Absolutely true, I swear it. That's why they always say in their manuals not to change to oil before the first scheduled change.
I hope I am not beating a dead horse here about Mobil One 5w30 and my 15,000 mile OCI's.with cheapie FRAM (2 for 5 for the PH8A) and oem oil filters
On one level this has been boring to me for 129,000 miles or 9/10 oil and filter changes. But boring is good!!
My 1994 TLC (with 116,000 miles at the time) was summoned to a CA "Smog Only" station. The smog only station is NOT good news, for it is tasked to get a MUCH higher rate of redlining vehicles and by law can not FIX smog problems. They charge more for a smog test and are capital equipted and mandated to give a far more rigorous smog test. So I brought it in BEFORE a much needed 120k mile MAJOR tune up interval.
It passed with FLYING COLORS!! The SMOG figures were almost at when it was brand new in 1994!! Based on the figures the test and also the bi annual smogs tests were total and utter waste of time energy money etc. So I bring it in app 126,590 miles. One of the inspection items is looking at the innards, specifically to check the valves adjustment and if it needs it it is a 200-300 dollar item and the Bosch hot chemical system flush (another 200 dollar item. So to say they have incentive would be belaboring the point. So anyway bottled back up and the mechanic AGAIN commented on how clean the innards were and he noted some of the original factory tool markings.
Now I did hear one person say (for Honda Civic specifically) there is break in oil and it specifically has some agent that traps particles and deposits them on the oil filter!!?? (lower than the micron rating for most OEM filters).
The way I have heard it explained which to me is more logical is the factory puts say a bit extra moly during assembly as part of the process and the OEM fill has a higher dose of moly to begin with. Also after the initial recommended time the factory has NO functional control over what oil a customer or dealer puts in. So at least for that recommended interval: 10,000 normal and 5,000 severe they can bank on that.
For my break-in/synthetic switch solution for my 06 titan, i will switch to synthetic once my odometer hits 1000 miles. That seems like a safe bet, and assuming that i will get approval by nissan to do this. I think i should be able to even though i have a warranty and a maintenance plan.
I would like to ask 2 questions: one regarding viscocity & weights and one about break-in
If i switch to synthetics on the new truck, is it more beneficial for the pistons,cylinders, etc. to use the 10w30 synthetic for my 1st oil change and then switch to 5w30 ?
Also,
i know this is off topic but since all break-in discussion board is gone or so it seem, i hope i can ask here..
My truck is 5 speed automatic, do i even need to break-in those 4th, 3rd, 2nd, and 1st gears so that the those gears can be in optimal level later or just stick with the Drive gear to break-in?
High
As for the 5 speed automatic just use the D gear for normal break in. I again only use those gears for special purposes, more passing power, letting the engine rev more per cycle etc etc. As you probably know an automatic transmission is more about fluid dynamics that actual gear teeth.
"break-in oil" isn't a very precise scientifically term, as you imply. It sounds more like marketing.
Best Regards,
Shipo
Mr_Shiftright or someone, i hope you can help me out a little bit since this is my first brand new automobile and im a little bit baffled about new engines. If i wanted to break-in a new engine effectivly to an extent on the street, you would tell me to vary my speeds by pushing the gas pedal down abruptly for a quick second and letting go of it right away right?, but not to push so high as to the maximum recommended rpm for break-ins? So there should be a constant fluctuation(up and downs) of rpm and mph when driving on the road for about the first few thousand miles? I want to make sure if i should ride hard and slow down a little hard or not. So far, theres been a couple times that ive been driving hard and fast:up to 70mph :shades: on the street then slowing down quickly and braking a little hard to make sure the rpm needle be "jumping up and down for joy." Most of the time i would abruptly push the gas pedal to reach 50mph on the road and then slowing down to continue my normal speed 40-45mph. I hope im not straining my engine. Thanks for any help, boy reading back my comments i hope i dont turn this topic into a breakin topic :confuse: But just to be safe... How bout synthetics huh? arent they wonderful?? they sure can change somone's perception on cars/engines overnight! haha
High
Perhaps I should have been a tad more clear about using the automatic transmission during break in. You can use the automatic transmission (gear selection) to "vary your engine speeds (and since you know and care your engine loadings on acceleration and de-acceleration), while for example, keeping your mph constant (or close to constant as possible). So this accomplish two goals 1. vary your engine speed 2. if your break in procedure has a sign post of say not going over 55 mph-65 mph. Since you dont want to do sustained high speed because all you really want to do is have those parts mesh together, such as brakes pads, rotors, tires, suspension shocks/struts, bearings, yada, yada.
NOW on to the boring part
Just got a 1996 Toyota Landcruiser back from a 60k major service interval (you know the BIG Kahuna) at the local Toyota dealer. The nexus here is the Mobil One 5w30 with either oem or cheapie Fram oil filters, 15,000 OCI's. (4/5 oil changes so far) Since this was time for the 60k valve check/adjust, the Landcruiser technician took off the valve cover and not only was the innards(in their words) "totally cherry" (aka totally clean and sludge less), but it required absolutely no valve adjustments!!!
Besides, many mechanics are only passing on anecdotal (meaning not scientifically tested) opinions, and I don't think they have much weight.
My opinion is that a little common sense for a few hundred miles is all you need--just enough to let parts expand and contract and get comfortable with each other.
But again statistically there is no study that has scientifically compared xyz filters with the conclusion being (along the lines of)ALPHA filter can go 200,000 MORE miles than XYZ filters or with no significant wear, so parts last longer, etc etc ...... But an interesting aside is FRAM manufactures FOR Honda, the Honda OEM oil filter. Not the familar hypnotic ORANGE color but.....
On the other hand, if the oem's were really serious about longer engine life, there are 4 (aftermarket) parts that should be on every engine 1. preoilers 2. bypass oil filters 3. larger sumps 4. OLM's
In so far as the synthetic oils are concerned it has been common knowledge for some time that break in is probably best left to oem filled conventional oil. However there are precious few oems that will say (either in print or warranty fulfillment: DO NOT USE SYNTHETIC OIL!! The only one that I am remotely aware of that does is the Mazda specifically the rotary (Wankel) engine.
Problem is, it will likely take 10K to 20K miles, depending on the engine and the oil.
One guy I read about had a mazda (not rotary) and switched his oil at 1K miles to Synth and he did not get a noticable MPG bump until 22,000 miles, which is when he estimated the break-in finally completed.
All the literature on the subject is pretty much in agreement, that synth will delay the completion of the break-in period.
Perhaps most folks would WANT (to need) a better filter.
The only filter that I do make sure I get oem is the VW TDI filter. Most of it is because of fit and not the "superior" filtering ability. In the TDI, you change the (paper) filter and not the outer cartridge. My sense is that JUST the (paper) filter probably cuts the manufacturing costs even over the ubiquitous "orange grenade" Moreover it does filter better by "clinical" measures. It is also specified for a 30,000 mile OCI.
While they may pay for dino changes every 3K for 30K miles, 10 oil changes, if you switch to syn oil, you may go between 5K and 10K miles between changes, whatever you feel comforable with...I go 5K between changes, instead of 3K with dino oil...naturally, if you go 10K between changes, then you will only change 4X, now, plus 10K, 20K, 30K, but your engine will have lived on syn oil forever, except for the initial factory filling...
So, you may pay more for syn oil, but you get what you want...if the dealer uses dino, and you want syn, you might ask for a refund on your "maintenance plan" and just move on...
I was a dino oil fan, no, fanatic, for 40 years, but the threads on this forum changed my mind...I changed oil on my 04 Ford and 04 Ram at 1000 miles, dumped the dino, went with Castrol 5W-30 syn oil, and never looked back...
The Ford is in service today, 30K miles, for oil change, flush power steering fluid, flush tranny/tork converter fluid, tranny filter, change rear end fluid, fuel filter, already has K&N 50K air filter...
Will change brake fluid at 50K, and coolant at 75K, along with spark plugs at 75K...
Thanks for your concern Marsha7. Well the total cost for my maintenance plan for 2 yrs is about $609. Besides changing oil/filter and rotating/balancing tires, they also inspect other parts of my truck (suspension, brakes, hoses, fuel components, steering components, and all lights) to see if i need some fix or repairs which will cost me nothing due to my premium bumper to bumper warranty. I am going see my dealer in a little bit and once there i will ask to see if i can change my own oil/filter and see what my options are: if they can provide me free syn instead of regular every recommended interval, etc. Besides, im perfectly fine with keeping the plan because by 30k, they would have replace the major services like engine drive belts, air filter, incabin filter, coolant system flush, auto tranny flush, wiper blades, & rotate/balance. To me, that total service i just mentioned right there outweighs the $609 that i paid initially. Most certified repair shops would cost me an estimated $1 grand or more to do that service because of the labor+parts.
So basically, IMO the inspection and the 30k major service maintenance is a keeper even if i end up telling them to not do the oil/filter change that was part of the maintenance plan. I'd be perfectly fine with changing my own filter/oil because i've learned my lesson to not let anyone else change my oil.
I'd do this because i rather have synthetic rather than no syn at all.
High
1. for most engines there is not the FEARED debris floating around.
2.However the(smaller sized) particles do indeed circulate than can possibly degrade LONG term, cause damage etc. However the media is not fine enough to filter these. indeed the filter can not filter. (too small). Hence my mention of the "bypass" oil filter.
So what % of folks run bypass oil filters? Again the definition of minority group!!! Am I saying there is not a place for oil analysis? Absolutely not. However if you take a snap shot of how what % of folks actually do oil analysis, well this is the definition of a "minority position"
3. Oil analysis is really for TREND identification
4. Defacto this is what everybody does with oil changes of 3,4,5,7k etc.!!!???? Again not rocket science I bet even YOU do this. So for example no less than Honda America recommends every other oil change to do an oil filter change 20k for the normal interval. Again FRAM makes Honda's OEM oil filters.
5. As for brand loyalty? Hardly! Champion Labs makes a far better filter and now at WalMart is even cheaper (2.07)
6. The use of FRAM as an example is really to show that it doesn't matter as much as YOU (or even me) has been led to think.
So if you can't handle that or are angry at the fact that it isn't as critical as you or I have been led to believe, I can understand your reaction/s.
Fuel mileage calculations don't seem a very good indicator since there are so many variables affecting fuel mileage.
The argument that "I broke my engines in carefully and never had a problem" doesn't work because you haven't compared the results to breaking in the same exact engine in some other way.
Here's an engine builder (see link below) who thinks that a modern engine can be completely broken in very very quickly, perhaps 20 miles.
I tend to very much agree with his analysis of modern engine construdtion, and his argument for a hard, fast break-in:
http://www.mototuneusa.com/break_in_secrets.htm
This is how I'm going to break my engine in next week but of course everyone should do what he is comfortable with.
Yeah, I think that the "break in" gig is a misnomer. To me the "break in period" has come to mean specific things.
1.like making sure the tire sheds the slippery mold lubricant slowly and the longer tire wear patterns develop. So the real reason to go 55 mph (and or less) is to cultivate LONGER term wear patterns.
2. parts such as engine parts, suspension parts i.e., springs, stabilizer bars, bearings, shocks, struts, brake pads and rotors all establish good wear patterns together, usually with an eye to longevity.
But the truth is you can flog it from the get go and just as long as one is not abusive, the warranty fulfillment should not be an issue.
:P that was the same link i was looking at whenever i was trying to learn how to break-in an engine. I too agree with most of his points. But he did say that not to use synthetic oil until the 1500 miles mark or two full days of hard racing. I think im going to switch out the factory oil at 500-1000 miles with another regular oil and then switch to synthetic around 3000 the first oil change interval like quockeio's idea. Ive been reading in that this particular person's view on cars that came with factory synthetic be dumped out within a few hundred miles and to be replaced with regular oil for a better breakin. I guess he wanted to state that regular oil produces more better friction and better sealing for breaking in an engine.
On the contrary, many people believe that new modern engines can instantly use synthetic and Mobil 1 states that we can use synthetic after 500 miles.
So, should i believe the oil chemists at Exxon/Mobil 1 or someone's experience and work on engines. I guess everyone just have to go with what they feel is right, right?
High
Best Regards,
Shipo
So as it related to synthetic oil, I am sure there are folks who are absolutely horrified to hear my synthetic oil and filter experiences. . But rest assured that in no way shape or form would I risk 250,000 dollars in automobiles to save whatever you might think I am saving, if indeed I had even the slightest doubt.
But really, so what?
That didn't help my 250,000 miles with 15,000 mile OCI's, now did it? Ran like a top. Sold it for 44% loss in 14 years or 3.14% loss per year. Total miles with 15,000 mile intervals, either oem or Champion Labs or FRAM type filters app 750,000 miles. You can believe what you want. If you don't want to hear it, don't bother to answer. I am doing it.
"I work on facts. Maybe if you had some training in the care and feeding of engines/turbines where there is research done because the cost can be enormous for failure of a part, you would see things differently. If you didn't, you wouldn't be around long. Don't change your filter or oil, that's your choice. Use whatever brands you want, also your choice. Just don't give bad advice based on your personal choice to do so to someone who doesn't know what risks that involves."
What I told you is factual, if you don't want to believe it, that has to be fine with me. I didn't tell anyone to USE FRAM. I SAID that I used FRAM. You are distorting what I have said. I do change the oil and filter DAH!!! So you do have a gift for distortion.
It very well could have been the case. So without going through expensive dyno testing, etc, count your lucky stars and enjoy!
I also just completed a "total" break in of my TDI. As some folks are probably aware, diesels do not develop their full compression until much later than a gasser. The VW TDI's case is full compression in and around the 50-60k mile markers. As a comparison to gasser, of immediate to 3k miles. So as an offshot full performance doesnt get better (in the the case of mph) until later. So the upshot is the "break in" procedure is sort of like breaking in a new baseball glove. Sure, right off the assembly line the glove is fuly functional, but....
So I can identify with what you are saying.
As in all other things in life: moderation is the key. Just drive the damn thing and quit worrying about it. :mad:
Larry
There were other Mobil 1 bottles 5w30 and 10w30 but didnt have the "New vehicle formula" and had the API SM and GF-4 indication. Although i believe that this is fairly insignificant, i thought i would just like to share. Plus, the label on the Castrol Syntec has not changed at all.
For those die hard mobil 1 users who likes nothing but the "best" i would stock up on the small amount of SM/GF-4 mobil 1 that is left.
High
However being brought up in "the old school" (late 40's early 50's cars on up) I have actually witness the "chunks" of debris floating around in the crankcase and sludge making ability of conventional oil. I saw the need and even used to do 1.5k-3k oil changes. So while I understand the need, history and the eventual histrionics of the behaviors leading to the habit of 1.5k-3k OCI's, It is total over kill for most of today's modern engines.
So on 2 recent break in's I used a fairly aggressive break in in terms of rpm bandwidth of 75% - redline. The first oem recommended 5,000 mile oil changes for the first two oil changes and I complied. The third OCI on up is recommended for 10,000 mile OCI's. The second oem recommended 10,000 mile OCI's again I complied. It also recommends the 2nd OCI to change the (FRAM) filter!! Again a no brainer. Both vehicles run like the proverbial TOP. So baring catastrophic behavior (not due to oil use) both will be just fine.
High
If the engine does not use any appreciable amounts of oil does that mean the the rings are properly seated, and everything is fine?
Conversly wouldn't the primary indicator of improper break-in be excess oil consumption?
I would like to know for sure that the engine is ready before I put in synthetic.
My last car had its first oil change at 1,000 miles, and then synthetic put in at 3,000. Seemed to do fine - valvetrain still looks new at 197,000 miles.
-Dudley
If you buy any kind of a demo, it could have anywhere from 200 to 5000 miles, so changing the oil at 20 miles is no-go
Even some new cars, never driven by consumers, can have 10-20 miles on them when purchased...heck, if you choose a new one and drive it yourself just to make sure it runs, you may come back with 30 miles on the odo...
Or, if the vehicle is driven from another dealer to your dealer, it may have 50 miles when you buy it...
Our new Ram 1500 had 206 on the odo when it was brought to us in GA from a Memphis dealer...oh, well...I did my usual procedure of changing oil and filter at 1000 miles, and converted to syn oil then...5W-30 Castrol Syn...
I also believe that if cars were factory filled with synthetic, lucky for those "rich" people hehe. But for those other "factory filled dino juice people", switching to synthetic too soon can mean longer break-in period.
I kinda agree with all of you.
High
I'm picking up my new Mazda3 tomorrow and I'm wondering what my time frame should be for switching to synthetic motor oil? Back in 1993, I bought a new Honda Civic and used synthetic from the first oil change at 5k miles. I was 18 when I bought the car, drove the heck out of it and sold it four years later with 178k miles on it (from commuting to college and delivering pizza). Needless to say, those were hard miles but I had not a single mechanical failure in all those miles. According to my mechanic, engine compression was almost as good as it was when new.
So, should I go synthetic with the Mazda? I've read in several places that I should wait for at least 5k to switch over. What's the overall consensus here?
I assume that you drive your cars pretty hard? If that is so, than switching it earlier than 1500-3000 miles may not be so bad of an idea.
High
