17907917937957961306
    edited June 2017
    It's been my experience that if the person's XJS is running regularly, that it's running with various non-critical things wrong with it. You have to have a lot of forgiveness and tolerance--trying to make them 100% is exhausting.
    See how tempting they are? You know you want to go buy this one....
    https://sfbay.craigslist.org/eby/cto/6173854500.html
    or this one:
    https://sfbay.craigslist.org/nby/cto/6171671320.html
    Hey, that '94 is only a couple of hours from me. Wow, a convertible and only $3500! Wait, I just remembered I have a toilet. It's much easier to just flush my money down that.
    or you can toss it on the Weber while you're cooking tonight.
  • fintailfintail Member Posts: 58,803
    edited June 2017
    I like the pic of the second one, apparently the car isn't worth getting out of another car in order to take a pic.
  • texasestexases Member Posts: 11,188
    edited June 2017
    Knew a couple years ago with an XJ6-they got rid of it after the monthly repairs exceeded the  $600/month payments. Said it was like flushing $100 bills down the toilette...
    Nah, that would cause smoke pollution. Maybe I could throw it in the Weber (once the coals are hot).
  • kyfdxkyfdx Moderator Posts: 271,322
    Can they do GM V-8 swaps, like they used to do with the late '70s model? Or, does OBD-I make that problematic?
  • tjc78tjc78 Member Posts: 17,392
    The gauges might be a problem, but I'm sure you squeeze in a 350 with a carb or late 80s 5.0 Mustang/LSC engine with the computer.  Those are speed density not all that much to make them run.
  • ab348ab348 Member Posts: 20,637
    Assuming you're talking about the XJS, my sense is that it wasn't the engines that were the problem with long-term ownership/use, it was everything else. Switches, seat and window motors, etc etc.
  • explorerx4explorerx4 Member Posts: 21,050
    Spin the wheel. Pick your money pit.
    http://www.motorcarsinc.com/used-jaguars.aspx
    There's quite a bit of truth to that--the basic XJ/XJS 6 cylinder engine was around for almost as long as the Chevy stovebolt 6. Replacing the engine doesn't solve your problems at all--if anything, it makes some things worse, especially the stress on the frame and the loss of that smooth, smooth powertrain feeling.
    It's everything ATTACHED to the engine that's the problem.
    But the V12 could be a real pain, right?  Fuel lines buried under stuff, leaks, etc.
    Well they actually raced that engine, believe it or not. They were a pretty good engine, but here again, the fuel injection and the electronics can bedevil you.
    Oh, they also liked to catch fire and they get about 10 mpg.
    edited June 2017
    The fires was one thing I remember about those Jag V12s...bake the rubber fuel lines inside layers of hot engine components, then have the leaks put gas right on those hot components, what's the problem???
    Saw a Starion/Conquest yesterday, no badges, bad YELLOW respray.
    Hard to find those injector lines, too.
    I don't know if I even knew these existed? From BaT:
    1995 Mercedes-Benz E320 Cabriolet
    Colors are pretty bland though.
    I remember them being crazy expensive, like 2X the base price of the sedan.
    Low production, and they were indeed expensive - that thing was 75-80K when new, in those dollars. I see them now and then, I think quite a few sold here when new. Values are still soft - I see nice low mileage ones some distance from 20K, even in MBCA ads. A couple years ago there was a 50K mile one for sale locally for 15K.
    I don't care for the accessory dash trim piece or modern stereo, but I love the 90s era MB white over grey.
  • MichaellMichaell Moderator Posts: 267,794
    Yeah, something like $75K in the early 90's
    I'm pretty sure I posted a few weeks ago that I've seen a green one at work a few times.
  • stickguystickguy Member Posts: 54,151
    you people gotta stop posting links to BaT. Besides sucking down an hour of my time, I find way too many things that attract my attention.
    I really like these, but can't believe the bids on a real ratty car that is going to suck down a whole lotta money to set right.
    http://bringatrailer.com/listing/1974-toyota-corolla/
    edited June 2017
    Those old Corollas were good in their day.   Not something I'd want to drive today, though.
    Wouldn't want to crash in it for sure.
    The market is warming up to old Japanese cars now, healthy bids for that. I've seen really decent money for period Mazdas.
    Heh. I remember my brother coming by with one of those Corollas in the late 1970s - purchased from a coworker for cheap - and taking me for a test drive. As we started to pull away he said "don't put your feet on the floor there" pointing to an area near the front passenger seat. I pulled up the rubber mat and could see the asphalt going past. Up here they were total rust buckets after just a few years. Can't see spending that kind of money for one of those.
    I bought a Corolla well used. I think it was a 75, and I got it in 83. Loved that car. Was an E-5 (fancy pants, 5 speed stick). Brown over brown. I'm sure it would be a penalty box today, but after a few junky domestics (gremlin, hornet) and the Opel from Hell, it was wonderful.
    somewhere along the line, it got crunched on the DS right behind the front wheel, leading to hole in the floor. I pulled back the mat (not even sure it had carpet!), banged it flat, and put a roof shingle I found in the garage over the hole (with a bit of tar/glue stuff to hold it in place), put the mat back over it, and was good to go. Nice solid floor, and no leaks!
    Japanese cars of that era didn't rust so fiercely here, but the interiors would eventually kind of biodegrade. That and general fall-apart seemed to finally do them in by the late 90s.
    Pretty Low Miles E320 cabriolet, last year of production:
    https://sfbay.craigslist.org/scz/cto/6173600684.html
    They were really good little cars but have the build quality of an Italian TV dinner tray.
    And no doubt it could be had for less. Those might not ever go insane in value, but I don't think they will depreciate much past this point.
    Yes, for the low mileage cars, prices should stabilize--but a miled up, regular production Benz will always drop like a stone. I've seen these same cars in good shape but with 180K on them for $6500.
    I saw one a couple years ago at a somewhat janky local auction - it had apparently sat outside for years with a leaky top. Rotten and moldy inside, parts car.
    I almost went to look at the 50K mile $15K one locally, but I don't need another old car, and I wouldn't want to wear it out in DD usage.
    Well, considering that you can still buy a 40 year old 450SL convertible for $10,000, I don't think holding onto an E320 and babying it is going to pay off. It's a nice used car---so use it up!
    I'm looking right now at a 2003 SL500 with 5,000 miles on it. What good did it do the owner to not use it? None. He lost a bundle of money and got nearly zero use and enjoyment.
    I just don't understand this sort of thing I guess. :'(
    I think the 300CE/E320 still has some special/rare stigma with it, and they are kind of elegant. I don't imagine them going as low as far more common (and thirstier, and less practical) 70s SLs. I wouldn't want to put a perfectly preserved low mileage baby through the commuting grind - do that to the maintained 100K+ car that has had all needs addressed. If anything, using up a low mileage car might cost more than doing the same to one that has been driven.
    First year R230, no thanks, the price can't be low enough. First and early run MBs from that era can be troublesome. Maybe he thought it would be a collectible, but even today a perfect 560SL is worth far less than original MSRP - a R230 will never get there/
    Aside from Benzheads, I don't think most people would look twice at an E320 beyond it being a nice used car. Old droptops will always be worth something but relatively speaking, it's a pretty dull car.
    Still, 15K for a 90s era cabrio with expensive maintenance isn't bad. Most from that era fare far worse.
    I read on Hemmings that 190SL/Pagoda/107 prices have now peaked and are receding just a little.
    Yes I think you're right---all the SLs are stabilizing or dropping a bit, except for the truly prime, exceptional examples. There are so many tarted-up rats out there!
    I just found an outstanding 230SL for a fellow---very original, unmolested Euro car, solid, clean, rust-free, every inch a beauty----about a 95 pointer, in the $60K range.
    But a show-quality (beyond show quality) 280SL just went to Germany for $145K.
    To most observers, standing a few feet away, they wouldn't notice the difference between the two cars. But the Benzheads certainly would note the price difference between a 230 and 280, and the meticulous attention to detail on the 280SL, down to the decals and diagrams on the relays and, of course, that the AUTHENTIC grommets on the windshield washer bag, which are not the reproduced stainless steel grommet, but the OEM bronze grommet! And of course, all panel gaps would be judged uniform with a thickness gauge.
    and thus do monks debate the number of angels on the head of a pin :)
    The 280SL sounds like someone spent that much on the restoration, making the basis car free. Maybe not poorly bought. It's almost always cheaper to buy someone's finished project than to do it yourself. I assume that car was completed by a well-respected shop.
    The local Volvo Amazon wagon is back in DD duty.
    This afternoon: clean early 90s Legend sedan, ~80 Corolla wagon, black on red 57 Chevy convertible, stock.
    1964 Fairlane 500 Sport Coupe. White. With a 289 badge on the front fender. The car had pipes out behind the front wheels and wider rear tires than the standard-looking front tires.
    On the road today - 60s Beetle convertible, Vanagon Westfalia (honked and waved at me, I was in the fintail), 56 Chevy, red 80s 911 Targa, 80s 911 Cabrio, E30 convertible.
    On the road this afternoon - 76-77 (I think) El Camino, very clean unrestored looking rig, red and white, L88 badge on grille.
    edited June 2017
    High school friend had a blue El Camino with factory 454. I've seen 427 swaps before mostly on older (60's) cars but what does an L88 grille emblem look like? I've seen the Corvette L88 hood decals but it's not like the typical Chevy fender emblems.
    I think it must have been an owner-made item - I can't find an image of one like it. It was a small badge in a blocky period-correct style font, at lower right on the grille. This particular El Camino didn't seem to be insanely loud or anything either, but was obviously cared for.
    Saw a pretty nice looking white 1989 (ish) 300ZX. Always liked those.
    I wonder if those muscle El Camino's have wheel hop issues with the light rear end of a pick up?
    Far north side Columbus around lunch time I spotted a 57ish Ford 2-dr wagon from behind...possibly a Ranch Wagon or Del Rio? Looked restored, nice blue/white finish with wide whitewalls and period wheel covers. But with a deep bark from the loud pipes
    Nice looking car in its time
    '56 Chevy 2D HT "ratrod". Very serious sounding engine. Talked to the owner---he's restored the frame underneath, has a 383 Chevy stroker, cammed, Dart heads, Hedmann headers, Black Widow exhaust. Body has surface rust, some cracked windows, sport buckets, nice interior actually but original funky dash. Wouldn't call it a "sleeper" though, because the engine note is "authoritative" to put it mildly. Very cool build. Says he has $16K in it.
    The blue in the picture does not do the color justice. I'd describe it as the baby blue of an infant's blanket. No green in it; just blue.
    I've seen that color before, most likely a 1975-80 car. I assume it was badged 450SL. The wheels are 1980s "Centra" brand, a popular aftermarket item back in the day. Whitewalls and wheels seem wrong now, but they were a thing back then.
