Visitor Agreement.
When construction is finished, I’ll post the after pic
My only complaint is they haven't figured out how to stream music to my record player yet. Jeez, Spotify, wake up already...
It didn't NEED all of this work. I chose to do 90% of it.
I'm not rebuilding the bottom end. All in all, including previous work, I will have swapped out the following:
carb
intake manifold
cam
timing chain and gears
lifters
valve springs
valve covers
water pump/t-stat
bigger aluminum rad
headers replaced manifolds
rebuild steering rack
power brakes replaced manual
added air con
added retro stereo
replaces ignition wires
replaced door cards and window sweeps and door handles and locks
repainted emblems
rechromed rear panel (gotta get that to someone)
I don't know the overheating problem; however, I suspect it is a timing/distributor issue. I believe total timing is way out of wack. I have recently purchased an adjustable timing light so I can really dial it in when I get to that point.
WOW, that is lot of work and expense. IMO, they haven't yet made a Dodge that is worth that much effort.
Just curios, what is an "adjustable timing light"? My tried and true Craftsman that I bought in the early 70's, either flashed or it didn't. There were no adjutments but maybe cars that don't have distributors require that kind of a beast.
It sounds like you have found a money pit but I wish you luck with it.
You can adjust when it flashes. So rather than guessing how far before TDC the mark is when it flashes, you can adjust the pulse until the mark is back to zero and the digital readout tells you how many degrees before or after TDC it is. What is silly about the Dodge is that the timing marks only go to 10 degrees BTDC, yet you need around 30 "all in" around 2500 rpm. No way to measure that with a standard light other than guesstimating or going ghetto and putting the timing tape on the damper.
Thanks for the explanation. It sounds like that gizmo is pretty accurate.
It would be cool to go see Bisbee, AZ, on the way to Tucson on I-10. Bisbee is home to the Copper Queen Mine, Copper Queen Hotel, the Stockyard Tavern where you could order up and place stocks around 1895 and stick around, have a few whiskey's and watch how your stock does. Bisbee, for a while anyway, was the biggest town between San Francisco and St Louis.
The Cross Trek is my daughters. The Forester is my wife's (her 3rd one).
I got the Legacy when I was looking for a replacement for the AWD Fusion. I didn't want a SUV and if you want a sedan with AWD might as well get a Subaru.
When working on a particular stretch of road I would always pull the accident statistics. Many times there were an unordinary amount of "excess speed" causes. I asked a state trooper why and he said something about when they don't know what caused the accident they check the excess speed box. Makes sense since they have to check some box, but misleading.
I subscribed to Arizona Highways long ago. It contained beautiful pictures of Arizona. It would have been nice to see them in person.
Recently this pic posted on Shorpy.com showed part of Bisbee in 1941. The "family liquors" signage fascinated me. Also some interesting pre-war cars to try to ID:
I don’t know about planned obsolescence, but if you look at the trajectory, ‘50s through the ‘70s saw analog vinyl rise. Late ‘70s through the ‘80s it was the cassette tape. Mid-‘80s CDs happened along through the ‘00s. From the time the iPod/iPhone was released (2010 or thereabouts), music on a small device became a reality in conjunction with peer-to-peer file sharing (music files, mainly).
Currently, the streaming services are in their heyday. But, once again, vinyl has made a comeback presumably because it sounds better (no real proof of that).
So, each format had about a decade of popularity, some had more longevity and popularity than others.
I’m sure if you had told the music industry that planning the obsolescence of the CD (which, in part, led to peer-to-peer music sharing like NAPSTER), they never would have planned it. That leads me to believe it was just technology marching on that caused all of these new formats.
I have a very good customer who is a complete MOPAR Encyclopedia. He recently placed "top 5" at MOPAR Nationals in Ohio. I told him about your overheating problem and what you have done to the Dodge so far. He came up with a few suggestions (which you may or may not have tried):
-Timing should be set to 35 degrees Top Dead Center
-Distributor should be pointing to the #1 Cylinder (it could fit on properly, but be off 180 degrees)
-A tooth on your distributor could be off
-Make sure the firing order is correct in the distributor cap
-Make sure the timing chain is lined up properly
-Aluminum radiators require special "Aluminum Compatible Coolant."
-Your distributor gear could be in wrong
-Thermostat could be bad, old, or incorrect
-The Heads/Valve Springs/Cam all have to match up (High lift cams require different valve springs)
-The Damper needs to be lined up
-The line on the harmonic balancer needs to match up with the timing chain
-Have you replaced the head gaskets? They need to be installed correctly (left & right). If they are installed upside down, they will fit, but maybe block a port.
He had a few questions that I couldn't answer regarding your over heating issue:
Does it run hot when you are idling or when you take it out on the road?
Does it run hot & bad (sputter, sound like it is choking...) or just hot?
When you bought it, did it run correctly? Was it overheating when you bought it? Has this over heating issue started when YOU changed something?
If you have any, specific questions, I'll be glad to call him and ask him for you and will show him pictures if you'd like to send me (he doesn't have a cell phone or email).
Edit, just noticed the cars at right. Sedan looks like a 33-34 Dodge,front clip of car at far right looks like a "standard" 39 Ford.
Here's the same area today:
https://www.google.com/maps/@31.4412584,-109.9129512,3a,90y,50.65h,74.55t/data=!3m6!1e1!3m4!1s40SlGK1_-2GA1tmkVtU9fA!2e0!7i13312!8i6656
As for vinyl sounding better some actually did. It really depended on the quality of the production and how new the record was. DMM (Direct Metal Mastering) records had absolutely excellent sound quality that matches anything today. The main issue with vinyl is that everytime you played a record the needle would cause wear on the grooves that would eventually reduce the sound quality. Back in the 80's and 90's when I got a LP the very first time I played it I recorded it on cassette and used the cassette to listen to music only playing the LP to record it when the cassette went bad.
Back around 1977 one of my coworkers gave me a 1970 Dodge Challenger convertible. It had been sitting in his garage for 2 years, the story was he paid a shade tree mechanic to rebuild the engine and it was “never right afterwards”. He was getting married, his new wife wanted to park in the garage, the non-running convertible had to go.
The paint was in bad condition, the carpet was shot, but the top still seemed okay and the tires were at least holding air. I borrowed a trailer, loaded it up, and hauled it up to the small town in East Texas where I was born and raised, about 75 miles north of Houston. My father had his own independent service garage, and allowed me to use his facilities. It took very little to get the car started and running, the old 318 V8, very reliable. But it had a strange overheating problem. Very strange indeed. I fooled around, trying to figure it out, and the passenger side head cracked. Really unusual, my father with more than 30 years experience had never seen anything like it.
I pulled the engine out and started tearing it down for a complete rebuild. Lo and behold, when I removed the water pump I found a freeze plug in the circulation hole or port on the passenger side behind the water pump. The side where the head had cracked. Obviously, the shade tree mechanic had inserted a freeze plug where it did not belong.
I’ll bet even the “car doc” would have had a very hard time diagnosing that one without tearing down the engine.
I had a nice Carver amp driving some Magnepan speakers with a Thorens turntable. My whole living room was considered the “stereo room”. I think I bought the first CD player in the little town I was living in at the time. Cost easily $1,200, but after I heard a demo, it was a no brainer. No pops, clicks, hiss and a signal to noise ratio better than anything I had ever heard before. I still remember the first disks I heard were.....Paul Simon’s “Graceland” and ‘Till Tuesdays “Welcome Home”. I was stunned.
I spent the next 10 years replacing my vinyl with CDs. Some of the remasteres were good....some not so much, and the vinyl was better, even with the hiss, pops, cracks and poor signal to noise.
A colleague at the time, had even more money invested in his vinyl system....two Conrad Johnson monoblocks, QUAD ESL speakers, a Linn turntable with a cartridge that cost $1,000 alone (remember these were ‘80s dollars). He spent more on cables than I did on my wardrobe. It indeed sounded spectacular.
He came over to listen to the new CD player I had. He bought the exact same one I had the very next day and began selling off his analog system over the next year.
Ah...the memories of being young and frivolous. Priorities changed real quick after that....wife....kid.....no more stereo expenditures.
When Edmunds did their not so seamless system change, I decided to just sit on the couch in the family room and use my dumb phone to sign up to the new Insider thingy and not go upstairs to do it on my PC in the office. For a while I thought I paid for that laziness but not really.
Let me back up for just a minute. Even before the Insider thingy, Edmunds had an incorrect email for me that I tried to change at least a dozen times over the years with no success. Finally I just gave up and when something glitched either with my hardware or Edmunds old system and I got the "Howdy Stranger" pop up page, I just had to remember the incorrect email address and enter it along with my user name. It always worked and I got in here so I just kept doing it like that whenever something glitched.
Then came the glorious change over so I figured once and for all I'll use my correct email but of course I'd use my same user name (@jmonroe). Sounded very logical to me but now Edmunds gave me a pop up box saying someone already had that user name (and I knew who that was) so rather than fight it I chose @jmonroe1.
Now for some confusion. When I went to the office later that day and logged in here, I see that Edmunds still recognized @jmonroe (the one and only original). Knowing now what happened when I did the switchover with my phone, I just let it alone using the old adage, "if it ain't broke don't fix it".
I know that sooner or later my PC or Edmunds will glitch and probably won't recognize the @jmonroe guy anymore so I'll have to go with @jmonroe1 on my PC also when that happens. But until that happens you'll see me both ways.
Also, even before the change over, Edmunds changed my mug shot and then changed it back again. If you guys remember, the original @jmonroe mug shot was a smiley green faced guy but now I'm a smiley red faced thing. The mug shot assigned to @jmonroe1 is a blank staring red faced guy with glasses. FWIW, neither of these mug shots look like Dean Martin. BTW, I see your mug shot has also changed. So much for seamless.
So there you have it. At least for now, when you see @jmonroe you'll know I'm posting from my PC and when you see @jmonroe1 you'll know I'm posting from my phone.
Don't blame me for this. :@ :@
Hey, they're just numbers. If Edmunds doesn't care why should we?
