A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
It sounds great and they want you to think superior to Mobil one. They recommend 10-12k change interval if not under warranty along with 3-5k mile oil filter changes.
INKY
http://www.amsoil.com/products/tso.html
Amsoil oil filter must be changed every 12,500 miles or 6 months with this oil.
Amsoil started in business in 1968. They really know what their doing.
I've been using Amsoil for 7 years and knowing what I know now, I will never go back to dino oil.
Sorry for the long post but just wanted to tell everyone about my experience. Been working on cars for over 30 years.
Also, RedLine makes a better manual tranny gear oil with their MT90 then Amsoil. Hands down winner on that one. More weights in the gear oils as well. RedLine appears geared more to racing whereas Amsoil is more average Joe driver oriented. Price is really the same as Mobil 1, problem is the lack of dealers and most do not stock inventory so shipping cost is an issue. Plus, the owner is somewhat arrongant (AJ Amatuso) in his statements and product claims. Who cares if he was a jet pilot!!!!!!!!!!!!!!!!!!
For the Amsoil users, after how many miles does your oil normally darken to black? Is the oil still good even though it is black?
years,agree with above posts about the 12k range
getting the silicon levels.I have a es300 and I
devised a way to mount the bypass filter.
A tip to any potential or current Amsoil users,
if you can qualify for a commercial account(use
oil in your business)try and get one,the oil will
be approx. 25% cheaper than the dealer.
Al
see what I mean about the cheaper price.
I have never tried the red line gear oils but
I had a brochure and they did seem to have a
better array of trans oils depending on what
metals your trans had in it.
I am a dealer ( I don't resell though, just a personal use user) and for $20/year I get the wholesale price. ( I have 5 cars to maintain so it is worth it for me) They have a new program for I think $15/year you also get the wholesale price. I am lucky though, my direct jobber keeps a huge inventory so I do not need to have shipping which adds to the cost tremendously. I never have understood why Amsoil does not have outlet stores but I guess that would destroy the independent dealer network.
For example, if I have a 6 cylinder engine with a 4 quart oil capacity vs. that same engine with a 6 quart oil capacity, I'd expect the latter car to be able to go at least 50% longer between changes. My reasoning is that you haven't changed the amount of work the oil is doing, but you have provided 50% more raw material to lubricate, clean, and suspend impurities. A longer drain interval would be a direct benefit of the larger oil capacity.
An extreme example is the over-the-road diesel engine that might have an oil capacity of 50 quarts......you don't see those vehicles getting oil changes every 3k miles!!! And they punish a motor oil, with higher heat loads and lots of sooty deposits!!! I don't believe synthetics are real popular in these applications, and many of these engines have an expected life of close to a million miles before an overhaul!!
Something to think about....
With that much oil in the system, I'd definitely expect longer drain intervals...
-Chris
TLC between 7.5-8.5 qts depending on whether you take the small or large filter.
The problem is one of royalties and costly up front testing. To wear the "donut" you have to pay royalites usually per unit and go through the certification and QA testing procedures.
These smaller companies can in fact have oils that meet or exceed the standards, but in fact do not and cannot wear the donut or logo, for the stated above reasons.
I mean, using the Mobil One, even with a factory filter, can't be all that bad can it?
Thanks for your advice.
98 Contour SVT 2.5L HO V6 5.8 quarts
00 Mazda MPV 2.5L V6 5.5 quarts.
These are including the filter, FWIW.
TB
market,that is probably the reason for that
rating.
The greater oil capacity is one of the reasons
I use the By-pass filter,I can get a one to
three quart increase depending on which element
I use.
Yes, the Honda filters are fine with the Mobil 1 oil. I think that the Mobil 1 filter is slightly better but not worth hassling about. If the dealer will put your filter on purchase a Pure One or Mobil 1 prior to future oil changes and see if they will put that on for you?
Al
Please provide some evidence. I should say that in my humble opinion that statement sounds as ridiculous as it can get.
Also would like to know if there is any info out there showing the reasons not to use synthetics in the rotary engines.
My .02
You can rationalize cheapness for yourself, all you want, just use so common sense (in the absence of knowlede) for others.
Later
RACING--Of course I would take advantage of synthetic oil's abilities to withstand heat, but really, many, many cars have won many, many victories before synthetic was ever used....so to what extent it makes the difference between victory and defeat---well, that I just don't know. I don't have the firsthand experience or the race team reports. But As one race driver said (Sterling MOss I believe) "the best race car is the one that breaks 5 seconds after the victory flag (explanation:--strong enough to win the race at a ferocious speed, but not so overbuilt as to impede its performance for victory).
The race car is sacrificial--if you don't believe that, I don't think you can win.
Synthetic in Rotaries---a plausible argument to NOT use synthetics in rotary engines is at www.mazdatrix.com
Apparently, it affects apex seals, but I can't recall if it was BECAUSE it left a residue, or because it didn't...one of the two.
mine went from dino oil to amsoil 0w30,was used in
a 28 foot motorhome that would overheat in traffic
all he did was change the oil no other repair.
If every oil manufacturer did a test and was
beaten by the synthetics do you think they would
publish the results?
You can believe it or not but I know of some and
have read posts here of users running synthetic
and extra filters and never changing oil just
taking samples.
I posted this before elsewhere but if you are
really looking for a long term test why don't
you make one yourself,run some dino oil in a
car for 7 or 8k and take a oil sample and see
what shape its in,it probably will not even be
the same weight that it started out as.then do
the same thing with the same car with amsoil or
mobil one ,sample will be quite different.
You should quit telling people the truth!! I am trying to get my kid through college with all the unnecessary conventional oil changes!!
If your friend wished to claim that he had a slightly lower temperature on his heat gauge while hill climbing in his RV, I' might concede that, but to stop an engine from overheating by adding synthetic oil, no way, simply no way. I'd need my face rubbed in it to believe it.
OIL SAMPLE: What good are those, except as sales tools? Here again, it's not good science...you take an oil sample, and they find "so many grams of this, and evidence of that" and you go, OH MY GOD, there's this STUFF in my oil....you're right, AMZ-OIL!
WEll, fact is, these residues and chemicals you find in the oil are not necessarily harmful. If you find LOTS of bearing material in there, and I mean LOTS, you may have a problem.
These tests are for industrial fleets that operate engines under tremendous punishment. They are mostly irrelevant to normal car use I believe.
I've torn down plenty of engines at say 100K that mic out perfectly and are ready for another 100K...this all accomplished with regular oil and regular changes (3K-5K).
How much more than that do you hope to accomplish with expensive synthetic oils and fancy filters? What is the point, really, unless you are really operating in a racing environment or hauling logs up mountains.
I just don't see the argument except to sell Amz-oil or whatever (which is okay, I don't think it is necessary a disservice to sell what may not be needed---if that were true, every over the counter and even "natural" drug company and vitamin company could be called to task.To say nothing of cosmetics.
I don't wish to be harsh, but I think the claims for synthetic oil do not bear scrutiny in the real world. I say that as a user of synthetic, too, on occasion. My Benz diesel has just turned 213,000 miles, and as near as I can tell from the detailed service records, it never had a drop of synthetic oil in its life.
So how do you explain that, and why should I use it then?
I still think a relatively cheap synthetic like Mobil 1 is a good investment. If you shop around you can get it on special quite often. K-Mart is a good source and I stock up if it is on sale. However, I believe the oil should be changed every 3000 miles if you are using synthetic or not. Cars with small sump capacities just cannot soak up all the impurities that build up under severe driving conditions. So that means just about all city dweller's cars.
A comment on crankcase capacity .... I was not impressed to learn that Pontiac, in the 1979 ongoing effort to improve fuel economy by reducing vehicle weight, reduced the crankcase capacity of the 301 CID engine from 5 to 4 qts. They also removed much of the weight from the crankshaft counterweights.
200,000 mile tests (each car). Two BMW's Two Olds. Oil change intervals 15,000 mi. for two cars, 7,500 miles for the other two. Results over 250 measurements on all parts(each engine) resulted in "almost no wear" I saw the parts. They came up to specs for n-e-w parts. Bet you never miced anything like that. Oh, did I mention all vehicles had Mobil 1??
Other info: Sequence IIIE sests performed by API for oil certification. Test Duration- 64 Hours: High speed, flat out, high temperature test of engine lub. ***No*** conventional oil can pass 128 hour test. Mobil 1 has passed Quadruple test. 256 hour. That my son is on a real life engine. They tear the engine down and measure sludge and wear.
More real life: 'Vetts are required to use syn because they run hotter and got rid of oil cooler because they could- with syn.
Expensive Oil/filters???- Chump change. Considering benefits and less work changing oil all the time. I have better things to do.
Later,
Al
Please stay with your dino, no one is asking you to change, in fact why are you even on this forum if you have no interest in synthetics???? Any engine will last 100,000 plus miles with crap for oil and a crap filter if you change it every 3,000 miles!!!!!!!!
Whatever floats your boat!
I guess what I want people here to consider is that there is a difference between a sales pitch and a fact, and I'd like to see which is which on any given claim.
This could be fun--think of it as a way of putting our and other's people's ideas under the microscope.
For instance....consider this:
Person A here says he measures his engines, and at 200K, there is "no wear".
Okay, great....but wait a minute....NO WEAR? Does this mean then that the engine will run forever? When does wear START? So it hasn't started yet at 200K? No wear?
By "logic", then, if there's no wear at 200K, and just about any modern engine will run 200K with good car (regardless of the oil you use presuming it is quality), then his engines will absolutely run 400K (since they are "new" at 200K).
Doesn't this strike you as implausible? It does me.
Here is my read on all this--
1. that synthetic oils will give you certain definite benefits.
2. That not every driver needs these benefits...some do, some don't
3. Synthetic oils have little or no effect on longevity of moving parts AS LONG AS the "control engine", using regular oil, is well-maintained.
4. Last of all, even if it were TRUE (and perhaps it is), that your engine will run 400K on synthetic oil, the rest of your car is not likely to last 400K, so what's the point?
Ball in your court!
can i use a synthetic Motor Oil should i wait a certain amount of miles for Engine to break in before switchin to MOBIL 1. Is it ok to use synthetic oil if ur car came with regular oil in the begining.
Mr shiftright
Your points are not worth arguing about!
If you want to separate facts from fiction you need to arm yourself with more info.
Otherwise you'll just get people upset.
I don't think that you want to provoke pointless arguing on this board.
