and the numbers I have (from testing a sample of my used oil) don't account for the amount of moly that has plated itself against the metal in my motor and embedded itself in my bearing's material. I don't know how much is in a virgin sample ... and because I'm too cheap to pay for a sample of virgin oil to get tested, I won't know, maybe not ever. The same thing applies to my starting TBN. I assume it's either 9 or 10 but that's just a guesstimate.
Still, I can't imagine going much longer than 7,000 miles on an oil & filter and given my test results, I am comfortable with that interval (TBN was still 4.5) and see no problems with Red Line's elevated moly levels. If I were to stretch my interval to 10,000 miles and possibly beyond, I'd more carefully watch my TBN and see how it decreased over time.
Speaking of TBN, which hurts it more: time or heat & stress? It would seem to me that TBN, the ability of an oil to protect against corrosion, would take a beating just sitting in your crankcase day after day after day. I don't know how much of an effect heat and stress have on anti-corrosive compounds.
And hey, do you know anything about the different types of moly? Do you know what "Red Moly" is? I remember hearing a reference to it but I can't remember where or any details.
n8wvi, I switched to Red Line almost a year ago because I wanted to use the best synthetic oil available. I was still under the impression that the best base oil (in this case polyol) would provide the best protection against the wear that had already occurred using other oils (mostly Mobil 1). The moly in their formula was merely serendipitous, as was its eliminating the annoying piston slap sound in my engine on cold mornings.
As for blending, plenty of blends are available commercially involving PAO and mineral oils but I would not want to purposefully blend polyol and something else. Besides, with my small sump (4 quarts) and drain interval of 7,000-7,500 miles, I am not concerned with the cost. I think I spend an additional $10-15 per year on oil changes.
Bummer on the STP Oil Extender. I remember the golden (copper?) colored bottle and the price which was not terribly attractive ... especially if people didn't know they were getting something significantly different from regular STP. I guess moly as an engine additive will remain an elusive ingredient for the foreseeable future. <:^(
It is simply not valid to be comparing the TBN loss from a snapshot sample of one vehicle with a snapshop sample of another vehicle. There are many factors that affect the TBN of the oil in use. Because an oil in one vehicle has better TBN retention than another oil in a different vehicle, this does not necessarily mean that it is the oil that is at fault, as it could well be an engine condition or one of many other possibilities.
I was told by technician (oil analysis) that TBN measurement is one area where errors are routinely made. I personally had a situation where a lab was reapeatedly reporting low TBN for an engine oil in an extended drain application. (under 5) I then sent another sample to a more expensive (ISO 9002-94) lab and they reported the TBN to be 8.9! This lab also had insisted that I provide a new sample of the motor oil at the time of testing. I do not know all the hows and whys, but I do know the result.
On anitioxidants - in the latest issue of Lubes-n-Greases there is an article on phosphorous in motor oils. Something I found very interesting was this quote: "ZDDP is an excellent wear and oxidation inhibitor". (Jim McGeehan of Chevron-Texaco) A point was also made that all ZDDP additives are not created equal, and that they are not all as evil as some make them out to be.
It is a ill-founded generalization ( IMO ) to say that motor oils which rely on higher levels of ZDDP for anti-wear will suffer rapid TBN loss as a result.
PAO is usually combined with a small amount of synthetic ester to provide even greater high temperature durability and improved chemical solubility. Synthetic esters are manufactured by reacting an acid and an alcohol. The reaction products are water and ester. Esters are very stable at extremely high temperatures and are used almost exclusively in jet engines. Unfortunately, full ester engine oils do not work well in automobile engines due to lower operating temperatures and exposure to moisture. If ester is exposed to high moisture at moderate temperatures, it tends to react back into the acid and alcohol. You can imagine what acid in your crankcase would do to your engine.
I agree, tbn comparision from one engine to another is not a good comparision but was actually a point i was making. that how in a lot of cases and in many cases that too much of a good thing can react to another in this case higher levels of barrier lube mo seems to not allow the detergents to work as well as one with less mo.
I have seen more than just his report using redlie that indicates higher levels of mo and more rapid tbn loss. Is that bad?, well if he was wanting to go 10,12,15 or 20,000 mile drains, it would be but for what he is doing it's fine.
Totally agree with chevron, not all barrier lubes are bad nor created equal. In most cases, it's not the qualitiy of the barrier lube but the amount that is used that has a detrimental effect on the base oil's ability to sustain.
that Metallo-organic compounds of sodium, calcium and magnesium phenolates, phosphonates and sulfonates are commonly used as detergents that apply to tbn levels
and that Zinc dithiophosphates, organic phosphates, acid phosphates, organic sulfur and chlorine compounds, sulfurized fats, sulfides and disulfides are along the lines for barrier lube properties such as zddp (some of which may cross over as double duty).
as for ill founded, OK, you got me, it is my opinion based on all the analysis reports i have seen where when higher levels of antiwear additives were present that the tbn's seem to drop at a higher level of rate than one that was not that high. Another one I found this commonly in was amsoil. Its 12 tbn would drop fairly fast as well, again, higher levels of barrier lube.
I just wanted to post some other results I just did while I had time. I now know that from my little personal tests that mobils tri synth seems to have some differences over the years. the oldest I had was an sj rated, when run, it would plate up in a reasonable time simular but not quite as fast as amsoils. the newer sl grade trisynth, would also plate up but after a longer period of time. Then of course mobils new supersyn oil, I couldn't get it to plate at all no matter how hard I tried.
of course this isn't scientific but it does show me that every one seems to have less and less antiwear barrier lube property the newer it was.
STP 6000 mile oil extender.. first observation showed to be dark and thin fluid like, not thick as the older standard stp additive. The older stp additive plated up in a reasonable time as expected. In comparision, the newer 6k stp didn't fair as well. After the new stp plated, I then proceeded to put some extreme pressure to see if it could be sheared and without too much force i was able to lock it up. The point of this is, that if moly is present it is near impossible to shear it once plated up. so if moly was in this product i'd think it was just barely tainted and that's all. The other indicator of zddp is the caution on the bottle states don't get into eyes also is commonly used in high does of zinc. This statement is not normally indicated in moly additives.
The falex main purpose is to determine how the barrier additives react to extreme pressures when the oil is squeezed or sheared out between two mating surfaces.
There is a seq III test that supposedly has a cam wear test which I assume is api certified for wear but as of yet I have not seen any thing on any oil (except al who paid and then kindly posted this info from mobils web site, which i appreciate) . This also was on the pervious tri synth and not the current new supersyn oil.
Point is, To my knowledge, I have not seen any kind of data available to provide information on barrier lube wear properties on each oil. The only tests available is base oil qualitiy information only but since now minerals are now riding on synths butt with higher flashpoints and such, this now is not of any real concern as far as i'm concerned.
Paraffin base oils refer to straight chain hydrocarbon molecules,,they are good stable oil molecules, so stable they form solids at near room temp sometimes! I remember a mechanic friend of mine years ago said the wax was good because it left a layer on the metal when it cooled so it would protect it next time it was started up, we always joked about making candles with Quaker State! (this was in the 70's though!) These days oil is refined so drastically with steam/catalysts/hydrogen it ends up nothing like it starts out....you don't want any waxy buildup in a motor.. The barrier lube is a VERY thin film of almost a liquid metal type substance, not a buildup that you could really see,,,think of scraping an iron skillet with a spatula, you scrape off the grease, but the skillet is still black (the black would be the barrier lube), scrape hard enough and you see shiny metal,,,whoops now you went through the barrier lube.. Is that a good example, anybody else?
I have been looking for soluble molybdenum as an oil additive to improve barrier lubrication. I've run across several alternatives, but most recently I've found a product called Tufoil, which has soluble moly and a very fine (0.05-0.5 micron) suspension of PTFE. I know that it may decrease the life span of my oil, and that oil analysis would be necessary to determine drain intervals.
Does anyone have any experience with this additive? Any pros/cons to using this stuff? It doesn't look like there have been any FTC claims against this product, and it has been relatively old (>20 years).
My vehicle is a 2001 T&C van. I use Mobil 1 or Valvolene Synpower 5W30 oil with Pure One Filters. The transmission uses ATF 4+ 9062. Are there any advantages to using the DuraLube oil or transmission protectants?
not the same thing as the Paraffin in the older engine oils... Gotta start looking back in the chemistry books soon,,,,esters are modified compounds of the basic starting componants...The Lubeguard products are very highly rated by the various transmission builders...not sure about engine builders though...liquid wax esters is NOT the same as WAX like we normally think of... Lubeguard, from what I have read is a good product. see ya anybody got anything to add here? Rando
Yep. tried on my 1985 Volvo. Increase mpg 1-2 mpg but a year after using it ( placed it in with every oil chagne) blew the main bearings, only 85,000 miles on the engine. I cannot prove it but I think Tufoil was to blame. Learned later that the teflon should be a give away that this is SNAKE OIL.
As to moly, Schaefers makes a moly additive for oil
As to Lubeguard, well, IMHO like all additives, if your engine, tranny etc. is running well you are wasting your money as it is very probable that nothing will change. that is what happened to me with Lubeguard, no difference that I could detect.
I would not use a PTFE additive. One study I read showed a slight increase in power and fuel economy ... but a testing of the oil sample showed increased wear as well. I believe they concluded that the teflon particles caused local oil starvation which caused the excessive wear.
There is a difference betweed Duralube and LubeGuard. Duralube is Snakeoil in my opinion and was slapped by the FTC. LubeGuard is apparently a good product. It is supposed to reduce oxidation, lower wear rates and probably most importantly reduces the likely hood of solenoids sticking. Possibly though if you use synthetic ATF the benefits are less. I also use it (with syn ATF) but like armtdm said it may be waisted money.
does anybody have any details on the pour point of this product?
It have been established that the vegetable oils have a higher lubricity
>>>Vegetable oils offer a number of performance advantages as well. They have a naturally high viscosity index and thus don’t thin as readily as petroleum oils in warm temperatures, allowing some lubricants a longer life. Vegetable oils possess superior natural lubricity—the ability to reduce friction—which results in less equipment wear. <<<< ....check out
and that is true. I see that after using AMSOIL synthetic ATF, the gears did not shift cleanly due to higher friction. After I added lubegard to the AMSOIL ATF, the shift are as clean as they can get.
anyway, since Lubegard is a wax after all, does it freeze up at 0F?
If I remember from a few weeks ago the pour point etc. is as low as the Amsoil ATF etc. As I have used Amosil since 25000 I did not find any change with the Lubeguard, guess you did.
I will be trying it in a few other cars later this summer, will see. Again, no problem in the other cars but will try anyway
After reading all the negative posts regarding the latest Mobil-1,I decided to go back to dino.So I changed to Chevron Supreme 10W30 SL(the$1.08 stuff).It seems to be a TOTALLY different animal than the SJ dino oils(as has been postulated here).
I took 2 clear vials and filled one with Shell SJ(5W30),the other with Chevron SL(10W30)-new,unused oil in both cases.The Chevron is VERY pale in color compared to the deep amber Shell.There is a distinct "petroleum" smell to the Shell that is totally absent in the Chevron.
I've not used a dino-blend before,so I have no comparison there.But the Chevron,to the naked eye and to the nose,appears to be very different.Admittedly,this is a most unscientific comparison,but,IMO,tells me that the new SLs are indeed something very unlike the older SJ oils.
I have two cars that I will be sampling oil in the next couple of weeks. Both have less than 20K on them. Both were switched to Mobil 1 very early one at 30 miles one at 3K. I'm using the 10W-30 in both vehicles. I will be going with the 10W SuperSyn in both vehicles. Hopefully that will shed some light on the status of the "new" formula. Hopefully someone else using Mobil 1 will do the same. I'm actually looking for better results with the new stuff. But I really don't have enough history to make firm judgments. Still 2 cars should be helpful. I have a third vehicle (2002) that also has the 10W stuff. I'll probably do that also. Gonna get a little expensive since I am going with a slightly upscale service. 27 bucks a pop.
a trend analysis report using the new supersyn oil. Depending on your driving habits, i'd be surprised if your wear metals don't show higher than your current oil.
I ran across this on another discussion board. I can't vouch for the accuracy of it, but it seems about right:
Shell Rotell T synthetic = 100% Group III hydrotreated mineral oil
Castrol Syntec = 100% Group III hydrotreated mineral oil
Petro Canada Duron = 100% Group III hydrotreated mineral oil
Pennzoil synthetic = ~75% PAO 25% mineral oil [carrier for additives]
Valvoline Synpower = ~75% PAO 25% mineral oil [carrier for additives]
Mobil 1 SuperSyn = 100% Group IV Group V, [PAO, Ester, Alkylated Napthalene [ and,SuperSyn anti-wear additive/system, perhaps this has something to do with SuperSyn PAO ]
Delvac 1 = 100% Group IV, Group V High additve treat levels - > 50% than Mobil 1 , no SuperSyn
Redline = 100% Group IV, Group V [PAO, Polyol Ester] API SG treat levels of Zinc ,and Phosphorous, and 950 ppm Moly
Amsoil = 100% Group IV, Group V High additve treat levels
Quaker State synthetic = ~75% synthetic? [ listed as 1-decene, homoploymer, hydrogenated ] 25% mineral oil [carrier for additives]
Quaker State synthetic blends = depending on product <10% Group IV up to <30% Group IV and Group I or Group II/III
I know this is a motor oil forum but I'd sure appreciate your obviously informed opinion on synthetic auto transaxle fluid. I'm coming up this summer on changing it and can't decide how to go. With syn I was thinking the only way to go is with a shop that has the machine that replaces almost all of the fluid. Wouldn't seem worth putting new syn in to mix with the conventional fluid in the convertor. What do you think? Anyone's thoughts on these two issues greatly appreciated. Thanks.
I agree with you and in fact have an appointment this week to have mine flushed out with schaeffers fluid. 2 things to keep in mind before you do this.. 1, don't do it if you have an existing problem with your transmission as it will exasperate your problem and 2, most times when being flushed, they don't pull the pan nor the filter and even though they can back flush the filter, I had my filter pulled and replaced prior to having the flush done.
Here is something else that I "snagged" off of another board. Once again, I can't vouch for it's correctness.
I hope that someone can get the definitive answer on SuperSyn.
According to Mobil:
-it is still 100% full synthetic, that is Group IV,Group V. It does NOT contain any Group III or mineral oil.
-Mobil 1 SuperSyn contains a new anti-wear additive: SuperSyn.
-ExxonMobil make a proprietary high viscosity PAO called SuperSyn which can used at low treat levels to raise PAO, Ester, or mineral oil basestock VI by 35-40 points. (1)
-an article on PAO from last year has a mention of SuperSyn PAO, which can be used as a basestock or as an additive, and can be called an additive. ((2)
"Goebel offers an intriguing idea: "It is interesting to observe how the new PAO chemistries are being incorporated into lubricants. Some formulations may use PAO more as an additive than as a base fluid, which is a different approach, because of the new characteristics of our PAOs such as SuperSyn.""
So, my guess is that SuperSyn PAO is used in Mobil 1 Supersyn as an additive to increase VI, fluid behavior, and shear rate.
Will SuperSyn turn out to be marketing hype? Or is it an improved basestock/additve?
============================ 1] ExxonMobil Chemical is the world’s only manufacturer of both low and high viscosity PAOs (see summary table below) which enables you to work with a single source manufacturer to handle all of your worldwide distribution needs. With commercial viscosity grades ranging from 2 cSt to 100 cSt and exciting new products like SuperSyn™ which exceed 1000 cSt, we provide our customers the flexibility to formulate and meet the most extreme requirements.
Our PAOs provide superior lubrication for such applications as passenger car engine oils, drive line lubricants, industrial machinery and heavy-duty truck engines. Used in conjunction with our ester basestocks, PAOs are the major component of worldwide synthetic engine oils.
Synthetic lubricants formulated with PAOs provide the following benefits:
Extended drain intervals Improved fuel economy Enhanced wear protection Wide ranges of temperature operation
Since PAO-based products significantly outperform mineral oil and enhanced mineral oil (Group III) based products, we can provide you with a superior PAO that will solve your specific lubricant needs.
SuperSyn
SuperSyn, a proprietary patented technology of ExxonMobil, is a high-viscosity PAO typically used at low treat rates to balance the viscometrics, shear stability and low temperature properties of a lubricant. Its viscosity ranges between 150 to 3,000 cSt at 100° C, and it mixes completely with conventional PAOs, esters and mineral oils. Used in engine oils, automatic transmission fluids, gear oil greases, hydraulic oils and other specialized applications, SuperSyn has the following features:
A viscosity index that is 35-40 units higher compared to conventional PAOs of the same viscosity grade. A pour point that is 10-20° C lower than conventional PAOs of the same viscosity grade. An increase of Synergistic VI when blended with mineral and synthetic base stocks. A high viscosity with good ambient fluidity.
For more information on SuperSyn, please see our PAO product data sheet below. If you would like further information on our PAOs, please contact our Sales Offices.
The auto industry is a few months away from issuing draft specifications for the next generation of motor oils. But there have been enough talk and hints to reasonably infer that these improved "GF-3" oils will require a substantial tightening of volatility. "Volatility" as measured by the principal, European test called NOACK, is the amount of oil lost (the light molecules) over time at a given temperature and pressure. It has a direct impact on high temperature engine oil effectiveness-especially on viscosity, emissions and oil consumption. Today's oils have a NOACK volatility limit of 22 percent. Volatility losses for the coming GF-3 oils-due on store shelves just after the turn of the century could quite possibly be limited to 15 percent for all grades.
To meet this stricter requirement, there's a good chance that motor oils made with conventional, solvent refined base oils will have to be supplemented with a performance "boost" of hydroprocessed base oil or a synthetic base oil-that is, polyalphaolefin (PAO).
This was clearly on Don Johnson's mind when he pointed to the new, half-billion dollar, hydrocracking refinery brought on line earlier this year by Pennzoil and Conoco at Lake Charles, La. "We now produce a leading technology base stock," noted the Pennzoil vice president for product support, "... [and] strongly believe that this kind of base stock will be needed to formulate for GF-3."
But Dave Goebel, Mobil Chemical Co's. worldwide synthetic fluids business manager, upon reading this might well jump to his feet and proclaim, "Hold on. Not so fast." Mobil Chemical has been producing a leading base stock for decades and strongly believes it may be an important part of GF-3 formulation. It's called polyalphaolefin, a fully synthetic base stock.
Johnson and Goebel may both be right. The question is how much of each for GF-3? And, of course, at what price?
Making PAO
In a late August interview, Jim Willis, manager of Mobil Chemical's Beaumont, Texas, facility, described the PAO manufacturing process in his plant. Willis's family has deep roots in both the Beaumont area and with Mobil: in 1929 his father began work at the Mobil refinery and Willis has now completed his own 37th Mobil year-with a few more to go.
"Conceptually, it's really pretty simple," described Willis. "Mineral paraffinic lubricant base oils are obtained by separating out, that is removing, certain non-beneficial parts of the feedstock. Synthetic base oils, PAOs, on the other hand, start with a specified petrochemical feedstock which is
Well, my problem with flushes is that I feel the pan should be dropped and fitler chagned after the flush, not before. Most places will not do that.
I did what you do not feel is proper, I did drain and fills inlieu of a flush.. First one was at 25,000 with a filter change and synthetic, granted, only about 50% was changed. then did drain and fills every 30,000 with synthetic. At 143,000 I had the pan droppes, cleaned tha magnets and new filter. So beeen doing the drain and fill on this 92 Camry since 25,000, tranny still appears fine. I personally don't trust the flush machines and their technicians. More interested in a quick job and a buck IMHO.
they are doing just that. AS arm did, I had my pan dropped filter changed and refilled with new oil. this has been around 6 months ago, but now i'm going to flush it and at the same time install an exteranl oil cooler as this is a ford escort and is prone to trannie problems and i'm heading to texas next month. We use to do this with out a machine, broke the line loose, started engine and kept pouring in new oil till dark oil was new looking. No difference now adays except with a machine and doesn't require running your engine.
From what I have read there are friction modifiers in the 5w and 10w/30 oils, but not the others..therefore the xw/30 oils are "fuel saving". Remember I was talking about mixing oils before? part of the reason that I don't just change 100% to the heavier oils is because of that detail...don't know how MUCH of a diff it really makes, I'm sure it must make some. I have never noticed enough diff to make me NOT mix wts though. I would like to hear more about that "slippery" detail though...anybody? see ya Rando
Due to many factors like, the improvement of the SL/GF 3 Standard, the mileage of my car, the existence of some older engine seals, Bob's barrier lubrication tests,discussions here and mechanic's recommendations I changed my oil to a Valvoline 10W-40 synthetic blend It still runs very smooth, but I noticed a difference on my oil pressure gage.
When cold it was about the same, around 80 PSI. When warm the conventional is about 45 PSI where the synthetic is closer to 60. I may be wrong, but the gage is higher when the oil runs thinner. Is this proof that synthetic really does flow better at operating temperatures? Any enlightenment would be appreciated.
Thanks for the replies, both marked. Never thought about the filter. A new dilemma, before or after? Curses. I agree about "a quick job and buck." All they have to do is kink a cooler line and all of a sudden, $$$$$$$! One of the local quickie lube places does the machine thing for ATF. I was standing in line at Walmart one day. Some guy was telling his friend he'd had the auto fluid done there. Sent chills up my spine and it wasn't even my truck. Nothing against the employees but I question their competence to be messing with my $2000 or so transaxle. If I go the machine route I figured I'd have it done at the dealer I bought it from last summer. (2001 Protege) Hate to mix new fluid with old. Do you guys use the synthetic ATF??
I have a tranny cooler and it just so happens to be located right in front of the radiator,easly excessable via the grill.I took the grill off three #2 phillips and removed one of the cooler lines.I then found a 2gallon bucket (kitty litter)I started the car and the fluid came out in a nice even stream,as this was happening I poured trany fluid in.I could pour three quarts in as it pumped 5 out.I ended up cycling 11 quarts through.I think it worked good.I was thinking the cooler should recieve the tail end of the fluid (Hot)returning the cooled fluid to the pan to be re used,so this method seemed to me to flush all the fluid out replacing it with new. And I'm getting my motor rebuilt (Previous post)And i'm going to use nothing but the chevron delo400 10w-30 from day one.so hopfully no more stuck piston rings.Tony
Based on a number of factors including age of my vehicle, this discussion site, the availablity of a much improved conventional grade, Age of some of my oil seals, and mechanics recommendation, I have switched from a synthetic 5W-40 to conventional 10W-40.
My Subaru has an oil gage. I noticed that when warm the oil pressure on the conventional is about 45 PSI, where the PSI on the synthetic was normally at 55 when freeway cruising. Higher pressures also occur when the engine is cold.
Does this mean that synthetic actually flows faster at normal operating temperatures?
Synthetic should flow easier and show less resistance thus lower pressure. I believe Amsoil literature states that you may see lower oil pressure when hot and when using their product as well.
less pressure drop through the various filter/fittings/ports/clearances.... so it probably is showing higher actual pressure because it loses less through out the engine... I thought there was a pressure regulator before the filter though , which would mean only so much pressure allowed at that point anyway,,,,but really slick oil may be keeping better overall pressure through the remainder of the engine,,,good for you! I have never used synthetic so I have never been able to compare it myself.
so do me a favor and quote me where I am doing my 180 deg turn around from the way I have seen it and still do. I don't see where I supposedly have changed opinion on this subject. It still is the same, oil has been shearing under 4k miles and that 3k drains were the only way to keep from having sludge without doing oil analysis and finding a quality oil that can extend.
So please help me out and show me what I have said different,as I can't put my hands on anything different. thanks. bob
Took an oil sample today and I was disappointed that the tube they gave with the squeeze bottle did not get to the oil sump. Apparently there is a crimp or something at the bottom of the dipstick tube. Had to do a sample with the drain process.
Anyway it will be interesting to see the comparison between the TriSyn and the Supersyn. Hopefully I have enough cars to work with. 6 if I decide to splurge. That's $360 for 12 samples. I may limit it to 4 vehicles. Don't really care about the '94 Toy Truck anymore or the son-in-law's '98 Quest. I'll be consistent and go with the same filters and same milage. By the time I get the results they will be out with super-super-tri-syn.
from what I was reading about ur opinion, u were very clear that Toyota has a problem with their engine design..&..their design is reponsible for shearing oil.
Now u are blaming the oil industry and praising toyota for making a high quality engine that is not worthy of regular oils available in the market.
There's been quite a bit of discussion in here about change intervals. Here's mine. I change my oil and filter every 10K, and that's only because I use Wal-Mart's 100% syth Super Tech. It's only $2.97 a quart. If you use Mobil 1 you can easily go 15K between changes. If you're using a good filter, such as a Puralator Pure one or Mobil 1 filter, there's no need to change filters in between oil changes. If you change any sooner, you're just wasting good oil.
You may have "read into" Bob's postings. He has always put disclaimers into his analyses, that Toyota engines are very reliable (even calling them "high tech," I believe). We should be glad someone has taken the time, using his knowledge, to figure out what's going on in these engines.
The Toyota engine design vs. oil "design" discussion may hopefully be a defining moment in lube history. Is this not where decreasing the specs of oil certification (ie wear additives) has caught up to the increasing demands of engine performance?
The main reason I subscribe to this schedule is because an old friend of mine (he's not actually that old, I just call him that because he and I have been friends for so many years) uses it with such excellent results. He's put more cars over the 300K mile mark than than anyone else I've known. He sweares by this oil change ritual. I'm not going to argue, you can't argue with results.
Dave
--- <b>Bror Jace
As you'll note on my tbn page, http://www.bobistheoilguy.com/basic_lubrication_design.htm
just a brainstorm....no scientific thought in it...
so, if Lubegard is using wax as a protectant, and nobody is complaining.....
see ya
Rando
--- Bror Jace
http://www.carbohydrateeconomy.org/library/admin/uploadedfiles/Harvesting_Lubricants.htm
http://analystsinc.com/about/locations/analysts_atlanta.htm
I set up another page with more videos
on more oils, ep additives, and fuel additives. http://bobistheoilguy.com/videos.html
hope that helps.
bob
According to Mobil:
SuperSyn.""
SuperSyn
PAOs (Polyalphaolefins) - Typical Properties
(PAOs) S.G. @ 15.6/15.6°C KV @ 100°C cSt KV @ 40°C cSt KV @ -40°C cSt VI Pour Pt. °C Flash Pt. °C Color ASTM
ExxonMobil SHF-20 0.798 1.68 5.20 230 - -63 155 <0.5
ExxonMobil SHF-21 0.800 1.70 5.40 245 - -57 155 <0.5
ExxonMobil SHF-23 0.802 1.80 5.80 270 - -54 150 <0.5
ExxonMobil SHF-41 0.818 4.00 18.0 2,800 123 -57 218 <0.5
ExxonMobil SHF-61/63 0.826 5.80 30.0 7,800 133 -57 240 <0.5
ExxonMobil SHF-82/83 0.833 7.90 47.0 20,300 135 -54 250 <0.5
ExxonMobil SHF-101 0.835 10.0 68.0 38,000 136 -54 265 <0.5
ExxonMobil SHF-403 0.850 40.0 400 - 152 -39 288 <0.5
ExxonMobil SHF-1003 0.855 107 1,340 - 179 -33 290 <0.5
SuperSyn™ 2150 0.850 150 1,500 - 214 -42 220 <0.5
SuperSyn™ 2300 0.852 300 3,200 - 235 -30 235 <0.5
SuperSyn™ 21000 0.856 1,000 12,000 - 305 -18 235 <0.5
SuperSyn™ 23000 0.857 3,000 35,700 - 388 -9 235 <0.5
2] PAO's
Window of Opportunity?
BY DAVID MCFALL
grades.
GF-3."
Making PAO
is
How about Lubricity? viz. the able to let sliding parts slide with greater ease?
Why do we take that for granted?
see ya
Rando
My former oil was Quaker State Synthetic.
bobistheoilguy "Engine Sludge/Oil Gelling--Toyota's Customer Response" May 3, 2002 5:42am
is a complete 180 degree turn from what you have been previously trying to educate us...I Wonder why?
thanks.
bob
