1105310541056105810593158
  • driver100driver100 Member Posts: 32,663
    abacomike said:
    Makes me realize why I always liked stick shifts so much!
    I liked them too, then I got older and realized...what happens if I break a leg or arm? I prefer a manual, but hard to find these days, and, I never know if I may have leg, knee, arm, hip, foot, hand, injury.
    Don't forget head injury, driver.  Alzheimer's is another problem, as well!   :D:p:D
    Oh yeh, and a football helmet.
  • roadburnerroadburner Member Posts: 18,563
    I never bother with paddle shifters.....not worth dropping a transmission for the thrill of shifting that way. Using Sport Mode to enter a highway.....that is very useful.
    How does using paddle shifters cause damage to a transmission?
    One thing is, if used to slow the car on a hill, it won't damage the transmission, but it is harder on the car than just using breaks. That is, could cause wear on a relatively expensive transmission as opposed to cheaper to replace brakes.
    Another thing is I was reaching for something in my wifes GLK, and I accidentally hit the downshift paddle, just as we were going up a steep hill. The car lurched to a slower speed, the engine was revving, and since I don't drive the car to often I pulled over to the side of the road and turned it off and then started it again so it would be in the proper gear....I didn't want to drop the poor thing into a lower gear.
    All driver error, but, since I don't use the paddles I don't feel comfortable with them. I don't think I used them in my 2012 535, and I have used them once or twice in my E400s, but, I get nothing positive from using them.
    Maybe in a sportier car....but, I don't get much satisfaction from them....doesn't replace a manual shifter.
    The ZF 8HP45 rev matches on downshifts. How is downshifting to maintain speed "harder on the car"? That's often the case with a true manual- mainly because idiot drivers don't know how or why to rev-match.So far I haven't heard of any ZF 8HPXX transmissions wearing prematurely when used as intended; failures are rare and usually due to tunes that boost engine power past the torque rating of the transmission and/or neglect(not changing the ATF in transmissions subjected to high speed usage every 50,000-75,000 miles).
    thebean said:
    I think it might be fun for all us old guys to list the procedure
    they have had that they hated the most.
    I've had my share, but nothing is worse than the preparation for a colonoscopy!
    Not the colonoscopy itself (you are twilight sedated), but the preparation
    is pure misery.
    is pure misery.
    I read Mr Beans medical procedure and I passed out for 4 hours. I don't even want to think about or read anyone's worst medical procedure ever!
    Mike could write a novel about his experiences :s
    I agree, it would be hard to actually damage a transmission by shifting improperly, but I have downshifted and the car did slow quickly. It isn't a big deal but everything contributes to wear and tear. I try to be as easy as possible on my cars....I try to drive as efficiently as possible...not necessarily to save gas.....just because the smoother the ride the more skill the driver has, and the easier it is on the car. For most people, slowing down can be done more efficiently and smoother, with less wear, just by slowing down using the brakes.
    If you are talking about racing around corners, then shift away....that will probably be faster, but, probably harder on the car than simple braking would be.
  • oldfarmer50oldfarmer50 Member Posts: 24,521
    Anybody know anything about this?
    http://www.geeky-gadgets.com/new-2019-fisker-emotion-unveiled-13-06-2017/
    I thought Fisker went bankrupt. 400 mile range sounds good.
    is pure misery.
    TMI!
    If downshifting your automatic quickly slows the car it is either defective or doesn't rev match. And actually, smooth is fast- not slow; it's all about the friction circle and weight transfer. If a car won't allow you drive it smoothly at a rapid pace it isn't all that well engineered.
    Finally, you never EVER downshift to slow down for a corner- you use the brakes; you downshift at the end of the braking zone so that the engine is in the optimum part of the power band and is ready to accelerate after hitting the(preferably late) apex of the corner.
  • cdnpinheadcdnpinhead Member Posts: 5,639
    Or you could talk to the wall.
    Using brakes (breaks for some) to slow down in mountain country is beyond incompetent, but it happens all the time. The vehicles of the people who do so can be smelled from quite some distance. A 6-8 mile 6% downgrade needs the vehicle to shift down. The easiest way to do it is with a manual. The hardest way is with my wife's vehicles over the past couple of decades, all of which had automatic transmissions without the capability to hold gears.
  • qbrozenqbrozen Member Posts: 33,806
    I could actually argue that manually shifting an automatic (when done properly) is LESS stressful than full auto. When manually shifting, you are cycling through all gears in order and keeping a steady tension on the drivetrain and always in the right gear before accelerating. In full auto, it responds to your pedal input, sometimes violently and by skipping gears, which puts a sudden impact on the drivetrain.
    edited August 2017
    bwia said:
    berri said:
    I was a little disappointed that the History Channel shows didn't delve a bit more into the designers like Harley Earl's Art & Color innovation. I also would have liked to see a bit of info on the independents. Thought the last episode was a little too focused on Iaccoca and Delorean. But by and large I enjoyed it.
    Hey - don't give away the ending!
    Hard to cover 100 years of American automotive history in 6 hours of TV.
    Now, if Ken Burns were given the project ...
    Does anyone know when the 3rd episode will be aired? And @Michaell, I thought Ford's patent fight was with the Amercan Society of Automotive Engineers. I had never heard of the guy (?) mentioned in the story. What's the real story.
    I thought the 3rd episode was aired last night.
    George Selden was the original patent holder for the automobile. The Association of Licensed Automobile Manufacturers was the organization created to align with Selden's interests and provide financial backing for legal action, such as against Ford.
    Try this article for more information
    @Michaell, thanks for the clarification and the link to ALAM. And by the way, the 3rd episode became available On Demand on Comcast yesterday.
    I'll keep that in mind for the future.
    What you have just explained sounds like paddles are good for certain instances....ones which are of no use to me, which is fine. If I could have deleted them from the car and got my money for them I would have happily done that.
    edited August 2017
    And have read articles which say:
    Why use the transmission when brakes have to be replaced anyway, and it is cheaper and easier "for most people" to just use their brakes! It it probably quieter too, for the people who live nearby.
  • nyccarguynyccarguy Member Posts: 17,736
    i like the sounds my car makes, "sometimes violently" when it responds to my pedal inputs:)
    You got that right! :p
    And have read articles which say: Why use the transmission when brakes have to be replaced anyway, and it is cheaper and easier "for most people" to just use their brakes! It it probably quieter too, for the people who live nearby.
    Using the transmission to slow the car is incorrect and certainly worse for the car, as I believe RB stated.
    Let me try explaining another way. You can see the road ahead and know what you will next be doing, the car does not know until you give it pedal input. So I'm applying brake to enter a roundabout, let's say. I get down to 40mph and downshift to 3rd before rolling off the brake and back to the throttle to hold a steady speed through the turn. Get to my exit and roll on the throttle. The car need to nothing but accelerate steadily and smoothly. In full auto, it stays in 5th through all of this until I roll on the throttle, at which point it realizes I want to accelerate again and skips down to 3rd while I am on the gas, at which point it releases the engine's fury onto the transmission and driveline in one fell swoop (or utilizes the torque converter to gradually apply power through slippage and heat transfer). Which one sounds smoother and less stressful to the car?
    of course, I'm not saying this is always the case or that full auto is bad. You can certainly drive very gingerly 100% of the time and never cause stress to the auto trans. But who wants to live that way? ;)
    I manually shift the automatic in the fintail a lot, as I don't want to be in 4th at 25. I also often downshift when slowing in some situations, as the engine seems happier when revving a little. It also doesn't seem to have the ability to skip gears (non-torque converter unit, if that might explain it). On the modern car, I virtually never shift for myself. It seems to know the appropriate gear, and rarely hunts around for one. Maybe being a diesel with endless torque everywhere helps.
    edited August 2017
    Had just come out of the gym and gotten into the car this morning when I heard a noise from the street behind me. Turned around a saw a car going down the street, but it didn't look like it was just driving by. Was sort of out of place. Then another noise. When I pulled out and swung around...
    Further observation revealed the source of the first noise... about 50 yards or so back up the hill, this car had apparently crossed to the wrong side of the road, went up on the curb, took out a street sign and uprooted a small tree, then came back across the road, up another curb, partially pushing over the fire hydrant that stopped the adventure. No broken water line, at least not before I left.
    Not to judge books by their cover, but if I had to guess, I thinking there's a good chance the driver was carrying little to no insurance coverage.
    Police, fire police and the water authority responded to the scene.
    Late 80s Oldsmobile?
  • ventureventure Member Posts: 3,188
    That seems odd in broad daylight. I wonder what incapacities the driver was operating the vehicle under?
    Me!   :D
    Fisker-Karma went bankrupt. Now you have Karma, and you have Fisker apparently.
    I thought the paddles would be cool when I first got them in my '06 A3, but to be honest, once the video-game novelty of them wore off, I pretty much never used them. S-mode on the DSG was just too good.
    edited August 2017
    OK, probably less stress on the transmission on a curve.....but, how about going down a steep hill?
    oldfarmer, I knew you would be drawn to that car. Why not put in an offer, probably get it for a steal right now?
  • thebeanthebean Member Posts: 1,301
    edited August 2017
    is pure misery.
    TMI!
    Yeah, you're right @suydam. It was TMI. I apologize for that @driver100. But when you've gone through this, you kinda want to share the love. :p I've also had numerous colonoscopies and @fordfool is correct - the prep is agonizing.
    You might be right, a car this old probably can't pass an emissions inspection and as a result can't be insured to drive on the roadways
    The G37/Q40 has one of the best sounds of any engine. I still contend my G37x was my favorite car ever.
    It's either an 88 or a 98. I think it's an 88 based on the slope of the roofline at the back but I can't tell for sure.
    Unless you are towing, choosing a lower gear to go downhill isn't necessary.
    edited August 2017
    I am 100% sure it is an 88. Oh well, the old thing had a good ~30 year run, more than many cars.
    We don't have hills down here, but when I am in a parking garage and I am driving from the top floor to ground level when I exit, the BMW brakes itself when I go down grade.  I find that an interesting feature.
  • ab348ab348 Member Posts: 20,600
    Got home yesterday afternoon to find an appointment notice in my mail for the Cardiology clinic - for this morning! It was dated July 27th on the postage meter so either someone at the hospital forgot to put it in the outgoing mail tray or the post office lost it somewhere along the way.
    I was available so off I went for a 9:20AM appointment. I finally got out of there at 2:00PM after seeing a tech, a (quite lovely) cardiology coordinating nurse who took a full history, and two different surgeons. After all that I am on their list for their next Death Panel Cardiac Surgery conference which is either this coming Monday or the following week, I forget (I was craving lunch and badly needed to go to the bathroom by the time this verdict was reached).
    I learned that they only do a few of these TAVI procedures each month and that the replacement valve they use (a quite impressive thing they showed my a full-size mockup of) costs $25,000. They seem to think I am a good candidate and I think I convinced them that I need it fixed. So now we wait for the decision of the jury.
    I'm off to FLL airport in about 35 minutes to pick up my son and grandson - due in at 6:00 PM EDT.  They flew Southwest Airlines.  By the time they get their checked bags and go upstairs to departures, I'll just about be arriving.
    I mentioned to my son to look for me in a white BMW - he then asked me what happened to my fixation on Mercedes Benz.  I told him he has his uncle (my twin brother) to thank for the switch.
  • explorerx4explorerx4 Member Posts: 21,030
    edited August 2017
    My Fusion definitely downshifts on it's own going down hills to help maintain your speed.
    I usually notice because the tach is reading higher rpm's than it normally would at that speed.
    I've only used the paddle shifters to downshift. It upshifts pretty readily.
    Yeah, the newer automatics are definitely better at holding downhill speed than the old ones were while on cruise control.
    Nah, busted up hoopties don't interest me. My father had an 87' Olds 88, that's why I noticed. Same color too.
    is pure misery.
    TMI!
    No need to apologize here. Sometimes the only way to get over a traumatic experience is to retell the tale.
    If it's older than 1996 the emissions requirements are lower, right? At least it is in NY. My 1995 would pass inspection with the dash lit up like Christmas.
    I saw the driver get out of the vehicle, no obvious impairment, so I'm thinking cell phone is a possibility
    I thought they were all that color. :D
    Speaking of which, the news had a story tonight on a 27 year old truck driver who rear ended and killed someone on I-90 because he was shopping online. He was doing a survey at the time. Unbelieveable.
    I think whenI go back to work as a driver next year I'll list "unable to text" as a job skill.
    I don't know why, but that reminds me an event I witnessed a few years ago.
    I walked outside the main gate of the baseball field where I am groundskeeper one afternoon. I noticed an older lady driving very slowly down the street. She veered off the road, on to a grassy area, and ran into a telephone pole right smack in the middle of the grill. She didn't hit it very hard, but the impact did buckle the hood a little.
    I started to walk over to see if she was OK when she stepped on the gas, with the car still securely against the pole. The front wheels were spinning and dirt was flying. Obviously she wasn't going anywhere with the telephone pole holding her back.
    I stopped since something didn't seem exactly right ( :o ). Then she backed up, put it in drive, and drove down the street; never to be seen again.
    Fell for some 'click bait'. Robert DeNiro's best movie roles.
    Ronin didn't make the top 17. Are you kidding me? :@
    To down shift or to use the brakes; that is the question.
    Which is cheaper to replace? Transmission, clutch,
    or brake pads. That is the answer.
    And that is all I was saying.
    is pure misery.
    TMI!
    Apology not necessary, understood. We are a very friendly group and this has been a good place to share problems. If it is of help to you, then I am glad to listen.....I can learn from good and bad experiences. I exaggerated to lighten the mood.
    That is what I was trying to say...but, that is PERFECT!
    edited August 2017
    OF, I gave you an lol because of this line "I think whenI go back to work as a driver next year I'll list "unable to text" as a job skill", which I found funny....not because of the accident or that someone was killed.
    But, I can't figure out what kind of car that is was. Any idea? It looks like a Bentley or something with that roofline and the gas tank on the rear fender. It looks too big to be a PT Cruiser.
