Fram 0.15 lbs
STP 0.2 lbs
Mobil 0.256 lbs
K&N 0.15 lbs
If pictures are accurate, there are some differences in the ends, the ones with black plastic pieces look more durable to me.
My take is IF that happens to be true in one's case : FLOW or roll with it, aka don't use the filter that doesn't seem to work.
That is true for oil also. I know for example Mobil One (synthetic oil) tends to run well in Toyota Landcruisers, Honda Civic's and Corvette Z06's. It certainly has been the utter trooper in Jetta TDI's.
We have been changing oil every 12 months per the VW schedule. This was typically about 7000 miles. The mileage is not low due to very short trips, my wife's commute is about 12 miles and 20 minutes each way.
I don't want to do oil analyses, but I am wondering if I can feel pretty safe in going to an OCI of 10,000 miles with full synthetic even if that means going 18 months between oil changes?
Having said that, the (gasser) VW 1.8 T engine might be an interesting exception. VW just settled a CAS saying (I have read in passing and this is by far NOT the gospel) they would bear all expenses on documented OCI's and 50% for more sketchy paperwork, in sludge case issues. After repair, they agreed to another warranty, 10 years /100,000. They also will issue new OCI's. So some would see this as vindication to probably a long and frustrating scenario. That is indeed the good news. The bad news is the 1.8 t engine, whether repaired or NOT, STILL cooks oil.
I would still probably stick to once a year oil change.
Krzys
Personally, I would do a 12-month UOA with TBN, but not change the oil at the same time, to see how the oil looks at that interval. The analysis only requres three ounces of oil, so an oil change is not necessary. If your TBN is around 4 and there are no other contaminants, I would run it to 18 months and feel confident about it.
Yes, the analysis will cost you about the same as an oil change, but two 18-month intervals will make up for it, and after that it's all savings.
Not sure which will be better for the engine at this point since I'll be keeping this car for another 5 years at least. T I A for all your help with this matter!
The Sandman
I just recently took a 94 TLC (I-6) with 187,000 miles on the clock (needing an oil change @ app 20,000 miles OCI (yes I did change it @ app 22,000 miles) to a CA state smog only station" for its smog test. The last major "tune up" is inxs of 30,000 miles ago. The vehicle is 17 years old. Essentially the MEASURED/detected mitigated emissions were all ZERO's !!!!!!! Needless to say.... all PASS !!!!! Good for another 2 years when it will again face the smog [non-permissible content removed]'s who will probably want dearly to EXECUTE this vehicle.
More on topic, the 7 or so quarts (Mobil One 5w30 )and FRAM PH8A oil filter (13 years old) were changed. If anybody wants a sample for a UOA, let me know I can arrange to keep the next sample for you. Indeed just send me the kit and I will send the sample to a lab of one's choice. :shades:
I had always thought the time based OCI was based on an assumption that if you did not hit the mileage figure, you were probably doing a lot of short trips.
The Sandman :confuse: :sick: :shades:
To obtain the most benefit from the LongLife service regime, the car should to be generally driven in a style/condition of use listed below:
• Mainly longer distance journeys
• Limited number of cold starts, engine is kept at operating temperature over a longer period of time.
• Daily mileage above approx. 25 miles.
• Constant speed.
• Vehicle used regularly.
Our usage does not really seem to fit what they suggest there...so for us, without going to the trouble of doing oil analysis, it would probably best to just stick with 12 months.
Now there has been comparisons between different viscosities as to which viscosity yields BETTER wear metals (aka LOWER). But for a general audience, this discussion can be labeled; arcane.
On the other hand, even people who follow and do UOA's really have a hard time believing (at times) the stuff written in black and white (color too in this day and age) laying right in front of them.
I use Castrol 5W-20, OEM oil filter. OCI is ~7K miles, 7 months.
For spotting a leak, you'd have to lift the car and look for what I would suspect would be a considerable "oil wash" underneath the car. That's not as big a leak as it sounds (those little drops add up) but it's serious.
For oil burning, you can perform, or have the dealer perform, a cylinder leakdown test, in which compressed air is injected into each cylinder and the rate of escaping pressure is measured over time. This test is also good because it can possibly tell you not only that you have internal engine wear, but perhaps the cause of it. For instance, a clever technician might notice air escaping out the tail pipe, through the crankcase breather, or through the air filter---each one telling him something different as to the cause of the internal engine wear.
Given the age and mileage on the car, I would not get my hopes up about Toyota doing anything about it. If it is any consolation, since the oil burning rate has stabilized, your car will probably run like that for a long long time, as long as you keep the oil topped up.
Oh, one last thing. Have the PCV (positive crankcase ventilation) system checked for blockage. A non-breathing crankcase will push out oil anywhere it can.
I suspect that the 15,000 interval for M1-Extended is a safe bet by the manufacturer in lieu of analysis. In other words, one could use the oil at that interval in most vehicles and expect that were it to be analysed after 15K, it would be readily protecting the engine. Beyond that and the specific application, quality of filtering, etc., would play roles in how long it would last before protection diminished.
The issue: Two types of oil approved by VW for this engine are Mobil 1 5W40 and Castrol synthetic 5W40. My daughter took her car to a local gas station for an oil change and asked for synthetic. No other instructions. The old Castrol oil was replaced with Duralene 5W30 full synthetic. I'm not familiar with this brand so I don't know the quality of this product.
After having been driven about 1,400 miles since this oil change the level is down about 1/3 quart. That's normal for this car.
Question: I have a supply of Castrol 5W40 synthetic. Would it be okay to use the Castrol to bring the level to the "full" line sometime before the level gets to the "add" mark? In other words, would mixing oil brands damage the engine or cause adverse effects? It would be convenient, since I already have the oil, but I don't want to cause any harm. Please advise.
I already have cans of the Castrol, so it would be convenient and economical to use it if mixing the Duralene with Castrol doesn't harm the engine.
First thing to do... verify in your owners manual as to the spec needed for your vehicle.......depending on what car it is , will make a difference as to the spec....it may be a API, or MB or V W.....I dont know what make and model you have....but the maunal will state the spec requirements
next check the spec of the 5w-30 oil the shop used....you can ask them, if you dont know......did the oil the shop used meet the spec ? If so, I wouldnt worry about it. But if not, the shop needs to know, and should change out the incorrect oil to a correct spec oil..........
Recently a new law or requirement has been adopted in many states. the new requirement calls for the shop, quick lube, dealer or other to state on the receipt, the brand, the viscosity and the spec of the oil they installed.....
I know for a fact that many, many, many shops use 1 oil for all cars..which is harmful if the oil does not meet the spec required....
With the variety of auto manufacturers it is difficult but necessary for installers to have a variety of oils on hand, due to the variety of specs needed today....seems like every manufacturer is requiring their own spec....
there is GM's Dexos spec and other specs by GM....Mercedes ben,z MB specs......VW specs.....diesel specs....Ford specs.....and etc....your owners manual states the spec...the oil used must have the spec on the back of the bottle...
So, next time you get an oil change, know what spec your car needs and tell the shop....to get your piece of mind.....The spec can also be met in a varitey of viscosities. Thats why the Viscosity whether a 5-40 or 5-30 is not nearly as important as the spec requirement............Hope this will help
I thought I'd take a shot at reviving this thread this thread- I've owned the car since new and I've run Mobil 1 5W-30 since the first oil change at 5,000 miles. I switched from a 5,000 mile to a 7,500 mile change interval at 69,000 miles and I switched to Mobil 1 5W-30 Extended performance at 114,700 miles. The only mods are a Mazdaspeed Cold Air Intake and a Hypertech tune:
I have always put Dexos spec synthetic oil in the Sonic , Purchase oil & filters on sale & change it myself .
Runs fime with a little over 45,000 miles on the clock .
Wyr
God bless
The Sandman
