2017 Dodge Charger Lease Deals and Prices
1246710
  • kyfdxkyfdx Moderator Posts: 272,640
    frank720 said:
    Can I please get MF and RV for a 2017 Charger Daytona 392  24month/24k miles?  Thank you :)
    frank720 said:
    Sorry forgot to include in Arizona
    Standard MF and 68% residual
  • dwgutwirdwgutwir Member Posts: 137
    Hi - for NJ (Philadelphia Area)
    '17 Charger 392 SRT
    12k/24
    12k/36
    What is the reduction in residual for 15k?
    Any other lease terms with preferential months/miles?
    '17 Charger 392 SRT
    12k/24
    12k/36
    .00024 MF and 64% residual
    .00002 MF and 59% residual
    Subtract 1%/2% for 24/36 months for 15K/yr
    36 months is the best term.
  • thebranksthebranks Member Posts: 18
    could i get the MF/RV for 36/12k on R/T392 in socal?
    Don't show an R/T 392
    My choices are:
    R/T
    R/T Scat pack
    Daytona 392
    SRT 392
    sorry, the scat pack please.
    Standard MF and 63% residual
  • RI32360RI32360 Member Posts: 26
    Good afternoon. Do you have the mf and residual for 36/10 for a  Daytona 392? Thanks.
  • MichaellMichaell Moderator Posts: 269,019
    standard MF and 64%
  • jamiealbanesejamiealbanese Member Posts: 3
    Lease terms for RT scat pack, Daytona 392 and srt 392 for 36 39 48 with 12k or 15k in New Jersey?
    R/T Scat: Standard MF and 61%/58%/52% residual for 15K/yr, 36/39/48 months
    Daytona392: Ditto above
    SRT 392: .00002 MF and 57% residual for 36/15. (other terms are a lot worse)
    Add 2% for 12K/yr
  • PabelcasPabelcas Member Posts: 7
    MF and RV 36/10 2017 Charger R/T Scat Pack St. Louis (Ballwin), MO 63021...Please
    Standard MF and 64% residual
    Pardon my ignorance, but what is the Standard MF?
    It varies from month to month - we've seen it between .00213 and .00270 recently.
  • tampasmokertampasmoker Member Posts: 78
    Can I get the numbers for May on the 2017 Charger Daytona 340? Thank you in advance.
  • rrrrrrr1rrrrrrr1 Member Posts: 4
    Can you please provide the numbers for a 2017 SXT in AZ.
    36mo - 12k
    36 mo - 15k
    .00010 MF and 55% residual for 36/15
    36mo - 12k
    36 mo - 15k
    36mo - 12k
    36 mo - 15k
    .00013 MF and 55%/53% residual
  • park5park5 Member Posts: 63
    Hi Do you have May MF/Residuals for the 2017 Dodge Charger Hellcat in NJ/NY?
    36mo/10k miles/year?
    .00013 MF and 64% residual
  • newtfoxnewtfox Member Posts: 1
    Looking for Money factor and residual on both 16 Charger Hellcat and 17 Charger Hellcat in Ohio. 36 months and 12k/15k year option.
    2017: .00013 MF and 61% residual
    2016: .00002 MF and 59% residual
    Add 2% for 12K/yr
  • bogeyman4everbogeyman4ever Member Posts: 18
    I'm looking for MF/Residual for R/T Scat Pack in NC/SC region. 36/10 and 36/7.5 if available. Thank you!
    Standard MF and 64% for 36/10.
    No 7500 allowance from Chrysler
    Sorry, can I also have the RT 36/15k? Just trying to see if there is enough RV and MF benefit to make the price difference a wash or close.
  • brookbixbybrookbixby Member Posts: 3
    Can you please provide me with the MF and RV for an R/T Scat pack for 36/12k and 36/10k in Miami Fl, 33173?
    Thank you!!
    Thank you!!
    standard MF and 63% / 64%
  • vmlhbk122vmlhbk122 Member Posts: 20
    Hi Sorry if this was asked before,
    would you be having the MF and RV for 2017 Charger SXT/SE with blacktop and Rallye pack?
    Does the MF and RV value varies based on package we on same trims?
    for Ohio state
    for Ohio 36m/10K
    for Ohio 36m/10K
    SXT AWD: .00029 MF and 56% residual
    SE AWD: Standard MF and 51% residual
    Trim and RWD/AWD matter. Other options do not.
    for Ohio 36m/10K
    Thank you. also could you help me with SXT RWD and SE RWD Ohio #6m/10K
    for Ohio 36m/10K
    Subtract 1% from residual for SE RWD
    MF for SXT RWD is .00013; residual is the same
    for Ohio 36m/10K
    sorry for my ignorance but my dealer gave me a different MF and Residual value. it varies drastically from the number i got from here. Why is it so? can i convince the dealer to use this number for Lease calc?
    vmlhbk122 said:
    for Ohio 36m/10K
    If your dealer is using Ally or US Bank for the lease, the numbers will be different. We do not have those numbers to confirm what you are being told.
    vmlhbk122 said:
    for Ohio 36m/10K
    Listing the numbers i got
    MF = 0.00145
    Residual = 57%
    for 2017 Charger AWD.
    Also could you let me know the numbers which you have is from which bank?
    vmlhbk122 said:
    vmlhbk122 said:
    for Ohio 36m/10K
    MF = 0.00145
    Residual = 57%
    Our numbers come from Chrysler Capital.
    vmlhbk122 said:
    vmlhbk122 said:
    for Ohio 36m/10K
    MF = 0.00145
    Residual = 57%
    Thanks this helps a lot !! Appreciate it. !!
  • houbmw13houbmw13 Member Posts: 15
    Can you help me with residual and MF in 33314 for the following:
    24/36/39 months 15K miles
    2017 Dodge Charger R/T Scat Pack
    2017 Dodge Charger SRT 392
    2017 Dodge Charger SRT Hellcat
    Also, do these numbers that you provide vary by location?
    24/15
    R/T - standard MF and 65%
    392 - .00024 and 63%
    Hellcat - .00006 and 66%
    36/15 39/15
    R/T - standard MF and 61% / 58%
    392 - .00002 and 57% / 48%
    Hellcat - .00013 and 61% / 51%
    The Chrysler numbers are regional, but we only have one regions numbers, this month. Haven't noticed much of a difference when we do have multiple regions available to us.
    Thank You for the response and information. Which is the best term you would recommend?
    Also are there any lease incentives from MOPAR or Chrysler for these 2017 Charger models?
    36 months should result in the lowest payment.
    We don't have the incentive info.
  • itsmeleeitsmelee Member Posts: 1
    Hi - MF and Residual for 07480 on an SXT AWD at 36/12k?
    Thanks Much!
    Thanks Much!
    .00029 and 55%
  • alexruiz91alexruiz91 Member Posts: 2
    Hello - MF and Residual for 92404 on a 17 R/T 392
    24/12k
    36/12k
    24/15k
    36/15k
    Thanks in advanced. I dont think im getting straight info from my dealer.  And im an employee.
    24/12k
    36/12k
    24/15k
    36/15k
    I don't see an R/T 392 - my information shows a Daytona 392 or an SRT 392.
    24/12k
    36/12k
    24/15k
    36/15k
    R/T Scat pack?
    Sorry.
    24/12k
    36/12k
    24/15k
    36/15k
    R/T Scat pack?
    Sorry.
    I show an R/T Scat Pack - standard MF and 65% (24/15) or 61% (36/15)
    Add 1% for 24/12 or 2% for 36/12
