That having been said, I have used Fram when no alterntive was in stock, but with 3,000 mile oil changes I wasn't too concerned.
Keep in mind that some offbrand filters are made by Fram. I had a Quaker State installed for $8 only to discover later that Fram makes QS. Ugh. Felt ripped off.
For those that aren't aware of the history, the "well known" criticism of Fram oil filters can be traced to one individual and one web-based article that has been repeated many, many, times over. The author may have had an axe to grind and continues to distance himself from the original publication. Web owners have been advised by legal counsel to "tone down" the article, and in fact more recent presentations have been significantly edited with the emphatic pronouncements and false statements removed.
I find it curiously hypocritical of of those that continue to defend the original source and the unfounded conclusions by saying that the author was not performing a "scientific analysis." If it was not an attempt to look at different oil filters scientifically, then the so-called analysis is worthless. The defenders continue to defend because doing otherwise might be construed as an admission that they got taken in by the illogical analysis and flawed contentions that resulted.
In reality we know nothing of how the various makes of oil filters perform nor how the materials or construction impacts actual operation from the Fram attack article. The only thing proven to be junk about Fram oil filters so far is the originating source of the myth that they're "junk" and that permeates the web.
Dusty
Last night, while watching a TV show on Discovery HD called "Rides", they followed the construction of a '32 Ford Hot Rod for the two daughters of Vic Eldebrock. They showed how the small-block Chevy motor was hand built in the Eldebrock shop. While assembling the engine, the builder attached a FRAM oil filter! Given that Elebrock can afford anything in terms of building the engine for his daughter's hot rod, I was impressed they chose a FRAM oil filter. Just another anecdote...certainly not scientific...but interesting, none the less.
1. What does the Oil Life Indicator use to determine how much life is remaining? The owners manual says it looks at temperature and rpm. Anyone have any more specifics about the algorithms used?
2. Any experience out there with synthetics and the GM 3.8 V6? Good, bad, brand, etc?
Desertrat
Because there are very good products out there in the market place, many of them less expensive and of much better quality than the factory recommended ones.
This past winter I had several oil changes done at Walmart (too much snow, too lazy). I requested Penzoil 5w-30 and Fram Toughguard be used and paid a little extra. Each and every time, they put in the wrong weighted oil and had to redo it, even after I emphatically warned them! Frustrating indeed. And last time they put in too much oil in my 91 Geo Storm. I'm too lazy to jack it up and drain it, so I'll have to live with it. Hope it won't do too much damage to the engine.
I did, however have an incident several years ago where a Wal-Mart technician stripped the threads on the oil-pan drain. My new-car dealer found the problem, I called the Lube-Express manager at the Wal-Mart and the next day he sent an inspector to view the problem. Wal-Mart ended up buying me a new oil pan from the dealer and also paid for the labor. So, I continue to return to Wal-Mart Lube Express even though they are routinely slow and always short of personnel. Good luck!
I think I'll only bring my older car to Walmart and keep doing my own oil chances on my new car whenever possible.
Somewhat off topic, but along the same concept lines; I have one vehicle that had: 1. synthetic oil in the engine 2. conventional oil ATF in the 6 speed manual gear box 3. synthetic oil in the differential. I swapped out the conventional ATF with Mobil One ATF and have effected a 1 mpg overall consistent gain.
for (I think) 100K miles. I can't live with that, so I'm going to have a complete transmission flush done @ 30K. If the factory fill fluid isn't synthetic, I'm going to change it to Mobil-1. I've always run Mobil-1 in the crankcases of both the Tahoe and my 4 Cly. Camry. Thanks !
With Wal-Mart, I've found that directions left with the service writer has little or any impact. I usually put instructions (substitute ST for Fram filter) on a sign mounted on the dash. That usually gets their attention.
The fact of the matter is that the machine will run just fine with the conventional ATF. However like you, I was chomping at the bit to change it, and I did to Mobil One ATF (synthetic)!? Just be sure that what the OEM calls for is covered by the specification of the Mobil One ATF. The reason why I say this is it can be a tad counter intuitive to need ATF in a 6 speed manual like mine!!
My driving is almost 100% city and only average about 6k miles per year. Sometimes after 6 months I still don't have 3k miles so I'm concerned about wasting a premium product like M1.
Should I just use conventional oil?
But as I approach oil-change time, I notice that now Mobil 1 has added this weight to its synthetic lineup. Here's my question: Mobil 1 calls their product "Truck and SUV SAE 5W-40 Synthetic oil" designed for "Gasoline and Diesel Fuel Engines". It provides "outstanding protection for gasoline powered trucks and SUVs" and "hard-working diesel powered pickup trucks and SUVs."
This does not sound like my car, which is a smallish sedan. Is this Mobil 1 oil really designed only for trucks and SUVs - is it in some way different from the Valvoline 5W 40, making it less suitable for my comparatively litte Passat? Should I stick with the Valvoline? Or is this Truck/SUV thing just market "positioning" - would the Mobil 1 would work fine in the Passat?
Thanks for your help!
In Europe most of the oil specs seem to be at the heavy end of the viscoscity scale - 40 weight. Over here we emphasize fuel saving, thus the 30 weight and more recent 20 weight trend. Who's right? Wish I knew. Neither region of the world seems to have a lot of oil smokers or early engine failures. Possibly the Europeans drive more like maniacs than we do, thus the love affair with thicker oils, or maybe the engine tolerances are different (looser to allow for better oil flow?). Who knows. It's an oil mystery the message boards haven't covered, to the best of my knowledge.
As for six month oil changes, I was always under the impression that the time element in oil changes (though usually ignored) is designed to take into account frequent short trips, notoriously hard on oil.
When I lived in an urban environment and only used my car for long weekend trips, with resulting low annual mileage, but most of those miles on the freeway, I ignored the time interval and just changed oil every 3,750 miles.
My mom, on the other hand, is a real "short trip" person who hardly warms up her car, and I tell her to take it in every three months (the most conservative time frame) even if she only has 1,000 additional miles on it.
I hadn't heard the condensation issue before. I think it is legitimate in the "short trip" model but doesn't apply to the "driven once a week on the freeway" model.
My daily commute to and from work is 6 miles each way, all city traffic.
12 * 5 = 60 miles per week (assuming weekday work)
60 * 52 = 3120 miles per year
Krzys
PS if you have no vacation :-)
GTX with 3k miles oil changes OR
M1 with 5k miles oil changes?
Right now I'm planning on changing to M1 @1k miles then change every 4k miles or 4 months.
I don't drive that much, 6-8k miles a year, but mostly stop and go city traffic. Wally World here charges $32.74 for M1 and a Supertech filter, so, I can have clean M1 for less than $100/year.
For this reason I highly recommend installing a Fram Sure Drain. This is an "install once" drain bolt that allows you to change oil on future oil changes by unscrewing, by hand, a dust cap and then screwing on a special drain tube that unlocks a rubber seal assembly in the Sure Drain.
Fram's marketing on the Sure Drain is poor. They make it sound like the Sure Drain is for idiots who can't un-do a drain bolt. In fact, it is a solution for grease monkeys who torque the heck out of a plug to insert it back in, and begin the process of tearing up the threads on the typical aluminum pan.
If you go this route, Wally World is as good as any (they are certainly nice enough over there). But make sure you give them the drain tube each time and make sure they know what to do - some mechanics just ignore the dust cover and remove and replace the entire assembly with a wrench, defeating the whole purpose!
This won't work on Chevy's. They use a special drain plug with a built in rubber 0-ring - a nice set up. I think this is their approach to oil pan death, a widespread problem (know three people personally, including myself, who've had drain pan death).
Oil pan drain plugs? I don't need no stinkin' oil pan drain plugs! ;-)
Best Regards,
Shipo
Where can I find an oil extractor?
Make, model, price, etc.?
http://www.griotsgarage.com/search.jsp?searchtext=10122
And again at this link for $62.86.
http://www.casporttouring.com/store/merchant.mvc?store_code=CST&a- mp;screen=PROD&product_code=24502
Given their closness in price, I suspect it will come down to who has it in stock and what the shipping charges are going to be (I've heard that some folks have paid as much as $30.00 dollars to have this thing shipped. IIRC, I only paid about $12 for mine.)
Please note, it seems that the MityVac is not compatible with these models:
1999 - 2003 Corvette
1999 - 2001 TransAm
Late model GM/V-8 engines
2000 - 2002 Ford SUV's (Explorer, Expedition, Excursion, Mountaineer)
2000 Ford Taurus
1992 - 1994 Toyota Camry
2002 - newer Porsche Carrera (dry sump oil system)
Best Regards,
Shipo
I use it on a VW Jetta TDI with top front oil cartridge filter access. I can literally complete the oil and filter change in under 8-15 mins! This also includes putting back 1 gal of oil.
It's twice the price of their non synthetic but far cheaper than name brand "pure" synthetics.
Can anyone tell me if this product is worth the difference in price over non synthetics. Our is this "blend" just a pig in a poke?
I change oil and filter every 3000 miles (about every 3 months) I have avoided synthetics up til now thinking the high price wasn't worth it since I change so frequently. But for the modest price increase I would switch to the blend if it offers a true improvement in engine protection.
boy, after a few thousand miles, I noticed the engine started to drink coolant, at a rate of 1 gallon/ 3 days....so I just replaced it and was too stupid and lazy to bring it in,,,,waited 10 days before I got it in...but by then the anti freeze got into the bearings...so needed a new engine....
so now the suburban has a new engine..and I put about 15,000 miles on the new engine already, with about 4 oil changes ...
question for all you knowledgeable people...
Is it OK or advisable to switch to synthetic oil now ? I heard that its OK after 3 oil changes...and that syn oil protects the engine better. However, I an leery of the cleansing properties will dry out a gasket and cause another leak and may need another major work or new engine ?!
How come some people put syn oil in thier American car with no problems ?
Can you all help me ? I was hoping for 5 diff POV on this...thanks...
