Visitor Agreement.
His junk box was full of scored and burnt pistons that had a thick scaly build up of carbon and crap that was welded on like iron.
He always had a least a dozen cases of Havoline up on the shelf and never used anything else for all his oil changes.
Once I saw he had the heads off a customers car that blew a gasket and the pistons had a layer of thin soft grey powder on top you could scape off with your fingernail. The cylinder walls still showed the cross hatch marks from new and were smooth as glass.
He had always done the oil changes on the car and was quite proud of showing anyone interested the difference a good oil can make.
In 2001, Texaco merged with Chevron but the Havoline brand name has been retained for all Texaco motor oils and other lubricating products along with anti-freezes. (Wiki quote)
When I take out my magnetic drain plugs for a Penzoil Platinum oil change, I see that same thin coating of grey powder that only leaves a little smudge on a Kleenex.
Coincidence, or the sign of a great oil?
My opinion is that with *modern* engines, you can take any oil can off the shelf in any store, and as long as it meets your manufacturer's specs, you can dump it in and your engine will probably run to its natural lifespan (about 175K these days).
In the "old days", when the earth was cooling and I was in junior high school, automobile engines were pretty crude pieces of work--they ran colder and the metallurgy was about as good as a Vermont wood stove.
Might one run a healthier engine for 175K with the best oils? Sure--especially under extreme conditions. But is it a matter of life and death? I don't think so.
But then, additionally, there should be no problems going 12 months and 6000 miles with the synthetic, rather than 6 mo./3K mi. Perhaps you are doing 6 months, due to being under warranty, which also makes sense.
Hyundai insists on 4-5K OCI, but, I'm not very concerned about their warranty at this point.
After switching over, I noticed that it stopped losing oil every oil change. I started putting it in our Ford Taurus which also would lose about 1/2 qt or so and it too would read full at my 3K oil change interval...
But, hey, if using synthetics and having some lab analyze your oil makes someone feel better, they should do it!
Do you really believe that drivvle?
So you are to believe that changing your oil at regular intervals is wasting natural resources and creating additional pollution? How?
Some better oils are recommended/warranted for 25,000 to 35,000 mile up to 1 year intervals.
Oh please, do tell. Which oils are recommended by the MANUFACTURER for 25-35,000 miles??
Valvoline and Castrol show 4 to 8 times less wear that Mobil 1 5w30 in much more accurate testing that a $20 used oil analysis.
According to who? For every oil analysis that says one thing, there are a ton that will say another.
Understand that silicates and sulphur (dirt and moisture) play as much part of contaminating the oils as does wear.
since you have a driveway full of assorted vehicles from 4x4's to a Harley, what oil have you settled on for all your projects?
The Harley gets Harley Davidson synthetic 20W50 oil
The Hyundai Santa Fe gets Castrol Synthetic 5W-20
The 4x4s all get either DELO 400 15w40 or NAPA Fleet 15w40.
the 70 has 290K miles and the 93 has 225K miles on it, so I see no reason to switch from the fleet oil.
The SantaFe and the Harley are both under warranty and I will use the oil I feel best protects them. Besides, the Harley is under service contract, so it's at the cost of the dealer.
So you can see, the oil I use depends greatly on the vehicle it is going in.
And I use the MANUFACTURER's recommended intervals for changing the oils.
Yep; I completely agree with that assertion.
I have a lot of learning to do should I choose to delve into that domain. :surprise:
I've seen some of the japanese bikes eat up tires in 3-5k miles, while some cruisers may go 15k miles without eating them up.
My brother-in-law's Harley has 12k miles on it, still on the first set of tires.
Personally, I find it far more tempting to cook the tires on a quick japanese bike than my Harley. :shades:
And I do agree that synthetic is the way to go on a motorcycle, especially the aircooled bikes.
As a father with two young children (2 and 5) and a wife who is very safety-conscious, I have become fairly adept at controlling my tire-cooking impulses. So, if the day ever comes that I can keep both a motorcycle and wife (the current one!), I will have to be tame while riding the bike.
My neighbor uses a synthetic in his; I will have to see what brand he uses.
I used to drive my Saab Turbo like an escaped lunatic. I'd wear out premium tires in 8000 miles, tops. That Saab engine LOVED synthetic.
My Subaru could care less.
Now I'm a bit more sane, although I do occasionally get my own cars into their upper limits when the "need" arises... I haven't found the speed limiter on my Impala yet, it's gone past 115 although it was wheezing pretty good at that point. My S-10 govern's itself at 96 but has room to go more if it were left unchecked, but it like the Astro Van it gets pretty floaty as it nears 100...
(this sounds like it belongs in the "inconsiderate's forum...")
I'd take exception to that with regard to the 1995-on Triumph triples. Some of those motors can go over 90k with just scheduled maintenance.
Anyway, I was thinking of the older Brit bikes. The new ones aren't even on my radar anymore, so I don't really know anything about them.
The argument might be moot, since it's extremely rare to see *any* bike driven to 90K---couldn't be more than one in thousands.
Are these new Brit bikes air-cooled or WC? I always was of the opinion that an air-cooled engine really needs synthetic oil.
My buddy's 2001 Harley Ultra Glide is ridden all the time, plus he makes several trips per year on it and it has 55,000 miles.
And then there is my 2008 with 2,000 miles on it. :surprise:
One of my older, more ridden bikes was a 1985 Yamaha V-max that had 65,000 miles on it when I sold it. But I was much younger and far more foolish in those days.
The V-max never saw synthetic, as in those days, it wasn't cheap to use.
There are a mix of air cooled and water cooled Euro bikes.
I know that most of Norton bikes are air cooled, some Triumphs are air (Bonneville series), some are water cooled, Some Moto Guzzi are water cooled, with a few of their classic series being air cooled.
Full fairing, with heat that blows on the legs when needed, stereo, CB, seems like 20 Cubic Feet of storage, intercom between passenger and driver, the list is endless. These guys ride all the time on those cruisers.
And they are usually pretty meticulous about maintenance on them.
There are a lot of Harley riders who think nothing about rebuilding their engines or putting performance cylinder kits on their bikes. To be honest, a Harley is almost as big a money pit as a boat, if you let it.
One day a car hood fell on his head and busted him in the noggin pretty good.
" The bloody bonnet fell on me bloody aid"
Huh?
I recall the most dramatic improvements in cold weather starting in my air-cooled Porsches and in my Mercedes diesel----both types generally requiring a pretty good spin of the starter to get rolling in the mornings.
I know I 've asked this question here before but does synthetic really seem necessary for my Civic? I do get free rotations at the dino shop which is good for the tires. I've also just renewed my 3 year 4-wheel alignment policy at the same place. They also know how to reset olm in the car. Luckily since I bought the tires at this shop, free rotations come anyways. Really leaning towards their synthetic brand...Kendall I think.
Decisions...decisions! Shipo, Ruking & Mr_Shiftright...what say the experts?
The Confused Sandman :confuse: :sick: :shades:
I'm no "expert" on oils but I'm trying to apply common sense here. :P
The extra $'s are not an issue here as I'd like to keep this car for another 6 to 7 years at least. And with retirement or disability happening at the end of 2010 or earlier, I will be driving even less then due to my increasing spinal issues. Luckily I'm happiest spending time in the house as the increasing pain makes walking very difficult. That's why Edmunds.com is a g-dsend to me.
Luckily I've still got some time to decide on what to do since I'm at 30% now. Any intelligent responses would be greatly appreciated. Thanks all.
The Sandman :confuse: :sick: :shades:
Synthetics with their natural detergent characteristic, started to clean out the gunk, sludge, varnish, thus exposing, "the real seal"...Thus the leak....
Todays synthetics are much more seal friendly than ever before, and are actually better for seals than petroleum based oils.
1) Extended oil change intervals that still allow the engine to achieve lofty mileage totals.
2) Superior cold start characteristics.
The above said, if I was operating a vehicle that was rarely driven and/or inclined to change the oil every three thousand miles (I typically go ten to twelve thousand miles), and I lived in a moderate climate, I would probably use conventional oil.
Best regards,
Shipo
Exactly,
I have to learn to remember that a lot of folks take the written words literal.
I am pretty sure I stated that "synthetic oil likes to flow better through leaks". Meaning that there would already have to be a leak.
Yes, when I said that they create leaks, I meant that they have a tendancy to make small or minor leaks worse. Not always and it isn't a rule. :sick:
So many armchair quarterbacks. :lemon:
The cold start characteristics of synthetic alone are enough to justify using a synthetic oil for me.
I'm glad we don't get those extremes here.
