A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Best regards,
Shipo
I know for example Mobil One 0w40 is probably just fine for the Jetta. However it is always better to know and understand what the specifications are, whether you comply with them or deviate.
I was just wondering if there was any potential issue with mixing 0W with 5W.
Between the two Mobil One normally yields better UOA's, but it does seem you are more concerned with the negative implications.
Also if you are really curious about compatibility with the residual oil left behind by by the other brand,there is no compatibility issues.
If you are truly concerned about the condition of your motor, have the old oil Exxon SF you take out analyzed, and then analyze the QC when you pull it.
As a general rule (without analysis) you can go around 5,000 miles and or three months with a safe level TBN number, most of the time.
I have also researched Mobil One MB 229.1 5w40 and MObil One 5w30 VW 507.00 I might go to one or the other when my Total Quartz INEO supply runs out.
I have kept one @ 20,000 miles (Mobil One 5w20, 0w20) as the oil filter change oem recommendation is @ 20,000 miles also so it just seems logical to do them all together.
How often would you change a full synthetic to keep your fanatic level the same?
I'd fit your profile. I've always done 3K w/conventional, but in the last year have started using syn @ 5K. Oil and filters are just soo cheap comparatively speaking, there's really no need to risk long OCI's.
As a non fanatic, as long as we are not talking about cars with turbos or anything, I figure 5000 miles is good for conventional and 10K for synthetic.
The Sandman :sick: :shades:
The 7,500 - (6 months), 25,000 and even 35,000 (one year) options with the above mention brand shows what protection is offered but you still need to be sensible about the how long you go before an oil change/oil analysis.
Yes, often there are. But, my wife's VW, which requires synthetic, has only one schedule listed...10,000 mi or 12 months.
severe -short trips with many stops, requiring OCI closer to the normal and traditional 3,000 miles/5,000 kms or three months - whichever comes first.
No, I don't think they are usually that extreme any more. For my 2007 Mazda that schedule is 5000 miles or 4 months...and that is with conventional, not synthetic oil.
3 months for us would be about 2000 miles...I'm not about to change full synthetic on that schedule.
This is a tad like a rubber ruler in that in the USA that can set off "emergency alarms" and panic overloads @3001 miles- just waiting for the engine to literally BLOW UP !! :surprise:
Europe in contrast than can mean 30,001 miles. :shades:
The US market seems to have a pretty high incidence of sludge a matics. So the first order of business is to make sure an engine and model and oem line was NOT selected. So for (only) example, Toyota has settled without admitting guilt, a series of engine models that are put in any number of platforms.
Many look to synthetic oils to eliminate sludge issues, but let me assure you any engine that "cooks" oil (consistently and normally exceeds the flash point of oil) will eventually sludge. It is true that certain synthetics are just less prone to sludging, aka have a higher flash point.
The real crime (no guilt of course acknowledged or intented admitted or declared ) is that it allows the continued sale of sludge-a-matics with minimal to no re-design or re-specifications needed !! So for example, I have not bought a Toyota Camry (sludge a matics) for going on 24 years. This is not to single out one manufacturer. There is literally a laundry list of oems and models. "Let the force be with you, Luke" and don't cross over to the DARK (sludge-a-matic) side !
UPSHOT: do one's homework and buy only those oems and models that have extended oil changes and are not "has been" sludge a matics repackaged for modern day consumption with sexy new body coverings.
TOYOTA DEAL: HERE COMES THE SLUDGE JUDGE
The problem is in their not admitting the sludging in a timely manner. Dealers were ridiculing customers as though they hadn't taken care of the motors, at the time that Toyo knew they had problems. They even made minor changes to the physical engine to try to reduce the problem. How would they treat a new problem? Admit or cover up--such as downshifting problems in transmission and computer control?
I thought synthetics weren't sludge prone.
Actually, the same has been true for me. Since that time, I have owned 5 Toyota Landcruisers. All have run a min of 15,000 miles OCI's. One was sold with app 250,000 miles on it. Another was sold to a MB diesel mechanic because he wanted it. I did state upfront I ran 15,000 miles OCI's and he looked at me with an attitude like... so what? My more recent ones run 20,000 miles OCI's and one is at 170,000 miles. (Garage king/queen). But the key here: those engines (I6's) have never been "sludge a matics"..... which really was the original point.
So anyone who buys products mentioned in the class action cases is in effect forewarned. I frankly do not know of the Toyota policy that says in effect, don't worry, we will fix the sludge problem with no hassles...
I suggest just reading CR at the local public library or the magazine stand. Also, there are databases (EBSCOhost) which I can use via my library to read most periodicals in a timely manner and CR is available after 3 months in PDF format online! While many people like and trust their ratings, I read them with a grain of salt looking for their inconsistencies in statements showing a preference between vehicles and other things where it's only their opinion.
Great!.
Now if the local library can just upgrade their AllData subscription to include home terminals!!! instead of having to use it in the library...
The oil didn't need to be changed, but I do change the oil and filter once a year.
It costs me about $90 a year to use synthetic oil, and with gas at about $2 a gallon, I save about $65 a year with better gas mileage using synthetic oil. I also know that there is less wear in the engine because all the wear metals in the oil are very low. I have been using Amsoil and doing annual oil changes for over 30 years now and it has worked for me.
A quick and dirty (read- but you didn't post the actual data) is your synthetic oil is really at the sweet spot (@13,000 miles) and 15,000 to 20,000 miles are almost a slam dunk. In fact, wear is HIGHLY aggressive when oil is new (0 to 3,000 miles). So oxymoronically when folks do 3,000 mile OCI's, they are effecting the highest and most aggressive wear patterns !! This is even as they are being told this highly aggressive wear patterns are ... good for the engine !! You in effect do not see the new oil SPIKE as over time, it smooths out over time and you are in effect seeing the AVERAGE and cummulative effects @ the 13k mark. So by pulling the oil "prematurely" you are not giving the oil the time and repetitions it was DESIGNED to dispense what it was truly designed to do, over repetition of miles. Again this is simple to verfiy or debunk. Just draw a sample @ 3,000 miles or less and send it to Blackstone (or whomever you use) and compare the wear results.
So for example, there are three measurements you should evaluate the oil in your case @ 13,000 miles. 1. totals are important 2. The first is that generic engines AVERAGE per thousand miles 3.your specific analysis, again. per thousand miles.
Here is one that I follow:
Calculated by dividing total wear metals by miles in thousands. The national average is 6.538 ppm total wear metals, less Mn and Ni. This is based on 51 ppm total / 7800 miles by Blackstone.
TDI Club Ave : 6.614 ppm. ~~~~~~ Club Ave. OCI : 9808 mi. 5/19/09
link title
Suppose your results are in the "top 10" range of 2.252 to 3.144 ppm. You do not wanted to exceed the "average" and you wanted to let the OCI go as long as possible. So your range is 6.614 ppm / (*9,808 miles) 2.252 ppm to 3.144 ppm per 1,000 miles = 2.94 to 2.104 =
28,835 miles to 20,636 miles OCI.
So for example since I am a belt and suspenders kind of guy, I cap it at 25,000 miles. (round numbers)I know full well the oil filter and engine oils are designed for 30,000 miles OCI's !! :surprise:
By the way, I put 5 quarts of Mobil 1 15W-50 in the crankcase of my Triumph Rocket III and have ridden 200 miles plus. The subjective improvements to clutch and engine response are just so outstanding.
Synthetic should be great for any motorcycle engine I would think, given the high heat, high revs, etc.
