Synthetic motor oil
17374767879175
  • rayfbairdrayfbaird Member Posts: 183
    The darker the color the worse the quality of the fluid. It could be indiciative of motor damage. Of course this is a close system, unlike a motor.
  • csandstecsandste Member Posts: 1,866
    if the oil is dark it means stuff is being held in suspension. Since the stuff is a product of burning fuel and is someplace, it would be just as viable to argue that dark oil is superior, not inferior to light oil, since a light oil means that the crud is being deposited in the engine and not suspended.
    In reality, oils are all sorts of colors when new and the darkening has very little to do with anything.
    On one car I have, I use synthetic Mobil One: motor oil, ATF, 75W-90 gear with a GM spec friction modifier.
  • malachy72malachy72 Member Posts: 325
    One can argue assumptions any way they may please. The proof is in the lab test. When the lab test says that the synthetic broke down after 5k miles, then the assumption is made that this is not the norm but only a 20% occurrence. I don't know if it's 20% or 1%, I do know enough not to assume. I wouldn't take lab tests posted on the internet for extended drains on other vehicles as gospel for mine. The lab tests done on my vehicle is its gospel.
  • frulefrule Member Posts: 82
    Could it also be that there is an improper assumption that synths are better for whatever reason(cost more,Amsoil's "guarantee" on 25K intervals,etc.)??And maybe test better in "laboratories".But when it comes down to day-to-day usage,dinos are preferable in the same manner that I prefer a 100% cotton shirt to a synthetic(polyester).Maybe my cotton shirt won't last as long,but it sure as heck is nicer during the time in which I wear it.And it does an admirable job at it's intended purpose.And...I PREFER it!
    Isn't this the real argument:what I prefer?Does anyone really KNOW that syn is better?I don't.So I'll use my Chevron SL happily,and change at reasonable intervals,with a decent filter until I think something more than marginally better comes along.JMO
    While it may seem that the lab tests are associated with the proof or lack of it for the use of synthetic, the truth is that it is a great tool for both conventional and synthetic users alike. While the remaining useful life of oil can be highlighted and documented, the fact is that it is a useful engine fleet management tool. While more expensive, if you only have one engine, you can spot and track trends and potential problems long before they breakdown at critical moments. For example, in a prior life I had 100 fighter planes which translates to monitoring more than 200 engines (spares etc) I had a NDI shop (non destruct inspection shop) that could literally analyse just about anything you could think of. It is good to see this older technology finally finding its way to the vehicle consumer market. The bad news is that rarely do the skeptics use it!
    The problem I have with this theory of "the darker the oil, the better it's doing it's job" is, you're basically saying that dino is better than syn because it darkens sooner. I'm not buying into this theory. I'm saying because syn is superior it's able to suspend this crud just as well or better than dino does, while remaining cleaner longer.
  • zr2randozr2rando Member Posts: 391
    "I'm saying because syn is superior it's able to suspend this crud just as well or better than dino does, while remaining cleaner longer. "
    If the detergents in the oil are working then the oil will pick up the crud and suspend it in the oil, the oil will carry it through the engine and the filter will filter it out. The oil will turn dark because of that, the filter is not designed to be able to take out small particles that can still discolor the oil, if it was efficient enough to do that it would NOT last long enough for any reasonable service life and would cost a fortune (and would NOT be a high flow rate filter either).
    If the oil is not getting dark fairly quickly then I would be wondering just where the carbon is going...or where it is staying...
    example:
    try taking some dirty chassis grease and rubbing it on your hands, try cleaning it with clear mineral oil (baby oil),,,doesn't clean it just makes it oily...add some dish liquid and now the suds are dirty,,,,,carbon is suspended now.
    Is that a good example?
    see ya
    Rando
    If you take equal amounts of "dirt" and put in dino and synth,which will appear darker(dirtier?)?It should be the same at least relatively.If one oil was significantly darker when new,that one might appear to be "dirtier".Otherwise they should be comparable,which has been my recent experience with Mobil-1,then Chevron SL in the same motor.
    bottgers:So by saying synth is superior because it "suspends this crud as well as or better than dino",how can you say "while remaining cleaner longer"?The same amount of "crud" is in both.They ar equally dirty (unless synth causes superior filtering).
  • yurakmyurakm Member Posts: 1,345
    You wrote: unless synth causes superior filtering
    Or people who are bothering about synthetic oil are also bothering about better filters?
    Folks who use synthetic oil may use better filters, but they still won't be "better" enough to get the stuff out that can discolor oil.
    If a filter was good enough to get that small size of particulate, it would be a very high $$$ and a very LOW flowrate filter...one of the bypass auxiliary filters for example could do that, but NOT the Wix/Pure-one/Champion..etc spin on filters that most of us on here use.
    Even the good ones like Pure-one for example only get the stuff that can reasonably be assumed to cause any identifiable oil-grit-related wear or damage...the smaller stuff can make the oil dark but is just not worth the extra $$$$$ to get out of the oil.
    Anybody who tries to use synthetic oils for extended drain purposes is WELL advised to change filters..(any filter)..midway through.
    It's just basic filtration mechanics...dirt happens...filters clog up...filters get changed...life goes on
    Just because oil is expensive does not automatically guarantee that it does EVERYTHING better than what it can replace. Marketing (and possibly misleading lab tests...I once had an algebra teacher prove 2=3) sometimes leads us pretty far away from well worn paths...
    that the arguments made here are tantamount to an hypothesis that umbrellas cause rain, because there always seem to be people with umbrellas walking around when it's raining. "Synthetics must be better in my engine because I use them."
  • brennekebrenneke Member Posts: 43
    Not even good bypass filtration will keep the oil honey coloured - it still darkens. I think you guys are getting hung up on the assumption that darkened oil is always dirtied oil. It is not always that way - the detergents themselves will darken the oil over time.
    that is backwards. I use synthetics because they are not only better but have a better bang for the buck! Trust me, I wish conventional oil was better ! The price is way higher for synthetic, even though the cost of manufacture is fairly similar! I would love to get synthetic's advantages for the conventional oil price ! Of course, I can dream on!
    Which incidently brings me to my next question... If the price were the same would you get conventional or synthetic?
    1. I don't think the color of oil makes much difference either way.
    2. Although I use dino, I think that syn. is probably better-- just not that much better.
    3. I don't side with the heavy oil folks, or the thin oil folks. Use 10W30 most of the year-- viscosity improvers can be a bad thing in excess.
    4. I start using STP (or Wal-Mart equiv.) as cars age at about 75,000 miles. When the new converter friendly oils replace SL, I'll probably consider adding it to all my cars. Car manufacturers are more concerned with converter warranty work than making sure your engine lasts 200K.
    5. We all need to get a life. Many people get good results with their cars taking them to Jiffy Lube when they think about it. Most oils probably do a pretty good job of lasting at least 5K.
    You and I seem to be the only ones in this topic who believe syns are better than dinos. Maybe they should change the title of this topic to synthetic bashing. I've never seen so many disbelievers!
  • fleetwoodsimcafleetwoodsimca Member Posts: 1,518
    You ARE using synthetic oil, right now! You admitted in this thread that you use Chevron SL. Now, the proof is in. This stuff is just as synthetic as many other synthetics. Yeah, I know-- the bottle doesn't say it's synthetic, and the price is a buck a quart. That only proves that you don't require being relieved of 4 times the money in order to feel like you have a good oil. Please keep it a secret, but I have purchased several cases of that stuff, and some Havoline SL, also. (:o]
  • adc100adc100 Member Posts: 1,521
    Following are results of my son's 01 GrandAm-3.4L Engine
    19157 miles on vehicle
    Oil drain interval- 6165 miles
    Mobil 1 10W-30
    Car is a work buggy- Distance to work22 miles (one way) It does get a lot ov short trip shopping trips at less than 3 miles.
    Iron 41 chromium 3 nickel 1 aluminum 9 lead 9 copper 97 tin 3 silver <.1 titanium < 1 silicon 59 boron 40 sodium 11 potassium 63 moly 7 phos 781 zinc 974 calcium 863 barium<10 magnesium 1890 antimony<30 vanadium <1
    Fuel% 1 % Soot < .01 H2o < .1
    vis 100C (cSt) 10.8
    SAE Grade 30
    TBN 6.06
    As you can see the oil held up very well. Wear products very good except for copper which is probably anti-sieze. Silicon is non-abrasive form from gaskets. Looks like 6K is very conservative. This oil was changed because my son is conservative. I should have the results of my 01 Sentra shortly which also had about the same miles on drain interval and the Vehicle is slightly lower milage (17K).
    I of course elected to put on a new K&N oil filter and "blindly" trust that the oil is still good!!
    Have been on vac for a while so I have lots of posts to read. As far as the dark oil issue. My experience in many years and many cars is that dark oil is usually (not always) caused by rings which allow more oil usage and higher levels of soot. In every case of at least 20 vehicles over the years: Vehicles where oil stayed clean there was considerable less oil usage. In all cases where oil stayed clean- the car remained in perfect working order into the 100K range. I personally am not happy withy dirty oil because it translates to loose or worn or broken rings (again in my experience).
    The Pontiac above is an example-very clean oil-no detectable oil usage-ver low soot level. My Sentra is exactly the same. Soot will be very low.
    You mean synthetic by "definition"determined in a lawsuit?I'll take it!How about calling our stuff "fauxsyn"?For a buck a quart?
    When will Chevron(or anyone) wise up and make and PROMOTE an additive made just for their oil???That would be a work-around for the vaunted API symbo.In the meantime,I'll happily use an oil which is MUCH BETTER than older dinos(which did pretty darn well with reasonable intervals).And I'll feel "smug" in knowing that I not only save $3.50 a quart,but I dump out all the "dirt" every 3,500 miles that floats around in long-interval synths(along with the acid,water,etc.).And I get a more frequent look at the undercarriage for potential problems.And I don't feel the need to use $10 filters,or do $20 a throw analyses that seem nebulous in scope from posts that we've seen.
    Maybe it's time to concentrate on the parts that "kill" more cars than oil-related engine failure;like transmissions going bad!
    Low yield autotrannies are a major disappointment of the "post industrial information age!"
    I really think the lube game is changed forever with the advent of the now undeniable merging of synthetics and the petroleum oils. Current thinking in the petroleum theory area seems to be turning to the idea that the dinosaurs had little to do with petroleum formation. It is coming into prominence to consider that primordial methane may be the building block, not dead dinos.
    Copper is not the only thing that is high, what about iron? At 41 PPM you are ten times higher than what I have been consistently turning in for iron wear. It appears as though you are using the new (low zinc, low phosphorous) Mobil 1, is that correct?
    Do you really mean to say that when one has an engine that darkens its oil, you would diagnose this as having "loose or worn or broken rings"?
    Good question. I have a 1998 Pathfinder with a 3.3L V6 that darkens oil quickly and consistently, and it always has from the day it was brand new. I presume that to be a product of the fuel injection system-- or at least not an indicator of piston ring trouble. The vehicle runs perfectly and is now at 39K.
    "If the price were the same would you get conventional or synthetic? "
    So why is this simple question SOOOOO hard to answer?? :)
    I think the iron at 41 ppm is quite acceptable. The SAE publications I have state 40 to 200. I have also read a Mobil Test where Iron in a Extended low speed/temperature test over a 5 year period and 7K miles gave an iron levelof 600 ppmand yet no abnormal wear or corrosion was found. The oil I used was the TriSyn .1% zinc. The levels of calcium,phosphorus, magnesium, and zinc are very consistent with other tests I have seen with the tri-syn. Also the viscosity was spot-on after 6K, which is very consistent for Mobil, in spite of a posting above which indicated a viscosity degredation.
    As far as the black oil and rings, I'm not about to debate it from a scientific standpoint. But statistically there must be something to it based on my experiences. It also falls into the realm of common sense.- Rings being loose or broken or not seated lets more oil out and more carbon in. The theory with the syn oil not turning black as soon is probably less oxidation plus for some reason (really sort of unknown) syn oil seals better around the ring area. The reason is probably due to the nature of the syn having a better affinity for metal. This information is 5 to 10 years old. Perhaps there is a better reason for it today.
    and apparently they are( Chevron SL). I would still not wait 10K miles to change the oil and filter.
    So what's the difference between the Chevron SL, and all the other SL's on the market? I went to our local Wal-Fart today, and every dino I looked at was labeled SL. Even the SuperTech dino is rated SL. It's funny their full syn isn't SL rated though.
    So I'm supposed to believe that any SL rated dino is just as good as syns? Or is it just the Chevron SL? If so, what's difference with the Chevron SL? Why is SL rated dino (or Chevron) just as good as syns?
    That the synthetics are the same as conventional oils because they meet the new SL certification is a gross misunderstanding of the certifications! Before the SL certifications there was the SJ ratings that both the conventional and the synthetic met. While the SL rating is more stringent that the not too distant past new higher rating of SJ. The distinction between synthetic and conventional still exists, even though the synthetic and the conventional oil do meet the new SL standards.
  • gregb882gregb882 Member Posts: 75
    Reiterating earlier posts of mine (3479 & 3487), I have 2 Cherokee 4.0L engines that turns the oil black within 1,000 to 1,200 miles - always has. Neither engine uses any perceptual amount of oil in the 3,000 to 5,000 mile interval changes I've employed. I'm clueless on what causes the oil to turn black so quickly - I should probably have the oil analyzed. But since it has done it on both vehicles right from the start, I considered it normal and didn't worry about it. By the way, I bought one vehicle with 9,000 miles on it and the other was brand new.
    "So why is this simple question SOOOOO hard to answer??"
    That's EASY! It is because the definition of synthetic has shifted and has been repeatedly degraded/altered from what it was say, 20 years ago. At this point, as this thread demonstrates, none of us knows what synthetic means-- as it currently applies. Some outfit has published a standard, and everyone including some court of law has decided to capitulate. Perhaps by the time I post this, the definition will be changed again.
  • armtdmarmtdm Member Posts: 2,057
    Well, at 19000 miles the engine is still breaking in and my experience with silicon is that it takes at least 20,000 for that to drop down.. However, with that said you have a combined iron and silicon that is in my opinion high. My lab cuts off silicon at 31 ppm but combined with a high iron indicates wear. Now copper, yea, I have one car about the same mileage with very high copper also but the iron and silicon are about normal. Every engine different but I would not extend intervals until that iron comes down, combined iron and silicon bother me!
    as if you are only ones defending synthetics' superiority over dinos. I'm sure if you read most of the previous posts, most people on this board never disputed that syns were better oils. Most of the discussion came from applications of everyday driving and extending oil drains. I think the points everyone makes here are cogent. The discussion has now been directed as to what are synthetics? Apparently the lines are very blurry. It appears that Mobil has taken a "If I didn't beat 'em, I'll join 'em" approach. I guess
    what should be of most concern to tried and true synthetic users is "What am I getting now for the extra bucks I'm spending?"
    Thanks for your input, this is quite an interesting discussion. Caveat emptor!
    Some activity here! I felt like the only one trying to explain to bottgers that things are not as simple as he thinks with regard to "synthetic" oil and "non-synthetic" oil.
    Very interesting question. I don't remember anybody asking it previously, although it seems like such an obvious topic.
    I'm banging the drum of Chevron Supreme and the other SL regular oils that offer these hydrocracked or base II or base III stocks or whatever they are. But...if everything on the shelf was the same price, I would buy one that truly had synthetic roots. Something like Redline, Amsoil, or Mobil 1, I guess. Why? Because their specs are a little better than the non-synthetics. At least I think so.
    I'm not convinced that synthetic engine oil makes a difference for most people in how well their engine runs or how long the engine lasts, though. And since the prices AREN'T the same, I am not spending 4 times more for synthetic.
    What is "clean" oil?
    Does the darkness of an oil, relative to its brand-new color, an indicator of the oil's cleanliness? If not, then how in the world can someone make a determination on how clean the oil is? Is that one of the main things that an oil analysis tells you? Which aspects of the oil analysis are indicators of cleanliness-- levels of silicon, etc.? I didn't think the color of the oil had anything to do with cleanliness, but maybe it does.
    At least one person here has recently equated "dirty oil" with "dark-colored oil." I had been thinking that was a bogus theory, but I suppose it could be correct.
    The other theory I am struggling with is the "dirty oil is bad" theory. It seems that the oil darkening with age is an indicator of good things, not bad things. I guess I have been assuming that the darkness of the oil had no bearing at all on how suitable it was to remain in service-- in other words, how badly it needed to be changed.
    Nobody's answered the question yet. Is there something special about Chevron's SL, or all SL's basically created equally?
    If you had 600 PPM iron in a sample, I guarantee you that you would be getting a phone call from the lab!
    Your silicon is elevated, as armtdm pointed out but, I would not be concerned that it is from dirt as aluminum is where it should be.
    I think it's fair to say that there's a considerable difference in performance. How much that means if you change your oil regularly, I'm not ready to say.
    BTW-- Let me give a plug for Bobistheoilguy's new forum. Great stuff in there. Because of the narrowness of the scope, topics can be hammered which would be closed down on Edmunds. I feel safe giving a plug, because there was some positive references to going to Edmunds on their new site. Anyway the new format is a big improvement, Bob. Congratulations.
    http://theoildrop.server101.com/cgi/ultimatebb.cgi
    When the conventional SL rated conventional can match the synthetics SL rated numbers I will switch. Till then the synthetic is a better lubricant with a higher tolerance for heat, better flow at low temperatures, less % ash (less tendency to form sludge, and for me the abiity to extend drain intervals, to 15,000 miles and beyond.
    even Chevron only says it is WITH Isosyn, not that it IS Isosyn. Valvoline Maxlife is the only oil that openly says it is a hydrocracked base. It costs about as much as a synthetic blend.
    Until Chevron says that is is a Isosyn base you can only fairly assume that it uses Conventional Dino as a base with some synthetic to improve its quality.
    Even with the new SL classification at least 5 bottles of synthetic and syn blend indicate that the synthetics are more durable. They've been making this statement for at least 15 years to my knowledge. Oil analysis has shown more durability also.
    Thanks for the information. As armtdm has said many times, trends is what you are looking for. The silicon was "attributed to non abrasive gasket/sealing material" Don't know how they really determined this. I did drain the oil. Unfortunately when I took the sample, I had to take it out of the drain plug as the sample tube did not fit down through the dipstick tube.
    malachy: It appears that Mobil has taken a "If I didn't beat 'em, I'll join 'em" approach. I guess What leads you to this conclusion? They only "evidence" available is that the pour point is higher and that is probably because the SuperSyn ingredient (Which is a PAO) is a higher viscosity with a very high viscosity indes. I suspect they now use less polimer to get the proper viscosity at 100 degrees C. Thats just a guess. But any information you could share is appreciated. As I have said previously, I am not a Mobil 1 fanatic- But the information about their oil is much more abundant than other oils.
  • curreycurrey Member Posts: 144
    OK, here it goes . . . I have a 2001 Mazda Tribute that calls for 5w-20. I have used that for the first few oil changes, however, on the most recent one I switched to 5w-30 as 5w-20 is difficult to get in a synthetic. (Yes, it is my $ and I am sold on synthetic over dino. Additionally, I know Amsoil carries a 5w-20, I just like to go buy it off the self when I need it). So now, after lots of discussion with people on this site about eight months ago, I have a 5w-30 in my Tribute. The consensus was that the difference between the 5w-20 and 30 was negligible. In fact, here in Florida, the 30 might offer better protection in the hot summer months. Furthermore, everyone seemed to state that the whole reason Ford and Honda are using 5w-20 is to raise the miles per gallon of their respective fleets. Well know I have a few questions:
    1. If that is so why is Mobile selling a 0w-30 stating that it will be the best in miles per gallon results?
    2. How much of a difference is there between a 0w-30 and a 5-w20?
    3. And finally, am I sacrificing anything if I run the 0w-30 in my Tribute this next oil change, or, should I just stick with the 5w-30?
    Thanks in advance for any and all advice on the above, please remember when you answer that you are talking to a guy who&#146;s only knowledge on the subject is where to drain it, where to pour it, and to make sure I change the filter each time.
    ps. If I am going to pay for synthetic, I want a true synthetic not a hydrocracked (although I have already made the mistake once and bought Castrol) what are the true synthetics, like amsoil, that are on the market.
    #3791
    While I don't know if they used this exact procedure, but a spectrum analyzer can pinpoint with ease whatever was in the oil sample.
    Also the synthetic oil ALSO had to meet the new SL test designation, so to say it went the Castrol court ruling way, would take a bit more technical research and familiarity than most folks are willing to sit through. Suffice to say that if INDEED you could demonstrate or prove that Mobil is lying when it tells you their synthetic oil is synthetic, you'd be rolling in a lot more money than you are now. The lawyers that usually get 1/3 of the take will also thank you!
    However, I am cynical enough to believe that large oil concerns (as well as all other large multi-national corporations) are more interested in bottom line profits. If a competitor has a distinct cost advantage due to marketing, corporations, like lemmings, follow suit. I don't know that Mobil has done this, but I would be shocked if they didn't and further shocked by their admission.
  • loubapacheloubapache Member Posts: 30
    The flash point is lowed as well. Now try to explain that with your theory.
    It is a double squeeze here. Pour increased and flash decreased (by quite a bit, especially in the 10W-30 viscosity). It has to be the base stock, IMHO.
    #3794
    The issue centered around whether you could call hydro cracked stock synthetic or whether or not the PAO or manufactured stock synthetic. While I have not seen the transcripts of the trial, I would hazard a guess that the lines were blurred based on the effects of the hydro cracked oil blended with patent law.
    I guess nobody can tell me why Chevron's SL is different than all the other SL's, if it actually is.
    I noticed something a little strange when I was looking at oil labels the other day. Every brand and type of oil I looked at was SL rated except for the SuperTech full syn. It still has the SJ rating. Would any of you happen to know why this is? I thought ALL oils HAD to be SL rated now.
    #3798
    Probably yes, but this seems to be a period of transition. I have actually gotten some good buys on SJ rated oil(Mobil One synthetic :) for a buck or two off the old sale price of 4 dollars or so) as they sell the old stock to get ready for the new SL rated stock.
  • mrdetailermrdetailer Member Posts: 1,118
    WARNING!! There is some rambling below
    OK... I'll extend my theory to the fact that the Flash point is lower, the pour point is higher, and the VI is higher (for this new PAO called "SuperSyn). There is really no reason to suspect otherwise. BTW I have adressed the question to Mobil via email about the higher pour point of the new blend. I did not ask about the lower flash point. Theorectcally the "SuperSyn" ingredient has been used in Mobil's Racing Generation oils for several years on the basis of it's superior lubricating qualities. It stands to reason they would not use a hydroprocessed oil to (which is known to be an inferior lubricant to PAO) for their racing technology. I really do agree that all big companies will screw the customer every time if it serves their interests and their bocketbook. Mobil is probably not different here (IMHO).
    currey The 0W or 10W is the viscosity at about 100F and the 30 or 20 is the viscosity at 210F. So for all operating conditions below 210 (which is like always the oil in your crankcase will be slightly thinner with the 0W. That is starting with a thinner base stock 0W vs 10W - the polymer works over the temperature range so both oils are 30 wt by 210F. Does that make sense? I would really recommend the the 10W vs the 0W- you just don't need the 0W in Florida. As I attempted to explain above, that will give you a little more viscosity (spelled protection) throughout the range (IMHO) Also the polymer needed to create this spread will be less. Less polymer-less oil sheardown or breakdown-according to some. I don't really know.
    As far as using the 0W-20 or xx-30. I personally wouldn't have purchased either of these vehicles (Ford/Handa), bc the 20 wt. thing is a bs ploy for a higher CAFE. I hate to play games with the warranty issue. Having said that I would use the 10W-30(syn only) and worry about the consequences later. Even common sense dictates that vehicles for which 30wt. is specified can safely use 40 and even 50 wt. As far as the difference in viscosity between the 20 and 30 wt. The vis of 20 wt is about 250 SSU and the 30 is 400 SSU. Basically that means that at 210F the 20 wt takes 250 seconds to flow through a standard orifice and the 30 wt takes 400 seconds. Sorry for the rambling-I warned you.
